View Full Version : 12v V6 Discussion
- I'm curious to see what production numbers we have here, mine is #1968
- GB: Electric Fan Kit with Evolution Motorsports (confirmed fitment for 12v)
- MIKTIP where can you get universal bosch o2 sensors from?
- A Reliable Source For Aftermarket High Flow Cats..???
- Does anyone have picture of the underside of a 96 FWD....planning to
- Do these two part numbers sound correct for a '96 AFC motor?
- Can someone show me where the engine coolant temp sensor is on a 96 12v.....
- 12V oil leak? Its not my oil pan/gasket either....
- Anyone interested in SPP EFK for $149 (Group Buy)?
- hey guys i got a couple more questions.
- My rear left O2 sensor just went out. Where is the best place to buy a new one?.....
- Do you have to remove the fan pulley for the EFK?
- Theres now one less 12v in this world...
- New exhaust review, custom 2.5" manifold back
- i just hit 166,000 miles
- A view of the on-board telemetry from the drivers' seat...
- 1.8T OWNZ the 12V!!!!
- Shaved Heads
- why does HP/TQ converge/intersect at 5250RPM's on EVERY internal combustion engine....
- Pre-use impressions: picked up the Dynorad yesterday and installed it at the designer's home...
- OK, This is it. The official OneEighth DP post..
- Question..... car is having a hard time starting... almost like it's not getting fuel....it started
- EFK mod.... need help
- Need new rad, any suggestions?
- Thermostat
- water pump pulley question
- Let's play "Whats that Fault Code Mean?" and our contestants are....(drum roll)........
- Didn't get to play with the car very long yesterday due to needing some time away to...
- Anyone know the diameter of the Electric fan kit for our cars....?
- Hey UrS4...
- Poll: Which one is easier? timing belt change or evaporator change?
- I finaly put my new rotors and pads on......anyone know what kind of brake fluid I should run?
- Running with broken fins on the fan clutch
- OT: Help please. re: a lot of flaky black stuff under the valve cover on my truck. Thks!!
- Just got my ericsson handsfree HCA-10. Will have some fun this weekend installing it. I'll post
- climate control replacement ?
- What viscosity oil would you recommend for summer? 5w50 good?
- Regarding the exploding fan post below......long
- FPR testing and calibration...
- if anyone does go the RC injector route there's one lil hitch in their giddy-up...
- Found my oil leak...
- Anyone do machining. Got a fix for Evap Cores.
- I've NAILED it to the wall!!
- @#$% Fan exploded !
- Only two additional runs thus far tonight and I'm parking the car for a few hours...
- What causes the sulfur smell? Running rich, right? (Long)
- 12v owners: Any interest in full exhaust systems?
- How hard is it to get behind the Climate Control in my 96 A4....
- Where is the CKP sensor?
- ok the data stream is going to start to roll in now...
- Miktip... I have a question about changing the evap. core
- further info on the Dynorad on-board dyno...
- Trouble shifting into reverse with automatic transmission
- Got the ARC-2 fuel/air MAF calibrator and fuel/air ratio gauge installed today...
- I got a few questions about replacing the crankshaft seal and the camshaft seals [fairly long]
- here's something you won't see every day, if ever...
- Re: On-board dynos; check out this site, let me know what you think...
- What's a good place to get some new floor mats??
- Whats the top speed on our cars?
- ETKA Question for Bryan or any ETKA "expert"....
- WARNING ON D.I.Y AIR CONDITIONING REPAIRS!
- Anyone have an A4 cooling fan they need to get rid of, or at least
- Audi is laughing at me... they placed the Power steering hose bolt under the brake booster...
- Can I use the remote transmitter from the newer model?
- Any specil technique/tool for attaching "quick connect" vent tubes?
- AC Questions, Please Help!
- Nedd Help: X-post from A4 forum: clicking in steering wheel...
- Is there anything I can do to get rid of backfire from my exhaust?
- one step closer to silicone hoses...
- Anyone in the LA area willing to donate thier car for a couple days?
- The dyno plans crapped the bed. Or... "the little car that wouldn't"
- JWG, or anyone else who uses Beru Ultra-X plugs...
- Has anyone here performed a DIY recharge to their A4's A/C?
- Odd creaking noise in the suspension?
- a brand new 96 12v has arrived...
- Audiboy and Mr. D (from MD), update
- Have you guys seen this....pretty nice! Anybody else tried?
- can anyone help with DTC 17912 intake air sys. bypass leak detected? TIA
- Is anyone running with their cat's removed? I was kinda kicking the idea around ....
- I'm going to change my front pads and rotors tomorow, anything I should know ahead of time?
- Car's back to Stage 2+ with MAF velocity stack and screen installed...
- Clutch options, anyone tried SPEC or Centerforce?
- has anyone tried making an intake downpipe?
- I did the telephone wire / TB boot trick yesterday ... worked nicely.
- Ok, here's the plan; my dyno run is going to happen tomorrow morning...
- Eibach + Neuspeed Bilsteins. Which Perch are you on?
- hey audiboy, didn't you used to have two of those air intake superchargers on your car?
- How do you program the code-lock for delta cc radio?
- Just out of curiosity anyone tried a B5 S4 exhaust system on a 2.8 12V?...
- Here's the new transplant brain and heart(s) for the 2.8 induction mods
- Another vac hose question about a '96 A4
- Thinking about reworking my intake setup...
- Dyno update...
- Manual Tranny question: My first gear seems to whine on acceleration and since I may be doing a
- Thought you DIY cone intake guys might like to see this...
- making a custom air intake and ....
- The 12v's first track event is comming up...
- Guess that rattle sound?
- Anyone done an RS4 oil cooler mod on a 12v??? Worth it or not???
- Anyone knows brake pads that doesn't need bedding?
- 12v All-Road edition
- lpg/natural gas mod for 12v? is this natural gas???
- Question......would Misterjungs HID kits work in old two peice halogens?
- I'm going to have to re-schedule my Friday dyno run...
- Audiboy, about your EGR mod...
- upgrade alternator
- I just had a crazy idea...
- I need new front brake rotors, what do you guys recommend?
- Weight Question: 1996 12v = 3228; 1997 12v = 3384; why???
- How do you know "Fried compressor"?
- did anyone have a fog light on their grill?
- Got the Velocity Stack today! Impressions...
- good day for parts 'round here, albeit expensive
- Audiboy! Will your EGR mod work on the older12v on a 90?
- Insurance Comparison Poll: (Carrier / AGE / FULL/Lia COVERAGE / Pts / Accidents / $$ per year.)
- POLL to 12v owners: At what mileage has everyone done timing belt+thermostat+water pump replacement?
- Cracks on valve covers and loose hose pics and ? Please Help!
- OK people have a look at this.......
- air intake shield: with or without?
- Pardon my ignorance but .......
- or you could do this instead ;o) [cheaper]
- MAF to cone adapters. what do you guys think??
- Anyone know the bulb type for the side marker on pre 99 A4? (square one) Thanks.
- How the heck is everybody?!?!?!?!?!
- pleasant little surprise this morning...
- Who has the turbo setup on the their 12v?? Is that running ok yet?
- My take on the latest dyno runs...
- Pics of my MAF inlet Velocity Stack
- speaking of A/C.. I have none ...:(
- Fuel filter question
- pollen filter for under $20... is this right??
- Some new tools showing up for all the 2.8 12V upgrades...
- Re-torquing the Head bolts...Do you need to remove the cams?
- Should I buy the A/C evaporator from dealer?
- my dash light drama
- If you are interested in a new ignition wire set from germanautoparts.com
- 2nd attempt at sealed crankcase ventilation...
- Has anyone here pulled/disabled their servotronic power steering? like/dislike?
- Is nitrous the easiest and most HP per dollar mod for a 12V?
- Please fill out this survey.... Pleaseeeeee
- Hey Mike, when are we going to see some Dyno numbers...
- Any changes needed if i run 19-20lb injectors?
- what are you front trak guys running for suspension?
- Morning, anybody knows about just daves 12v emblems?
- Got spanked by an Acura RSX
- FYI: Sears' Professional Mechanic's Gloves on sale right now for $12.49...
- sealed/vented catch can revisited...
- Once a few more items arrive,I'll be testing the BBT.
- Anybody read European car June isse? Some wierd procedure for cleaing carbon deposit, at least to me
- Yay!
- Oh for Pete's sake - Part II
- RPM at idle
- Anyone knows B&M newvolt?
- Got my STI (made by Bremi) wire set (#431) today
- AAAAARRRRRGGGGGHHHH!!! I can't break outta the 9's and I'm SOOOO close!!
- oh man... need help
- Why do S4 seats sit so high up?
- anyone ever heard of this little gem??
- Aftermarket Catalytic Converters...Audi 100..
- Anyone seen a filter like this?
- Thanks to JET and Bryan!
- sway bar
- NEED HELP FOR CD CHANGER
- Injectors I'm going to order from RCE...
- Looks like an evironmentally friendly catch can won't work as originally planned...
- Working on Improving Breathability and Power :-)
- UrS4: Is there a complete summary of mods/gains to be done..
- UrS4 - here's a crazy thought for you. Tell me what you think...
- has anyone here had to replace there egr valve? and if so what were the symptoms?
- Another timing belt question....
- Acceleration Times in Second Gear...
- Covers cracked (The ones on the sides of the engine with audi rings). Anything to worry about?
- How do you do the bolt tightening math ? e.g; 52 ft. lbs, 18 ft. lbs
- UrS4 - do you have any other mods to the intake manifold?
- 3" MAF-to-Throttle Body silicone induction hose is fully installed...
- what tools do I need to change the timing belt?
- Now you see it and now you
- Who sells an oil temperature sensor for a 12v?
- hello guys, two quick oil questions.....
- While we are on the exhaust subject. I get prsttt sound from under the car while on throttle. It
- What's the biggest restrictionon these motors?
- Got my neuspeed exhaust installed. What a PITA! Lots of drone inside the car.
- Yes Dave, ECS has those made and they are not available anywhere else... cept maybe here
- on the climate control should A light up?
- This engine really is something......
- Anyone have a blank switch cover(the one by the fog light switch)they are not using?
- Got a question....pulled my codes yesterday and nothing showed....
- Does anone know if ECS had this made or is it a OEM item from some place?
- Hey UrS4...check this out ... free power!
- Injector upgrade questions
- Upgrading old MAF sensor (078 133 471) to later type (078 133 471A)...
- Uhm, help?
- Playtime
- Advice Sought: 2000 S4 or keep my 12V?
- Evaporator S*CKS *SS
- Here's why the latest MAF mod works so well...
- Does anyone knows the dimension of A4 center resonator?
- Sheesh I've got a problem but this is a problem people would love to have....
- I am installing the Zex WET NOS kit but my buddy insists on putting the Dry kit in his 12v
- I need new spark plug wires...
- Who was installing the ZEX kit? Do we know how it went?
- UrS4. What is the O.D. of the inlet to the TB plenum? Can't find the other post where you posted it.
- Did some 0-60 runs, here are the results...
- HEY - igozoom97a4 - yeah bro your a real cool dude - i dont know how that story really..
- Hey DAVE - is any cone filter smaller than yours 'bad' for gains? and what is the ..
- Again. Dash does not light up
- Samco Sport 3" MAF-back induction...
- INTAKE question - anyone know where to put the sensors??? (i'm still trying 2 get a real answer)
- I never knew! Car runs fine with MAF unplugged
- 96 A4 keyless entry question...
- Hey guys - got some pics of my 'do it yourself intake' and had some q?'s
- Fellow 12v Drivers I need your help....
- Didn't even know this forum existed! Nice to see the 12v folk getting together.
- What are you A4 guys using for coolant...?
- Skirt install on my 12v (alot of questions and pics)
- UrS4, a couple of ? for you...
- Removed the screen from my MAF, not as imressed as I thought I would be, but still worth while.
- flow-matching MAF to modifications...
- I thought that the cat back exhaust was the same on a A4 12v and 30v. Is it?
- how about a MAF screen that doesn't restrict flow? Impossible you say?
- May '03 Car and Driver tests the 2004 S4.
- Has anybody ever done those 0-60 in 7.8 sec?
- So I made a list of my modest mods....
- With the help of UrS4's TB, I was hanging with the chipped 1.8T's on the run today. =D
- Am I the only one with an unmodified stock engine?
- MAF inlet velocity stack prototype 1
- Guys I just did my intake on my 96 (12ver ofcourse) and had a few q's?
- I'm a fraidy cat!
- what kind of oil does anyone use?
- Some 0-60 times for the new Stage 2+ TB...
- How do you remove the top speed limiter on a 93 100s?
- Just for the record my sons 90S started idling rough yesterday....
- Mance,how much of a flange (in red) can you get on a 3" ID pipe when you put a bell mouth on it?
- Pics of my A4 with my new 17" RS4 Replicas.
- stock airbox MAF inlet will now become a true velocity stack...
- Vibrating Noise ... Help (please)
- hey guys, stupid question what are those two blues hoses that cross over the top of the valve cover.
- I wanna get greddy oil catch can...need help
- A/C Evaporator core
- using fuel filter as oil catch can
- couple of questions
- I will be removing the MAF screen and so I thought I'd ask if there is anything else I should servic
- My mechanic says I'm crazy if I install an EFK
- Was there ever any progress on a 12V chip?
- Installed my Hosetechniques vacuum lines last night.
- A question about the plenum
- What's the largers tire that will fit the A4 spare wheel well?
