View Full Version : 12v V6 Discussion
- Question about cam and crank timing after head gasket..
- HELP...Car not idling!!!
- Does anyone know the part # for the seal/cap on the back of the pass side valve cover
- Apexi SAFCII is wired in and working on my 12v
- Question about Timing Belt Cover--Is cutout section normal?
- question about spark plug wires
- Need gasket help - 12v Air Intake - it's all wrinkley!
- Cross Post: CEL Code P0401 EGR "Flow Insufficient"
- wouldnt soldering generic o2 sensors be better than splicing?
- so today I was at wal-mart for the post boxing sale in Canada here
- MikTip (and Mori too!)- do you think oil consumption of 1qt M1 5W-40 every 3,500 miles is ok?
- Oil Pressure Light On 2000 RPM
- X-Post: Help, my car won't start!
- I replaced the front caliper piston seals and boots
- TB replacement kit for 1996, 2.8 12V
- My heart's a-breakin'....
- Happy Festivus!
- x-post:
- Upgraded Throttle Body for my 95 A6 Quattro
- If anybody is in need of wheels...come and get them!
- Anybody have a Bored Out 12V Throttle Body they want to sell???
- Plug wires. What's the general preference?
- Any opinions on waterpump brands? Ready for the TB and pump service.
- Love this video! A8 twin turbo diesel v8 goes 800 miles on a single tank!
- my oil consumption increased after switching Castrol 5W40
- Is flushing the cooling system with water enough to change the coolant to G-05?
- EXTREMELY VAGUE.. i know. car making a strange noise while idleing (almost like an air hole)
- Camshaft Position Sensor
- ok dont flame me, did a quick search and didnt' see much, anyone tried a 12v to 1.8 swap?
- Remember my noisy "wheel bearing"?
- codes codes codes what do they all mean .
- any parts that can only come from the european audi dealerships that i should get on my next trip?
- Intake question regarding aluminium tubing .
- X-Post about alternator....
- Eng. LIGHT
- I miss my Audi :(
- P0116 Code again,...possible reasons I learned via 'search'
- Converters in Exhaust
- what is this adjuster on EGR thinnigy for?
- question on catch can I am designing.
- does anyone have any of mances used products that they dont want?
- Paging Mr. D Paging Mr.D Looking for Info.
- My oil consumption!
- WTF..oil light pops on. I am putting 1qt in every 500-600 miles in the winter.
- Cylinder 3 misfire. I pulled the plug to find the electrodes caked with crusted oil, time for valve
- the a4 has now new inner and outer cv boots one upper control arm and new sway bar uplinks..
- Hey guys think its time to finally part with the A4 . . . thoughts on new car?
- Mulholland Hwy + night time + (mostly) broken-in 12v = . . .
- About to order timing belt
- Anyone know which year 12v has the larger throttle body to convert into a SXTB by Mance?I have a '97
- Well my Experience With German Castrol 0-30 so far
- Catch can suggestion
- here she is sitting with 11.5 " of snow on top..
- warm up time for a 12V when cold?
- 12V develop this!!
- Oil cooler leak, 96 A6Q 12V
- 96 A4 idle problem
- PCV question
- Mori: fun with sludge...
- May 12-14, 2006 at Hallett, OK midwest audiclub DE
- oil light after tb
- Sweet! My official Mosport shot made it...
- Mr. D...
- Measuring block question for ppl with ProDiag or VagCom...
- Mori, you mentioned you changed your diff fluid recently. Where exactly is the front diff drain? I..
- 2Bennet Bored Throttle Body - Effectiveness?
- Well, I got my camshaft position sensor off. But I busted one of my hoses.
- Busted my oil pan this morning..
- Calling the boys, repost over to the 80/90.
- 1995 GTI VR6 Owners - need some electrical wiring help
- My engine fault codes...gulp...what can you make of these?
- Interesting read: 40 reasons for oil consumption (AW's longest post ever?) ;-)
- My car won't start...I think it may be fuel filter/pump related.
- Universal 02 13913 working fine.
- Vibration on acceleration?
- Calling all 12V owners with engine pictures...
- is there a way to bypass the camshaft position sensor ....
- Head Gasket time! : )
- Automotive engineer on oil consumption and engine break-in (nuthin' much new)
- so tomorrow is going to be back in the 50s again its 26 right now so i can finnish my car hopefully
- I still have an extra Intake Manifold if anyone wants it, as well as an RS4 grill and K&N panel.
- Anybody looking for a new project? I marked this OT cause its a 99
- 1stGenA4Q is now Tourette(stillanoob)...more inside
- Replacement of vent hose on back of head? [hard plastic]
- O2 sensor , I already did a search found nothing of use to me
- How many quarts of oil for my 94 100cs tranny and rear differential?
- I think I need a flux capacitor for my car?
- BG K 44 formula is still the same?
- VAG-COM in port huron, mi area
- Cambelt Emergency v6 2.6
- Exhaust size recommendations
- I need some help finding out what is killing my catalytic converters....
- Dec 3 at Imagine automotive Lenexa ks Audi club GTG and Tech session
- Anyone with a 12v have a timing belt/tensioner fail??
- so Mori is a couple pics of the 12v engine that i am planning on useing on the 4k
- Need MOre Hp HElp.
- the purolator filter i got doesn't seem to want to be prefilled.. at all..
- The Drugs on my O2 sensors just wore off
- so my rear differential is leaking btw the center and left shaft...I'm also getting a humming sound
- Mr. D, Matt or anyone else who has spliced in the Bosch 3 wires . . .
- Hey Mori man I found some Rotella SAE 30
- what size is the collar bolt for the axle shaft...
- cam seal/cap
- Modify shift quality through VAG-COM?
- are there any codes to use at checkout for fuel poweR?
- I tried BG's 44K fuel treatment recently. Subsequently my cats died. Any possible connection?
- hey guys, I'm hearing a dull thumping sound coming from the left rear, any ideas what it could be?
- collect call for MANCE!
- anyone know if mance still sells his snub mount?
- ***moribundman*** How/where/what do i check to see if i have that sludge stuff on my car?
- Hi Guys, it's been a while
- Keeping the car cool on the track...
- to get new headgaskets and oil pan gaskets and valley pan gaskets wheres a good source fo that?
- Shifting issues....
- best oil to use @ 186xxx? currently using valvoline 10w 40. what should i go to ?
- Ahhhh!! something is eating my timing belt
- headgasket -> valve stem oil seals ->...P&P?!?
- Can I clean the MAF on my 93 90 cs Quattro?
- Anyone ever Boosted one of these V6's? ANy info would be great
- Will NOT Idle after cleaning ICV
- 1PissedOff90 is your new oil cooler union bolt about 101mm? You had mentioned...
- Pro Diag question...
- the code that came up is 00560 EGR incorect signal. Any Ideas????
- Problems!!! Cat failed, not running a code, and car is having trouble idling
- how to remove knock sensors on a 12V engine
- S4 suspension on A4
- Question about firing order
- ok heres one i didn t like when i got home last night noticed where i debaged over a year ago..
- blower motor replaced
- Hit the 200,000 mark!
- Can't...finish...the...ninety...quattro. :0(
- How to tell if timing belt procedure was done?
- Sluggish at high rpm's
- So I bored out my MAF today...
- Anyone know how to reset service indicator with ProDiag ?
- Plate on downwind side of MAF - remove it?
- Mance, calling Mance.....
- Mori, another oil question . . . Sorry. ;-P
- My fotki red Audi's album is ready
- Mr. Mori, where have you located Redline 75w90 in Calif.? I'm havin' a tough time. Thanks!
- grey and light brownish kind of a smoke
- 2 Quick questions...come inside come inside!!!!
- TB Mod: DIY?
- Twin-turbo possible???
- SUPERCHARGED?
- What color/kind of ECT sensor do i get?
- um how bad is this
- Well, identified the whirring/chugging noise from the motor...
- where you live at?
- So when I flush my coolant system... should I switch over to the pink stuff from the blue?
- 12V AFC engine management
- Can anyone describe what "rattling cats" (no jokes Mori...) sound like? I think mine are...
- another question about 90 quattro transmission oil (since i m new in this forum)
- ISV price difference
- question regarding transmission swap and compatibility to the 12v
- so i am looking at a stage IIc ecu from 034efi anyone here use this?
- injection
- could i use the cruise control vacuum motor to open the
- JWG can you please give me a list of mods you did to your 12v
- i have 96 2.8Q 12v and i need ported throttle body!!
- heres the pic of how much play my moms inner tie rod had and the new..
- Climate Control
- x-post... looks like the old girl is going in for another overhaul :(
- What are you guys using to remove studs? As in exhaust manifold studs.(edit)
- Intake ports
- may sound like a stupid question --- regarding 3-wire vs. 4-wire MAF sensors
- Anybody have the write up on EGR mod?
- Could you rig...
- Is there another name for the snub mount?
- Need a new CAT.
- What happened here?
- Need quick help guys...
- Mori, what the @#$! is in that FP60?!!!!
- brake bias, has any one attempted to change it on a b4 90 ?
- Mori, You still have that droning noise?
- Is 3k ohms too high for Ignition output stage?
- tips or pictures of custom brackets for 99.5+ fog conversion?
- Dropped my 12v off at the shop for some easy fixes.. I thought..
- how to change the crankshaft sensor
- Unusual whirring, almost chugging noise coming from engine at idle?
- So I found out that neither my belt broke or the tensioner didnt fail. DONT CLICK IF YOU'RE EATTING!
- Would retainers for a 20v 3B, AAN, ABY work on a 12v AAH head? Thx.
- HEEELLLLPPPPP!!!!!!
- A/C problem, I think? There is a green connector on the top passenger side of the radiator..
- Well found my leak
- no tension on accessory belt. the tensioner is shot rite?
- Hey Justin figured I would let you know...Audi event at VIR Nov 19-20 Quattro club
- Few questions... My 90 has been sitting for about 5 months.
- if you feel movement when you shift gears are the motor mounts bad or the tranny mounts?
- other than age, are there any reasons why an accessory belt would break?
- Cam's anyone have some other than stock.
- AAAAAAHHHHHH!!!!! stupid head bolts!!!!!!
- Lightweight Pulleys
- ABS problems on 96 2.8QM
- vag-com question and custom exhaust question
- Paging CrazyCab and mattd860 and anybody else interested in buying my car...
- Any Narrowband A/F gauges that show the actual ratio (xx:1)
- Hey Moriiiiiiiiiiiiiiiiiiiiiiiiiii,
- X-post...Help guys
- AC does not work, how much performace can I gain by getting shorter S belt and omiting compressor ?
- Transmission noise...
- trans and motor mounts replacement question.
- Hydraulic or Mechanical Valvetrain
- well i need help ASAP.. i posted this somewere else but need 12v people.
- If anyone is interested in attempting the Intake Manifold Porting and Polishing Workshop...
- supercharger thoughts ... using m45 eaton
- EGR System Plugged
- Email me pics of your red audi's,,,
- Kansas City Audi GTG--Wed Oct 19th--River Market Brewery 6:30 PM
- muffler
- So next May is D-day. The 12V is going away.
- supercharger whine
- got a prob with my 100
- Cross post from the 80/90/CQ forum...
- Schrick Cams
- I have all 4 Audi rear brake hoses, brand new, laying around that I don't need. For a B5 A4q.
- after someone q about 30v heads in a 12v with 30v electronics..
- Crapzolaa coolant leak
- OK.. nother question even though my last got NO response...
- So it looks like it's my turn for new rotors :( story and questions within...
- What gap should I run on NGK V's ?
- Do 12v pistons have enough meat to be milled down?
- how many CFMs can this engine take?
- Heater Core Flow
- need input from 12V'ers please
- so i ordered the pressure spindle thingy from samtag the 3207 matra.
- *sigh* A mysterious droning noise is driving me nuts
- 12v to 30v
- Ready to do tb upgrade....Mance, are you out there?
- exhaust
- at 250k miles should i replace my injectors or have them cleaned?
- what is the inner tie rod??
- is it possible to disable the EGR valve...
- Anybody have any thoughts on these?
- Any suggestions when changing outer CV boots about having to remove brake components..? more
- Does this mean the timing belt is too tight?
- Stand Alone
- exhaust
- chip
- Curses!!! Those O2 Sensors
- Whats the problem here?
- thinking of upgrading exhaust
- Anyone know what type of assembly paste to use when replacing the seal kit on a caliper?
- I am going to replace the timing belt. Is there any good step-by step description.
- Stalling at idle, rough idle
- Paging moribundman, Mr.D, Jretal, MikTip...
- Rough Idle.. post DIY MAF.... vac lines look OK.. no codes..
- Anyone have a pic of the inside of a 12v MAF that mance bored out?
- silly question....
- Xpost... I need a used engine CHEAP !!!
