PDA
View Full Version : 12v V6 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37
  1. next fluid/oil related question. my local Audi mech (whom I trust) swears that I can use 75w90 GL5
  2. who else has ran nitrous on their 12v?
  3. Xpost: finally got my 12v lookin how i want it...
  4. Check this out !!!! Supercharger
  5. moribundman, did a search to find info on oil. have bought M1 15w50 but even though it's got the A3
  6. I did it... I bought a 2002 Audi A4 Avant 3.0 with Tip
  7. Someone on the B5 forum mentioned using this VW 4 wire O2 sensor instead of the Audi one. Opinions?
  8. Been a while...just wanted to check in with the 12v crew
  9. Weak power windows
  10. Anyone know where I can find an AFC engine for cheap?
  11. ok, so we ruled out the SMT6 piggy back... what about the PRS8 standalone?
  12. 272 cams are in.
  13. Anyone heard from Mance????
  14. which Intake system for 12v ? ? ?
  15. Hey MM120 is this similar to your ecode problem?
  16. what'd be involved in dropping an AAH into an A4?
  17. Mr. D. - any update on your motor with the AAH cams?
  18. my DS rear door wont shut...
  19. Another day, another deer
  20. Replacing suspension next week, question?
  21. anyone who's worked on the washer system
  22. (STFA'd and long) Back When UrS4 first posted about the o-rings...
  23. Weekend Project!
  24. Oil Temp
  25. hi temperature after 272 cam installation ----DAY3---- NEW INFOS
  26. For all the noobs that are hell bent on forced induction for the 12v...
  27. ok guys, need help FAST.
  28. supercharger for 12v . SEARCH FOR MOTODYNE....HAVE A LOOK
  29. 80*c thermostat
  30. 12V SUPERCHARGER.is it safe? is it worth the $ ?
  31. No need to worry! I talked to Mance and he is fine but he has not gotten back online yet.
  32. UrS4, if you are out there, please let us know!
  33. Happy Friday f/ the 12V forum insominac
  34. Remind me not to change quattro clutches for $250 anymore..
  35. Who here has driven a 2002-2004 A4 3.0 Quattro? I'm thinking about getting one...
  36. My $60 muffler...
  37. Anobody ever go to these guys?
  38. CEL codes...
  39. Engine Swap Questions
  40. Drag Day - May 21st - Lebanon Valley Dragway (New England/NY), Sign Up Now...
  41. test
  42. Andreas from Austria, you out there?
  43. ok guys, best way to tow an A4 from 200 miles away?
  44. can someone explain "manifold switchover" to me please
  45. anyone know how to get ahold of RobK?
  46. ENGINE.HAD TO REPLACE MY ENGINE ENDED UP WITH A 2.6 V6 NOT A 2.8 WHAT MAKES IT A SMALLER ENGINE
  47. ENGINE
  48. Engine Temperature After EuroSpec 272 Cam Installation
  49. I've had the AAH cams installed in my A4 for a few days now and I am very happy with the results.
  50. Got a problem.
  51. Plugs
  52. Help with noise, please
  53. Timing belt too tight?
  54. Audi/VW parts compatability list?
  55. NorCal Audi Club Marin drive: Saturday May 15th, 2004
  56. hey guys my car is sometimes hesitating (spelling?) to accelerate???
  57. Couple pics of my $40 muffler
  58. So I been looking to where my car might be leaking oil. On the belly pan near the filter there
  59. Is Mance back on-line?
  60. 2-1/4" od Band Clamps for Brullen Exhaust
  61. If I found a complete engine for about $600, would it be worth it to ship coast to coast?
  62. I heard UrS4 moved his operations to Taiwan ...
  63. FEDEX MUST DIE!
  64. Barbarian Motor Works beats Audi!
  65. Is "Update All" failing to work for anyone else?
  66. I miss Mance....this forum is definitely not the same without him.
  67. AAH VS AFC
  68. Got my A6 TB today (special throttle body)... and it is sweet :)
  69. 12V Turbo Charger or Supercharger?
  70. new user need parts
  71. Velocity Stack vs cone style intake? & Exhaust install?
  72. Update on the fan
  73. Anyone have a camshaft locking tool they can rent me?
  74. Confused about this o-ring buisness.
  75. Still have problems w/ halogen one-piece ECodes
  76. probably a dumb question about the VS
  77. I took my car out for a drive today (its about 80*) and when I got done i parked in the parking lot,
  78. Need help. Installed new cams and I'm pretty sure one of the sprockets is slightly out of alignment
  79. Help! Diameter of exhaust flex piece before cats?
  80. There's a new service check (euphemism for recall) forA4, A6, and A8 made between '94 and '99
  81. Can the older A4's (96) get the new flip key upgrade?
  82. Hmmmm?
  83. What triggers the MMS200 ECU to go open loop?
  84. Help me with upgrading my 1993 audi 90
  85. Umm Help?
  86. MAF O-Ring help needed...
  87. My 40 dollar muffler experience
  88. gear puller?
  89. ROFL!!! This had me in tears.
  90. OUCH
  91. I am taking my little brother to look at a 01 1.8 today...what to watch/look for?
  92. Check out this velocity stack in my subwoofer.. lots of pics:
  93. Hey Bambi killer!
  94. Calling the guy who was looking to buy a 96
  95. Fog light install
  96. Well, I just posted about my headlight problems in the B5 forum.
  97. Ok, just made an impulse buy....
  98. hey guys I would like to install new spark plugs, what brand should I get?
  99. 4 wire MAF swap complete (and a question.)
  100. :-(
  101. Objective performance point S3 TB and DIY MAF
  102. Anyone need a good chuckle?????
  103. Info on 471 MAF
  104. 2004 Northeast Audi Summer Event Info/Registration/Forums/Site is up!
  105. lots of new faces around here. that could be good.....
  106. Anybody use a K&N Intake Kit?
  107. Make the oil stop!
  108. Where are we on the SMT6?
  109. eurospec 272 cam installed and reviewed, please check this thread out
  110. installed stage3 MAF...
  111. Question regarding the installation of the MAF VS...
  112. tried STF but it's making me angry...will the bigger OEM maf work with the ECU from small maf?
  113. is tdl still in extistence? if not ...does anyone else sell heads?
  114. VS - what the hell is it?
  115. Does this look like the correct oil cooler o-ring for the A4?
  116. My first car was a Hyundai Excel so I found this article interesting...
  117. We have these two speed humps on my work street which I always slow down for and some cvnt
  118. How freq do you guys carb clean your ICV/ISV??
  119. timing belt
  120. Mod Questions?
  121. Hey nothing, did you get your MAF in yet?
  122. commercially modified TB's
  123. informative link
  124. My morning check-in, catch-up and updates...
  125. When a clutch is burnt, does it usually require the pressure plate being replaced too?
  126. guys what do you think, force 5 has the special TB for 100 plus S&H
  127. cam and crank oil seals
  128. 97 A6 Q: Best acceleration performance boost for the $$?
  129. Problematic Cats ???
  130. pics of new sirius sat. system (i know i know, off topic, but b5 forum is annoying)...
  131. My computer is DOA after HD crash last night...
  132. would anyone want a 96 A6 TB to toy with ?...
  133. Any Ideas for a Hi Flow intake?
  134. Age poll (i know it kinda lame but i am just curious)...25 here
  135. What kind of exhausts are you all running?
  136. Does anyone else know where to get a motor snub?
  137. I think just made a really big booboo...
  138. Poll?
  139. Tool Gurus: Any options for rear brake caliper tool better than Harbor Freight? . . .
  140. Anyone have the AAH heads on the AFC block yet?
  141. For those of you in south florida...
  142. "S" throttle body vs standard throttle body: Ways to tell the difference...
  143. Poll: how many times have you gotten a CEL? State miles on car and number of events
  144. I'm a rockstar
  145. Dang, eep, your site kicks arse! Oh, how I've missed it.
  146. Catalytic Converter
  147. Malfunction Indicator light came on tonight
  148. Nice product...
  149. Mance I just ordered a MAF VS from you, ignore the note about the gasket.
  150. With the "timing advance" topic fresh in my mind,
  151. Pics of special throttle body?
  152. ARGH!*&^!@% I HATE PEOPLE(*&!@%!@
  153. Hey, guys... I was considering this 98 A4 for my wife (she loves it, too). Any opinions?
  154. Mance-
  155. ok let's try this again...
  156. MissileMan, good to have you back!
  157. Just sent an e-mail to ECS Tuning (long).
  158. Mance: SXTB only for '95 up?
  159. IM Workshop: Finally... my upper IM half is ported, polished and gasket-matched to the lower half...
  160. so guess what's come back to life........ my previously defunked upper IM half.
  161. Q for miktip, mance, or anyone else with an automatic
  162. Lucked out! The heads I got for my A4 are AAH heads!! :-)
  163. need help! what TB do I need to get for the SXTB?....
  164. Mance, or anyone else with a "Special" TB... does anyone have a caliper measurement to...
  165. This is a good deal.....:)
  166. UrS4 - Did you receive my email re: snub mount?
  167. shokan just emailed me back saying that they have a used TB for $185...
  168. How much can the A4 tow???
  169. A4 sports suspension
  170. I drove Patience's '93 90 12V w/ S3 TB last night...
  171. Due to all this chipping talk.......
  172. Ram Air Question
  173. Bit OT but... The 1.8T turbos are just plain K03's right?
  174. splitfire ARM-1 question.... again
  175. MMS200 chip?
  176. Mr D., YGM
  177. mance if i sent you a stock maf and stock TB...
  178. mance(or anyone else) give me a good reason not to install...
  179. Got my racing akimoto ram air IV today from summit...for those interested...
  180. Ok guys my lil' baby just turned 60k, what should i be looking to do, maintenance wise?
  181. What spark plugs are everybody running. I know that the DENSO iridium power IK20 plugs are good...
  182. 96 A4 v6 quatro.
  183. Ok, think I'm gonna buy a 1.8T... Screw this 12v stuff..
  184. Let the Abnormally Aspirated mods begin!...
  185. lighten up ur day
  186. anybody want to test an AAH ecu for me
  187. Finally, some good news!! The custom-size o-rings shipped today. Should have em by the weekend.
  188. More frustrating news on heads as it relates to compression ratio...
  189. hey mance, you got this piece for the TB laying around...
  190. FINALLY! I'm back online, & a day sooner than expected.
  191. Anyone know of any good salvage yards in south florida/miami?
  192. Getting rid on my LLtek intake...last chance before Ebay...
  193. WHere is the Coolant temp sens located
  194. If anyone wants a good high-end Fluke Automotive multimeter let me know...
  195. OK guys, compatibility/conversion information.
  196. Oil pressure problem
  197. Mance, regarding the timing advnce how involved is it to advance the sensor mechanically?
  198. Happy belated easter Mance...
  199. The more I look at the AAH cams the more I can't see how these could generate in excess of 3-4%
  200. If any of you DIY'ers are interested in some heads that may or may not have bent valves for $50 each
  201. I just noticed 12v.org notes the rev limit on 12v at 6700rpm, is this AAH or something?
  202. UrS4, do you think I have to worry about passing emissions with either
  203. Mance, some correctionsregarding your planned head work...
  204. rough idle
  205. Ok guys, read it and weep. Or; why we cant get more ignition advance with what we have...
  206. Successful MAF mod for 1993 12V
  207. What's the upside of the A4 cams?
  208. Questions from a begginner...
  209. So what's the deal with the AAH heads? will they fit on the AFC and...
  210. Split second ARM-1 signal question
  211. just to note...we are at 50 pages and close to 2500 threads, pretty impressive!
  212. sigh, no ARP head stud kit for the 2.8 12V or the 2.7T. Why can't it EVER be easy!?!
  213. MikTip... anyone make a cam-mounted valve spring compressor specifically for the 12V?
  214. I can't use a 30v IM for my 12v can I?
  215. Those with ETKA, I need a hand with two part numbers...
  216. I've had the skinniest o-ring (largest ID) in for a few days and over 200 miles now. The ECU should
  217. how does this look? this looks pretty good to me
  218. Besides the STASIS 12v, whats the A4 (12v) with the highest power output...
  219. ok getting pissed...where can i actually PURCHASE a racing akimoto ram air filter?...
  220. Help please!!! Just got done replacing my front upper control arms...
  221. I STFA and need to know how to bleed air from the cooling system on a 96 2.8 engine.
  222. Bad day for good news. I pulled the pan of my spare 2.8 12V today and I'm 90% sure....
  223. Mance, any reaction on this?
  224. I just ordered a set of AAH Camshafts from a '93 90...
  225. Clutch Dilema, I need input please!
  226. so I bought a flex shaft for my dremel and it went up in smoke after 5 minutes =/
  227. was looking under the hood of a few 98+ A4's yesterday... wow that's a lot of plastic!
  228. PW: Yes, I changed my SN, you call me Snowman anyways, thought I'd help you out...
  229. Line up; who wants one? (electric superchargers ;)
  230. Posted in the 100/a6, low response: How bad is an exhaust gasket fix?
  231. I HAVE CAMS!!! AND OH, THEY ARE FUN!!!!......
  232. Throttle body part numbers (1995 90q)...
  233. Double checking...O-rings on entrence and exit or...
  234. i have 078 033(maybe) 471.....
  235. Mance, how clean should I try to get the Stock MAF before sending back? I think I"ve done all I can
  236. Problem...T20 bolts holding sensor on MAF have metal nipple in the middle!
  237. Hurray! gifts from "the man" =)
  238. O-rings...where to start testing, big hole or little hole?
  239. Mance, I'd like to place an order, just 3 quick questions...
  240. Mance..have u received any of my emails?..
  241. hi, master miketip, got some question about performance camshaft
  242. Mance, do you know of a way to measure the air volume entering each individual cylinder?
  243. For those of you interested in a Throttle body to play around with/modify...
  244. Pentosin 7 or 11S?
  245. Question for all machinists and metal workers
  246. Mr. Cheap
  247. Hey Mance, YGM
  248. Jesus H. Christ the new Fluke hand-held Oscilloscopes are friggin EXPENSIVE!!!
  249. Grrr... last o-ring ship date has been moved a week further out AGAIN. Now showing 04/23 ship date
  250. cams go in tomorrow, will take pictures, and report on performance...
