View Full Version : 12v V6 Discussion
- I posted about what is the proper tb change interval a couple of threads down [more]
- repost: VS+stg 2silicon>cone filter...that is all.
- UrS4, upper control arm end link question....
- bottom end question
- Oil, Engine Flush, A/C Service
- 96/97 A4 12v owners, has anyone broke the timing belt before 90k? [more]
- Anyone know where I can get a set of Pagid BLUE pads?
- Still need MAF with Haltek- I think?
- O2 sensors
- Hmmm?
- More Catalytic Conv problems...
- UrS4, don't know if you saw my post below...
- Re: 92 100 FWD, have issues with radiator low speed fan..
- Mance or Rob K, another stupid OT question you might be able to help me with...
- So what's the best panel filter, Mann or Audi OEM? How about Green Filter?
- gun drilled cams Hall Sensor trigger window provision...
- Ok, not getting as much help from the B5 forum as I hoped... Those of you tracking your cars... Q:
- would it ok to use an expoxy rated to 200 degress to fix a broken breather hose?
- I need some feedback from guys with F/A meters on the exhaust "pop" issue...
- Pittsburgh peeps and hockey fans...petition to keep Pens in Pittsburgh...
- So, I guess you just scotch tape these bad boys right on...
- Ok, here's the Haltech I'm "really" getting... and some info
- I know I'm a late bloomer but.......
- rather OT... Mance, you know where I can get an el cheapo Tig welder?
- *slow news day*
- anyone ever make 12v badges?
- What the.........
- What kind of transmission fluid does 97 2.8 12v (automatic) take? Synthetic or regular?
- Oil filter question...
- kinda stupid question
- well we will never get a chip but my new engine will have a Haltech F10X...
- Hotmail is expanding my email storage space by 2500% to 250mb!
- missing wire harness in a 2.8
- My passenger side floor is soaked.
- debadge?
- young hothead, ygm
- auto rx..
- Cat Converters & small oil leak questions....
- I think we can assume the deceleration popping on the 2.8 12V is "normal" given...
- You'll love this (turn up your speakers):
- X-post: 12V V6 losing a bit of power leaving from a stop when cold, and at high speeds
- Reminder: Achtuning Anniversary Car Show and BBQ this Saturday!!!
- Where can i find mod info on 96 audi's?
- s2 silicone and VS impressions (incase you haven't read enough already)
- Its been several months since I changed my clutch...
- AAH/AFC exhaust popping on deceleration poll & worksheet
- Slight hum when I'm on the gas, goes away when I'm off of it? Any ideas? Also I get a thump when
- x-post in case anyone cares.. regarding that A/F gauge i mentioned a loong way back =)
- am i the youngest?
- classes
- Procedure for the Valley Pan Gasket Anyone PLS....
- Well, I broke my balls. My Vac ball, I mean...sickos
- does anyone have the 12v supercharger video? im curious and i did the search but that link is down..
- who's got the best price on a water pump for my '94 90q
- does anyone on here in a 96 or 97 12v have a trip computer in their car?....
- Anyone have the spring rates and other data for H&R cup series coilovers?
- Can anyone run me down a copy of Audi TSB: Group 26, number 96-02?
- I feel like a noob. Bentley says we have a secondary air injection system on our car...
- valve cover gasket replacement a no go
- x-post: tranny noise, have a look if you have time, thanks...
- engine still heating up even after fan problem fixed
- UrS4, what if the fuel pressure regulator is leaky?
- XPost: Here's one of my spark plugs... supposed to look like this?
- Control Arm install question. =(
- Ok so I know it's not fuel-related...
- need a favor of someone who has time.....
- kamei
- One of the best/cheapest & easiest to use diagnostics you can own...
- I'm thinking about getting new wires and plugs.
- cluster question: Can you put any B5 cluster in the 96, or does it have to be a 96? mine died and...
- Waiting patiently for Mance to figure out the backfire/burbling on deceleration . . .
- Mance, regarding you snub mounts...
- OK, I've HAD it!! Figuring out the backfire/burbling on deceleration just became JOB 1 at my garage!
- if your O2 senseors are going out will you have a cel or not?
- runnin stockie
- Anyone looking for coilovers?
- For you out there who doesn't know nology hotwires, please read...
- suspension question
- brand new
- 100 mile follow-up report on the Magnaflow/HushpowerII exhaust system...
- what actually goes wrong in an o2 sensor?
- Mance, I would like to commend you on the excellent product that is your snub mount...
- Mods i'm looking for...
- good exhaust buy on ebay, maybe...
- stuck on o2 sensor removal, got one out, can't get the other out...help?
- Mance, YGM.
- I have an old o2 sensor from my 91 gti, and the plugs fit perfectly for my 100
- Here's the quote from Stasis on stainless equal-length headers
- UrS4 - did you ever install the smaller Optima deep cycle battery?
- Parting out my 96 A4...
- Ok guys, I'm back from my vacation
- ok, how the hell do I pop the trunk when the trunk popping cable fails?
- Goin' on Vacation, so no brown noses for a week
- Mance regarding last week...
- Step by step pictorial of new HushpowerII Revision 4 exhaust installation...
- Help I need!!
- HushpowerII is installed and working wonderfully!!!
- Why am I bothering with Cams?
- Single axle drivetrains eat 15% why do we eat more than 30% ?
- Replacing power steering pump - will a pump from a '95 90 work in my '97 A4?
- i heard someone talking baout putting the sc that the vr6 corrado uses into our a412v..
- ok, i need to take a break from this place. too much fighting.
- Is 175 road hp unrealistic?
- Mance YGPP, I hope I got it off soon enough
- Dyno Update
- tuned knock sensor dampeners very close to becoming available...
- Lookie what I found! I'm hunting down my rougher idle since my TB boring... :-(
- Can I replace my keyless entry with the switchblade style remote? 97 12v
- I just finished my second 12V IM and I'll be very happy to never do another one...
- Good deal on an LLtek intake for the 12v in the classifieds.........:-)
- Mance, got ur package with the O-rings today thx. Really dumb question . . .
- Any interest in re-man MAF's?
- A Little Background
- Polishing IM - When is it too much?
- After you wrestle with a pig for a while you figure out that the pig likes it...
- How duration is measured and what's required to calculate duration
- Hey UrS4 - I think you need an edit on your eBay listing
- OK Guys, let's see what happens on the dyno
- Mance, did you put the S2 hose kits up on eBay yet? I have a friend who is interested if you still
- Dyno Testing
- anyone ever put some crazy thing in their engine bay like
- Mance, just got my VS and S2. Thanks. My car is in the shop now, but will put on soon.
- Porting the Intake Manifold
- I'm hot and my A/C is still dead :-P
- anyone have an sxtb or xtb they dont need anymore?
- The Kansas city audi club is having a tech session with lifts.....
- Where's our resident Rocket Scientist?
- has anyone put a s2 silicone on a small bore MAF??
- Heh, let's change the subject for a moment!!
- oil
- does anyone have a special throttle body?
- an email I received overnight from "pgoyer", esteemed forum member & resident Nobel Laureate...
- Hey Mance YGM
- Pre-installation specs on the Flowmaster Hushpower II muffler...
- S2 Hose Kit from AA is bittersweet
- Off topic: Need to install both lower control arms (ones with ball joint / straight) in the next . .
- Good news is my oil pressures are normal. Bad news is that leaves only one option...
- My initial impressions with the stage 2 silicone hose kit
- 2004 Northeast Event Pictures Up...........
- A couple pics I took on this past weekend's roadtrip...
- while my oil consumption has improved it's not fixed...
- I'm getting new plugs soon, I am assuming I should get new wires too, which ones do you guys...
- the rare rare "racing" throttle body,ie; RXTB1 is for sale
- Headlight switch failure.
- Great seeing all the 12V people representin' at NE GTG!
- fog mod...
- Here's some headers for ya! ;O)
- the best laid plans...
- Is the oil pressure relief valve in the oil pump?
- the wires to the radiator fans on my '94 90q...
- my oil use problem resolved or: some people have all the luck
- Calling all 12v guru's...
- hey Mr. D, just called Shokan for the fuel gauge sender and parts...
- Please Help ME!!!
- UrS4...YGM
- New world-beater lightweight PS pulley on the block...
- FWD A4 owners. Another possible option for a rear sway bar...
- Anyone here going to Waterfest?
- WHEW!! Qualifyting is finished for our class and we got 3rd in "open" class...
- Headers
- Anyone have the 12V timing belt tools they'd be willing to lend out?
- nice meeting those that came out last night in Kansas city follow the link for photos and..
- Throttle Body Upgrade for 12v
- Mance
- 12v idle problems........
- A/C Recharge questions
- Whats the cheapest way to make my 97 a4 12v GO faster
- TB Question.....
- For any Audi owners in the PacNW, 300+ owners gathering this weekend
- Pikes Peak Update: Just sheared the right rear axle in practice...
- Mr D... I'll be in DC for a conference this weekend....
- Mance. The part # for the Magnaflow mid-muffler you used is a 11" muffler.
- Mance, Where are you?
- Mance, YGM
- I'm camping for the next 5 days, hold all my calls. And stop innovating til I get back, TTFN
- Pikes Peak car has passed safety and tech and is ready to go....
- Mance, you ever get my resend of my last email from my hotmail account?
- For those interested, I just bought OEM NGK plugs from Advance Auto Parts for $4.28 a plug.
- UrS4, what is your mileage around town?
- Got some news from the mechanic today
- Bi-Turbo S4 resonator installed and pretty much as expected...
- S2 Hose Kit received -- Thanks Mance!! Quick question...
- Do any of you guys have a hitch on your A4? I got a favor to ask...
- passat vr6
- Doh! Just looked at my airbox, & it's cracked on two sides
- anybody use one of these?
- There is a tiny hair sized crack in my snub mount probably only goes about 1/4 the way threw it. But
- Auto to Manual Conversion
- Bike Rack Options!
- Driveline Lash Questions
- Good news, my Chevy 350 sound is not my EM gasket (or lack of), it's my cats (driver's side)
- Ran a leak-down & compression tonight in preparation for heads in August...
- UrS4...YGP (You've got PayPal)...
- Is anyone in need of a 471A MAF + extra sensor?
- For those of you who haven't heard it on the news yet, our base is now accepting commercial flights.
- What goes in here? My belly pan has been off, and the engine is soooo dirty now.
- Plugs and wires
- Finally I've got an hour to kill tomorrow morning. Spending it at the muffler shop...
- I heard two people comment today that they change their spark plugs every oil change (5-7.5k).
- Anyone know where I can download a bentley (or similar) for a `91 SL500?
- this guy is asking if www.abnormallyaspirated.com is legit.....please answer him
- 2004 Northeast Audi Summer Event THIS WEEKEND!!!
- Hey, anyone know the website for d-bilas dynamics?
- Never used Milltek Exhaust on eBay...
- UrS4...YGM
- Nvncibl, did your valve train quiet down?
- The 30V throttle body prioject has begun...
- my car sounds like a chevy 350... I have no exhaust gaskets, methinks.
- exterior neon
- Dyno Day with the UrA4...
- Hey ur S4
- I need a 12v pulse on key on and another on key off.
- Rocket Man, I can't find your post! :-(
- UrS4...re:S2 Silicone kit blow-out...
- The new 2004 Pikes Peak Hill Climb and SCCA ITE car...
- Sad day for me....
- Headers...
- do they work?
- green plug by right side of TB ???
- No one confirmed if I had the S TB.
- How can I increase my power cheap ?
- Sparc plugs, oh my!
- What oil to use for newly rebuilt engine?
- Good News: I got more than the 50% flow I wanted out of the AFC EM...
- broken spark plug cont....
- Ok now we'll move on to EMs in-depth...
- MM120, are you around?
- would you do this if it were available to you?
- Mance.... are the prices on your website up to date?
- V6 12valve cams
- Bling Overload
- DIY wannabe XTB. Close? No. (bww)
- Any pics out there of the engine wiring ?
- What can I use to dissolve/clean up clear RTV with, that won't harm paint?
- I noticed SuperSprint has a cat-back for the 12V A4. Anyone know the pipe size? Any opinions?
- Moribundman, remember the teflon tape discussion we had awhile ago?
- Why can't we design our own HEADERS?
- Anyone know what the AW record is for mileage on the A4???
- Shop cleaning: S2 Silicone kit blow-out...
- My custom InterComp VST20 valve spring tester is going on the auction block...
- 2004 Northeast Audi Event -- June 25th & 26th
- Mance, would two 2.5" Mandrel U-bends be enough for the cat-back?
- amazing difference between soaked/scrubbed and ultrasonic cleaning of cams...
- I hope our exhaust manifold gaskets aren't this bad!
- This is my least favorite part of the timing belt work...
- AAH/AFC exhaust manifold weights, specs and flow rates
- Audi, Audi, Audi on the winners podium at LeMans....
- My email address is shot
- Mr. D, how about a Carbon Fiber collector? Didn't know it was *this* strong!
