View Full Version : 12v V6 Discussion
- New wheels and BIG tires installed. Immediate opinion enclosed.
- Package arrived, it all looks great. Thanks Mance! As soon as it..
- can't ever find these in classifieds
- video i found in the deep woods of the internets..12v content
- Look ma! No separate hose joiner!
- $909.60 for plates... Good till August. Damn Quebec.
- Picking up PS/Pump today, guy at parts shop has 2 listings.
- pulled code 2331
- Engine noticeably rougher at idle and throughout rev range after VS install. Normal?
- HVRS Group Buy pic for the 12V Development forum...
- Long time no see, so how's the development of the 12V?
- strut mount install..
- Upper Oil Pan
- Mance, YGM! :)
- Remotes on 97 A4 (Our cars but not engine related so maybe a tad OT)
- At a dead end. Dont know what to do next.
- WOOHOO! New baby! and VS question...
- Pic Request: Breather Hose Mod for DIY Hose Kit
- #3 spark plug wet and black...
- 600cfm intake for V6 ABC / AAH
- jumpin idle, storeing code..
- Cooling System Leaks
- hey everyone
- One last little air flow/speed secret then I'm cutting you guys off for now... ;-)
- Ok, a quick down-n-dirty mini silicone elbow workshop...
- Anyone want to weigh in on this 3" tight radius 90 hose to use in a DIY hose kit?
- Has anyone heard of this?
- Paging BigAlk or any other European A4 (B5) owner!
- since all this talk about s3 hose kits..
- Interesting ignition improvement . . .
- Next time someone says they have an S3 Hose Kit, ask em to show you the S3 velocity stack...
- Recovery sleeve GP update...
- Does anyone have the write-up for the DIY Adjustable Intake Manifold Switchover
- Rapidfire 9s - Improvement over stock
- DIY intake question & answer thread - uh oh's and so on PICS
- These ducts look like they'd position nicely behind the B4 bumper...
- what is the VW/Audi part number for the big over sized (diesel?) oil filters that work well on a 12V
- 034 has some 90* silicone elbows..
- Rapidfire 9 users, what kind of mileage interval are you using with yours? I've got 30k on mine now.
- antifreeze bleeders?
- More timing belt issues - cams moved! 94' 90S 12V
- just started on my maf
- Would running high temp spark plug wires cause high nox
- Hey Remember my 12v rear mount turbo set up? Its Done!
- Engine running odd
- I'm at a cross roads guys... what should I do??
- High Flow cats... what's out there for 12v?
- 471A vs. 471C MAF - Any benefits to the C?
- akimoto
- Timing Belt/waterpump replacement? dealership says 100K, shop says 60K, book says 60K
- oil leak after timing belt maintnence....
- I had a long 4 weeks, but the car runs again . . . (a long post to make-up for read-only viewing)
- No Heat / Radiator Flush?
- 12V chassis poll results after 4 days...
- I just found a few emails from some of you guys
- WOOHOO! New 12V! What goodies does Mance have available lately?
- Alright, I just made my Mance payment, who else is left?
- DIY maf on 95' audi 90
- 12V chassis Poll. Which chassis is your 12V?
- yo CrazyCab
- 272 duration camshafts... Where are thou!
- Hey guys, are we still on schedule for the 1st on the GB?
- Please help with steering issue...tia
- Cam follower replacement
- Oil Leak
- Ok... I already STF but still can't find the info on the DIY Hose kits...
- Well as I am told that there are no stupid questions...here goes.
- Any folks with a VAGCOM in the Los Angeles area on the forum? If possible...
- Question for all the IM P&P Done-Did-Its...
- Hey Mori - you heard anything about a fully synthetic M1 5w40 "ESP"?
- trying to locate the heater valve??
- timing belt tensioner torque 45Nm? is this correct, seems very tight for M8?
- The Recovery Sleeve GP may have to be postponed or suspended...
- I may be parting out the blonde, wondering peoples experience with selling tuned 12v...
- Did you see this thread???????????????????
- 96 a4 2.8 throttle position sensor?
- What type terminals are on the alternator?
- Repost from B5 forum: Drivetrain problems, part two.
- got a question regarding the cleaning of the inside of a Intake Manifold...
- RS3 MAF and VS are in.
- before I go home to check for my extra EGR temp sensor..does anyone know the specs on the threads?
- Is the Split Second A/F ratio meter still the meter of choice?
- Picked up some VW throttle bodies..... adapting them to my 12v
- air leak around IAC valve.....
- Mance recovery sleeve group buy (6)
- X-Post from 80/90 Forum...............
- I noticed today when nearing my destination, my engine was revving to 1500rpm without me touching
- Abnormally Aspirated Still Around???
- can I use RTV for the IM to IM gasket (no gasket..just RTV) ?????
- need some IM 12V parts
- Catalytic converters?
- Mr.D has retired from the forum, right?
- Anyone have their power seat fail?
- ISV help. constant stalling.
- Poor Heat - Low flow - Bad water pump?
- x-post (Attn: Mori and other oil guys)
- Intake manifold
- x-post
- MIL Bulb Replacement
- Very large power loss at higher rpms
- Needed: 12v V6 AAH in the MI, OH, IN, IL area for pickup *soon*
- I am un able to locate NGK or RF 9's in the town I live in. Any other spark plug reccomendations?
- IAC valve fit problem. My IAC was bad and the replacement
- Anyone have maintenance intervals for a 1996 A4 2.8?
- 36-38 lb injectors, I need some. anyone got?
- Contemplating mix and match with 2 A4's need advice
- I think I am having coolant circulation issues? Oh and WW on the chick in my sig.
- Yo Dragon-Ryder: YGM menng.
- Amsoil oilless cone filters
- What are the potentials??
- exhaust????? questions and ideas
- Chip (new info....I think)
- mis firing, lack of power, bad engine vibration under load. The CEL
- What is the level of difficulty replacing the O2 sensors? Best source for them?
- Anyone have a used but working throttle position sensor? I'm in need...
- no heat after timing belt.........help its 10 degrees out!!
- made an interesting discovery last night about the IM butterfly screws
- Where can I buy a camshaft position sensor?
- yellow goo on inside of motor...help!
- If I think the blower motor is shot, can it test by vag-com to verfiy?
- Hi! Anyone have Mr. D's link to the IMW? Can't find it.
- Location of gage temperature sensor for 12V 2.8 V6
- Oil pressure light....
- Tips/suggestions for installing ARM-1? Pics of installation/wiring would be great!
- MAF write-up for part number ending in 'A'
- Does anyone know the part number for the valve cover screw? I have a AFC engine if that matters.
- Cylinder Head Workshop
- should i part it out or just get rid of it whole?
- Poor Mans Throttle Body Mod
- &!$%....sprung a coolant leak....
- '97 A4 12V 2.8 quattro auto MPG 17
- What is it?
- Oil Leak
- UR Flywheel
- Will a 2.2L throttle body fit?
- Timing belt tools - Looking to borrow or rent
- IM Workshop files?
- xpost from b5 a4(timing belt question)
- Mori... you whore you ;)
- Crankshaft timing belt sprocket
- Oil Pan gaskets
- Will a Purolator L30257 work for a 92' 100?
- Unknown connector
- need a clutch for 96 A4 2.8
- Well after 6 years happy motoring and almost no faults it's the end....
- The status of my car after three years of ownership. And where to go from here.
- I am having trouble uploading a picture. Anyone else?
- My 12v is supercharged
- Anyone have 12v heads for sale? Mother-in-law's A6 AAH/AFC popped teh TB.
- professional advice on cams...
- what differrence would an aftermarket fuel pressure regulator have on a stock engine?
- What's up old 12v board! Here is something that will get your blood boiling........
- Another MAF question =)
- Mance parts?
- How do i remove my traction control system??? b5
- OK I got me some dielectric greese for my plugs...now how/where do I apply it?
- Anyone ordered one of these direct-fit cats for B4Q? They are not OEM, but fit in nicely.
- Differential Drain Plug - Solved:
- Manual transmission/differential fluid - where can I get it?
- What would you do...?
- Does anyone make cams for this engine
- yo islingtonaudi, have you seen these oil caps that go with your nice new shiney valve covers??
- Drain Plug help needed
- So I just changed my oil. I noticed that the small vac hose that goes under the drive side breather
- Where to get G12+ Coolant?
- Here's something a little different...(you might need your shades, Mori...)
- So...Ignition Coil most likely cause of no-spark on 12v?
- Recall JS (Ignition Switch), some '96/'97 A4
- Doing some homework... anyone willing to lend or rent me the 12V timing belt tools?
- Anyone have a photo of the 12V Throttle Position Sensor (or its location) handy?
- Hi guys!
- I have a motor from a 1995 90cs with only 7700 miles on it
- For those who have glyptal in there IM or else where in your engine
- Help w/ my '92 100CS - serpentine belt tensioner
- 2.8 12V vs 2.6 12V, just how similar are they?
- IS300 1, 12v 0 clutch slipped bad into 2nd. I think we would have been even otherwise.
- $90 for a plastic hose???
- Help with manifold vacum.
- 1996 A4 Quattro intake manifold
- How about this 5W40 Mori?
- X-post reference 4 wire to 3 wire MAF sensor conversions on a 12V
- For those who did the Head/Im workshop what grinder/s did you buy?
- Old reader new poster.. Schrick cams?
- Big Mouth .. Akimoto WHERE!?!?!
- poll: a4 owners with s3 hose kit.
- oil pan removal and reinstallation
- single 2.25" cat too restictive?
- Got new exhaust on, cats backward (CLIP inside!)
- Car stalls at idle different code though
- Small crack in my air box....Is it a big deal?
- first ? Induction mods worth it?
- Updated serpentine tensioner x-post
- Hey Doug ((islingtonboy), thanks for the RapidFire 9's, glad you have some laying around!
- How can you test if an EGR valve is bad?
- What are these numbers printed inside the intake runners on the head?
- Trying to remove EGR valve for cleaning
- strange idle after cat/o2 replacement
- Anyone have any cam profile data on the stock AAH cams?
- Anyone need a 471A MAF with sensor?
- Could someone help me identify a leak? noob ---->
- 15 degrees this morning and car is parked outside.
- AAH cam belt change
- 2.7tt
- Anyone know of a good source for black anodized hose fittings? I'm going to convert my...
- Power loss, HELP!!
- Supercharging?
- Looking for built engine,parts,transmission, etc...
- Here's a guy putting a turbo in a 2.8L.
- so after replacing my HG i have a loud Tick coming form the middle of the block?
- My non-technical oil consumption findings/fix ... thoughts Mori?
- I noticed an oil leak behind the oil cooler, any idea on what's leaking?
- Where can I find some cheap parts?
- Heads are off. anything cool i should do?
- does any have a 471A MAF??? I need one.
- 1pissed90- after seeing your dyno thread I am wondering if your redline is still at 6300 if so why
- Are rapid fire 9's the same as ac delco 9's?
- Coolant is brown and leaking..
- spark plugs
- mpg is down after running the s3 hose kit, any ideas why?
- Does anyone have a write up or link to do the tranny mounts? I only saw tranny mounts for the 1.8
- I was just stfa on some 3 to 4 wire maf sensor swapping questions and came across this
- got board last night so i removed my MAF screen to see if I would get a cell.
- Is the seal on the sunroof one solid seal or is it cut ?
- Coolant leak
- Oil filter mount (12V engine) - can this thing be replaced?
- Bow-chicka-bow
- Difference between a 30v and 12v engine and car?
- FLASH interior!?
- Uh...stupid question regarding the APR snub mount
- how tight do the O2 sensors have to be??
- Does this forum have a moderator?
- Anyone successful in fixing the cruise module?
- 12V Performance?
- on a similar issue regarding the throttle boot breather tubes...
- so close..yet so far away.. how the heck do i remove the breather tubes from the throttle boot?
- anyone know a good place in Canada to get OEM 12V plug wires??
- explanation of Bosch ECU....
- Anyone with a fully-modded-NA 12v planning on a dyno run?
- Cheap low end?
- Rough Idle, hesitation and 'jerking' when lifting off throttle......
- I think I have found a new place to order parts....................
- got a problem with the clutch
- Overheating problem, any suggestions?
- Mance, have you had time to check if the 3.0L block is compatible with 12V Heads ?
- just wondering if this 90 degree silicone elbow (X2) will fit for my intake project?
- Yo Mr D...Did you get my reply email?
- are the spark plug wires from 96 97 98 12V A4's the same as the ones in a 12V 90?
- 3" silicone pipe intake question.
- Website for supercharging the 12v....................
- 12v Trigger set up
