View Full Version : 12v V6 Discussion
- help me decide on what rotors to get already have my pagid blue pads ..
- I think my Catatonic Perverters are borked.
- OK, replacing the coolant temp sensor did not fix my problem. :-( Need some help...
- Mance, question re your choice for clutch/flywheel . . .
- Mance, did your A4 exhibit that 1st geat chatter that I hear is common?
- Is it possible to over due the MAF by hollowing it out to much.
- 4 wire to 3 wire mod- ugly new detail
- Mance, did you see my question at the end of your sway bar post?
- Is this something I could use to control speed on on my 1 speed(25k RPM) grinder?
- Mance...have you see this...
- so far Audi likes the Castrol 5w40. good on startup, good on sound, good on consumption
- Valve cover gasket problem
- Idea for diagnosing CATs?
- Watched a snub mount go into a 93 90 in 15 minutes
- X-Post: OctoBEERfest Trivia Road Rally & GTG in Eastern PA - 10/23
- happy HaPPy Joy joY just ordered some Pagid sports for..
- A day in the life of a govn't employee...
- AAH cam install
- UrS4 did you get my e-mail about the CAI kit I want to order.
- How do I get my injectors cleaned. Take them out and have them claned. Or take the car somewhere and
- I need a stock A4 resonator.. Where can I get one used in great shape or new.
- All of u guys with the auto tranny!!!
- My brake-power sucks. 4 new rotors, pads WERE barely used on old rotors,
- Dash bulb part numbers (not all of them -- not yet)
- Any of you guys ever pull the upper pan off?
- Probably a stupid question but I purchased a 12V LED from Radio Shack...
- my friend just bought a 90 and.... searched, no luck
- Remus Exhaust? Where to buy?
- where is it that stocks pagid blue pads? ready to order them today for the Kc october DE
- UrS4,mori,Dr.12v and the rest of the hardcore engine tuners...
- Is our odometer display backlit?
- Mance what kind of clutch will you be putting in with the new engine?
- Need some help wiring a relay, please....
- This Saturday (9/25) - near Hartford, CT - Dyno Day and Audi Gathering - Come join the fun!
- What grade Mobil 1 oil should I use? (Grammar???) Car has 150K
- Since swaybars are a hot topic of late I thought a correct installation "how-to" might be valuable
- oil change today. was able to find the new Castrol syntec 5w40, so I figured I'd run with it...
- CAMS!!!!for 12V
- Venome Module Snake Oil?
- A4 and S4 interchangable parts?
- yuuuuummmmmmyyy :-D
- UrS4, regarding ARX
- How much do you think front are rear SPORT stock sway bars are worth? 29mm front, 15mm rear
- Anyone have any tips to clean out the gunk around the spark plug holes?
- Like my new wheels?
- My interesting evening....
- Where's goyer?
- x-post (you've prolly seen it already, too): blower housing "mod" to ease remove/install...
- When you put in the new cams 264 do you need any other pieces?
- you guys should try to "develop" the 12v into something but a heavy lump of crap...
- Where's a good place to get a new lower control arm? Parts connection is a no go. Thanks.
- OK guys I did the smog check challenge today...
- How do I diagnose CATs?
- Help a fellow 12v owner.
- strange noises coming from rear of car [more]
- sun roof opens n closes frequently
- Bad couple days for my car... :-(
- Fun times at autox's :)
- Guys I got a question. Sometimes after I drive my car, it smells like .....
- rough, uneven idle. poor acceleration. poor milage.
- Anyone have a Valve Cover Gasket write up
- Opinions needed. Should I auto-x with a bad coolant temp sensor?
- 12v mods...
- I have viberation :) need some help.
- Need some help. Replacing seal kit on front caliper. How do I get the piston out of the caliper?
- Mr D, get the sways on yet?, first impressions?
- Thanks for the snub advice!!!! URS4...wow, your stuff is the best!
- wish i had a camera this afternoon.
- Running with no cats? (i.e. test pipes)
- @ URS4 - how do you measure?
- x-post... need a lil help with a picture
- At the risk of beating a dead horse I'm over 200 miles into the "rinse" phase of Auto RX....
- intake install
- X-post; After a 3 year search on 4 different Audis I've finally got a Gatorback serpentine belt...
- Snub install...is it really that easy..?
- Reminder: 9/25/04 - Audi Dyno Day and Get Together - Come Hang Out - near Hartford, CT
- (x-post) Replaced Cats now the car stalls...
- Has anyone drained/flushed their coolant lately...
- changed some things up and disconnected the battery, did nothing.
- Moribundman and all the other oil gurus...
- 12 Valve Heads!! Please Help
- Anyone know what years Audi used that blank (cubby hole) switchplate in the A4 center console ..
- Did Vortrag, when it was going out of business sell its products to Statsis ?
- Intake Manifold Workshop Question
- Anyone have another gallon of Bulldozer they want to get rid of?
- Weekend at BIR
- for the a4s who has the oldest manufacture date my doors sticker says 06/95
- Jestnomen, is everything Kosher? E-mail me.
- OK guys I have gotten a 16785 EGR insufficient flow error code twice now.
- I can now attest that the "rumors" are true...Optima batteries can gas if over-charged.
- Know how?
- Does anyone know the speaker sizes in the front doors and rear deck?
- Holy moly! Super Mario Brothers 3 in 11 minutes!!!
- Is there a way to know if you have AAH Cams
- i finally hit it....
- UrS4 Got the TB today :)..
- Got a question about locking system...
- Menzerna Finishing Touching Glaze+ Menzerna FMJ
- VAG Com interface Not Found... How to fix??
- Did the SMT6 officially end up in the toilet?
- x-post, not getting much response in b5, shoulda just started here anyway, thanks
- I have no defrost, the fan is not coming on, x-post, PLEASE read.
- 12V AAH Exhaust manifold gasket change
- Mandrel bends are in!
- Mobil1 5w40 "truck & suv" syn oil. My consumption is between .5 qts and 1 qt per 1k miles.
- They posted the results to the auto-x...
- Jretal... you may be the only one that can appreciate this...
- X-Post . Y do ppl have to do that???
- Valve Cover Gasket
- Can you believe they can do this?!?
- Well the timing belt is finished - some naked pictures too! (bww)
- I actually fiberglassed my intake collector today. I'll post pics later...
- 9/25/04 - Audi Dyno Day and Get Together - Come Hang Out - near Hartford, CT
- S4 EXHAUST
- Pressure Relief Valve
- wad up guys! maybe u guys might be interested
- Direct Port Programming
- help on ac/heater
- Oil news!
- PAGID BLACK vs. BLUE Comparison
- you may find your 12v slow, but at least its not ugly
- Part numbers?????
- and the hits just keep on comin....
- etka people, can you do me a huge favor.
- I'm gettingI'm getting a tick sound from my driver side valve cover. I noticed it after putting in
- Did anyone ever find a cheap source for the DIY acid bath??
- Burning Oil?
- Loss of Oil Pressure
- So I installed an intake I bought off of ebay, I was gonna hold out for a heatshield, but since I
- Mr. D.... got a full (almost) video of one of your runs from Saturday.
- Can the sensor from 471 fit on aluminum housing of 471A?
- Newbie/Inevitable 12v Mod questions
- Well the time has come, wish me luck...
- UrS4 Please email me
- Replaced my timing belt, did I do something wrong?
- I think we may have a new member shortly...
- I think I might be in trouble with my S3 MAF conversion
- OT (not engine stuff): x-post. Both bottom float pins in my rear caliper carriers bent,
- Rear Guid Bushing, #11 in the pic. How do I remove it? The car is a 1995 FWD 90, thanks.
- Had a great time at the Auto-X! Thanks to Mike (aka Hokie_90) for posting it and
- Anyway to get a comprehensive list of 12v engine mods?
- What ever happened to the guy with the 12V A4 & the MotoDunce SC?
- Did anybody else get the e-mail from amy chan. OMG it freaks me out. (here it is)
- UrA4 - where did you buy your rack and did it come with a warranty?
- Anyone interested in a set of metric wrenches?
- Mance, should I run the Auto-X tomorrow with both the ram-air and stock intake open?
- 12v rebuild bits (coution x-post)
- Supercharger Question
- Jretal, how was the Glen?
- ordered some new parts.....
- Okay, new developments (read: how are you guys always right?)
- URS4, What is the lightweight lifter availability??
- AutoRX update. Wish I had better news...
- Oh the agony
- Success with Bosch 13913 O2 sensor....
- arrggg!!! this saturday will be 3 weeks with no car. its killin me.
- Question about Spec Clutches.....
- Just dropping in quickly to say "hi."
- 9/25/04 Audi Dyno Day Spots are now Open - Wethersfield, CT ....
- Does anyone have an extra set of valve covers?
- The world's easiest quiz
- The problem with having aftermarket exhaust is every ricer wants to race.
- Hey guys... everytime I start my car,my fans go to high and...
- Old News is the Ecs ULTIMATE Timing Belt kit Every thing I need for the job?
- Someone has OEM lifters for sale in the classifieds with less than 4800 miles for only $80!
- Had RCE flow test my (115K mile "stock") injectors
- 02 sensors, Wiring Harness, ECU... pulling hair out --->
- Miktip, can you e-mail me? Had a quick question for ya and can't find your e-mail. Thanks.
- Well the time has come sooner than I was hoping...
- E-mail me if you want a Gmail invite. I have a bunch.
- I need help diagnosing a new noise...
- I have OEM lifters with only 4800 miles on them. Are they worth anything for resale?
- Gun-drilled Cams and Lightweight Lifters are in. Went for a quick test drive...
- Mance, YGM!!! Thanks. ;-)
- Valve Cover gasket
- Bentley help, please. Need the torque specs for the nuts that hold down the cam bearing caps.
- Is the Magnaflow cat w/ muffler really loud?
- My car is running rich???
- I makes em so nice cuz I use "twice the rice"...
- OK MrD I dont have all night to find out how the gun-drilled cams & lightweight lifters...
- Induktion Motorsports says they'll install the mandrel bent pieces into my exhaust system for
- REPOST !! How smooth is "good enuf" for the MAF housing?
- Got the Remus on the way. Not the easiest beast on the planet to find or buy...
- Oil leak.
- New tires mounted and wheel bearing installed today. Woo-hoo!
- Mr. D what exhaust pieces have you put in now?
- Found the source of the squeaking in my right REAR wheel well . . .
- I need an ETKA search and some Remus advice...
- Anyone here using MIL eliminators for the cats?
- Just a heads up guys....
- Pics of Magnaflow muffer installed and bad cat...
- Weekend Projects...
- UrS4, just how smooth does the MAF need 2 be ?
- Just picked up a eurotuner Mag and
- Some AA stuff up for grabs.....
- FYI, I'm going to be scarce around here for awhile
- *edited* - no more gmail invites left
- Mance, do you have a ratio that you use to mix the 100+ octane fuels?
- Dyno! DYNO!
- Mori, curious what your comment on this thread would be?
- I was turning onto a busy road. As I pulled the shifter into second the shifter popped up!
- UrS4 and others with Innovate LM-1.
- x post....93 V6 overheating
- So the old girl seems to be sweating oil again :(
- ok i need some help from those of you that have done quattro fuel filter...
- All I did was love her and she does this to me...
- xpost about my suspension, or why not to buy fk products.
- MAF questions...URS4...
- g-mail invite to the 1st correct answer to this
- Ansa exhaust
- Glue to glue down my dash board vinyl cover??? Mori, can you help a guy out?
- Can anyone summarise the OEM audi big brake upgrade for me???
- Just finished DIY steering rack replacement...
- anyone know 0-60 time on a 1993 Audi CS Quattro
- GAH!
- Ram Air Headlight: Completed, tested, mother approved... Lots 'o pix
- Mance - new SS Headers
- just ordered used abs sensor from dads, they are cool as ****...
- ok about to do fuel filter change, what tool do i use for the FF strap...
- Anybody replaced the analog clock with oil pressure gauge? Where from to buy the gauge and sensor?
- Apparently "heated O2 sensor" means "HEATED O2 sensor".
- just a new pic. Stupid camera wouldn't focus.
- Tie rod ends are changed!
- i this what i need for tranny, if so isnt this really cheap, redline mt-90
- Amusing News Article for my 12V friends....
- Is the 12V 02 sensor different than the 1.8T?
- I have 1 Gmail invite. First person to reply with the correct response to this question gets it...
- FYI: For those of you who don't have Google's e-mail (gmail).........
- Dad bought me a shelf-unit-thingy and I cleaned up the shop a bit.
- Mance, how do you line up the gasket from IM to Cylinder Head properly?
- No cool pictures here today. :(
- UrS4... you get my paypal?
- i need atleast 1 new ABS sensor in the rear, where is best place to buy...
- holy crap, well after i paid $25 for fuel filter, i realized that i need some help with the swap...
- Jretal, YGM...
- Is there any place that can do tranny work on a quattro other than the dealer?
- Anyone have an extra AFC engine they are looking to get rid of? Just need the bottom half.
- Mr. D, Please pick up the courtesy phone...
- catalytic converter...
- Remember the fan that can keep running after shutting off the engine?
- I updated the "Mods" section of my site...
- I suppose I'm next in line for the tie rod end change.
- Gorilla biscuits
- pivot-rod-to-tranny nut and bolt
- ETKA help again...
- Beru O2 sensors
- Paging Mr. D
- Time to R&R the engine mounts and snub mount
- Hey Mance, did you get my 2nd email last week?
