- Inner Tie Rod End
- Wheels wheels wheels........
- I got the bent wheel blues =(
- VAG-COM versus ROSS TECH
- Tranny question...
- So it appears it's a wiring problem or F125 switch problem
- Sugestions for best roof rack/snowboard rack combo?
- Who's Avus Silver S8 did I see yesterday about 2pm getting on the Taconic..
- Wonky Gas Gage
- 98 A8 Totaled, have left over parts (control arm kit, trans filter, etc.)
- I feel like I just found $3500.00 on the sidewalk!
- Fuel Pump Follow
- airbag light randomly came on last night....any thoughts?
- ABS Warning
- A8 Recall for transmission cable
- Huy Guys, what do you thisnk about the Hyundai Genesis? Everything I read is great..
- Hey Gabor - How's your calendar look?
- 2000 A8 Interference Engine?
- NAPA has audi control arms...who knew?
- My Car is at the Detailer's
- How many A8's will pass the 200,000 mile barrier?
- Bell underneath the car in reverse, sometimes in D too.
- Anyone have a picture of the D2 A8 executive edition center console?
- Paging pkrasusky - Ill be in Hartford Monday through Tues afternoon if you want to grab some beers..
- Arrrrgh! A8 is entirely covered in tree sap! Anyone know of a good, paint safe product for removal?
- Friday VAG Yuck for Geezers.
- Tranny drain plug replacement - opinions please
- frozen lug bolt
- More bits of info on the 5HP24 - anyone already see this? 6HP26 vs 5HP24
- 2001 A8 Window motor replaced with A4 part
- 98 A8 For sale in Denmark Wisconsin
- Tozo I have a question
- Finding led tail lights.
- OT (a little bit) what's the best mobile NAVIGATION system to use an A8??
- The morning creaks are gone - at least in the S8. A double wiping with silicone lubricant...
- What is a "breaker" D2 A8 worth in parts?
- 2000 A8 TRW heavy duty tie rod ends
- Getting My Car Detailed this Weekend
- What's the status on the facelifter + RNS-E ? Still no BIS-navi possible ?
- Tip: heavy key-chains shorten the life of ignition-switches.
- winter is coming in Alaska
- Hey PaulW, does your PRND light up different?
- Is there a relay that controls the fog lights/
- Million HP Salute - remembering a friend
- Suspension: difference in "spring buffer-blocks" ?
- PK, and other interested parties, you has a mission ..... drive fast in VT, legaly! (see inside)
- Thanks to whomever wrote up the headrest fix procedure and pics!
- Anybody know if a wiper transmission from a '98 will fit an '02?
- Air bag light update.....
- Alternative x-pipe position
- "Self correcting" imbalance
- Sloshing sound behind dash when a/c on
- R8 Photoshoot Video
- S8 stock shocks/struts...how long they last?
- Details on my Buy-To-Order car program. If you are looking for a used A8/S8, please see inside.
- Any 97' owners interested on a tiptronic shifter assembly?
- Hard start after shut off.
- HID
- Would it be a bad idea to use the amp turn on wire to power my ipod adapter?
- Took every fuse out of the panel, check them all, they're fine.
- Can anybody use a trailer hitch w/ lower rear vallance included.
- BMW cylinder head
- 97-99 Front Spring Replacement Procedure
- Anyone here from Connecticut ?
- Control Arm kit for 2001 A8?
- My transmission whine is fixed
- Free to a good home.....4 OEM 16" rims & tires....
- paging Paul W
- Engine Swap
- Fog lights will not come on. What say ye? Fuse?
- Leather Cleaner Recommendations
- NAC ~ Let's play name that leather:
- Brake Pad Warning light after replacing pads/rotors?
- superrrrsprint
- Anyone know how many channels the stock amp has on a pre-facelift A8?
- 01 S8 for sale - Manheim PA - info inside (NO RELATION...just passing the info along)
- Finally found something about the A8 that I don't particularly car for.
- Did that group buy for the dash rings ever go through last year?
- Left front window motor wanted
- Beautiful black A8 4.2 for sale - Netherlands
- Introduction and a Photo of my S8
- Does anyone have a spare TPS? (old, used)
- Bad Cat???
- RS6 anyone?
- Hunting / Torque Converter
- S8 FOR SALE!!!!!!
- 40V intake manifold (IM) jammed vacuum actuators, removal notes.
- 2001 S8 Transmission Failure Signs
- Audi Extended Warranty Group Purchase, see inside for details if interested
- Installed Tozo'd VB & TPS - hunt is gone, no highway dropout...have a question though...
- Help. Radio removal tool sheared off in head unit...
- Less expensive option for nice performing exhaust? 928 Porsche OEM
- Big Red Brakes - BIRA Contact Info? Who can Clear Coat?
- 2001 S8, 60k..services up to date exept plugs, trans redone in 07.
- are the washer tank pump grommets available as separate parts? Mine is leaking and I don't see them
- transmission swap appears to be a success! (long)
- Oil goes down, value of used A8 goes up?
- suspension component thunk
- Tozo & some others might be able to make sense of these pics/diagrams from a ZF repair kit.
- Anyone here live in Connecticut with a vag-com ?
- CD's hiss. AM reception poor. What gives?
- Anyone know the bore diameter of an A8/S8 rotor?
- My dad needs a trans on his A8, you guys used this guy on ebay?
- tip 'o the day - squeaky control arm
- Ciggy lighters won't
- What's supposed to be here? missing some sort of trim piece. And I tried on some OEM wheels.
- So lately my car sounds like its not running on all 8 cylinders...HELP
- How to remove 3rd brakelight cover when sunshield is installed. Cannot pull the cover backwards.
- EPC light on and no throttle, getting these codes. All buttoned up and ready to roll!
- Rear electric sunshade
- ODB II scan tool(from local auto store) shows "(MIL) is off" and ...
- Warning light update.
- Thanks Gondar! Now Gabor, Paul or anyone...S8 dies after starting...
- kudos to the list
- Brembo vs. Lucas front brakes
- I need Gondar's help!!!!
- looking for wheels in Chicago/NW Indiana
- can anyone run a carfax for me?
- gps, navigation problems
- 142 mph in speedo and still climbing before I let off due to exit. Planted and solid as a rock.
- transmission is installed, not quite right though
- Key stuck in ignition after breakdown
- Question for those with aftermarket xeons -
- should i buy it?....
- Newer ETKA for XP?
- the D2 vs. the D3
- Replacing Door Mirror
- timing belt 90k or 105k?
- 98 A8q partout in Boston fyi
- PaulW, did your rns have these side bars?
- timing belt issues in the 40v engines?
- What are the main relevant changes between a D2 and D3?
- Fuel Pump Replacement Costs
- intake manifold (IM) jammed actuators, saga continues
- body kit(s) for the d2, STFA to no avail
- strut measurement - I lost track of your post or email :)
- Replacing 125mm mirror with 175mm
- any European members have the electric tray table option ?
- Is it normal to hear air movement at the master cylinder as the brake pedal is pressed?
- Brushed aluminum shift trim mod. Pics inside...
- Rear caliper won't go in (be rotated and pushed back)
- New wheels
- OT: Never steal cars in an unfamiliar neighborhood.
- has anyone changed a rear main seal on a 4.2? There's a reference in the Bentley about a "dowel"
- Vag.Com
- Unburied.
- electronic issues after body work
- Can a McPhearson spring-tensioner of 1000kg compression-strength, pull A8 springs together or..
- Intake manifold (IM) actuators jammed/finally unjammed
- pic request: 20" B7 rs4's on a d2
- Why do I have a slight whine after transmission service?
- Got my Tozo'd VB back this morning....need hardware advice....
- RNS-D questions
- Crazy tow Idea....or is it?
- Trans Oil Change pump
- rim question
- starter hookup - Paul, read your post about connecting to the wrong solenoid post
- Warning light help, please!
- Winter Tires
- DIY alignment
- Bosch ABS "brain" rebuild/replace
- Transmission Information :Tozo! ;-)
- ****Hartford CT GTG - New Date - Wednesday, September 17th
- Forced cabin air circulation - How does it work?
- specs on custom s8 exhaust?
- Ignition Control Module/POS - which is which
- I won 1st Place at DubFest 08!!
- when do tie rods/control arms need to be replaced?
- intake pic
- tie rod ends & control arms
- Riverside Audi
- //S6 Plus Avant - anyone 'interested'?
- ***Postponed, 9/9 Hartford CT GTG, due to weather.....new date to follow
- Audi replacement fuel pump failures
- Stupid Questions, (New owner with NO manual)
- New noise under hood, what is it?
- I have 3 codes. 591, 592, 1044 incorrect software code.
- 40 V intake manifold --jammed actuactors, disassembly of IM-halted
- So my fuel gauge read empty on a full tank once agan. I had replaced my fuel level sending
- For the tranny specialists: a tip from across the big pond
- headlight leveler alarm
- what kind/type of fog light do we use? (face lift) h3?
- Talk about lesson learned
- proper name for the pie plates?
- Is there a substitute for Mineral Oil
- I am looking for a green bumper for a '97 A8
- Key Source/color code
- Remaining lurking for now with a new V8q 5 gang
- Whoa! The THUMP! revealed
- In an attempt to get rid of those morning squeaks as the chassis settles in...
- When is enough enough?
- Have 18" wheels for sale with tires made by RH!!! 12" tires in the back!!!!!!
- Transmission control function: Perhaps only Tozo has interest
- my elaborate transmission fluid filler
- cool...turning the steering wheel causes 'rubbing' noise...
- Advise please....Now that my interior is all torn apart, I am taking the...
- I guess I can go ahead and order my new S8.
- 2002 S8 shuddering. Im scared of what this might cost
- A8 stock strut/shock lengths
- Anybody tried to use a TT MFSW?
- Another RNS-E install with questions
- Changing oil on the D2 for the 1st time got 2 questions?
- Temperature Thumbwheel on Dash ??
- mass air flow
- Vavona wood saga
- So...I slammed the brakes around 70 mph and the car left a 15-20 foot skidmark on the left side.
- So, one major hurdle cleared- head was able to be fixed at the machine shop. It is now on it's
- ECU defective
- Changing rear discs and pads. Does handbrake need adjusting afterwards. (Pads are almost gone)
- OK, another S8 coming down the line for sale (sold the last two S8's)!
- 99 Trunk Lid won't seal, opens itself on bumps wtf
- interesting reading (MP's replies in particular)
- Are there any repair manuals for the A8?
- Vibration in rear
- Gentlemen... HELP...How do you get the %^&*$# drivers side AC vent out?
- Stainless brake lines?
- 19" Tire Offerings
- NAC: Watkins Glen - Vintage event... freebie crew passes to the first callers
- Assorted Questions / Inquiries for 2002 S8
- Week 2 Update: Ferodo DS2500
- Tozo....got a A6 4.2 slushbox sitting around......I'm losing reverse, failure is
- new brakes for next week
- ZF Valve body rebuild
- Where do you guys buy CV boot?
- FYI: Failsafe thermostat at autozone, pn 7304-192, $20.
- Spacers cause vibrations. I give up...
- looking for Cashmere A8 L
- Who here is going to Road america next week for the Audi event?
- OEM timing belt supplier : 2000-2001 A8?
- //SFest '08
- Does anyone want to see an F clutch repair?
- Anyone elses brakes go to the floor after not being used or being on a four point lift?
- Can TB be changed without renting tools on 01 A8?
- eng conversion
- From our BMW friends regarding Transmission service
- Harsh kickdown
- '03 S8 transmission..vs. 02/01 S8
- V8/S8 owners
- paging paulw and kynz
- CRAZY TRANSMISSION?
- Road trip
- '97 A8 Ignition Switch would not turn off engine
- ***Reminder, Hartford, CT GTG - 9/9/08***
- Help...First time post
- High Mileage anyone? my '02 is up to 195k miles now, still going...
- x-post: Spacer Sizing Tests
- S8 rear brakes on A8 ?
- NORTHEAST AUDI End-of-Summer JAM.....3 weeks away!!!!
- Replacement Nav Knob ?
- Dear S8: Where have you been my whole life.
