PDA
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. Sunroof motor compatibility/rewiring?
  2. Headlight adjustment
  3. D2 17114 trans code, limp home
  4. Bad vibration from the rear axle
  5. 2002 A8L front suspension
  6. Installed old trans known thought good not taking fluid not moving qheels
  7. Code P0192
  8. S8 headlights like a candle!
  9. 2019 A8 will not shift into gear.
  10. Windows and wipers
  11. 2008 Audi A8 - Stream music
  12. 2000 A8 D2 front bumper damage... end of the road?
  13. Replacing LEDs in power window switches
  14. A8 D2 2001. Cant open trunk/ central lock pump disconnected! ​​​​​​​
  15. 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
  16. S8 D2
  17. BG: AUDI S8 D2 Problem TCU
  18. CA: 1997 A8 at local junkyard - anyone need parts?
  19. Audi S8 wiper reservoir / airbox
  20. 2015 A8 Quattro “Steering Wheel Defective” message
  21. O2 Sensor not reading.
  22. Anyone have a PS rack / pump for 2001 A8L?
  23. How to determine if A8 or S8
  24. S8 Purchase or not
  25. Swapoed to a 6 speed. Looking for login to trans for adaptation
  26. S8 Akilles heel
  27. Pinch Bolt Size
  28. Timing belt lifetime
  29. D2 S8 No start after trans fluid flush
  30. 06 quattro key issue
  31. BA: Audi A8 D2 4.2 220kw (ABZ) engine coolant temp. senzor G62
  32. Cluster LED panel replacement
  33. Cheap Final Edition 2002 S8 in the UK
  34. Cam lock bar
  35. Humming/growling noise near alternator
  36. Both low beams out
  37. Rear headrest motor
  38. A8L Quattro 4.2 2012
  39. Belt tensioner igniter??? D2
  40. UK: HELP coolant level warning issues, A8 2D 2001 2.8v6
  41. Not turning on Audi a8 2006 L model
  42. Carplay Head Unit in a D2?
  43. Correct injector?
  44. Audi A8l w12 coolant issue
  45. iv a 05 a 8
  46. MIL is on
  47. FR: Disque ventilés
  48. Headlight range control
  49. NO: Castrol Transmax DX3 on 4HP24A (CML) gearbox
  50. LT: What is this metal plate that fell out of my intake manifold?
  51. S8 fuel tank
  52. Question about installing aux led light bar on a 1997 Audi S8
  53. New housing and brakedisc does not fit.
  54. Audi A8 D3 2003 3.7V8 wipers/windows/horn not working, cockpit/lights/heater/radio
  55. S6 PLUS / technically S8
  56. a8 d2 transaxle fill
  57. Letting the ‘98 A8 Quattro go
  58. Wiper Relay - where is it?
  59. FR: Fuite liquide et huile
  60. 2001 S8 Boot/trunk Help
  61. Help with MMI - "entertainment is being initialized#
  62. Help confirming the fan clutch is my problem, plz...
  63. A8 D2 Windscreen HELP!!!!
  64. Interested in buying an S8 near me. Some questions
  65. S8 2002 fl d2 won't crank
  66. ABS Module won't accept code
  67. 2013 A8L faulty air vent actuator
  68. Seeking a D2 PS rack and pump
  69. Fog light grille
  70. WTS: BNOS OEM D2 S8 mirror frames/assy (R+L)
  71. Upper and lower radiator hoses
  72. D2 S8 long crank
  73. Roof rack
  74. SE: Hand brake not passing inspection
  75. WTB: headlight screw cover
  76. should I buy?
  77. A8 D2 3.7 Q sport fuel wiring diagrams - please help
  78. 97 A8 stuck in park
  79. 1999 Audi A8 rear wheel bearing
  80. NL: Passenger mirror dips too much in R
  81. A8 D2 FL Menu control switch removal help
  82. European Spare parts ordering
  83. G28 sensor part numbers or pictures anyone?
  84. Some stuff to get rid of
  85. Car Died While Driving 35mph
  86. Driver's Center Armrest Won't Go Down.
  87. D/S marker lights on with ignition off
  88. UK: High Oil consumption
  89. Digital clock
  90. Memory seats + adjustable mirrors
  91. Glove box replacement 2004 audi a8
  92. S8 D2 wheels and set up
  93. Immobilizer Delete or Bypass
  94. D2 A8 L - Added a subwoofer
  95. MMI erases favorite and shorcuts
  96. 2001 A8 Electricity issues
  97. Anyone near Ira, MI? (north of Detroit)
  98. Can't get the gas pump housing to connect to the hose for second tank
  99. Symphony II CD 6-disc Changer Help
  100. 2009 audi a8l 4.2 master rebuild kit
  101. Oil pressure specs for D2 S8?
  102. Windshield molding
  103. Rear Drive Shaft (Support Bearing) 2001 S8
  104. NL: Bent valvles
  105. Broken connection?
  106. Driver door window regulator source?
  107. Recode A8 D2 with HID Xenons to Halogen to remove cluster errorvlight
  108. 2006 A8 Rear seat Air bag, light is on now.
  109. What to replace a D2?
  110. D2 S8 eibach springs
  111. Hey my headlights wont auto level. Audi A8 D2.
  112. 2001 S8 Restoration
  113. RIP Follow up; Now in Pick/pull yard
  114. HVAC died
  115. Any recs for good shop that knows D2s well in Boulder, plz? Looks like Apikol moved..
  116. ZM: Lost communication with power steering control module
  117. Catalytic Converter
  118. B8 S4 brakes on D2 A8?
  119. Headlight Switch
  120. Instrument cluster- light sensor pin lost
  121. RIP
  122. 2001 S8 Subwoofer
  123. Urgent advice needed
  124. fuel lines and fittings
  125. D2 S8 front bumper HELP!!!! PLEASE UNITED STATES!! PREFERRED NOT OVERSEAS!
  126. RO: Audi A8L W12 production numbers?
  127. POWER STEERING TIGHT
  128. 1999 A8 quattro Front outer CV Boot
  129. A8 D2 front bumper body kit to look like d3
  130. coolant exp tank mounts
  131. Coolant tank mount
  132. Do I Need VAG COM to clear TCM DTC codes?
  133. 2001 A8L
  134. Wiring diagram or pinout for headlight control sensor 4b0907503a
  135. NO: If anyone has ideas or tips for me. (Quattro swapping my FWD Audi A8 D2))
  136. Seat heater mods
  137. Big black blob on audi navigation screen
  138. ZF Tranny Experts, please HELP!!
  139. 2007 Audi A8 D3 FSI 4.2L
  140. Front overhang protection
  141. 2016 A8L relay heating issue
  142. 02’ A8 Codes after Transgo Valve. Please Help!
  143. 1999 A8 SWAP TO A 5 OR 6 SPEED MT
  144. A8 4.2 40V supercharged
  145. my A8 won't start after battery went dead
  146. headlight swap
  147. rear window defogger
  148. Long cold start
  149. NZ: Seized motor, 4.2L
  150. Mysterious issue with locks, interior lights and doors
  151. Oil pressure switch location?
  152. Where to get Engine Mounts?
  153. Affordable Bumper/Valance Options
  154. Fule assembly cap tool
  155. UK: New D2 Owner! HELP HELP
  156. My former S8 now on FB Marketplace
  157. getAudiparts.com | Your 2021 Black Friday/Cyber Monday Savings are HERE!!!
  158. 2001 Audi S8 any help or info would be appreciated
  159. Steering wheel wiring termination
  160. Cigarette lighter socket
  161. Indicator/blinker housing interchangable between models?
  162. Hooked up jumper cables backwards now 99 A8 won’t start…
  163. Transmission Leak 2003 S8
  164. RNS-E Music Information Not in DIS
  165. Help with camshaft position sensor code P1347
  166. Safe way to start these cars that have been sitting for a long time?
  167. UK: Cambelt Change.
  168. TIMING Covers
  169. Audi A8 D2 with hydro pneumatic suspension
  170. Car menu button not working.
  171. Wheel stud conversion?
  172. 2000 A8L Fuel Tank Removal
  173. 5HP19 downshift problems.
  174. SE: HELP Audi 4.2 2000 jerks between 1300-2000rpm
  175. Need a door
  176. Unknown Connector
  177. UK: A8 Chain HELP PLEASE
  178. 1/2 gas tank shutdown
  179. Problem with Electric fan ABZ engine
  180. cluster issues
  181. 2002 Audi A8
  182. A8 stainless Steel exhaust
  183. Locking issue
  184. UK: A8 coding?
  185. FL car phone?
  186. PIF in Classifieds: Nice 98 A8Q, free to good home
  187. Audi A8 facelift xenon headlights
  188. Help with brakes servo suction pump
  189. all gear indicators & all door open indicators lit, no crank
  190. d2 dual fuel pump experiment
  191. ICM Delete and FSI Coil packs
  192. NL: ABZ oil cooler delete?
  193. photo ids
  194. Thermostat replace
  195. 2000-2003 headlights
  196. SE: Blue smoke only on decelleration
  197. Old member, new login
  198. Junction box with starter cables
  199. misfires on bank 1 and cam sensor code
  200. Transmission going into safe mode
  201. Transmission gear return problem
  202. Coolant Leak near Radiator Drain Plug (2003 A8L D2)
  203. ETC failure
  204. Fog lights
  205. D2 FREON AND RECHARGING?
  206. Transmission solenoid issue
  207. Mystery Wires Under Hood
  208. UK: Low Compression
  209. Joining the club!
  210. Oil warning light comes on at certain RPM/speed
  211. Orange wire in the boot
  212. Audi S8 4.2 Supercharger Options
  213. How do I shut off the solar-powered vent fan?
  214. Help with the Brake light switch
  215. D2 S8 paper weight
  216. 5HP24A Pressure regulator valves -options
  217. Stainless Steel Flex Pipes purchase on line?
  218. Engine ECU
  219. Proper way to flush the heater core
  220. Rear brake caliper
  221. Driver Door Lower Molding Clips
  222. Leaking coolant from heater connector?
  223. Prefacelift S8 ESP problem
  224. right front turn indicator assembly
  225. S8 D2 Only firing on 3 cinders
  226. Confusion with coolant temperature sensors/switches
  227. UK: Bentley/erwin workshop manuals?
  228. Which ECU? Help appreciated
  229. Anyone have a rack and pinion assembly to sell?
  230. Timing belt parts?
  231. Help with heater control valve and AC
  232. S8 O2 sensor 2 wiring goes inside car?
  233. HELP: Hazard light/ blinker relay
  234. Need help
  235. Can anyone tell me what part go’s here I’m looking at a friends car no nothing about
  236. Good Power Steering rack (A8-D2) for sale?
  237. Facelift transmission into pre-facelift car
  238. IT: A8 D2 Accident repair
  239. Trunk door locking motor
  240. EGR engine light
  241. Drivers side back door glass, anyone?
  242. What's it worth? Definition of excellent
  243. Brake Pads
  244. Boston Meet Up
  245. 32V V8 Upper Radiator Hose
  246. RPM gauge is wrong, too low
  247. Been having issues with theses codes for awhile now
  248. 4.2L overheated
  249. A8 d2 190,000 ?
  250. Only passenger side heater blow hot air
