View Full Version : 12v V6 Discussion
- parts
- sold the a4 a minute ago.
- Back to my Audi roots....few questions....longish...
- Delta CC radio and iPod hardwiring:
- can i put an engine from an auto into a manual car?
- Quick TB question
- Anybody selling any used mance mods?
- anyone give feedback on Walker O2 sensors???
- Anyone have any lower grills for my 96 A4?
- Mori here is a topic over in AWOT you might like.
- Mobil 1 Extended Performance Motor Oil - 10W-40
- Hey kids, now it's time to play everyone's faaavorite game - GUESS MY FAULT CODES!
- What temperature does the stock fan clutch engage?
- in need of replacement
- Anybody got a drivers side light w/o broken tabs they'd like to part with?
- Anybody have a write-up on removing heads?
- Frequency of Power Output Stage (POS) and/or Coil Failures?
- I thought the B4/B5 people would like to see that
- Finally installed P&P Intake Manifold and AAH Heads.....
- Tips on tweaking my intake
- To The Owner of 12v.org
- MAF topic again...(I got the small MAF housing)
- Hey Mori, where can I buy FP60 in California (please...)?
- Rogue connector after Timing Belt maintenance
- I am asking for some advice...
- I tried some of the Prestone SuperFlush this last week and...
- underdrive pulleys
- Are these ODB tools worth $60 (with the 2x2 connector for my ODB1 car)?
- This is kind of obscure but I'll ask anyway
- 93 and 95 90q engines interchangeble?
- Tires???????
- anyone know where I could find alum. valve covers?
- Question for those who have used the cam alignment tool.....
- Doubts on fuel additives/ injector cleaners
- Snow tires?
- Did my rear brakes the other day
- oil leak
- 93 100cs Stalled last night
- Mr. Miktip (or anyone else...) any suggestions on replacing valve cover gaskets..? More
- Definitely worth a read...
- Question about DIY silicone hose kit:
- Head Gasket
- Clank Clank Tranny noise on decceleration
- Why AFC is different from AAH:
- Used heads or basic rebuild? AAH w/160k, bent valves. Valve stem seal and gasket source???
- IIRC, there was somebody on here a while ago who put a turbo on the 12V. Do you guys remember him?
- starting issue with 97 v6 a4 12v
- Bardahl All-U-Need for injector cleaning ?
- Hey guys another brake question.
- Indy shop in/around Springfield, MA??
- Oil Puddles
- pulled aah angry sticks from a 100 v6, should I go back and pull the heads to?
- Anyone change center consoles?
- A/C only coming out of the center vents. any ideas?
- hard to damage 2.8 v6?//
- WTB: AAH heads. PA/NJ is best. TIA.
- Cross Post from B5 Folder.. AFC Fan Pulley?
- please read this !!! does the throttle body from a 92 100 CS work on a 95 A6 quattro?V6-2.8L-12v
- Greddy Oil Catch Can
- Motodyne supercharger?
- I bought Duralast 7mm spark plug wires??????
- Might be getting a 12 valve with 270,000 miles on it...
- possible ecu upgrade for 2.8's?? My friend found this for me on the jegs.com website. Would this
- Audi Driving Experience, Circuit de Catalunya, Barcelona, Spain...
- Is 12v.org dead? or anyone know where i can get cell codes, 2113 i believen is the one i need
- Vacuum hoses specs ?
- vac line clean out
- Yellow's!
- x-post... it's official...
- broken timing belt poll
- quick question on the DIY MAF
- Anyone have parts for sale?
- Shop says bad coolant sensor. I think bad t-stat any write up on 96A4 sensor replacement
- Paints drying on my 93 90S
- Does the 12v engine have piston oil squirters? I searched:
- So mance are you installing Beryllium Copper alloy valve seats?
- Anyone have any links to a good place for cat converters. I have the specs inside my post.
- Timing belt came off
- anybody ever r/r oil pressure switch? any tips how to...
- Car possibly running too cool? Coolant Temp on trip.
- Ok guys, realizing the overheating situation isn't a fluke...
- I actually did my thermostat without removing the timing belt
- Rear Shocks - best source for miscellaneous parts ?
- STFA... No help... MikTip...
- Need tips for intake mod....whilst spending little money!
- I want to get rid of my plenum when I install the silicone hose kit..
- miktip do u have email?
- Looks like i've got a problem :o\
- My battery is going south. Which Optima battery do you all use?
- Got a vag-com...extra info needed.
- Broke a stud on the exhaust mani.... replacable??
- Is it possible to recode any features
- Help Interpreting Compression Test Results (B4 90s)
- Gas Mileage: Is 13 MPG Acceptable for a 96 with 105k on the meter?
- Well I think I got the phantom sunroof...Thought it was just the old girl yawning doing highway...
- Dumb question about rear rotor replacement
- Miktip, curious where you found your ignition wires?
- high oil temp
- Crank locking bolt and cam lock.
- 12v.org canNOT be displayed
- Winter Tires
- fan stays on
- Compression Test Results - thoughts? B4 90s
- ECU Questions
- Paging Mance
- lower oil pan
- How many bulbs in the 96 Climate control unit.
- Anybody have any front fenders lying around?
- Hey need help with a EFK electrical question...fan not coming on..
- Hey guys! Just sayin hi again.
- Plenum off, what else to replace?
- Saw my old A4 the other day and so I thought I'd drop in and see what's new...
- engine vibration
- Brake pads gone, should I also get new rotors ?
- Ignition Advance? (Please don't shoot before reading)
- Removing CAT
- Anyone know if there is a write up on removing the tranny in a 93 100s?
- USA ETKA guys...
- PES Supercharger
- Making an S2 hose kit - I think I know how, but need consult.
- OT, somethings been on my mind...(OT means not related to 12V Development)
- Did Mance ever develop any mods for 30V A4's?
- Car won't start, and I have a feeling it's not your everyday problem...
- 94 100 heads = 96 a4 heads?
- Last EFK question I swear...Do I need the 1280 (CFM) or the 1720 (CFM)...Thanks for the help!
- 1992 B4 80 2.8e headgaskets????
- Is this Still Mances main e-mail ? (salinas212@AOL.com)
- Moderately OT: Clear Corner Liability
- will a 94 100 IM fit the 96 a4 IM?
- no start
- Mance, am I to understand from this post that the smallest ID o-ring for the S3 MAF
- What EFK's are people running I'm looking at the EVO = $199 or the SPP =$179
- Hey Justin, Did you get your brake pads down from the attic yet?
- Xpost:Ok guys I'm spamming the forums for help :) lil ETKA help... but not for my car
- flywheel question.....
- location of secondary air injection pump and hose picture?
- v6 cam belt check
- Does anyone think 3/16" aluminum plate is too thick to make shields for my front rotors?
- with the high gas prices, i thought i could get away with using 89 but the car felt really slow, how
- do i need any special tools to install suspension on 97 a4?
- Long weekend working on both cars . . .
- lower oil pan mounting bolts one of them is stripped, how do I go about fixing?
- 94' 90q transmission and engine, 4 sale
- 12 valve SUPERCHARGER project completed...
- What oil should i put in my motor??? J/K
- 1992 Audi 100 Questions
- a4 2.8 engine oil pressure switch anyone know?
- I think im keeping my car <3!
- what do I do if I lose one of those bushings on the plenum?
- Cat Convertor
- Superchargers
- Is there a documented setup for belt size etc for deletion of AC?
- Odelay YGM :)
- what to use to top off final drive?
- ECU ??
- curiosity... how much horses do you guys have with 12v?
- How to acquire Mance Etheridge's performance parts?
- Installed UrS4's snub and Allroad tranny mounts...
- Paging anfernee! still have the Bilsteins + H&R Sport for sale?
- Farewell Old Friends
- exhaust bolts and studs questions
- Catalytic converter "death rattle" opinions needed.
- Resetting computer
- got these codes pulled off my computer...
- Bench test for Cam Position Sensor?
- couple of questions on exhaust removal and drive flange seal replacement
- Anyone running a single cat, single pipe single muffler setup? What resonator do you use?
- Does anybody have an extra MAF sensor for the 12V ?
- got pic?
- After auto-x this weekend realize I NEED an electric fan...Still very happy with the setup.
- Almost died... Quattro is very deceptive...
- I have searched but I need to be pointed in the right direction about O2 sensors
- A/C Compressor Type
- Can one of you boys point me to cylinder 6? :) Finally got a VAG-COM
- so if these things weren't so expensive...
- 96A4Qa question about hard driving that returns
- Got an alignment done. Suspension is tight, tires OK, wheels balanced. I have some steering wheel
- parts for sale
- Just wanted to say hey to everyone...
- Harbor Freight has the Brake Caliper Tool set on sale for $19.99
- CEL - Throttle position sensor/idle speed sensor - help
- wiring diagram
- Cat Conv noise
- check engin light
- How hard to replace the a/c compressor?
- input please.
- Looking for exhaust for 12v quattro??
- my 12v is for sale.
- I finally installed Mance's ol' ARC2-NE this past weekend . . .
- Stand alone engine management systems
- Anyone have a old/spare corner blinker bulb socket laying around...Part number would help too!
- How good are the standard rear shocks ? (A4 2.8 1996)
- I had an alignment done at a race shop today
- ignition key blunder
- dont laugh, just gimme an answer
- Audi Ownership - the Saga Continues!
- Help identifying this thingy - 2.6 (b5) 12V
- Where is the A/C clutch relay...
- whats 12 v
- Ridiculous question but I still would like a real answer...
- A/C Issues
- ignition coil ??
- if i weld to straight pipes back to my muffler on my '97 A4 2.8 is it gonna sound yucky?
- anyone looking for another 12v? saw this posted on the mid-atlantic forum
- found this under my car today....
- Anyone rented Blaupart Cam tool kit recently?
- Best deal on steering rack
- Off to the Audi Driving Experience in Barcelona Spain...
- Unique Question Re: '96 12v Delta Bose Stereo
- TAP now has a chip for early '92 & '93 2.8 V6's ?!?!.....
- ok tring to take off the upper im off and cant seam to get it to budge..
- yeah i know its just a few posts below but i had to bring it up.. anyone know anything more about
- Guess what oil Mobil recommends for older Porsche that are out of warranty?
- from STFA, i see that recharging the A/C on my own is not gonna happen easily...
- Anybody interested in used A4 1.8T shocks/springs w/ 10k on them?
- Props where due....
- AutoXing this weekend!
- Got my replacement Clear corners today and have a question....
- a/c and rpm
- Is it ok to do this?
- Anyone got an extra upper oil pan from an AFC engine?
- Any autotrans experts here...?
- i'm a moron....
- Just a note for those considering RS4 front bumper with ram air.
- Are Carquest oil filters any good?
- S3 Hose Kit replica finally completed and installed.
- 12v into a 4000?
- Attn. Walmart shoppers....M1 5w-40 in the family size (5q) $19.97! (I thought $4.49 was a deal! )...
- Could someone please tell me if the small fitting on the S3 sleeve...<edit>
- anyone know the measurements of a stock flex pipe for the 2.8
- lube and plug ??'s
- X-post from the 90 fourm..vally pan gasket
- Need some help here guys, steering issues. Updated.
- 1PissedOff90, JWG, or someone else who has done heads and or cams, i need advice.
- Mr.D, CK NYoC, about those defective mystery water pumps
- How bored does a cop have to be to ticket a parked car for expired tags???
- i have 97 2.8qt 12v about what rpm should i shift at for optium fuel consumption and power
- how to set timing if cams were removed?
- Anyone have tubular headers for 1995 90Q up for grabs?
- Hey Mori (and anyone else)- M1 oil is on sale at Pep Boys out here in CA. for $4.49. One catch...
- 12V TB upgrade ?
- so the old girl is starting to worry me here... slight over heating problem...
- looking for a shop
- Goodies for grabs
- Aww crap - CEL/MIL on the ride to work! A little aid, if you would
- does anyone here still run 272 eusospec cams?
- lol 3500 dollars for my car? Wow..
- How tough is it to change the Valve Seals? Scale of one to ten, 1 changing tire - 10 is overhaul.
- After 2 months of BSing, I finally got my A/C working this morning...
- Another hit from the Killer Summer road work....
