PDA
View Full Version : 12v V6 Discussion
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. I tried a dif. approach at boring a non s throttle body...didnt want to use epoxy this time
  2. asv4k8, are you out there??
  3. O2 sensor fault code question.
  4. just as there are many different tb's ...
  5. custom headers
  6. Pic of the machine shop ive been using thought it might interest some
  7. what lifters should I get when replacing afc cams w/ aah???
  8. EGR Temp sensor port on the I.M. What is the thread and pitch? M10X1.0??
  9. TB spacers
  10. Some VERY interesting numbers for AFC lifters...
  11. AAH AFC ?? im new
  12. is the S TB the only yummy part that can be pulled from an avant ??
  13. Mance, could you please complete this post...
  14. Guys, don't make too much over TB part numbers. Remember that "any" 12V throttle body...
  15. My car has really come alive with the Mance MAF installed.
  16. Looks like the 12v forum is coming back to life after all!
  17. a burning question about flow
  18. What should the throttle body part # be for 96' A4 AFC?
  19. Mance's XTB boring/tapering process...
  20. Anyone know part# for those engine cover screws and clips (to hold it down)?
  21. starting a list of whos interested in a mance xtb or sxtb
  22. RSXTB pics...
  23. are these the right part numbers for the Bosch O2 sensors on a 12V?
  24. s and non s-type TB (i was wandering about the larger bore in the s type)
  25. URS4 are you selling bored TB's ??
  26. total audi peformance bored TB??
  27. s and non-s TB's
  28. all butterflies are out of upper I.M. So now I just pull the "rods" out??
  29. Random fact: Early build 1996 a4's have the same blower motor as audi 90 1995
  30. Oil Pan Removal?
  31. why did audi do it??
  32. Anyone want to chime in on why my car is running so bad? (Codes Inside)
  33. 2 down...4 to go ...
  34. is there a way to bore a TB without a machine shop?? whats the best way??
  35. There's a crack in my air box
  36. anyone know if theres a site online that sells oem audi air filters??
  37. the stock airbox is on its way back in....with a addition...
  38. i have a tb off an older 12v..
  39. driven about 65 with maf..
  40. whats the verdict on filters for a stock air-box? (paper, coton, etc.)??
  41. High-Flow Airbox workshop starts...
  42. asv4k8 YGM.
  43. So what does everyone think of this idea to get some more air into the "positive pressure" area...
  44. where do I grind off the back of the welds on the butterflies?
  45. Tracking shows my new airbox inlet MONSTER VS is "out on truck for delivery"...
  46. 1996 Audi A4 Oil Filter
  47. someone please humor me and show me a picture of a "flex hone"..thnx.
  48. intake
  49. is it really impossible to find a MANCE MAF??
  50. whats the most restrictive part of the 12v 2.8??
  51. went ahead and installed maf last night..
  52. anyone got a extra MAF they want to part with? I need a 471 (A) MAF
  53. Its all here Thanks Mance!
  54. I have been away for a week....did the run of VS's get out the door on time?
  55. Need help locating Vacuum Line
  56. Think i might get someting in the mail today:)
  57. for the northerners.
  58. best cleaner to use on my ICV?
  59. Anyone need a NEW AFC lower oilpan gasket for the cost of mailing it? (probably nothing)
  60. At what virtually assures drawing the weasel outta the woodpile again, I have a new project...
  61. Did i miss something ... did that supercharger thread get deleted?
  62. WTB OIL PAN FOR AFC ENGINE
  63. Source for engine rebuild kit
  64. 243k on my 96 A4 2.8L
  65. Mance, I sent you an email on Sat. Hoping you got it.
  66. Just Checking: In a 90CS can I replace the thermostat w/o bumper & Timing Belt removals.
  67. This forum is coming back to life...I can feel it
  68. Addition for engine!
  69. cant wait till next week now :)
  70. relay ?s
  71. Best Place to purchase haeders? 97 2.8.
  72. as soon as it gats warm I am re-installing stock ait box..need oppinions on what flows best please.
  73. RS3 MAF update: if it weren't for "prattle-minded" I wouldn't have ANY mind at all...
  74. parts?
  75. oil pump / timing belt
  76. There are 4 remaining RS3 MAF purchasers who have not sent their $200 deposit...
  77. Just reupholstered my back seats what a pita..took 4 days (already did the fronts/door panels)
  78. Sh#t I think I'm gonna cry.. I just picked the worst week ever to be away from the forum : (
  79. Can a bad oil cooler gasket cause oil in coolant and vice versa?
  80. I LOVE days like today....snow!
  81. humm.... does anyone here know the oil pressure bypass valve rating on a Mahle OC 246 Oil filter???
  82. Spot Crude price falls 10% from record peak on weaker demand after 12V owner fixes oil pan leak...
  83. CEL came one ...Pulled codes
  84. In need of MAS Airflow Sensor adapter
  85. Just ordered a spare set of heads to get port/polished/big valves :)
  86. Crap guys! I just noticed Monday is MLK Day. No mail pickup/delivery...
  87. Big bore throttle body
  88. No Start, No Codes. No Check Engine Light. CEL
  89. The making of an airbox velocity stack...
  90. 12V starter location...just curious.
  91. Are there any stasis tracksport owners? What would be an ideal spring rate for the 12V?
  92. And then there were none. Thanks guys... I'm on it!
  93. RS3 MAF installation instructions...
  94. Custom Magnaflow exhaust: Installed...
  95. Where to get an Egr valve gasket?
  96. UPDATE!! As of noon MST today 3 RS3 MAFs and "NO" VS's remain available...
  97. PSA: I'm going to make a small, "one-time" RS3 MAF production run...
  98. Hit or skip? craigslist
  99. Oil Pressure Reading: 75PSI at 900RPMS!!
  100. wonder how much total cost to put a 2.0T into a B5 a4 12v engine space..
  101. anyone have big valves/seats for our heads? i need some
  102. Were can i find the coolant bleeder valves? 97.
  103. 2.6 V6 12v Tuning
  104. Just installed a Mance Velocity Stack and S2 Hose Kit
  105. Homemade knock sensor....sort of, but works for really cheap
  106. dead POS again!
  107. Engine oil light
  108. Source for rebuilt 12v AFC heads?
  109. MAF for sale...
  110. Free up hp or gain hp?
  111. Vacuum hose Question ('93 90CS Quattro)...
  112. Anybody have nitrous hooked to thier 12v?
  113. I like how "suspendedaccount lol" got suspended.
  114. Exhaust Q.
  115. For whoever might be interested I'm going to be making up a few of these...
  116. Would you bore out the maf to 3" without having a VS?
  117. I'm Andrew from Canada. Not Rob making new accounts
  118. I have an S3 Velovity Stack and Silicone hose
  119. Anyone got a set of spare injectors their looking to get rid off??
  120. Questions about the egr delete
  121. Wonder about a supercharger. Have a 97 2.8.
  122. Just saying thanks to everyone...Finally got a "new" car (sig) Have old parts.
  123. Code 00554 solved, 00537 & CEL still appearing (94 cab)
  124. QQ. is the Intake Manifold identical on the 94 90 and the 93 100?
  125. No Heat
  126. The never ending hesitation story
  127. Ok, I think I'll try making a super-efficient "sealed" catch can for the 12V...
  128. DualMap
  129. Hmm going to have to be on this form more b/c i want S3 stuff.....
  130. Anyone got a PS camshaft cheap?
  131. Funny thing when I washed my engine..
  132. Can I switch my 471A MAF to a 471 MAF, it's a dumb reason but I only have the hose for the 471.
  133. no spark
  134. Can anyone use some connecting rods or a crankshaft because they are heading to the recycler?
  135. Boring out a MAF
  136. So I installed my Mance MAF and returned back to stock air box from K&N Cone
  137. what is\everyone running from there "Recovery sleeve" to valve covers as PVC pipe....
  138. Anyone need some Arrow-Magnolia Bulldozer degreaser?
  139. engine issues
  140. think I have asked this before and forgot the answer....regarding sea foam...
  141. asv4k8, did you ever send me a email about those heads?
  142. At a loss over severe power loss.. HELP :(
  143. Paging asv4k8
  144. I have extra S3 MAF and Velocity stack if anyone needs em
  145. Average price for TB job?
  146. Ticking noise follow up
  147. Paging JWG
  148. Do anyone have an idea where the G110 coolant sensor is?
  149. Check engine light
  150. Did anyone ever got the same thing as I have now?
  151. Anyone make led gauge cluster lights that dont burn out?
  152. 70 mph / 0 RPM / oil pressure warning light. What's the problem?
  153. I've used sea foam many times and am wondering,......
  154. coolant smell
  155. location/size/thread for block heater "hole" on a 12V?
  156. I noticed NGK changed their web site . . .
  157. Ticking noise at low RPM
  158. what is that in my basement?...
  159. JE piston order form...im confused.. has anyone ordered forged pistons for the afc motor, and know..
  160. What is the URL for VAP's homepage... Though I had it bookmarked but I guess not :-(
  161. Fuel System Cleaners?
  162. Anyone know if Mance (VAP) is still willing to "make" STB's or Hose kits and VS's...
  163. A very sad update on the 12 valve robbery.
  164. can the sealing strength of coolant/powersteering hoses diminish?
  165. i know little of turbos, and would eventually like to put one on my b4.....
  166. X-post anyone have a site where i could purchase eurospec or schrick cams?
  167. Click Me link inside vr6 turbo a4...look at all the space free'd up when you get rid of that......
  168. whats the reason my coolant light blinks at startup (before ignition).......
  169. Check out my new bike w00t...cost more than my turbo setup :( but its bad ass!
  170. Just got an idea after reading the "insulating the MAF" tech article
  171. Just a quick question about turbo's on the 12v,
  172. rough idle
  173. islingtonaudi I am looking to duplicate your intake setup using my own DIY MAF and TB
  174. Starting troubles
  175. Question regarding the AC on button and how it toggles the rad fan....
  176. Used cylinder head preparation?
  177. I finally posted!!!
  178. I just finished reading some info from AW and other sources on H2O and/or ALCOHOL injection......
  179. Troubles with finding valve covers
  180. is the 6-cyl High output coil pack listed on 034 a dropin replacement for our 12v's? maybe I......
  181. Dumba$$ on ebay trying to out smart me..... not going to happen, read on, another one like GVee....
  182. help for a vw friend
  183. rs4 b7 steering wheels..why isnt there a chinese knock off of these yet? factory ones are $1849..
  184. New to Audi, but first impressions!!!!!!!
  185. 12v'ers! Whats it worth? S2 Silicon and VS from Mance back in the day...
  186. EDIGREG........since you and I often [politely] but heads regarding pcv setups I have a question...
  187. Does anyone have a good write up on how to do an oversized valve job on our heads?
  188. What is the difference between these injectors?
  189. question about flywheel/flexplate
  190. Whats the torque on the camchaft sprockets supposed to be?
  191. Question on 12v Heads.....
  192. looking for a transmission pan
  193. can aomeone explain EXACTLY what occurrs if the ecu goes into this "limp mode" that...
  194. help needed for a kunckle head
  195. Anybody have a good DS cylinder head for a 96 A6 lying around?
  196. PSA: Still looking for Mance MAF
  197. anyone go any good ideas for R&Ring the oil check valves??
  198. Dyno Days in Louisville Ky this sat fyi ! anyone have some nitrous i can "borrow" lol seriously tho
  199. intercooler options: side mount with pusher fans in front of the radiator, or....
  200. oil check valves?
  201. someone needs to jump over to VWvortex 89/90 forums and school those....
  202. Anyone have Mance's e-mail? Can't access through work. Trying to get some info for insurance.
  203. Anyone need a used AAH oil pump. (Cheap)
  204. I found an A4 but it needs some parts
  205. Anyone have an 2.8 (AFC) oil pump layong around?
  206. Still having issues with hesitation
  207. Does anyone know 100% if the 1.8t flywheel fits the 2.8?
  208. Coolant in oil after new headgaskets...
  209. Has anyone here ever had a code 2331 come up after a t-belt and w/p job?
  210. just baught a 92 100, need some help
  211. 034 catch can.
  212. Starter motor replacement
  213. On a lighter note, x-post from our brothers in der originale "S" cars forum next door...
  214. Ignition Upgrade questions...i searched....does anyone have a write-up? phoenix x project where r u.
  215. Oil problem
  216. Temperature gauge prob!!
  217. 12v sport cams
  218. Gone?
  219. Am i dreaming or...
  220. All time low for 12 Valvers...There is a Thief among us. This is long...A 12ver robbed me last nite
  221. I need a new motor
  222. where do i put the velocity stack?
  223. has anyone had experience with lightweight flywheels? recomend one? what weight?converting to manual
  224. looking for a s3 or rs3 maf anyone have one laying around?
  225. problem persists...(hesitation)
  226. Cracked oil pan.. anyway to repair
  227. what is proper way to flush coolant? Is there a bolt somewhere?
  228. Can anyone identify these wheels? they look like bbs but im not sure...they are awesome looking
  229. Anyone know how to hot wire our cars...Don't have a key...just need to be able to restart...
  230. finally installed a new radiator after 3 months of filling reservoir every 5 miles.......
  231. UrS4's Custom Magnaflow Exhaust.
  232. Magnaflow exhaust on the bed...
  233. Early christmas gift for me....
  234. Would using MMO screw up an oil analysis? I'm using Rotella 5w-40 right now and consumption is about
  235. For those wanting to more closely emulate S3 hose kits, or...
  236. AFC Oil Pan Part
  237. Ok boys, the silicone hose kit is finally done...
  238. I feel a slight kick before I turn off the car, anything I should be worried about? What could it be
  239. How many of you run your engine topless, no fancy plastic covers not counting timing belt cover
  240. V12 cams
  241. if I were to dismantle, clean up and Gasket match/head workshop a set of 12V heads....
  242. Would a code for a post-cat O2 sensor affect my gas mileage?
  243. Can I use the spedo/cluster from my 97 with computer in a 96 A4 with no computer...
  244. Were can i buy new Vac Res Ball??
  245. 12v.org is working again
  246. question for jbrentd12v
  247. Reminder to change the oil plug and gaskets.
  248. got rid of my CEL today, seems problem was not flow not turbulence...
  249. mucho oil on intake plenum
  250. paging sam.sun
