PDA
View Full Version : 12v V6 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. Crank when it feels like it
  2. Octane Rating AAH vsAFC
  3. Help Please
  4. Quick question, a little off-topic
  5. 97 12v catalytic converters
  6. Prepping for the weekend...Starter removal questions...Miktip, seems like you know this well...
  7. Possible to replace cluster bulbs on the A4?
  8. F/S 3" 77MM MAF -PN- 078 133 471A
  9. weird noise (whine).........
  10. X-post... need help guys... my PS Rack is on its way out :(
  11. Just had my magnaflow cats installed. O2 sensors on the way from shokan
  12. Seafoam 6.99+shipping???? wow expensive... how many of them do I need ?
  13. I learned how to test the 1.8bar(26psi) oil pressure switch.
  14. I hate 12v engine... thinking of engine swap...
  15. Vacuum System; Manual vs. Auto Trans.
  16. For those interested, I installed the Philips Vision Plus halogen bulbs yesterday...
  17. On the subject of turbo's
  18. Mori--just for you . . . Photographs of current state of my Engine Rebuild
  19. Anyone recall off hand the cluster bulb size? thought it wa 1.1 but looks like they say 1.2...
  20. what are my option choice to get more hp? (except exhaust and intake)
  21. How does the serpentine belt tensioner work?
  22. Holy crap! Almost 500 members in the 12v group!
  23. Does my engine mount look shot to you? (ignore red arrows)
  24. anyone got a picture of what the brake booster looks like?
  25. which vac line to use with seafoam...
  26. stasis.
  27. Anybody ever convert from a 4-pin MAF to 3-pin MAF?
  28. X-post of my little cleaning adventure today
  29. anyone share some input on wireing a air/fuel guage?
  30. Sea foam @ pep boys? or only advanced auto or auto zone?
  31. Are there any oil filters other than the MANN filters..........
  32. high revs after atf change.
  33. How bout a lil' x-post for ya kids?
  34. Ex-30v owner turned Mercedes interloper with some N/A tuning questions...
  35. Two codes popped up today
  36. electric fan prob
  37. Anyone interested in a Bentley Manual?
  38. Ignition switch changed, starter still over- engages.
  39. Check Engine Lights on.....5 Faults
  40. New member to the family!
  41. Car back from 60k service... some problems...
  42. URGENT: I need the spark plug wiring diagram...
  43. PLEASE PLEASE PLEASE HELP!!!!!
  44. unstable idle... what could be the culprit? (12v)
  45. How can I get my hands on a S2 or S3 intake - and what's the difference?
  46. Just picked up the Bosch 02 sensor recommended by mattd860
  47. Hey There New to the Forum
  48. Hey Justin, do you know anything about this place??
  49. Does the Oil pressure switch read temp or does it just measure the oil pushing threw the hole?
  50. Dropped car off @ Don Galbraith Motoring(Devon, PA) for 60k service @ 8AM this morning
  51. Oxygen sensors
  52. I'm seriously thinking about camshafts. Any suggestions? Prices?
  53. Ok so now i have my compression tester any techs or how to's on what to do next?
  54. Anyway to test the oil pump or at least tell if its working?
  55. Out with the old, in with the new...if you need me ill be next door! BWW!
  56. Just to let Y'all know......
  57. Ok i am ready to start work on my 4k and want to get a compression tester..i want to test my 12v too
  58. ok... so i'm gonna pick up my car today...
  59. Are lightened pullies considered a viable way to free up HP?
  60. Anyone have the VIN breakdown/explanation chart?
  61. Overheating problem on 97 A4 2.8
  62. Oh the HOWLING!
  63. Shifter button sticking (A4 12v 1996)
  64. Dumb question, but it's familiar ground for me.....
  65. Brake in??
  66. Clutch issues...Please help (did search)
  67. CD Changer Woes: 97' A6, help needed
  68. Yee-haw! We're hotttt on the BRAC (base closure) list!!!
  69. Anyone got pics of the subframe Neuspeed brackets installed? STIFF is the closest holes right?
  70. Rack & Pinion Assembly hydraulic fountain
  71. Is there dirt filters in the cooling system of the aah engine
  72. Bryan, can you help me with a part?
  73. Todays work. I jigg rigged my oil pressure switch yesterday with epoxy :?
  74. Help? (repost)
  75. Any of you guys have an aftermarket keyless entry?
  76. You guys will NEVER believe this one...the amazing self healing 12v (MPG skyrockets for no reason)
  77. Some pics from weekend Timing Belt Job!
  78. OK MORI...what are your impressions on these fluids...have YOU checked your blinker fluid?
  79. Anyone get the adjustable sway bar links in yet?....Impressions?
  80. Can anyone point me to the link to replace a fuel filter on a 97 A6? Mine has the filter up front
  81. 96 A4Q 2.8 12v shudder at 3k rpm
  82. 96 a4 remote-Died! Anyone have a second hanging around?
  83. Ok guys anyone cleaned out their garages recently?
  84. Do you guys use a spark plug wire boot puller, or do you just yank.
  85. s3 MAF
  86. Another firestarter....how would you define a "proper" tuneup for these engines? I've owned...
  87. How much you think my car is worth (trade in or ebay wise)?
  88. 1.8 (26 psi) pressure sending switch. Is it possibly for oil to leak out of the rubber that goes..
  89. Buying from Europeon Automotive-looking to break the 50$ threshold and save myself some future time
  90. Evoms Question
  91. Timing belt supplies (FINALLY I WILL GET IT DONE THIS COMING WEEK!! *school is over*)
  92. Mori! ;O)
  93. Wow... new O2 sensors made a nice difference!
  94. mattd860, how are your knuckles doing?
  95. Anyone tried a "Carbon Activated" cabin air filter?
  96. ECS Light Weight Crank Pulley
  97. What to do about my mounts?
  98. MikTip- you recommend the AC Delco Rapidfire 9s over NGKs. What's the advantage? Gap specs?
  99. A little off-topic, but I trust this forum....
  100. California dreamin'....would a A4Q 2.8 5sp bolt up to my A6 2.8Q auto with a few mods?...
  101. I know, I know, nobody cares about UrS4's S2 hose kit anymore...
  102. I'm going to be getting new air filter, spark plugs, and wires...
  103. Is it humanly possible to do a complete timing belt job in 5 hours....
  104. Hey guys . . . anyone ever mounted a trailer hitch on the back of their 12V?
  105. Is there any reason I should not...
  106. I thought I recalled group buy adj. sway bar links awhile ago but can't find it now...anyone have it
  107. Despite my fear of incurring the wrath of Mori....
  108. Bored Throttle body, intake manifold help plz!!
  109. Fuzzbeaner, it has arrived at last
  110. How long does it take for a motors seal's to deteriorate
  111. Teach Me
  112. Hey fellas... anybody have a passenger side tail light hanging around?
  113. What about 12Valve to 1.8T with DBW? Have to change tranny and all other stuff like 2.7T?
  114. Finishing up Timing belt :?..
  115. For you UPS chick lovers ~~ :-D
  116. Paging Fuzzbeaner
  117. My latest mod that I'm installing next week...
  118. induktion work rate / price?
  119. Cool car commercial inside (can you tell what make & model it is?)
  120. Anyone in MA with a code reader? Even if not, read in and give me some O2 advice!
  121. What do people have their 19mm rear sway bars set at...Impressions?...
  122. Mr D. You here? I sent you an email.
  123. pictures ^_^, 9 of them 1.3mb total ^_^ broadband recommended =D !!!
  124. The real deal on the ECT sensor on the AAH.
  125. 2.8Q to 2.7QT
  126. A quick question about spark plug wires.
  127. I am going to get NGK's from Advance Auto Parts and found NGK BKR6ET...
  128. Got my O2 pre-cat sensors replaced (Bosch Original replacement) got this code...
  129. 5th Annual Audi Expo! - It's coming!!!
  130. A4 12v spark plugs and cables...
  131. What tools are needed to bore out primary venturi on Throttle Body?
  132. Islingtonaudi how did your magnaflow go?
  133. Oil Oil Oil.. put it in watch it drip out.
  134. getting magnaflow cats this week. Round or oval? 2" or 2.25"? (the big ones are $20 cheaper)
  135. Does anyone know if this has a VS in it?
  136. my trans is on its way out, i need help
  137. Repost from A6/100 Forum: 15.7 Miles Per GALLON!?!! This keeps getting worse...O2s, right?
  138. Anybody ever order head porting tools from Standard Abraisives Motorsports
  139. Did the first compression test on the car today...
  140. changing my clutch?
  141. Uber 12 valve A4 upgrade sequence?
  142. Alright, so the power steering fluid I want is:
  143. Matt YGM
  144. Well I put some M1 0W-40 in the 12V about a 1,000
  145. A question for Mr.D-12valves0turbos....I saw your Magnaflow post from a while back and...
  146. Should I bother putting OEM sport suspension from a 30v on the 12v? Would it make a difference in
  147. TOadman2.8 were yoube
  148. Mr. D & Mori, YGM
  149. Should I put gasket sealer around the Intake manifold gasket?
  150. Tuning AAH - input needed.
  151. Drifting story :P
  152. intake air box
  153. ECT sensor location, where is it?
  154. mori -- how did the brake job go?
  155. Can't get 35mm bolts for the New tranny mounts...Ideas???..
  156. Any of you guys interested in a TAP1 TB?
  157. Well the updated ICV is definitely easier to install...
  158. read in a forum that NGK multi grounded plugs (P/N BKUR6ET) are best. True/False?
  159. Ok so i was told that the only way ....
  160. Does the AAH and AFC share the same flywheel/clutch hardware, does it
  161. OT: 2" Silver Nub Antenna For Sale
  162. AFC lower valve spring seat
  163. Will plug wires from 30v fit?
  164. How much does a rebuild engine for my '93 100s go for?...
  165. Needed: Pic of G62 Temp.vsResistance
  166. repost from B5 forum: I need help with this error code
  167. sulfer smell from exhaust
  168. Is there anything other than the ICV (aka IAC or ISV) that would cause stalling?
  169. How do I check my oil check valves?
  170. Totally Hypthetical Turbo Question
  171. hi everyone! long time no see... hope everyone's doing well
  172. Repost from 80/90 forum, progress on my project...
  173. Going to replace every vacuum line on my motor - extactly how much should I order form ECS?
  174. Acceleration...received this from my son.
  175. Here's something thats gonna raise an eyebrow or two. Dyno Pull #1
  176. So its my oil pump...
  177. Guys..
  178. A question for people who know about cylinder compression...
  179. Secondary air pump
  180. If you were to be given 10 grand (USD) and start the car from stock what mods would you do?
  181. Help - Does anyone know where the..
  182. How often does the T-stat need changed on these cars?
  183. Should this noise concern me?
  184. Tricking my A/F ratio...Got my VAG-COM and as I thought MY O2's are coding...
  185. For sale: S2 Silicon Hose kit and Velocity Stack
  186. Cold start hesitation
  187. what do you guys think of this intake for the 12valve
  188. Diff is self-destructing....
  189. Attn. peeps w/ EGR mod: Since there's been recent talk of EGRs...
  190. Mr. D, It has arrived, Thanks : )
  191. mori i dont understand the fuse sh*t at all lol... i opened my fuse box (pic)
  192. Car is still dead. It's not the ignition switch, battery, or fuel pump relay or pump. No power in
  193. Engine Codes.....
  194. Is it me or do i see a Velocity Stack in there?.... Mance are you working on "other" projects?
  195. Hey anyone Know of a cheap place to get Bilstein Sports...Have to order them today!
  196. Check valves, where to buy other then dealer.
  197. Repost about cylinder heads, any and all help is appreciated.
  198. Cold starting issue
  199. porting AAH head
  200. Any difference between the 2WD a4 1996 bilstein shox and the AWD shox?
  201. Stupid question: 12v or 30v?
  202. exhaust
  203. Hey guys, I finally got my CEL codes read. please help...
  204. OT- Jees...
  205. where can i get a 12volt line near the door? I just got my ricey illuminate door sills...
  206. Oil pressure drop, im lost...
  207. Somebody please tell me what I have do to fix this...............
  208. Houston....... We have mice!
  209. problem starting, seems to not be getting enough gas...
  210. Stolen96A4 how much was it to repaint the hood?
  211. Magnaflow Cat purchase question
  212. Got a present in the mail today, thank you Mr. D
  213. Quad exhaust?
  214. CHECK THIS OUT!
  215. Climate control Code15.7 Air Flow Flap, sporadic block???
  216. I need to get rid of this Special TB.....
  217. Pictures worth a 1000 words?
  218. EVAP pressure sensor
  219. hlp pls: no cruise, pump ok, vacuume ok, .....more
  220. I need the diagrame for the Valley pan gasget removal.
  221. BEWARE OF NAPA THERMOSTATS
  222. Drove 2000 miles since I used seafoam and NO more oil consumption!
  223. All my vac lines are good.. what to try next for IM not switching over. I am going to buy a selonoid
  224. Approaching 70k mi for a 96, car eating gas like no other.
  225. How many mori's do we have on this forum??? Confused~~
  226. Temp Sensor?
  227. ***FINALLY GOT MAGNAFLOW INSTALLED!!! ***
  228. I am thinking about changing my trans., engine, and snub mount(s)...
  229. Representing for the 12V's again this year,,,
  230. How much is the lift on AAH-cams? What would one want to aim at when getting new ones?
  231. Valvetrain
  232. TAP Cone Intake
  233. Wanna see the rich people brag?
  234. Even though there are a bunch of review out there, I'm still throwing my 2 cents in on the S3 MAF ;)
  235. I'm getting rid of my 12v -- say hello to my new mint green Kia Rio!
  236. Farewell to the 12v... Hello to the 1.8t
  237. So the 12v is going up on the block as I just ordered my new A3...
  238. Mance Adjustable Sway Bar Link Group Purchase...
  239. I need a fuel pump relay, the part number on the relay is diff from the part number in the archives
  240. Anyone used these? Central differentials?
  241. Repost to assess interest: A4 meets C-4
  242. Cleaning my garage and found...
  243. LOL, think this response is a scam? :-)
  244. Is this check valve positioned correctly?
  245. B7 troll, please come to the front desk!
  246. Mance's Solid Strut Mounts are the best upgrade so far...
  247. Good deal on the two timing belt tools on eBay for the 12V engine...
  248. please help. CEL problem
  249. STFA trying to source the Titanium epoxy putty.. cannot find
  250. Hey guys, I'm having trouble starting my car. Over the weekend I noticed that when the key is in the
