PDA
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. Transmissions and Cruise Control
  2. Bi Xenon retrofit?
  3. is quattro 50/50 or 40/60 or..........I'm talking front/rear output...I know, uneducated,etc etc
  4. Hey PaulW, since the new susp in Oct, I have been driving, ahem, more agressively and worn out
  5. I truly apopogize for my "taking photograph through peephole" comment...
  6. What Fuse?
  7. New Codes and Vac Tube Replacement
  8. Another couple of questions...
  9. Looking at getting an D2S8. What are the differences between the years, and...
  10. 2 more questions...
  11. Hey PaulW, do you have a remote control for bass level?
  12. S8 Suspension or coilovers for an 1997 A8
  13. Long but worth the read
  14. What ohm does the stock stereo run at?
  15. Coolant loss...no overheat...exhaust gas (block check) positive =Head gaskets...
  16. How would one go about tightening the front door woofers?
  17. Facelift clear corner... :-(
  18. How do you block a laser jammer?
  19. did you kow about this product????
  20. A8 1998 3.7 Missfire cyls 5 6 7 & 8 - running out of ideas.
  21. transmission probs
  22. Heineken mini-kegs are a blessing-curse disguised as the obvious.
  23. How many original D2 S8 owners here?
  24. Transmission issues how do I contact Tozo?
  25. What type of Vacuum Line do I need - 01 S8
  26. how do you remove the whole ashtray assembly?
  27. 2001 S8
  28. Anyone know how to determine if a wheel was made by Hartmann?
  29. New Transmission has 500 miles on it how do I get it recoded to shift better
  30. error codes
  31. Radiator replacment
  32. XM logo part 2
  33. falken 452's up or down - what say you??? i'm talking 245 45 18
  34. Sillyfast - Did you have time to get an audio clip of your new exhaust mod?
  35. Tools for 92 cs100 water pump change (I know this is d2 but you guys are the best)
  36. Ferodo DS2500s - installed. Many thanks to Randy for his pad comp. data, as...
  37. Which audi's has everyone driven ( Does not have to be yours)
  38. 6-speed manual conversion
  39. spare fob
  40. Hello Everyone...another new guy
  41. B5 S4 guy looking at a S8 and have some questions...
  42. Help wanted! I need a better switch setup for my fridge.
  43. Just a thought!
  44. PSA: reminder regarding scams
  45. Another one bites the dust.....
  46. Tozo business opportunity?
  47. Oil leak
  48. ok - pulled some codes on the sensor. I thought this was an oil "level" sensor?
  49. Does any one else wax their rims or am I just ridiculous?
  50. I think I did a bad thing......
  51. I finally took a long distance cruise in my S8...what a treat!
  52. snow snow snow.....
  53. Auto transmission torque converter lock up problem....
  54. Suspension Needed
  55. Factory D2 roof bars installed.
  56. Cheap D2 that runs $3,900
  57. help with wheels please-A friend of my daughter who is building a drift car has offered a swap deal
  58. hey..... pkrasusky !!! how come your sig doesn't have Exxon in the picture??
  59. brake light signal
  60. found fluid on garage floor from back end of car-any ideas?
  61. no it isn't!
  62. chipped ecu
  63. oil pressure warning light - update:
  64. Top Speed ?
  65. Oil change thanks audipages.
  66. 02 sensor location
  67. Well being thousands of miles from the US I have now met two AW members
  68. 98 Passenger side mirror noises
  69. TCU question
  70. minor facelift
  71. 98 Audi rear Air bag light is on , need help to trun off/ reset
  72. Well, there's a pile 19" high of snow on top of my bird bath.
  73. Check out this "S8 spoiler" Ebay ad! LOL
  74. Sebring 2008 Club Shirts Now Available for Pre-Order
  75. pics will be posted soon
  76. S8 pics
  77. headlight leds
  78. new tires and wheel spacers
  79. anyone have the ability to create a DVD?
  80. Is 89 octane ok to use on the 4.2 motor?
  81. hewbie here
  82. New (to me) S8
  83. This is why I love my A8! (sequel to "This is why I love my S8!")
  84. Two D2's in the stable!
  85. Best complete timing belt kit
  86. I bought an RS6 -- S8 anyone?
  87. Crank no start update: Everybody check your ecu NOW!!!!!!!
  88. Some Jerk door dinged me last night...Paintless dent repair?
  89. Paging Perpetual Novice. Do you have a wooden shift knob in your car?
  90. 99A8- can I dremel a clear corner?
  91. HELP...I'm leaking oil like crazy!
  92. What's up with the defog.
  93. 2002 S8 engine cranks but would not start ?!?!?
  94. S8 engine misfire
  95. Opinions on 3rd party warranties
  96. Why is the D2 more suited for owner maintenance versus the D3?
  97. This is why I love my S8!
  98. Pricing for a S8
  99. Check engine light came on the other day. Any help to understand is appreciated. TIA!
  100. Anyone with an S8 experience paint/finish peeling from the front brake calibers ?
  101. Grill Question
  102. Lets play name that part
  103. what is the best way to replace the front axles?
  104. A8 GmbH "Individualized" and "Security" Brochures Now Available!
  105. How are the door moldings (upper and lower) removed?
  106. Anyone seen my TPS reports? Does this happen to be the TPS in the A8? I don't recognize it...
  107. I broke my own record. 1hour 50 minutes for tranny removal out of a
  108. Crank with no start. Codes inside. loooong
  109. Woot!! New MAF and Vac' Hoses
  110. What is the general consensus on tranny filter kits, I understand from earlier
  111. Re: 6 Speed madness is spreading
  112. thanks
  113. Tires
  114. anyone removed there belt driven fan for an electric one?
  115. Trying to use an iPod with my RNS-d
  116. getting ready for a May DE here in the midwest
  117. shock questions - kind of long
  118. Tozo'd VB and TPS
  119. Isn't this beautifull?
  120. Looking to buy brake pads...need help?
  121. Where to find a used water valve and aux coolant pump unit? new/ used? anyone parting an A8?
  122. ordered the vag-com and bentley, however ...
  123. Need to get a filter/gasket for my tranny....
  124. now i'm scared...tranny issues
  125. Need new driveshaft...or used i guess
  126. Manual 6 speed madness is spreading!!!!!!!
  127. has anyone purchased their vag com used?
  128. Ride Height? - '03 //S8 sits 1/2" lower on front right than on left. Likely suspect(s)?
  129. Need help with DVD graphic for XM /Nav Plus use
  130. cutting the rear muffler out of the exaust
  131. :: ECS Tuning :: Eibach Pro Spring Kit - Last One In Stock - ON SALE !!!
  132. Hello
  133. Anyone in Miami? Doral area... If so, would you be willing to check out a set of wheels for me?
  134. Anyone need some salt? I'm glad these things are aluminum.
  135. Well after two years as an AW'er Ihave compiled a lot of PDF files and
  136. Rear armrest black hole
  137. Now What? :-| I seem to be losing brake fluid...but I don't find any on the ground.
  138. arm rest
  139. Level sensor replacement write-up
  140. Fuel pump arrives this week.
  141. S8 Transmission Swap
  142. Speaking of Power Locks
  143. Just installed my new Grom ipod interface
  144. Power Locks problem
  145. D2 S8 or D3 A8
  146. A question about inspection in PA
  147. 2001 Audi S8 Fog Light
  148. have you seen or tried these brakes for a8 98??
  149. bilstein shocks
  150. Oil Leak...basically after sitting for 2 hours, I have this much oil on the ground....
  151. Component Question
  152. '01 S8 oil filter help
  153. So I bought a Rosemeyer over the weakend,
  154. Don't drink and drive! Even if ...
  155. Update on no heat to the cabin
  156. Transmission Hunting
  157. vacuum lines
  158. Anyone else have/had problems with the steering wheel adjustment controls?
  159. big white cloud of exhaust ....
  160. water in back seat floor board ....
  161. Audio Upgrade Options
  162. Lost Vent Cover
  163. Cheap.....
  164. Hung w/ some locals today and found a new S8 buddy
  165. Wanted! Left & Right Front Bumper Face Plates
  166. Anyone know the difference between 32v head fasteners and 40v head fasteners?
  167. Fixed the Blower Fan problem! It was this relay #203. But the diagram (FR: ricoblanco) does not..
  168. Thanks to PaulW.....I just fixed 3 headrests
  169. FS Cruise Control Switch fits 96A6 & 97A8
  170. A8 Braking issue
  171. Idle issue; occasional stutter/hiccup, but no stall..
  172. Is there a D2 online buyers guide available?
  173. Track Wheels
  174. what's going on with the Audi A8 marketplace... prices have plummeted
  175. Is Audipages.com down Paul? Or is it my PC?
  176. Very Surprising Car spotted (teh uberAudi)
  177. Heres a new one to me. on my battery, the cable has fused itself to the + terminal.
  178. Coming to Indy Monday and Tuesday. Does anyone have any recommendations on...
  179. Starting a new thread...see below my HVAC fan stopped working.... where is the blower FAN relay?
  180. Hey, blacksan, how's your transmission service going?
  181. MD S8 Sighting
  182. Anybody have a pre facelift black antenna base?
  183. CEL light and sputtering
  184. clear corners found on on EBAY!
  185. POLL: How many listers are previous Audi owners and what models?
  186. PW-My driver's sport seat has a phat lip :-(, any suggestions.
  187. Strugglin to get shift lever into Park position... zoinks.
  188. Paging PaulW please pick up the yellow courtesy phone...I upgraded...
  189. Im officially in the market for an 02-03 S8. Lemme know if you have any info....
  190. What's the sticker on a S8 again?
  191. Help. :-( My HVAC fan no longer works. I was unclogging the drains and got about...
  192. How about this one. No wiring required :)
  193. CEL diagnosed...I think
  194. what do u guyz think about WOODEN steering wheels??? are they comfy??
  195. who has a phatbox in their 1997 a8?
  196. Warranty extension on Coolant sensor
  197. GPS Satellite Reception Problem
  198. Installed my Tozo'd TPS lastnight...still having some issues
  199. Are the prices of 2003 S8s right?
  200. OK, who was driving a black //S8 in Wheeling, IL just now?
  201. Fodder: in the Advent of Today's $13-15k '01 //S8... what 'floor' are we thinking might exist for...
  202. Steering assembly u-joint
  203. D2 Quattro GmbH (Individualized) and Security Brochures Anybody?
  204. Lookin for wheels again
  205. Exhaust work done... love it.
  206. Alright I give, why does the driver info screen flash 2:00h?
  207. HELP! windshield replacement - (long)
  208. Track Brake Pads for 323mm Setup A8
  209. Look at this douche.
  210. Gasoline smell.
  211. Cold Air blowing through vents -
  212. Rear Bumper Repair
  213. Speaking of D2's with 20" rims; prepare to laugh/cry
  214. Hey JAZBO. Do you work on your car yourself or is there a reliable indi in the Cuse?
  215. rear windshield - defrost lines?
  216. Going to buy an A8 4.2 Quattro 1996
  217. 2001 S8 Flashing CEL saga... LONG -- TOO LONG
  218. Body SHop BooBoo on my fr.turn signal...
  219. a8 transmission
  220. 97 A8 fuel pump prices
  221. 2002 head lights in 2000 (problems please read)
  222. New Rims for my S8
  223. What is the clicking noise from under the hood when you leave the key in the on position?
  224. Lately the cabin has been "inhaling" short ...
  225. Help Please - Longish plea describing conditions...Gabor please if you would read this
  226. What is the life expectancy of a pre-facelift transmission?
  227. Parting my 1997 A8 quattro... black, chrome package, solar roof, and list of misc. items
  228. Cheap 01S8 and 05A8
  229. To trade or not to trade... Advice guys
  230. I just realized that pkrasusky talks like a lolcat
  231. Is that true: AUDI KEYFOB PROGRAMMING PROGRAM REMOTE KEY REPROGRAM.??
  232. I need a shop in Orange County Cal
  233. 250 miles and my gas light came on - Anybody "beat" that?
  234. 1998 Audi A8
  235. Greetings from NOOB (long)
  236. rotor / pad GP didn't take flight, however, please reference this for Brembo / Ferodo purchases:
  237. Very nice V10 S8 D3 around town of late-soooo agressive from the front
  238. Remove center console cup holder??
  239. made the lower bumper grills, and question about cd changer....
  240. WTF! Who has the S8 in Gainesville?
  241. What is the range after the beep goes off and the yellow gas pump light goes on?
  242. Torque converter failure- What to do?
  243. A8 fuel pump
  244. For TwinCitiesS8-picsof Garmin ppc mod [from post below]
  245. Alllrighty - I'm finally asking... WTF's with 2nd-and-a-half gear???
  246. S8 most likely being traded in next weekend. Please email if interested
  247. Meeces - WTF to do to rid them thar varments from me underhood bits???
  248. Engine Error Code (Cylinder 7 Misfire)
  249. Update on possible oil cooler leak...........
  250. Subwoofer Update after 4 weeks
