PDA
View Full Version : 12v V6 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. CF Engine Cover is DONE! :o)
  2. EGR - insufficient flow - vacuum question
  3. Power steering fluid, Anyone try Valvoline?
  4. Calling Mr D for exhaust pics!! Or anyone else
  5. hesitation...opinions please and thanks
  6. Looking for a velocity stack. I would use the classifieds, but I doubt any 12vers or 12v goodies
  7. where to get replacement hoses from the valve cover to the intake
  8. has anyone found the timing belt/roller/tensioner for less than $120 lately?
  9. Unorthodox flywheel & Ultrarev.com
  10. attn miktip or jrenthal help please
  11. Quick oil question (very straight forward)........
  12. Flexalite Oil cooler kit.
  13. Dose anyone use RSD TB?
  14. Need a stock 5 spoke 16" Rim (with or with out Tire) for a 96 A4..
  15. It's time for the A4 to go......
  16. Re-post from 90/80 forum................
  17. "short Block" differences between the 12 valve and the 30 valve?
  18. Finally got my valve covers and A6 TB, can't wait to get started, but..
  19. Hey does anyone have a TPS that I can have/buy?
  20. Reassembling Fuel Pressure Regulator
  21. i need a motor oil for extremely hot weather
  22. 1995 A6 12v -Cranks but no Start. What items to check?
  23. Anyone have an extra ACDelco Rapidfire plug around?
  24. Kind of a performance upgrade for those who prefer the OEM look but want to swap the Delta Radio.
  25. Valve Covers
  26. Alack! The B5 to Allroad tranny mount conversion writeup hath disappeareth!
  27. Help w/ fog lights Wiring Diagram Anyone?
  28. rough idle and really bad gas milage, i did tune up but
  29. just finished boring the MAF, and re-installed it..
  30. New Audi Parts !!!
  31. Hypothetical question about O2 sensors
  32. Can anyone diagnose a P1411 with no noticeable vacuum leaks?
  33. Pls help me locate the variable intake valve
  34. I posted v b chil-n's igntion switch find to the FAQ, btw.
  35. Motodyne unsafe?
  36. 3rd x-post this week regarding oil/filters...thanks all for the help
  37. Check out my car at Ronal used for a photo shoot.............
  38. Timing Belt Questions...
  39. Oxygen Sensor
  40. can anyone confirm bypass pressure valve spec of 3 bar (43.5 psi) for a 1993 90....
  41. no pull beyond 3500 rpm...
  42. anyone know where I can get a urethane snub mount? also...
  43. X-post for the oil filter wizards from the 80/90/cab section...
  44. Anybody want a cone intake? I'll trade you for my stock one!
  45. hey guys, whats the risk of removing the cat converter?
  46. recoding transmission to sport mode
  47. At the risk of being sent back to where I came from, what 12v mods can be applied to the 30v?
  48. Anyone have a used LLtek CAI that they are looking to get rid of?
  49. strut recommendation for 1996 A4 12V FWD auto
  50. Paging 1PissedOff90
  51. This is not good at all
  52. how hard it is to get to spark plugs
  53. Question for those familiar with the 12V Intake Manifold Port and Polish...
  54. eRam electronic supercharger
  55. What would cause valve tapping sound at low throttle?
  56. Coolant leak from the side of the oil pan
  57. (Formerly stolen96a4, stolen12valve) Got an 04 RSX type-S today, A4 is on the market now.
  58. Whoops.. cam sprocket moved am I in trouble now?
  59. need opinions
  60. Yes Virginia, there is an RS3 MAF...
  61. where do you guys suggest to get a serpentine belt online?
  62. Where is that engine code?
  63. What are you guys running for spark plugs??
  64. Wanna see a really clean Saab engine?
  65. APR S4 HFCat.. fitment?
  66. Aluminum...
  67. EGR Valve - Need a Fix ASAP
  68. Mori, et. al... What's the word on E85 and/or gas stations that read on all grades:
  69. 1pissedoff90--I own a 1999.5 audi a4 2.8L 30V if this is needed info
  70. "1pissedoff90" this is for you--tell me a little about the mod you do to the MAF
  71. Who has the most miles on their 2.8 12V without rebuild. 126K for me, I'm sure will be beat soon.
  72. Intake Manifold Worshop..................
  73. In deep, guys. Could use some advice.
  74. Need quick help! Please. Pic request..
  75. Noise problem
  76. Stripped Hex Bolts on Crankshaft/Vibration Damper
  77. Need a crank pulley 078 105 251L
  78. with the renewed interest in headers everyone seems to be over-looking the options...
  79. looking for headers, found these
  80. Is this a cam seal? Take a look.
  81. Mori, whats the best oil for summer?
  82. Not an engine question, but I thought one of you guys might know...Jretal, Mr. D, Mik Tip?
  83. Oil Chart ...................
  84. Which way are the fans supposed to blow?
  85. Putting my AHH cams in my AFC and was wondering about some things....
  86. First post on this forum, I think... Custom Exhaust & rack
  87. Hey Justin...I think this Glen coverage on SPEED is giving me that itch I can't fix with penicillin.
  88. Replacing the A/C High Pressure Switch
  89. I might/will get beat up on this
  90. Mori, would you (or anyone) know if the Mahle OC 311 filter has been replaced with...
  91. need help with a part number
  92. **new** choppy idle after 'S3' hose kit install PLEASE HELP
  93. Car pings when cold...in my search I've found some causes yet,...
  94. Riddle me this my 12v friends... why is my car overheating w/ the a/c on and not any other time...
  95. i was reading older threads
  96. Rebuilding heads - what else?
  97. Did someone say Lloyd and headers?????????????
  98. Mr. D, a couple of questions for you if you don't mind....
  99. Well... Its hard for me to say.. but I'm leaving you...
  100. i know, double post... but can the aluminum valve covers...
  101. calling Mr.D-'97 A4q 12v! re: headers!
  102. Need some help identifying hose sizes.....
  103. what are some good perfomance mods. that can be done to 12v's to crank out a few more ponys?
  104. Hey guys, i gots a problem where she won't start, can ya'll help diagnose? Here's what happenin...
  105. Where is the relay box? ('96 A4)
  106. have a '96 A4, looking to be fast...HELP
  107. Will there always be codes stored if your MAF
  108. Audi Expo 2006 - Come be a part of history again!
  109. Misfire problem.
  110. Low oil pressure :( could it be a bad oil pump or what???
  111. Cross-Post. TIA
  112. Would anyone know if there are slight differences in the aluminum 12V valve covers? Specifically....
  113. Intermittent Check engine light
  114. BMC Part Numbers.........................
  115. RS4/S4 Trans Mounts?
  116. Radiator fans and noise
  117. Oil pump help (before I start something I can't finish)
  118. Vent line from EGR vacuum regulator solenoid valve
  119. Oh by the way
  120. It's too hot baby
  121. Mori..........
  122. Small rubber inside noise damper
  123. someone please help me (very frustrated!)
  124. Super n00b question... who or what is Mance...?
  125. What's normal for the temp gauge?
  126. BBK, Step 1: BMC......................................
  127. 96 A4's use H7 bulbs for the headlights right?
  128. audfi a4 2.8 quattro 1996
  129. Running no thermostat
  130. Dual Exhaust
  131. High uneven Idle
  132. The Secondary Air Injection system has me so confused.. P1411
  133. Mori.......................
  134. Anyone looking for a 411 ECU..?
  135. Strange miss at 1400 RPM...
  136. Valve cover mesh filters......
  137. My recent used oil analysis (M1 5W-40 -- 8,000 miles)
  138. Need an oil recommendation please......
  139. Does anyone know a source for the pressure relief valves (under the valve covers) besides the dealer
  140. Engine Damage
  141. Problem with washer pump, need help...
  142. Hey MikTip..... Do your MAFs come with the sensor?
  143. Ok.. without getting flamed... Has anybody seen the new Malibu Maxx SS?
  144. Would it be a worthwhile benefit to replace the valves with stock sized Na filled undercut valves?
  145. Im Gaskets
  146. Ausfahrt and others interested, Got the exhaust done today first impressions...
  147. Yo Mori, quick oil quetion for ya.
  148. The bleed screw underneath my coolant reservoir is stuck.
  149. hey MikTip, What gains did u see after installing the 272? any dyno charts??
  150. Get your Tetrachloroethylene localy!
  151. My impression after installing my Nology hot wires...
  152. engine coolant temperature switch connections
  153. 100w fogs...
  154. Pulled off Throttle Body on 94 audi 90
  155. Doing exhaust ... final clarifications
  156. Fog light mod on early C4...?
  157. Will carb cleaner burn out your maf?
  158. what would it take to turbo or supercharge a 93 12v v6?
  159. A quick teaser of things too come :o)
  160. 12v cam question
  161. friend in need, TIA
  162. anyone have a write-up on how to remove ac compressor and dryer for a '96 a4?
  163. maf
  164. Does anyone have a part number for the rack & pinion??
  165. scratched head gasket - need a new one or not?
  166. Anyone looking for an AFC clutch kit...
  167. Help with oil system problem....
  168. Possible Overheating problem.....help please
  169. ?HEADS? Will AFCs fit my AAH Block?
  170. 94 Audi 90cs
  171. Oops....forgot to connect the hood release cable -96 12v - 2wd
  172. PSA: Lots of misinformation being spilled around here these days. ;)
  173. Anyone have a carfax account?
  174. vibration in front end?
  175. Yikes!!! Snapped bolt on coolant pipe to head... suggestions?
  176. Mori, just curious, how do you think the new T&S 5w30 compares to the standard 5w30...
  177. I guess Rapid Fire #9's are still available....................
  178. induction kit
  179. Question for Miktip! (anyone else with dex-cool knowledge)
  180. *NEWBIE* Will the AFC cam tool fit the AAH???
  181. Another good 5W-40 oil option for the 12v
  182. upgrades for the 12v
  183. Mori, I struck liquid gold! A few stray qts. of M1 5w-40 SUV at Kragen. Get 'em while they last!
  184. Looking for an accessory belt tensioner ...
  185. Zex Kit in an auto A4 12V
  186. mori, may want to pop some nitroglycerine before reading this...
  187. *NEWBIE* Will AFC top-end gaskets fit an AAH???
  188. it's offical, my power steering pump is dead. Does anyone have a write-up for the replacement?
  189. How do I bleed the coolant system?
  190. Quick Exhaust Question...pipe sizing, trying a combo system....
  191. This might interest those of you who choose to use the Mann W940/25 instead of...
  192. cooling question hlp pls (puf of blue smoke)
  193. allroad tranny mounts
  194. Audi Expo 2006 - It's coming!!!!
  195. Anyone got a pair of 12v aluminum valve covers nice and cheap? Email me.
  196. axle's anyone
  197. By the way.. anyone know what the paint code is for 97 laser red is? Or where can I find it?
  198. Anyone Need to Barrow? TOOLS 3242 & 3243 Bay Area California
  199. Ok I got the right one this time...Carfax anyone? 3p3aa46k0st542819. thanks
  200. Camshaft 3242 & 3243 Tools to lend??
  201. Oil in Radiator overflow - 3-4 quarts lost
  202. Do the dimensions of the VS matter or .....
  203. Take a look at my old plugs. See any issues?
  204. Well sold the Audi . . .
  205. Paging MikTip...what kind of mileage interval are you getting on the Rapidfire 9s? Just curious
  206. Zerex Coolant Chart
  207. so I started getting a rough idle and did 2 things seems to have helped
  208. recommend some decent spark plugs? nothing high-tech, just regular plugs
  209. Found WHITE GELLY GOUP!?
  210. What are the problems that are guaranteed for A4 12v owners
  211. Check Engine light and failing idle
  212. Thought I would spread the news..Another one bites the dust. :(
  213. Rear squeek/whine dont think its the wheel bearings...
  214. AC Delco Rapid Fire #9's
  215. Opinion Poll - Remus Muffler Worth the $$$$
  216. Is the thermostat on the AFC an 87C one?
  217. where can i buy Rapid fire #9?
  218. I have 2 resonators
  219. Rear muffler repacement poll: Magnaflow or Flowmaster?
  220. Intake for a 97 A4 2.8
  221. Sir Mori, I did a search but any good feedback on Rotella-T 5w-40 Synthetic? Since...
  222. Question for the A4 guys re thermostat replacing.
  223. Can someone carfax for me?
  224. Does the timing belt have to be removed to replace the head gaskets on my '96 A4?
  225. difficultly level of DIY replacing AC condenser?
  226. Hey guys, it's been a while...In need of some help with a Funky code...Fuel level sensor Circuit??
  227. allgermanparts.com dropped the price of bosch Idle stabilizer down to $132
  228. Rack and Pinion replacement ...does anyone have DIY
  229. Arrrg! If I had hair I'd pull it out!! How do I get the cooling fan pulley off?!
  230. Oil consumption
  231. I need to do some work, looking for lemonade
  232. Found it!
  233. So I call today my local VW dealer...
  234. Will taking the resonator out of the exhaust system negatively effect it at all?
  235. Various Issues **CRITICAL** ---> Emissions Must be Passed
  236. Anyone running a Bosch Premium 3500 oil filter?
  237. Oil change hassles
  238. wire/plug combo
  239. MAF question?
  240. Advice Please: High RPMs & Hesitant Acceleration
  241. dohc or sohc
  242. Rattling is driving me NUTS!!
  243. where is my lower line AC port?
  244. Whats the longest anyone here gambled until changing their timing belt? I'm at 102k right now...
  245. where to take fuel injectors to get cleaned?
  246. Terrible Gas Mileage!!
  247. Underhood stickers P/N
  248. SERIOUSLY slow right now...97 2.8 qm
  249. Free serpentine belt...
  250. Looks like Audi's R8, R10, and Mance's 90 are not the only one's using Mahle's pistons . . .
