View Full Version : 12v V6 Discussion
- Dashboard vent assembly
- Need help..engine codes P0401, P0170, P0173 keep coming up....
- I found a site with an AAH Cylinder Head Gasket Set for $83.79....
- Hey CvTech... I was looking the TB from the engine you sold me...
- Scott...(or anyone else in the Pgh area)..know of any exhaust shops who can do mandrel bends?
- "Want-to-clear-out-the-garage-a-little" Fire sale/give-away list . . .
- AFC intake valves needed/crank +cam lock
- leaking coolant
- hey people
- X-post: Exhaust manifold compatibility ("California models"...?)
- Race Parts Yard Sale!!
- After reading the old posts on the IM workshop, I can't find the final verdict on ...
- Coolant temp sensor color?
- Mance's additional HP
- Did Mance ever produce the "Timing Adavnce Kit" .... (link inside)
- Temperature gauge 2 marks past 12 O'clock after turning off engine
- Car not going Rich at WOT... ideas?
- no one in B5 forum can figure it out.. car randomly dies while at idle after car i warm.. rpms go up
- i cant find a working link to the Mance IM workshop. More importantly...
- AC Problems...
- fuel and temperature gauge
- Paging all Mance parts owners selling anything ....
- Cam Tool w/ Crank Lock on EBay $5.00 starting bid.
- cold starting probem
- I have a stage II hose kit and velocity stack for sale in the classifieds for those that are
- Paging quattrorally...
- AC recharge
- About to tackle TB on my 97 A4 ... any tips?
- How many different temperature sensors are on an B5 A4?
- gas tank size A4 '97 quattro 12V auto
- seafoam question.
- need help fellas
- Does anyone know what years Audi used the 12v in European A4s?
- are all 12v injectors the same?
- Rough Idle with cold start.
- P1423 & P1411 fault codes after DIY silicone/Recovery sleeve/RXTB
- Crank Speed Sensor Alignment
- could someone help give me a price quote?
- IAC help X-post
- Rack &Pinion for this car
- compression test results...and other stuff
- I have a question about my trianmission fluid in my 93 100s.
- ABS sensor code - where should I start?
- 250 hp 12 valve, yeah right :)
- does this sound like a steering rack problem?? please say no...
- X-post I need some help
- AUGHH! Alternator problems! Please help...
- Need help with codes
- BOSE SYSTEM
- Jerking,rumbbling in the engine bay, and sounds of a misfire
- Problem after EGR & valley pan service
- Sad day for my 12v...
- oil cooler gasket replacement??
- Paging Mance or anyone who knows the answer...
- IM cleaner...
- engine blowing blue smoke...need new one soon
- Help. Need cam bar and crank lock tools
- refresh my memory..how long does one drive after putting seafoam in their oil?
- Idle Troubles When Hot.
- TB install trouble - car apart in the driveway!! Help Please!!
- Clogged radiator damage?
- out of curiousity.... exhaust smells
- cleaning intake manifold
- Firing intervals?
- Mance's silicone elbow workshop - anyone have the picture?
- Mori, a followup to a previous question.
- "Supercharged 12V"
- 96 A4 2.8 QM timing belt change
- i need more power
- 12 o2 sensor.
- alright, so after spending three nights in the archives...(maf ?'s)
- How hard would it be to swap a FWD engine into a Quattro?
- Hyd Lifter noise on my '96 A6
- Question about the A/C connectors to check the freon level, and all that good stuff...
- Any one have a pictures of the back of the block on a 90? My friend is trying to put his back
- wow 3 codes!!!
- OK I have a problem with my intake manifold that I need help with please..
- question regarding a Intake Manifold that I have.
- one quick question..
- need help with T-belt job....
- 02's and MAF
- Engine Rattle, Disappearing Coolant, Bad News! Help!!
- I have a few parts I am need to sell off of my A4, what should I ask for these?
- Look what I have been working on for the past months...........
- mpg improved :) hole in the exhaust :(
- Spark plugs
- Shopping for Oil Filters
- Paging jbrentd12v. . .
- Paging Agaeris....................
- 12V Superchargerkit.
- Oil Service Light??
- WTB. audi 2.8l 12v engine
- RXTB, DIY hose, DIY recovery sleeve pre-install jitters
- help with muffler...
- Lost the alternator duct
- Anyone need a velocity stack?
- x-post from 80/90 forum: what kind of velocity stack is this?
- Type A -MAF?
- Oil Pan gaskets - What's going on?
- anybody?
- DYNO RESULTS.
- 97 A4 12V Accessory Belt Length
- interesting regarding oil and smoking
- Hey Mori... OT for here, but oil related...
- Hacking the 12V ECU
- Broke the nipple on the vacuum reservior (help)
- So what's the word on the A6 ECU?
- Is it possible to..
- good ole 12v, just ment to be stomped on...
- Maf and nice day..
- Heat Sink GB Update #3.....Anyone want to join? 1 more needed.
- X-post: Illustrated 12V Timing Belt / WP / Crank Seal / Cam Seal / Expansion Tank job
- 1993 A80 Quattro (UK) - Big Brake Upgrade
- ok so oil filter question again...
- AAH CAMS!!@
- DIY intake question.....mance?
- Fix oil leak - 1998 A4 Quattro 2.8
- Oil change procedue for 98 A4 2.8
- Crank bolt sketchiness... I just removed it with a ratchet - it was hand tight!
- off topic help BORBET
- Crankshaft holding tool question
- Heat Sink GB Members................
- How much does a stock 12v weigh?
- o2 Sensor questions. Need some help!
- Pretty good day..
- Drove from KC to St. Louis and back this past weekend.
- Camshaft seals - tools?
- bas gas mileage??
- Engines knocking rod bearings i believe
- ok so according to 12v.org I have a AAH/AFC oil filter question
- gonna be a lot of 12V (1993) to 12V (1995) swap questions this week, thanks in advance....1st one...
- Oil Pressure issue
- temp
- does the 12V in my 93 90 and the 12V in my soon to be mine 95 90Q both use the same oil filter?
- Is CRC QD Electronics Cleaner suitable for cleaning MAF?
- Some 12V stuff for sale
- Rough idle cold and hot......please help!
- Selling the 12v and S3 maf and VS
- Heat Sink Group Buy Participants, Attention!!!!!!!!!!!!!!!!!!!!!
- 12V 2.8 timing belt procedure scanned image
- I hate to do this but - S3 MAF FS...
- Ugh - Alternator is dead...
- Gotta a funny issue w/ the car overheating... and I think it's due to something in the TPS...
- tuning options..
- Does anyone else run 87 octane instead of the recommended 91 minimum?
- Paging jbrentd12v re headlights and suspension
- Help, lifter noise after low oil pressure
- I want to try running duno oil....any rewcommendations ? thx
- aah or afc?
- Problems with A/F meter...
- Anyone from Charleston, WV? I need a favor...
- Anyone ever used Acetone mixed into their gas?
- NGK spark plugs for 96 and 97 MY
- IM workshop
- while the exhaust subject is still hot..
- Please complete the list, what is missing in that head gasket kit
- best way to go for custom exhaust??
- i wanna buy some of mance's products (bored maf and s3 hose kit) anyone selling it?
- Stumbling 12V part III - Thanks All! and why the brake + ABS lights?
- Any word from Mike (Hokie_90)?
- Mr. D's Custom Exhaust Pictures
- Any update on the GB for the POS heatsink
- AAH motor vs AFC motor
- with new/clean ICV do you need to VAG it?
- unknown tube..
- Bored Maf??
- mances instructions??
- need help on diy mods new to 12v
- Alternator replacement.
- dropfest...
- S3 Hose Kit..........................
- My 4000Q tried to kill me in 1989...
- Front crank seal
- Thought of you guys the other day. My Girlfriends Brother "test" drove the R8 in michigan.
- bad stalling issue.
- run in with an evo today..
- S3 MAF intake mod question
- The verdict is in - NO o-ring
- 1996 A4, power loss. Car feels slower then when I bought it a year ago.. HELP!
- menace mods??
- Oil pooling around #3 spark plug.
- Still trying to decide if I want to fix the 12V
- Mance, did you ever run into this guy?
- thermostat questions..
- Timing belt time ---> anyone willing to lend me the 12V tools? I'll pay shipping both ways!
- Anyone looking for some AAH cams?
- For those seeking POS heatsinks there are options...
- Anyone have a USED or NEW bored out throttle body they wanna sell?
- 90 Degree plug for ISV?
- Engine choices
- Looks like POS is 12V only as every other engine/chassis I've checked is different
- Group Buy for Aluminum Heat Sinks - need 10 people at $55.00/heatsink. Here's the list:
- I wonder if Sir Mance-alot might make those nice POS heatsinks available to us mere mortals..? My..
- Whats the take on Stebro exhaust products..?
- Worth it?
- A8 alternator
- s3 hose kit install..
- OOPS well when I get the right MAF housing I'll know how to mod it
- need help with my 12V ...high idle after 3" intake with XTB..
- Car stalling, surging when hot, power loss EXPERIENCED GURUS HELP PLEASE ( kinda long)>>>
- Where can I find a new POS module? Does anyone have a part number? TIA
- Heheheh... POS module on new heatsink is running 103*F cooler than on stock mounting plate...
- ok just got my pro mounts, need install instructions...
- What's a used TB worth (in working condition)?
- My stumblin' 12V - Part II
- I have a plugged vacuum hose coming out of my TB...
- 450exc115, Have you started your engine R&R ?
- Intake FlowTube update (still more questions than answers)...
- Grinding Sound from 4500rpm to 6000rpm??
- beside thermostat, what else could cause engine to...
- POS Module heatsink finished...
- Bar high @ idle. Please help.
- Air/Fuel ratio gauge intall question.
- Ok, so... Ive tried everwhere and noone has a 12v catback.
- I think something like this will work nicely for the POS module heatsink...
- anybody have a Intake Manifold they want to get rid of?
- optimum shift points..?
- A major inconvenience avoided... (updated)
- I now have a coolant leak after a head gasket job.
- Replacing the Oil Pressure Sending unit??
- There's a post I made a few days back that got deleted within the "Borat poll" and I wanted to...
- Mr. D's car for sale?
- I'm looking to buy a hose kit and VS
- S3 MAF - o-ring or not?
- Hey everyone. Help me out here. CEL (after 4.5 years) when I push the pedal past 1/4 throttle
- PACKAGE ARRIVED!!
- Interesting place to put a 12 valve.
- 2 stage intake - what after 4k?
- IM Workshop commences!
- Looking for exhaust..... can anyone post links pleasE!!!!!
- My thread with the 12v parts was deleted cause I didn't post in the classifieds, so....
- Good to see the Borat troll has been delt with.
- All you FWD guys...
- Does it look like everything needed on a head gasket R&R is in this kit?
- Cat back questions.. Im shopping!
- check engine light at highway speeds! OPINIONS!
- Thought you guys might get a kick outta this...
- cam installation..
- turboz kit!@!
- Is the OEM O2 sensor wideband?
- FYI for the HVRS owners...
- Dropping transmission on 12v
- She's at it again...the 12v is stumbling!
- For those that have requested it, get ready....
- Timing Belt and Such pricing. . . .
- H&R coilovers and Stoptech's installed (x-post)
- Mance stuff info
- gonna clean and oil my cone filter, never done it before, tips and tricks please?
- spring refreshment for my 95 b4
- Speedometer question...
