PDA
View Full Version : 12v V6 Discussion
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. Are these decent compression results for 238K?
  2. After fighting with this pesky little SOB I finally won the war after 18 months...
  3. Ecu Pin Diagram?
  4. Does your car idle evenly? (2.8l 12v V6 AAH)
  5. Again with the fuel injector..
  6. No runs, no drips, no errors...
  7. All that's left is the installation...
  8. clearing codes ODB-I on 1993 90CS quattro???
  9. Thermostat on 95 12v
  10. tools for this engine....
  11. 93 90 quattro, misfires... HELP
  12. poll, 5 year + club in this forum....
  13. Bad tranny solenoid
  14. Help with installing new fuel injector.
  15. Need help with 96 A4 12v
  16. Where are the common coolant leak points on an A4?
  17. EGR removal wrench question
  18. What's with those lousy ICVs?
  19. Turbo
  20. Lotta differences between the very early and subsequent B4 fuel rails...
  21. Help with cooling system -Just finished doing a head gasket replacement and lots else...
  22. I need some help identifying various 12V model fuel rails...
  23. Looking for an upgraded alternator something in the 180 amp range. any suggestions?
  24. Possible RPM Sensor issue
  25. New IM 1-into-2 inlet vacuum body installed...
  26. Another 90 12v question
  27. For Sale
  28. Help Please - Vaccum lines on '95 12v
  29. Special Statagie for finding Oil leak??
  30. I spent W-A-Y too much time making this part but in the end I have EXACTLY what I wanted...
  31. Now the large-bore IM vac intlet fitting for Bertha and brake accumulator gets a bit tricky...
  32. Got my grommets in the mail...thank you!
  33. these is what i meane by 3 times the size...
  34. sometimes this dog is a Chihuahua...
  35. what is "normal" for vac in HG? 20ish?
  36. I hate personal periodic self-maintenance but today's my day...
  37. Back to the drawing board on the distribution manifold...
  38. Found my donor aah motor today, got it pulled from a 92 100, in great shape..
  39. for vap
  40. quick question...for a straight answer..
  41. Bottom of the 7th & I'm on the horn to the bullpen. Time to bring in the BIG GUN...
  42. Finally looking to mod my 12v
  43. 3litre a month oil leak
  44. EGR woes. EGR Delete!
  45. Finally! Now tomorrow I can start getting some under-hood work done on this thing...
  46. New 2 stage vacuum storage/metering assembly componentry...
  47. I never knew...
  48. Anyone "know" what the cruise control vacuum pump motor vacuum line "tees" into....
  49. IAC Anyone?
  50. 2-stage/dual reservoir vacuum setup w/individual adjustable solenoid metering/distribution system...
  51. hey EDIGREG, i was reading your page on gun drilled cams, and had a question:
  52. crap, 12v.org is down...
  53. Anyone have a good recommendation on where to purchase a vacuum guage suitable for all this testing?
  54. doing my airboz workshop and the "foam filler" my wife brought home says it will com-bust at 240F
  55. EDIGREG, is your link to the Airbox workshop broken?
  56. so after my Sat morn garage sale crawl (yes I am old and cheep) I did some troubleshooting on my vac
  57. I AM da man! I killed my '06 emissions numbers! I mean COMPLETELY wiped the floor with em...
  58. Mance, how much longer till your motor is up and running, did i hear you say a week?
  59. WOW this little faux pas could ruin your whole day...
  60. Irratic (idle & near idle) behaviour...
  61. More VAC numbers...My 12v pulls 18 In Hg...
  62. here is my Vac numbers for my 12v
  63. After a 100 mile shake-down drive I'm a happy camper...
  64. Last pics before I throw it all back in tomorrow morning...
  65. I forgot to mention... For the official timers it took 29:32 (mins/secs) to remove the IM...
  66. ok, s'more o' that magic stuff...
  67. Another potential source of intake manifold vacuum leak...
  68. Now THAT'S the kinda sugar papa likes!!!
  69. 3rd times the charm, yep the IM has to come out one more time...
  70. Mance, some questions on my new injectors:
  71. The magic IM bolt-loosening phenomenon revealed and a work-around for it...
  72. What's that riddle about how to get 3 different animals across a river in a single boat...
  73. I LOVE the Life the forum has had the last couple weeks!
  74. where the hell am I leaking oil from!!!!!!!.................................
  75. Heheheh... I got the "magic loosening" IM bolts figured out!!! Even confirmed it...
  76. Lunch-time IM update...
  77. IM Gasket-lapping update...
  78. Mance, what kind of dry sump are you using and can you post some pictures...
  79. Knock sensor display::what do you think of this...
  80. FS: I still have an XTB that I purchased from Brent that I never used.
  81. couple of IM questions
  82. Home Brew MAF
  83. Ok, ALL other IM gasket sealing surfaces are fine... quite good in fact (totally flat)...
  84. Last pic before final lapping. Due to how deep I had to lap my IM halves...
  85. Up at 3am thinking IM #2 has GOT to be a fluke on how badly warped the upper/lower halves are...
  86. If I had ANY idea things were this bad I woul'd've started with 100 or 150 grit sandpaper...
  87. Ok, I started the IM R&R this morning after locating some decent gasket material I had stored...
  88. I'm gonna have to wuss-out on the IM R&R today... I'm 2 square inches short of having...
  89. part needed for throttle cable assembly....
  90. This is like Disney Land for me...i want to go.. long gif warning
  91. VAP TRIFECTA ! (sorry had to go for it)
  92. Tomorrow it ALL comes apart again as I can still only pull 16 InHg of vacuum...
  93. well my shiney-new one-of-a-kind, stainless steel, equal length headers have to go...
  94. If you guys haven't tried the new Loctite threadlocker gels you're in for a treat!!
  95. Joe@Axis Can you still get valve cover gaskets?
  96. Im well-tooled & knowledgeable enough to deal with LOTS of different events but magic shouldn't
  97. After searching and getting little... Who's using the 034 chipsets in their 12v's and...
  98. What is the easiest way to lower compression?
  99. Starting Problem, starts up and dies 2 seconds after.
  100. After all my extreme carefulness and attention to detail I'm headed over to Champagne...
  101. With the intake manifold workshop completed some thoughts....
  102. Lago Blue. What did you say you had done to your injectors?
  103. What is the XVS testing status? Haven't heard anything back from testers...
  104. Just ordered these injectors: (thank you mance for your guidance)
  105. More cylinder head work, helpful hints, pictures and a mountable jig fixture for perfect injector...
  106. Anyone got some spare cash?
  107. I think these will work for my motor: (tell me if otherwise)
  108. What not to do to your 12V
  109. CCing the cylinder head intake runners...
  110. Torque speck needed for re-install of O2 sensors.
  111. Vac hose routing questions...
  112. swapping a B5 12v into a B4 chassis?
  113. Ummmmm OEM goodness,,,
  114. people with B4's of the year 1995/in the US can you please chime in and tell me........
  115. BMW vac line re-re-re-visited...
  116. Can the AFC be a direct swap for an AAH?
  117. Another Starter??
  118. Well the compression check results are in.
  119. Oil LIght Help 96 A4 12v
  120. no start issue with my 95 90q...
  121. does anyone here have a set of B4 motor mounts?? I dont care if the actual mounts are toast...
  122. Swapping power seat with Manual Seat
  123. With some friendly persuasion from Mance the butterflies are reborn...
  124. Can anyone instruct me on how the butterfly shafts come free? This side is...
  125. A few pics of my P&P on my new intake manifold...
  126. TurboHoses velocity stacks are apparently out of stock. I ordered on 7/8...
  127. :-) Great googly moogly my airbox:
  128. Edigreg, got the intake all buttoned up. Question, the vacuum line coming thru the firewall....
  129. Got my wisdom teeth taken out yesterday, car's just sitting in the garage. . .
  130. Installing ITB's on the 2.8/12V is gonna be a fretfully spendy and complicated process...
  131. how can i tell what make steering rack I have?
  132. Cheap man's airbox velocity stack:
  133. 92 100 won't start
  134. quick question bout my air box.
  135. sold the 12v
  136. Anyone have considered the Magnaflow XLTurbo product to replace the stock resonator ?
  137. ok...does anyone know if the 034 density motormounts that are designed for the....
  138. Had a little stoplight-to-stoplight fast dance this morning with an LS2 400HP Pontiac GTO...
  139. Cheap lights!
  140. timing bar
  141. X- Post from the C4 forum. Bad day for the A6
  142. Those of you with non-stock exhaust...
  143. Tracking Down Vacuum "T" dimensions
  144. So.. My car was in an accident and wrote off. I am keeping the car though.
  145. ok 15-59mph rev limiter cuts in right at 59mph on a 96 a4..see for times
  146. Need to make sure about EGR valve
  147. I finally got keyless entry back into my life along with other conveniences & safeguards...
  148. with tire size 225 40 18 iirc when my speedo reads 60mph i am actually going 60.5..
  149. Regarding BMW vacuum hose
  150. Anyone interested in an upper radiator hose to an A4?
  151. Low-Speed Tracts of the I/M: Full Radiuus Entries..
  152. Part number request
  153. posted in 100c4 forum but maybe its better here.
  154. Hey Jon, how's the silicone hose intake coming along?
  155. So neither my windows or sunroof work anymore. Ideas?
  156. Has anyone used the street or track density motor mounts from 034?????
  157. help! Steering rack took a crap..
  158. Ok, here's an ISV/3" induction hose fix that affords ample additional clearance...
  159. will a AAH crankshaft work in the AFC?
  160. Edigreg, ygm.
  161. Any guesstimates on hp levels the stock rods will take?
  162. Recondition or second hand engine?
  163. Anybody thought about making a VAP-Mod wiki page?
  164. Mance question please..
  165. Ugh.....no more headers for me.
  166. if anyone can make the test i ask vap...it would be great...;)
  167. question for vap..
  168. Not sure if this has been posted yet... Timing belt tools.
  169. Mance: Info needed on the V8 resonator setup
  170. Sold one of my A6q's last night. Now I have an excuse to drive the Mance-modded one!
  171. Mance put your stopwatch away..!!
  172. Who made me? **For the Enthusiasts**
  173. EDIGREG, could you please post a picture of your silicone hose setup? Also, just to confirm...
  174. Dropped by the shop today...
  175. RANT: ..Got a catalytic converter rattling right now.
  176. RON to Octane conversion?
  177. exhaust update
  178. It's strangely quiet and peaceful here....what gives? not nearly as exciting to click on the link
  179. finally got some MMO, thanks to Lago Blue....
  180. who was making some POS heat sinks? I forgot.
  181. OEM Noise Damper Mounting: Possible air leak...
  182. lets all have a laugh on/with Luxus...
  183. Did my head gaskets
  184. my unfinished recovery sleeve i am trying to finish and cant find the barb npt ..
  185. Possibly already discussed... Rumbling/Popping/Backfiring under decel while in gear??
  186. does anyone have a source for new afc valve springs, rebuilding and havng a hard time finding em
  187. What do you guys think of your BMW vacuum lines?
  188. EGR Valve Problem? Help...
  189. FYI, Checker Auto offers Goodyear/Norma clamps. {EDIT}
  190. all back together after head ->I.M. gasket match and P&P'd I.M. install
  191. 80/90/CQ X-post.
  192. Everyone cross there fingers. I got her all back together and about to start her up....
  193. hole in side of bell housing A4 Q automatic 2.8l '97
  194. Here are my initial 15-60mph results......
  195. Code p0322 after new motor
  196. Name of metal coolant pipe in front of radiator...and where can I find one..
  197. Pinging @ 1/2 primary throttle. 95 A6Q New ACDelco Rapidfire 9's, p&p: tb, intake, maf, and...
  198. Adjusting manifold butterfly switchover for under/over-travel to correct gap...
  199. now my silicone 2 ply hoses are in ! Thanks Mance for the link!
  200. uht-o...is this gonna be a problem?
  201. Vacuum leak, found hose, can't find where it goes...
  202. Jonny 5 no disassemble...Reassemble!!
  203. So I thought I had a XTB, but looking at pics in the XTB process...
  204. My new O2 sensors and a quick MPG question for the 12v A4s.
  205. I found out what caused my accident....
  206. Today's progress. Taking my time as I have the 93 to drive
  207. DAMMIT, it's 98.1F and 13% relative humidity at Denver International Airport right now...
  208. My initial 15-60MPH timed runs...
  209. What is the best "lube" for squeezing my new injector O-rings in while on the injector?
  210. Yep, I was out there again early. This time with my winter tires...
  211. Older Audi Keyless entry...
  212. all 6 done!!
  213. doing my V pan for the first time on the 95 and have a question or 2..
  214. RS2 airbox looks interesting.
  215. Some 4:30am 15-60MPH timed runs... (*edited*)
  216. Oil leak progress
  217. looking for parts store, or website
  218. 3.5 out of 6 intake ports in my heads done and I am NOT touching another file until tomorrow.
  219. intake plenum legnth?
  220. I am all for pointing out the shortcomings of others....
  221. ok, the three sets of 3mm screws are gone. it'll be a week or so before i have more.
  222. some pics of today's carnage/progress....
  223. I ma gonna start to charge 12v's rent around my place.
  224. Why does the Audi oil cap say low oil will damage the catalytic converters?
  225. what can I use to patch a small hole in Silicene hose?
  226. 96 a4 security system wiring diagram? anybody?..
  227. does anyone have this part i can buy off of them?
  228. 12V comes apart today.
  229. The high-flow airbox has now lived up to and surpassed any/all expectations...
  230. Rear Tie Rod Assembly... Will a 00' S4 Part Work?
  231. Replacing original I.M. Butterfly shaft seals.
  232. Any truth to this O2 sensor test?
  233. ok this is what I got to lock my IM butterfly screws in place....
  234. just got a tracking # for my intake hoses i ordered.
  235. New here, need IM butterfly bolts
  236. new to area
  237. Speaking of ECM's...how interchangable are they...
  238. Recoded my ECU today. No more EGR code.
  239. OT: Brutal Tractor
  240. wash.rinse.repeat
  241. Weisco need help.
  242. Ok, here's the initial 2nd gear 15-60MPH timed runs...
  243. Ya know what might be an interesting thing for us to do is make a time/speed run....
  244. What does this mean..."18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D"....
  245. Datalogging, Butt dynos, and MS-Excel Spreadsheets.
  246. VAP's Mods...
  247. Ok, 2nd road test of Hi-Flow airbox and I'm starting to warm up to it...
  248. Thought, get a bumper "re bar section" form wreckers and cut a hole for a intake duct in it....
  249. The Hi Flow Airbox is installed. But first test drive doesn't reveal much if anything improved...
  250. Some bastard shot my car
