PDA
View Full Version : 12v V6 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. Thinking about selling my 100s
  2. Vacuum hose question...where ...
  3. Hey, have any of you oused "the big" oil filter?
  4. What is good to go with head gasket job??
  5. coolant in oil...any possibilities besides headgaskets?
  6. crankshaft position sensor location
  7. 95-97 a6 quattro exhausts
  8. Alcantara Shift Boot - DIY total cost: $5.00 time 30 min MAX
  9. Rear sway bar links for a 96 A4 Q
  10. exhaust questions
  11. Engine Oil Temp.....I think i have a problem....
  12. problems with my 1993 90S
  13. LET ME SAY if you have not replaced your engine and tranny mounts on your 12v
  14. Testing an MAF....
  15. sluggish sometimes
  16. Mr. D, how's it going? Figure I'd check in on the old 12v forum...
  17. question about cleaning the idle control valve
  18. Hey guys red oil light came on yesterday. Question.
  19. Crack valve covers!! Where can get new ones?
  20. Blast from the past post!
  21. FYI: ECU coding (MMS 200, 300, 311) euro coding, EGR problems go away (if you don't need EGR)...
  22. Spark Plugs
  23. where to start
  24. How do I go about cleaning up an entire gallon of used oil that has leaked onto my garage floor? :-(
  25. Slipping Clutch or ?
  26. What is the inlet circled in the pic? TIA
  27. coolant leak?
  28. Tune-up kit from Blauparts.com. Is there are better deal to be had?
  29. just bought a 96 2.8 i need some help
  30. Stock exhaust pipe sizes
  31. Anyone got a good pics showing Vacuum hose routing on their 12V...
  32. complete timing belt kit +extras
  33. What's the little "tube" that hangs down from the bottom of the expansion tank? I seem to be
  34. Directions Didn't cover this step (PHOTO)
  35. blue smoke after warm up!
  36. Ok.. so does anyone here ride Panther 429 wheels? If so I got 3 like new spares for
  37. Front Bumper Details?? (PHOTO)
  38. Where do you guys get your air filters from? My online spot is down.
  39. To people who have replaced our vacuum lines with BMW vac line...
  40. 1995 90 2.8 12v waterpump help
  41. well im going to join the ranks of the TB people
  42. Jretal, any results for aah cams in the afc?
  43. WHATS THE BEST INTAKE KIT FOR THE 2.8 12V
  44. bleeding coolant with a stripped 5mm bleed screw
  45. what's a good price for a new EGR valve?
  46. pics from last weekend at the topeka KS DE..
  47. I think my thermostat or water pump or headgasket just went????
  48. Stalling in Park and Neutral
  49. Those who have done a timing belt on an A4 could you tell me...
  50. Can I get the block radiator fluid drain plug seal off the internet or just go to the store?
  51. Your experiences with newer car battery formulations? Less and less warning of impending failure?
  52. cruise control?????!?!
  53. I found the cause of the ignition coil shorting out
  54. New guy, looking for a place to start
  55. hello!
  56. Hey Mori, door lock question for ya.
  57. MFZERO....how deos this sound???
  58. Idle issues and spark plug/wires question
  59. 12v potential
  60. replaced plugs after 15-20k miles, running lean
  61. Coolant Flush
  62. I should have just bought a new car...but I didn't, so please help.
  63. changing plugs, wires, fliters, etc.. gonna do the seafoam thing
  64. Any of you guys need a passenger's side valve cover off my AFC A4?
  65. Snub mount. What exactly does it do? Just curious. Thanks guys.
  66. Weird idle problems..
  67. Replacing all 4 O2 sensors..
  68. Fried Ignition Coil a la Surprise
  69. throttle stick and wierd power
  70. Looking for info on V6 12valve....
  71. METAL valve covers needed...part numbers/sources?
  72. Got three DTCs
  73. would the 06A oil filter work on the 12valve? I ordered the wrong one...this is the old, smaller 1.8
  74. Quick tire question... Anyone ever tried 255/40/19's on an A4? I got the super deal of a lifetime...
  75. oil cooler gasket replacement question..
  76. New, dedicated MAF sensor cleaner
  77. 93 exhaust note...
  78. Mori . . . worth a look . . . Cosworth has its own line of oils . . .
  79. BMP Tower Brace
  80. velocity stack
  81. Mr.D-'97 many turbos!
  82. Anyone with a camshaft holding tool, please read
  83. Does anybody know when the 12v engine went from normal to low-tension rings?
  84. gonna make 2 of these today....any reason I should not in my 12v?
  85. exhaust
  86. does any one have comparison pics of "078 133 471A" vs "078 133 471"
  87. overheating/coolant loss
  88. Are you supposed to see a partial opening on one of the holes of the ICV
  89. Just paid for eight+ hours labor to get all four wheel bearings & rear diff fluid replaced . . .
  90. for any one interested there is a 471 maf on ebay...search for "audi maf"
  91. Can I just unplug my ECT Sensor and drive it
  92. First TB change front crank seal yay or nay?
  93. $79 plus tax for part # 8D0 422 891 C
  94. I installed those cheepo champion plugs in my 12V
  95. ICV Cleaning Procedure with a Twist
  96. Bored MAF...purchase/procedure for modification?
  97. Mr Paul....do you have pictures of your car with window tints?
  98. Does anyone have a lightweight flywheel?
  99. Xpost regarding spark plug gapping in a 12V
  100. anyone ever use these spark plugs?
  101. Hey guys... what are the torques I'm suppose to put on the nuts that hold the retainers for the cam.
  102. Does TDL racing still exist??
  103. so I am on my way to pick up some SeaFoam....do's/dont's?
  104. Some good pics for Valley pan/Egr/Intake job. 97a6Quattro
  105. Anyone have some burlwood wood grain laying around?
  106. Hey Jretel where did you get the rotors you use?
  107. Looks like I screwed the pooch pretty good here on my coolant bleeding...
  108. Hey Mori, any updates on the M1 T&SUV replacement oil?
  109. 80/90 Guys, repost.
  110. Throttle Body Removal
  111. Noob... Stupid very stupid question
  112. ICV woes
  113. Big brakes
  114. Will the cat back exhaust from a 30v 2.8 come close to fitting a 12v?
  115. where to buy rapidfire #9
  116. Car is stalling after I replaced the ECT. Before I changed the sensor, I was occassionally getting
  117. So I'm in the middle of the Valley Pan/EGR dealio.
  118. Engine miss question,,,
  119. Is RobK still around
  120. Sport steering wheels for MY 97 and older. Has anyone bought one recently or not so recently?
  121. 12V conversion to 30V is it possible
  122. Power loss issue...help!
  123. X-post from B5 A4 forum: Any suggestions for high performance injectors for the 12V V6?
  124. JWG, regarding the oil filter going into bypass at high rpm...
  125. Leaking oil from the engine block, shop told me its a gasket that usually fails
  126. yesterday o2 sensors only 45 min.. driver side was already loose could that cause a rough idle??
  127. can you believe this guy..no way was the 12v a waste
  128. hey guys, quick help...
  129. So tonight...
  130. Performance mods
  131. Legit ECM modifying Question
  132. Need your opinion.................
  133. My Fault codes.. and plent of them :(
  134. Valley pan gasket done, EGR valve question.
  135. Looking at the new EuroTuner and was thinking
  136. How many cycles does it take for the EGR insufficient flow error to reset?
  137. Mori: Your opinion on CM oil filters . . . gimick? performance? application appropriate?
  138. Where can I buy an EVAP Purge Valve?
  139. is our stock exhust 309 stainless or maybee 304 ?
  140. leakey oil filler cap.
  141. I am going to tackle the valley pan gasket tomorrow and I have a couple questions....
  142. the area I have moved to does not carry Mobil 1 5W-40....
  143. Will a 2.25 in band clamp like this work on a 60mm (2.36 in) exhaust pipe? TIA
  144. Need help diag starting issues
  145. paging KMHPaladin. How do you make your sig change when you refresh?
  146. My new 2001 A4 2.8
  147. Repost ...... Smell of oil
  148. Were to buy performance parts?
  149. been searching for a faq for engine mount replacement anyone have a link for one?
  150. Motor Question?
  151. 87 Audi 5000S Oil Leak from fill cap
  152. I need help. Coolant temperature sensor function.
  153. Remus or Stebro rear muffler for my 12V 90 quattro?
  154. Can anyone direct me to good muffler & resonator upgrades?
  155. head gasket question.
  156. Because it is snowing,
  157. Anybody recomend a REALLY good extended warranty program? OT
  158. If anyone is interested . . . .
  159. Registration for Audi Club DE at Hallett (Tulsa, OK) in May is now open!
  160. Changing valley pan gasket, back together, very rough 1-2 mins
  161. YEA!!! looks like tomorrow i am going to replace my O2 sensors on my a4 12v
  162. Does anyone have an online source for AAH oil check valves?
  163. ok.. so I broke one of my Panther 429 Silver wheels with polished lip...
  164. Update on Injectors and DTC Codes that resulted...sort of long
  165. Question for those of you running poly bushings on your cars... (JWG, Mance, and others)
  166. what do the old and new headbolt tools look like?
  167. downpipe
  168. next weekend should be putting in new O2 sensors YEA!!!!!! only 123k on my origionals..
  169. Searched... 1995 Audi 90 w/ 12v, not getting spark...
  170. so is it the front or the rear o2 sensors that lower the gas mileage?
  171. Supercharge my a4
  172. time to order O2 sensors dont want to splice anything who was happy with where they went?
  173. Im trying to go to the dark side!!
  174. Could a loose plenum gasket cause stumbling and hasitation during full throttle?
  175. ok i lied, i AM leaking oil, not sure where from tho, when i pulled the plastic under body cover..
  176. What are symtoms of a failing head gasket?
  177. thermostat or temp sensing unit?
  178. Serpentine tensioner...
  179. Problem with EGR - Insufficient flow
  180. Follow Up on Injectors with AAH and AFC
  181. WTF My valve cover gasket is leaking. I just replaced it a few months ago.
  182. question regarding some oil filter info on 12v.org
  183. Springtime modding needs to begin. Opinions please
  184. grey smoke again..... i cant believe this, i just dont want to...
  185. 1996 Audi A4 2.8 runs great but sometimes kills or turns off while in idle completely randomly
  186. Impending lifter problems with this setup?
  187. Anyone here have camshafts
  188. does anyone know how to change the thermostat
  189. The valley pan/head gasket infamous oil leak scoop
  190. I have joined the "darkside"
  191. cold air intake
  192. Quick question about thermostat position
  193. How far would you trust this?
  194. Anyone looking for a complete 12 valve engine.
  195. Great. Looks like my thermostat has failed...again.
  196. Where can I find the ECU pinout diagram? I've got my SAFC today:)
  197. Orange Coolant?
  198. Oil Leak!
  199. oil cooler(heat exchanger) question. It appears that the coolant has been leaking...
  200. morib, so im going to pull my spark plugs today, then possibly get a compression test ran. But
  201. Could someone give me some insight on these three codes I got the other day. I cleared the codes but
  202. AC Delco Rapidfire 9
  203. 2000 2.8 exhaust replacement in Boston Area
  204. Any A4's in the MD area still have their stock muffler installed and want to swap with my Magnaflow?
  205. How much coolant can I expect to lose when replacing the hoses on the oil heat exchanger?
  206. Hard to start when using engine warmer.
  207. any local places sell silicone vaccum lines?
  208. a1crankshaft
  209. This has to do with halik's supercharger project, sort of
  210. DieselGeek shortshifter with new housing installed . . .
  211. initial supercharger test fitting... high beam def' won't make it
  212. X-post. Coolant disappears...
  213. paging moribundman and all you other oil guru's
  214. changing the o-ring on the oil cooler, do you need to remove the coolant lines
  215. Well....my 12v is very broken... i need some advice.
  216. Update and Question on Injectors
  217. What's a good way to control boost level on a supercharger?
  218. Mr. D, please check your mail
  219. Shell Rotella T
  220. I hear people talk about nitrous as a crazy way to add HP...but wouldn't the ECU spit that out?
  221. Cheap place to get tranny mounts?
  222. ok my LAST oil question
  223. well there is a good side to changing my oil and putting in 10w-30 (my normal oil)
  224. replacement ICV... where and how much??
  225. Need Injectors...Help
  226. From now on all oil-related questions go to G Peen Jr -- I feel he's the best man for the job
  227. 1000k result of Pentosin 5w40 synthetic...
  228. castrol GTX 10w-30
  229. 1995 v 1996 12V TB kit
  230. how big is the crank pulley in diameter?
  231. Engine stalled and won't start up.
  232. Im using Mobil-1 full synthetic 10-W30 oil Good or Bad Idea
  233. woohoo scored eaton m62 (benz supercharger) for 150
  234. Does anyone know the weight distibution for a 96 A4 12V QM?
  235. It appears my engine has lately been running a little richer than usually
  236. Part number for Throttle Body to inlet manifold gasket?
  237. Castrol 5W-40 survey
  238. M1 5W-40 survey
  239. If you like M1 5W-40, better stock up now -- this oil is being discontinued!
  240. Crankshaft Oil Seal Replacement
  241. need help identifying this connector
  242. Mori... you whore!
  243. Engine Temperature
  244. Air bleeder valve blew on my 100s. The screw is in 2 pieces, the cap and the rest inside the valve.
  245. Wow.. kinda OT i guess... but my wife hit a pothole in my car with my aluminum wheels...
  246. Stand Alone and CEL question (Long)
  247. hola amigos!! Merry Christmas and Happy New Year! Anyone have a Throttle Position Sensor for me?
  248. anyone else wire in an SAFCII
  249. X-Post: Coolant boiling problems.....
  250. New Expansion tank... now I've got coolant light flashing
