View Full Version : 12v V6 Discussion
- Anybody here used Magnecor plug wires?
- Car getting hot
- Question on wheels guys . . . . ADR Kasai 17"
- changing clutch & transmission shortly..... anybody want a 4K old clutch?
- Paging Miktip again
- installed intake on my 2.8 today... ideas for harness or heatshield?
- 16845 Fuel Level Sensor Circ Range/Performance
- Whats this thing in the lower front bumper?
- Mance, are you there???
- Mance's exhaust pics.
- What size vacuum lines?
- RobK īs mail adress wanted!!
- 97 A6Q 12V Chk Eng Code 16785 EGR Insufficient Flow
- Mance is your car running on haltech yet?
- spark plug wires for a 94 100CS
- Paging MikTip,
- Just ran the blink codes on my 94' 90Q - only one showed
- Anyone got a outside air temp sensor for A4 to spare?
- x post: blink codes how to get em?
- what can i do to get horsepower?
- X-post to maybe the best 12V spark plug boot removal tool ever!
- Tighter than a bullfrogs' butthole.
- FANTASTIC newz !!! I found the "thrown away" MAF sensor !!!!
- Does anybody know if these tie rod ends are good?
- Anyone have a set of cams or know where to get some for a good deal?
- Bad waterpump???
- x-post... need a lil help with some electrical wiring... anyone?
- Check these out-
- UPS man was kind to me today :-D
- Okay to use Generic Bosch o2 Sensors?
- Cracked MAF Sensor Housing
- Rear brake calipers
- Water Water everywhere
- x post: about expressautoparts.com
- I got the engine home but lost the bolts to the stand :-(
- What exhaust do you guys reccomend?
- Ahh, the bumper. Anyone realigned it?
- Anyone selling any Abnormally Aspired mods?
- Paging URS4, I want to ask you a question about snub mounts.
- Stage 3 MAF and throttle Body
- x posted in A4 forum
- We're all gonna die...
- durring the track even a couple weeks ago durring my 3rd run session i was around 5500rpm ...
- Does anyone have any experience with Total Seal rings?
- Vacuum Ball Damper Thingy Installed...
- I believe I'm about to become the 1st street-driven, normally aspirated 12V to lose the Hitachi ECU
- 12V TB / Vasserpumpe Question
- I am ignorant so help me a little.. :) I am trying to figure out if the IM is turning over.
- Bosch 4+ or BKR6E?
- Smog Test...
- Question about silicone
- What Spark Plugs should I get?
- anyone heard of emerged@aol.com making an intake
- Mystery object--Is it part of my car?
- What was it that Mr.D or Mance used to clean the IM?
- Before Pic; PS Reservoir plumbing
- We have one Audi wrecker in the entire Bay Area
- The interior door opener on the driver's side is going to fall off
- My results after using just one bottle of Gumout Regane cleaner.
- motodynes chip for the 12v
- Snubberama
- Need your opinion *important*
- When the crank is locked at TDC, what position are the pistons in?
- Mance, u get my mail about the B4 aluminum spoiler?
- I love VTEC in my Audi!
- Poopy pump........
- IAT sensor Location???(1996 A4 , 2.8)
- How To: allroad Tranny Mount Conversion
- X-post... the local Audi stealerships arent showing any recalls
- Headlamp alternative
- how much hp and tq can i get out of a 12v with the following mods?
- Old (blown) engine is coming home tomorrow...
- Anyone ever try this TB Linkage adjust?
- Anyone know of a supercharged 12v
- Does urs4 still sell his AA parts?...
- What to mod in order to change where the A4 clutch grabs
- rectal projectile
- Well guys, I haven't been here much lately
- Have any of you tried these headlight kits?
- Rain and snow in SoCal. Perfect Quattro weather...
- Is the post-cat O2 sensor with the green plug for the passenger or driver side???
- Mance you seen this? Electric water pump.
- Problems starting.
- My local dealer just tried to charge me $21.50 for an oil filter!!!!!!
- CEL-ebration! (not really)
- X-post to pics of Right Bank Direct Fire Coil conversion
- Thought you guys would enjoy some autox pix from the event I had
- I've seen this intake somewhere, anyone know where?
- Any ideas on the dbl click i hear just before the car starts
- Getting ready to install stand-alone engine management...
- Any news on the "Mystery" Spark Plugs?
- There's a 30V V6 forum now ....
- new '96 a4 2.8...need advice
- one more from topeka ks
- one pic from Heartl;and park yeah i am obvsully the a4 not the jag..
- So I'm getting some funny readings from my ARM1 A/F meter... lil help please...
- anybody using g-tech pros out there?
- X-post: Can anyone help?
- as posted on the A4 forum..ebay'd SC for 12v
- how much hp and torque could i expect from porting and polishing the manifold, new throttle body,
- new here... sry for the noob question
- So I took a hack saw and dremel to my MAF.....
- Anyone have a list of ground connections for the engine?
- Ahh, to bad Odelay, you could have had 4 posts in a row...
- for those tha have used the pagid blue pads have you had alot of brake dust from them .. i have..
- how do i check to see if the mobil 10w 40 drive clean is in the correct spec or audfi engines?
- how amazing just a simple alignment can make the car if it is out of alignment..
- How to: Adjustable Intake Manifold Switchover
- Do you guys think they can do this to an A4???
- How much HP will this give me.....
- For those of you that have changed your differential fluid on a 96 A4, is it the same as the 1.8T?
- Latest issue of Euro Tuner lists the Stasis 12V race car at (tested) 200WHP....
- mance, is that your hillclimb car in the new quattro quarterly?
- Which forum for info on 1.8T?
- Allroad tranny mounts. My opinion!
- I'm going to try the new oil fitler for the 1.8t's (068) for my next oil change. Any reason not to
- Does the Passat have the same 12v 2.8 motor as our 12v's?
- Pix from the off roading incident, as well as new oil leak pix :-\
- Replace two 2" cats (1 empty) with a 3" cat
- If someone can solve the MAF and slightly possible water-lock problem, you'd have a badass turbo 90.
- Hmmmmm, this is odd
- changing spark plugs tomorrow, should I reset the computer?
- A few pics of my S3 hose kit and S3+ throttle body before cleaning.
- Just received my Neuspeed rear Sway Bar reinforcement brackets...
- Mori; here's a progressive photo arrangement of ARX pre-treatment and current status
- To those who were looking for BG 44k
- UrS4, how's the ARX doing?
- Strange engine sound - looking for advice
- Wanted to buy: Splash guards for '96-97 a4...
- on a 96 a4 2.8qm do we have a bosche 5.0 or 5.3 brake system?
- Need new cats... please help. (XPost from 90 forum)
- finally had someone local mention a place european motorsports..
- OK what's this mystery box?
- going to get an alignment this week after replaceing my tie rod ends do we have power assist ..
- thought you might get a kick out of this.
- Well, we almost had one less 12v on the boards after my friday afternoon excursion...
- Sweet. Audi wins Manufacturer again.
- Does anyone know off-hand if there's a way to stiffen up the gas pedal feel?
- So.
- Do the MAF o-rings help it idle or run a specific way?
- S4 Exhaust Piping
- tail light prob
- Mance, did you get my mail about the CAI kit?
- All the talk about grades of bolts made me look into this issue
- With all this "mount chatter" going on....
- Adjustable Intake Manifold Switchover Teaser
- '96 A6 2.8 has a Timing CHAIN??? Is this true...?
- Update to Allroad transmission mount conversion...
- URS4, Any news on the LW lifters?
- Where is a good place to get B5 tranny mounts?
- Allroad transmission mount conversion...
- My Dyno Graph, for those who care....
- Now that I'm getting rid of my 93 90, what do I do with latest Bently &
- got my front tires to lock up today while bedding the pagids..
- Opinions wanted; would I be wasting my time by putting an O1E tranny in my 96' 12v
- Climate control blower working intermittently (sp?)
- best audi commercial ever dang was it funny...
- Tic, Toc, Tic, Toc, . . . Mance, how did you do with the tranny mount install this morning?
- Keyless Alarm
- if my abs controler is shot can i just unplug the 3 fuses for the abs and still run at the track for
- Valve cover breather hoses vs oil consumption
- Can't figure it out...
- Spark plug heat index and a possible effect on timing?
- Help in figuring out what type of 12v I have
- UPDATE Re: All Road tranny mounts...
- Saying Hello
- Scott12v.. Did you get your car road worthy so I check it out yet?
- Free/Cheap Parts: 12V Intake Manifold and assorted bits...
- What else could contribute to poor gas mileage other than MAF and O2 sensors?
- representin'
- For those 12V owners seeking stronger/longer lived tranny mounts...
- Mance, YGM -- Audi content (mystery spark plugs)
- Fluid service interval for(Q) manual trans?
- May be leaving the fold...
- get some bling for your ride....
- First autocross in my '97 A4
- UrS4 -- mystery spark plug Bosch F7KPP332S = VW 101 905 631
- Dyno Day Results, for those who are interested.
- tganci, I sent you an e-mail yesterday. Let me know if you're still interested.
- HELP guys!!!
- Wondering what RPM's i should be at around 70-80 mph
- I dont know much about metals and strengths so some help would be nice.. : )
- I'm playing with spark plugs, too
- replacing clutch soon, should I get something better than Sachs?
- While I dont know what these spark plugs are I do know they are DAMN GOOD!!
- And the winner of the lowest horsepower of the day award goes to...
- Hi all...not been around for a while and need a link....or some info
- Got some super-secret spark plugs for free to try under some very mysterious circumstances...
- What happened to AA?....
- Good wheel cleaner
- Going to the dark side...
- I'm putting my 16's on for Dyno Day. Is higher tire pressure better for higher HP numbers?
- New to forums, just bought a 12v a4 on ebay
- Mance. Do you know of any trusted online sources for purchasing small qtys of ABA Hose Clamps?
- Can someone give me a technical explanation of why we need backpressure in the exhaust?
- New noise...
- Will the driver's side valve cover on the AAH engine have the same mounts...
- Anyone have experiance with Koni coilovers on A4?
- Any regulars live near Greesboro NC?
- Anybody ever post anything and come back to check on it...
- Oil leak
- Am I in the right place?
- Well, my B6 Avant will meet its new owner tomorrow. Long live (I hope!) my B5 12V!!
- tick in the box
- Is the rebuilt MAF sensor thing only for the 1.8t guys?
- BG 44k?
- Mance, there any performance gains by picking the 3" in/out cat over the 2.5" in/out cat?
- Question about Intake Mani switch over (AGAIN!?!?!)
- How much would it cost (out of pocket) for 60k mile maitainance?
- I finished my swaybar links today. If you're interested I posted em over "there"
- Hey Mr. D.
- JET Performance - Amusing
- Failed Calif. Smog...
- Will 265/35/18's fit on and A4?
- Once again, the stealership is worthless, I need a part #, front door speaker grills, TIA!
- Car won't start !!!
- Just so ya know I haven't been idling my time away pining over the loss of my web site...
- is this chip a viable?
- I pulled my Beru spark plugs (paging JWG)
- Can someone tell me if they see anything wrong with this thermostat?
- Oil Pump
- Anyone take a actual caliper measurement of the "Special" TB wall before sending to Mance?
- mance, kinda off topic question for you...
- Anyone had a rattling sunroof?
- Q: will the aluminum valve covers of the earlier AAH motors..
- ended up getting the EBC sport groove rotors for the front and zimm oems for the rear..
- 00-02' S4: H&R/Bilstien Sport Shocks & Springs, fit a 97 a4?
- LOL, this is pretty funny. Dyno Excuses...
- canta4dit, I need you to e-mail me back. Hopefully you're on the net today.
- Anyone in a WA Audi Club?
- Can anyone give me the P/N of the sport steering wheel??
- anyone know what MMS 200 does with intermittant knock sensor
- Real nervous about pulling...
- RKing? Are you around?
- Ok guys the AA site is gone and I wont be renewing as forum sponsor...
- Heat index numbers
- Anyone in here done the A8 big brake upgrade?....
- Dr. D
- Ladies and Gentlemen, I have an adjustable Intake Manifold Switchover RPM.
- control arm bushing removal tool
- Exhaust for 97 2.8
- How do I determine if a cam is AAH or AFC?
- When I click on 1997 in the Wiring Diagrams of my Bentley I only get two engine choices ACK and ABE.
- so yeah, im an idiot! please help (long)
- what do our fuel injectors flow? Also what would be a nice upgraded flow for new fuel injectors.
- May be the cleanest and leanest O2 sensors I've EVER pulled from ANY Audi
- Not that I have any idea how the MAF works or how it's even related to an S4 maf.
- All XXTuning Dyno Day Graphs (& pics) are now posted for you to compare to your hearts content..
- a4 gas needle recall?
- anybody have a passenger side amber corner that i could buy...
