View Full Version : 12v V6 Discussion
- Last day for Stage 3 throttle bodies at the best price they're ever going to be...
- OK next question....If i have no MAF will a VS make any difference?
- EVAP CORE CHANGE COMPLETE!!!
- Bryan or someone: Could you please run this part # 4B0 998 099 B . . .
- Where does the vacuum hose coming f/ the firewall connect to???
- Latest feedback on 3 silicone hose kit installs and their pereception of benefit/gain
- Where is my MAF?
- Exhaust problems....
- Does a 1.8t Borla Catback Exhaust fit on a 96 FWD A4?...
- Almost done
- Got the car back today, I have AC :)
- Earth Calling.........
- I really hate to bring the oil issue up, but there are some clever people here (involved and long)
- Ok, now I can't get the evap housing assy out.
- Finally!! Silicone hose kits are here and first one's installed on my son's 90S...
- HELP!!! In the middle of removing glove box right now
- mission accomplished......
- I am thinking of getting aftermarket exhaust for my A4 2.8Q 12v; any suggestions?
- UrS4....Velocity Stack in a stock 90 airbox......
- UrS4...ever used/heard of the CarChip?
- Tried removing sport steering wheel last night
- Another intake question......
- Velocity Stack poll results...
- So how many projects can you count in this photo?
- Anybody know the size of the larger oil drain plug and gasket??
- 8000K HID
- Moribundman/Morbid Man ;0)
- Cross post: Help! 96 A4Q- Transmission acting up
- Clutch pedal assembly
- Air Intake Question...
- Are the H&R PCS COs built by Bilstein??
- Evaporator came in today
- whats up all, quick question. what size are throttle body bolts? are they a torx?
- filter mod
- Poll and question for velocity stack owners out there....
- urS4 ordering
- ASR, Traction Control.....
- Rob K
- EPA Required Emissions Warranty
- TopSpin Design Real-cam available!
- Is there any way to search this forum?
- I just have to brag - I got a new torque wrench!
- 12V 2.8 died, please help.....update....
- Paging MikTip....
- Programming windows to roll up w/keyless entry???
- So I installed the UrS4 over the weekend, some impressions...
- All the black 3" silicone induction hose shipped today...
- My driver's side window started acting funny the last couple days.
- Annoying intermittent fault
- Auxilary fan only turning on when A/C is on. Because of this, my engine is overheating when at idle
- Trim Kits for a 95 90cs?
- Got two Toureags in at work this morning...
- Will a center resonator help on a 12V
- how can i search this forum? it doesn't appear in the search options....i want to find the latest
- Vacuum system changes
- TB-to-Plenum vacuum hose ?
- UrS4....got a question....
- 12V Engine
- Looking for help installing an iPod to the Delta stereo system...
- Anyone have the link for Just Däve's car? Is it still on ebay?
- Audi 2.8 12v Performance Question?
- How do you open the lower oil pan?
- Can anybody explain to me what exactly is "brushed aluminum"?
- Review: SPP/Racetec 4-Point Strut Brace . . . Thumbs-up
- Ok I'm next in line for intake removal and EGR valve replacement...
- Did anyone ever try to use LEDs for their turn signal (1157)?
- Timing belt tool 3242 & 3243 for $99. I think it's a good deal
- Might have some leftover cash after the body repair
- Anyone with the 2-pc projector headlamps and clear coners?
- dead instrument cluster lights
- Anyone know of a tech article on replacing the evaporator?
- is it possible to Programme factory keyless entry on a 96 a4?
- Does anybody have opinions or experience with these (oil filter coolers)?
- Does anyone know if the fog lights from 2000 Audi A4 2.8 fit 1997 Audi A4 2.8?
- Made the appointment to get the Evaporator core replaced...question:
- How much is the average cost to have Timing Belt+waterpump+thermostat service done on 12V?
- anyone got part number for tb gasket on a 96 a4? tia
- New Audi in the driveway!
- Why doesn't boring the MAF housing cause an over-lean condition?
- So what's the deal with the TDL 2.8 12V exhaust? Why do they use...
- Even more intake manifold switchover info regarding altering RPM setting...
- Got the new flex shaft tool installed and put to the test today...
- A good explanation why the pre-95 2.8 cars enjoy SO much more gain from intake mods...
- Trunk lock stopped working...
- Will newer switch blade remote work for 97 with older style remote?
- If I was to tackle TB cleanup, would I need any gaskets replaced, or can I reuse the old ones?
- Anyone have access to a readable vaccum hose diagram?
- Friggen idle issues....
- OK... another question to those of you who installed an EFK
- Intake manifold switchover occurs a smidgen before 4000 RPM
- 96's with no central locking
- Anyone knows where I can get spray paint that match audi color code?
- can these fit in our cars?
- What places besides RC will clean and blueprint injectors? Like to shop around.
- Me and my car at Loudin, NH getting my COM racing licence....:)
- When looking for Mustang injectors, what do I look for?
- Anyone have a write up on changing O2 sensors??
- My headlights seem too dim. Anyone know what the volt/amp spec should be going to the bulbs?
- Adjustable fuel regulator for the 2.8, 1:1.7 gain
- CV boot busted! What's the worst thing can happen if I don't replace it?
- Stupid Poll Time!
- The dealer is going to charge a guy I work with $430 to clean his EGR valve
- Evaporator Core victims....I'd like to look at some prices for the core itself
- I changed my oil cooler o-ring today, much to my suprise
- MikTip (or anybody) Need a part number....
- Help! EFK install question!
- About the intake manifold tuning control system
- Shopping a new Flex Shaft Grinder...
- Audiboy... it was the stoopid Radioshack relay all along!!! Thanks for your help. Now I use 60 amp.
- Audiboy's duh man!! He's 100% right on the entire manifold switchover sequences...
- Another new EFK blues....
- Another jet engine added
- Is it possible to short the O2 sensor wires to aid in fooling the ECU?
- Anyone looking for a parts car? 95 A6 running great
- Nav system? Even with the B6 model, the A4 Nav system's pathetic... (m)
- Flushing Cooling System
- Some data on the manifold switchover and a way to manipulate it's threshholds...
- What's the expected life of the original clutch? I'm a careful driver and use the ....
- Anyone installed ISOFIX/Latch system in a '96 A4? Dealer says there is no part --
- Please, take a look at my tool box and tell me what I still need
- I saw the most ridiculous thing tonight....
- car repais suck
- EFK install question
- Trouble Getting spark plug #1 out...
- Do I need a 24mm, 12 point, deep socket to turn the crankshaft?
- Interesting exhaust size info on the 380HP kit from MTM
- Lets kick this manifold switch-over thing around, try to find some free hidden ponies...
- A new toy for my car :)
- Anyone else have this problem?
- Preliminary repair estimate on my car is $5500+...
- EFK question...
- ATTN Missile Man 120... were the parts you order from AutohausAz.com for your timing belt...
- Do we need to put relay for the EFK?
- EFK Switch...
- Interesting torque numbers while doing timing logs yesterday...
- Couple of things: Timing can't be done as planned and ALL pre-96 2.8 cars run more timing advance
- what is the correct size of cone filter..2.75 or 3" on 96 a4?
- Isn't Tantrumwerk making a 12v exhaust? How is that going along?
- Is there an oil filter with replaceable filter cartridge available for our cars?
- Oil pan replacement question please help
- The Hall sensor (cam position sensor) is same part number across the board for all 2.8 12V engines
- I know it's more engine talk here than anything else, BUT..
- Question about ported TB
- I have velocity stacks again... finally!!!
- Ok guys... here's the list of parts and part numbers for my Timing belt change... Do I have...
- Mance...what is this (EFK)?
- what spark plugs do you guys run on your 12v? Where's the cheapest place to get them?
- 12V Nitrous info.....
- Audiboy; I may have an A4 timing solution. Tell me what you think...
- i need help making more power on a 97 12v, who makes a supercharger?
- overheating problem..
- Please refresh my memory
- Stage 3 throttle body will now replace Stage 2+ and it's LOTS cheaper!!
- Will this muffler fit in A4 12v?
- So, my sister's thinking about getting this '97 2.8q - anything she should consider:
- What is this?
- Just wondering where to start with sway bars....
- hard to replace rear o2 sensor?
- Offhand, anyone know the trq specs for the oil pan bolts?
- A really good read on chassis dynos and why their numbers are to be taken with a grain of salt...
- Happy effin morning to me!!!
- Throttle Body Questions
- Are the timing belt tensioners spring loaded or do you set the tension?
- What's APR snub mount for?
- The engine runs so smooth now!
- do you guys think this would make a good project car??
- need help finding 2 front o2 sensors on 12v 2.8 engine
- Hey, all of you speed junkies!
- If I push it to E, get about 300 miles on a tank
- Got my new ride. A 97 Nissan PU. Now the following will be removed in order to sell the car.
- I just ripped the intake manifold out (LONG!)
- What is the best Timing belt and components?
- Doncha hate it when this happens....
- Where is the link to the 12V MAF mod and Velocity stack mod?
- MPG for 12Vers?
- FINALLY!!!! Got the Goods!!
- I am not selling for profit, so please don't delete this thread (muffler for sale)
- Tipped the certified scale last week at 3,300lbs even, w/half tank of gas
- Update to using sealant on my 1996 Evaporator core. kinda long!!
- I put some instructions together on how to remove the intake manifold - Does that sound alright?
- Anybody here in the PA (central-PA) area??
- Ok guys... it's getting that time that I need to start looking into changing the Timing Belt...where
- EVAC core replacement
- How was everyones holiday?
- Update: Inspection Sticker ticket causes insurance to go up (worth reading)
- After this weekend's heavy rain, i noticed a nice puddle behind my driver's seat...<m>
- 97 a4 2.8 12v quattro exhaust/engine noise NJ/NY
- Paging Scott12v... Gotta question and you can likely answer it...
- Can we do the zip-tie mode on our cars???
- X-Post from A4 fourm: B&M Installed, impressions...
- UrA4 Mods
- Any ideas on some simple mods to make my 96 auto A4 more fun to drive?...
- I just have to annoy you all a bit more...
- VentPost: Looks like my drama with the clutch master/slave cylinder doesn't end at replacement...
- Brand New cosmetically blemished EFK 4 sale. 1st $90 takes, includes shipping to lower 48 states
- I guess you guys can tell what I'm up to...
- For those of you with cracks in the black valve covers...
- What, no camshaft tensioner?
- It's all in the details...
- can anyone get me a part # for a 94 90QM throttle body...
- Still no other EFK-related failures reported from my poll at the A4/B5 forum...
- Saw interesting show on Discovery Channel about Ford's magnetic clutches.
- Got the oppurtunity to hang out with the Stasis guys last night..
- Oil Drain plug question...
- bogelo... ? I'm worried about you...
- Full Boar Exhaust...heard of 'em?
- Anyone know what will cause aux. fan to run constantly? Any fixes?
- Driver's door handle (outside) not working correctly
- Dash lights out...questions?
- I have a noise coming from first gear can anyone help?
- Just replaced my aux. cooling fan. Is it supposed
- EVAP core change
- Mr.D Do you have any pics fo the 17" RS4s on your car??
- Please HELP! A/C died, 96 a4 2.8
- Looks like my car will have to go.
- HELPPPPPP.. what is this cable for?
- So as far as the Evap core thing goes...
- MORE EFK Questions.....
- EFK Questions
- I'm trying to source an electric fan over here in the UK...
- So my mechanic refuses to change the evap core...
- Big job's coming up tomorrow...wish me luck
- Not sure if this has been said before on this forum......
- heheh I'm a paid advertiser now. I can hawk stuff here with prices and a clear conscience...
- Ok I got the engine coolant temp sensor in now......
- So, once and for all... what is the preferred 12ver's choice for an EFK design??
- Coolant temperature problems... already replaced coolant sensor....
- Could someone please tell me the part number for the Engine coolant temp sensor 96 12v
- Ok guys... would it be worth it to put the EFK in my 12v... those of you who have...
- Cylinder head bolts on a '96 A4
- Anybody ever replaced the prop shaft seal in front of the rear diff?
- Anyone have the mounting bracket for......
- x-post from A4 forum: For the day crew: SPP EFK Groupbuy for $139 shipped
- FS:96 A4 Black 5speed. Thought I would post it here since there is tons of 12V love.
- Here's a pic of the car taken from my Nokia 7250......could be worse!
- Anyone know a place in MD OTHER THAN a dealer that could replace the Evaporator in our cars?
- I'm hot on the trail of an oil leak - please give me some input
- Does the A4 have a belt driven rad. fan?
- Is the Yahoo newsgroup still active now that we have this forum??
- I can't find any place in MD that can mandrel bend the exhaust piping. =(
- X-Another New Toy, it's christmas in June (May) for me...
- Could someone give me some advice on a code I pulled today...
- Further info on new exhaust, pics this time...
- Anyone know what is the diameter of the 96/97 sport steering wheel?
- Let's kick this exhaust thing around a bit. I'm thinking 2.5" "may" prove a bit too large...
- Been reading the archives regarding fan clutch failiures....
- UrS4, do you have any inlet velocity stacks yet??
- check engine light..code inside..
- Here's a question about something that's really been bugging me............................
