- Okay I need my 01 A8L gone.
- Damn A8!!!
- engine mystery..... ideas?
- OMG!!!! my belly pan is missing!!!
- what is the INLET that is on the front passenger side of the radiator??
- So, ~ 40 S8ers raised their hand. ~ 20 leaky lumbar past or present.
- Back from Chicago and Trans is best it has ever been
- Anybody seen these wheels before?
- Vag Remote Coding for 03 S8.....
- Nitrous Install, De-Chroming, and Wheels on the S8
- if you fall asleep in Starbucks your friends will fuch with you. justsoyaknow.
- Poll - How many S8 owners are on this forum. Please, even if you know I know you raise your hand.
- OT: I would never have thought there was a guy with the exact same flag as me.
- someone in need of a facelift bumper should snap this up
- Anyone here from Gainesville? I saw a black A8 today and a silver one the other day.
- Tip mode in 3rd ~ 4K revs, stab brake, down to 2nd making left at light, get on the gas and BAM!
- audi a8 1997 1998 1999 all parts
- Techron + trans recoding works well!
- One week left on S8 ultimate pedal group buy- only 2 more orders needed...
- almost a week since getting tozo'd ...
- Tire size question
- I have a stupid question. Looking into the coil shaft there is a spring-like connector...
- POL about shift points. What do you guys think.
- A few pics of the A8L at the DE that another KC club member took
- oxygen sensor O2 sensor 2000 AKB 40v installation notes how to
- Have the D3 transmissions improved enough to improve longevity?
- anyone know of a good source for a cam chain tensioner for a 01 A8 4.2?
- How would I take apart the front door panels and fix the exterior lower trim?
- Does anyone happen to have a post-facelift front bumper 'blank' insert?
- Speaking of lowered, does this one look stock or lowered?
- Anybody have side shots of there car lowered on either B&G springs or H&R?
- Paging tozo also
- Thinking about ordering B&G springs...thoughts? opinions?....
- Test drove a 1999 A8 today...
- I think I asked this before but, does leaving the key in the ignition on position do anything?
- Anyone have an orange side marker? The buffer took care of of one the tabs.
- Paging Tozo!!! I need your (& Eddie's)! help
- Does anyone know if the 07 S8 wheel will fit on the 01 A8?
- transmission woes...
- S8 Leaky Lumbar Third Request. Comon guys, would you *please* send me your contact info?
- Very interesting X-Pipe design and info... what do you guys think
- I need ideas for front license plate
- Update on plugs
- Finished the wheels!
- OEM CATS - off a 2000, think they're the same for other years (don't know if "L") matters
- WTF, WTF, my stumble has become more pronounced, farting and spitting.
- Protective film for S8
- SKIRACER FBSers - help me help you/us. I dropped a quick note to my Recaro POC and...
- opinion on grills.....
- This past weekend's DE experience - these land yahcts are awesome.....(very long)
- 99 A8 hit a deer
- Engine rev's hunting
- Anyone have
- Sportec ECU and TCU Chips
- Another '01 S8 coming up, silver, 83K miles, good price. Anyone looking?
- solenoid screens on the transmission?
- KYNZ- trying to email you back but your hotmail address is getting rejected.
- OEM CATS - email me if you're still looking. Just took off the DR side, doing pass side now.
- Positive reinforcement for checking things on my car when I'm bored....
- D2C vs. D2S xenon HID headlights
- 17 x 7.5 '03 A6 5 Spokers on DC Craigslist $350 - no affiliation just passing it along.
- To all that responded to SKIRACER'S FBS Poll. I will be drafting a note to the Recaro POC and...
- I have a stumble at idle in Drive, I guess because it's under load.
- The itch is starting all over again...
- 2000 A8, has transmission been updated on those?
- Premium or regular ?
- So I got a chance to take a ride/drive in a pretty good condition '03 CL55 today...
- Can anyone tell me whether a 28mm offset will have rubbing up front under suspension load?
- Paging PaulW - S8 satellite radio conversion question
- Re: that x-pipe, didn't somebody install one of those with no problems?
- hey I have a great idea. Lets make a critical engine part out of plastic and then
- H-Pipe Delete, X-Pipe in, Video and more...
- Where is the best place to buy a fog light grill cover for a D2 facelift?
- don't you think it's a bit to much?
- Car going in for tranny fix
- Paging Tozo: YGM
- that ONE oil cooler bolt is ruining my day.
- Magnaflow X-Pipe dont work so well
- S8 owners- do you suffer from FBS*? POLL!! (Edit- please post even if yours works-thx)
- S8 2002 Trunk Leak
- Need advice: Transmission has lost first gear and needs replacing
- VW tech said that there was no damage to the GLI motor...
- Control Arm Project (Special Tools Required?)
- Got the Ross Tech Software and This is What it Said...
- Hub Centric Spacers...The 10mm ones I got for my 03 dont fit......
- I got a response from Recaro on the lumbar support. Full e-mail text included here...
- R8 with normally aspirated V10 seen testing...
- Wheels
- Maintenance - Electrical Related (behind the glovebox)
- Noise - Any ideas?
- Misfire codes - just run Techron through the system?
- So, do you like the new paint job? Interior is under construction.
- new interior ?;s
- Went to install the 10mm spacers from the recommended source and.....
- What should I unplug to make my fuel guage read empty, even if it's full?
- If I had $900 to thow around......
- S8 TRANSMISSION FAILURE???
- Anybody in the Chicago Area with an 02/03 with OnStar want to Try OEM Bluetooth?
- Paul ... Re: D3 FAQ Digest
- getting tozo'd this weekend....
- Stealership strikes again.
- A8Q European shift program
- I might be dumb enough to try the HHO on my car, with gas at $4/gallon. I did...
- looking for wider stance.
- 03 S8 Ipod Integration...This kit works perfectly in my car....
- How long has your rebuilt transmission lasted?
- Remote coding - Vag-com
- front end noise
- Get Your Red Recaro Interior Here!!!!
- Looking for Los Angeles area service centers S8
- D2 A8/A8L/S8 FAQ Digest Up and Running - We need your help!
- ABS Light On, ESP OFF Light is On following a weird unexpected braking while accelerating...
- Steering rack failure caused by lowered suspension?
- A8CT
- Recommended aftermarket additions to 2002 S8
- ryoung: Here's a pic of my strut/MC. As you can see, it would be hard
- thinking about this new mod. what do ya think?
- front axles
- ZF to offer 8 speed slushbox
- 40V timing belt question... Chain tensioner covered under Great Lakes Silver Warranty and I'm trying
- s8 air filter
- 2002 S8 transmission
- Does anyone know how the front door window switch panels come off?
- Paging A8CT: Do you still have your intake manifold?
- Rattle Can Engine
- Any way to get set of nav CD's besides walking in to dealer and bending over?
- Brake Block=Hell of a difference in braking!
- I never use the key to open the trunk so today I tried it just for giggles...
- Retrofitting an S8 wheel into a prefacelift A8, aka the 'I has funktioning tip buttons mod'
- Exhaust thread? what has anybody does as far as exhaust's goes on our cars? i wanna do one asap.
- Has anyone here attempted to refinish their rims using this process?
- 130K Mile A8 Fix List; Inputs wanted
- Recommended Service Intervals...
- Clear Stone Guard Stuff
- oil changes, where do you usually go?
- Hands Free Phone Interface in 2003 S8
- Anyone need a steering wheel, airbag, and self cancelling ring fro a '99 A8?
- So what is the desired offset range for the D2? 28-35mm?
- Thought I'd show you guys some video of our Southeast 77 car Quattro De Mayo event last week
- what type of signal is sent via the ecu to the tachometer?
- OK, who wants to put an S8 tranny it their A8?
- Back! With an S8.
- Three questions...
- fuel pump removal tool?
- Angus - Here is your tiptronic steering wheel retrofit procedure
- Front rotors replacement
- This is what my //S8 looks like with 20mm spacers...
- oil leaks on s8 pre facelift engine
- Ok I'm gonna beat a dead horse. Tire size for 18" rims, 245/45 right?
- Aluminum mod.
- fully loaded front brake calipers (single piston - '98 thru early 2000)
- Starting problem
- Check out this post on the D3 Board - sure sounds like "hunting" to at least two of us
- AC Expansion Valve. How to check? Or do I even need to?
- the eagle has landed..... got the car back
- Cleared all codes- why is my CEL still on?
- So did it get deleted?
- Off to the Fatherland...
- Hybrid A8 - Hoax or No Hoax????
- Windshield Sun Shade? My new gig's parking lot is uncovered so...
- Funny how I don't click on those exhaust and suspension posts any longer
- flashing lights
- Anyone going to Carlisile next weekend?
- H&R's for S8, who's got em?
- Paul or somebody... X-Pipe source?
- Arrggh! Transmission pan gasket!
- Brand New S8 Owner (Own 1994 URS4 as well........)
- Cheap Facelift D2( seller going Green LOL)
- Anyone need great condition black full-alcantara interior?
- hey PW - can you recall what size this is?
- holy crap airbag screws are tight
- Ben I want a brake block but my emails to you keep bouncing back!
- tranny saga continues.... (go figure)
- Rattling/Clacking on cold start - Cam chain tensioners maybe? Pro_Imports sez...
- Tozo- I'm getting a little impatient waiting for the promised photos.........
- Conflicting wheel offset info............
- New A8 in the fleet........
- My list of things to do.......
- Well -a different perspective-for the last month or so my son has been learning
- Audi A8 Electical issue
- My Speed Detection Countermeasures... 2000 A8L *video*
- Anyone here in Salt Lake City? I need a car checked out.
- codes codes damn theses codes
- Squeaking Steering wheel fixed! Clicking gone too!
- How to replace pre-cat o2 sensor? I don't like the Bentley answer...
- Gabor, this has your name all over it.
- Audi to buy back A8s with tranny problems @ 1.5x KBB exc. cond. retail price
- A6 estate 1998
- finallly got pics of new wheels, what do you think?
- oh wow, now THIS is a nice steering wheel
- TimD - did you find an insert? Maybe this one will work for you...
- Can someone tell me the pin assignments for a pre-facelift S8 instrument cluster please?
- Help with hands free cellphone 03 S8 (long)
- Tinting done, Technical Inspection done, Brainerd International Raceway here I come, can't wait....
- Wanted: 18" D2 S8 Avus Rims
- 235/45 's on 17 inch rims?
- got my hoffel rear bumper, taking the car in for quad exaust like svens!
- FWIW I just sent the enclosed note to Recaro. I will also reach out to HBL per Chris' note.
- CAPTION CONTEST >>> Factory Approved D2 Replacement Jack:
- A8CT - Troubleshooting G266, Oil Level Thermal Sensor
- anyone have step-by-step instructions on replacing out a passenger side fender?
- Saw a black S8 in Lexington KY last night. Anybody here?
- Lumbar supports ...
- Folding mirrors on the blink...any suggestions on root cause???
- Incredible! Did anyone see this near crash of an R10 last week? (Video on bottom of page: see link)
- Fixed codes 16687 and 16684
- Just hooked up VAG-COM for the 1st time
- BW's custom cat-back kitty cat.
- OT: GM, Marketing & Business Development, VW Group
- Pre-Facelift lower grill options.....
- the girls this morning. also a comparison of prefacelift on B&Gs vs. S8 ride height.
- wanting to put a tip shifter wheel on my a4 i know this is the wrong forum
- hey all, question about used A8s and S8s in the states
- Any adverse effects of wheel spacers on the wheel bearings?
- I need a 40v intake manifold (Guy with the silver car that just burnt?)
- You guys must go and see IRONMAN on the big screen.
- if I get my car back... I want to take the wheels and suspension off. How do I move it around?
- Rear Window Lockout Switch - Flashing Yellow?
- '01 S8 brake question, Brembo or Girling front calipers, how to discern?
- oil level sender - a "little" progress.......
- as long as were on the exhaust topic
- Quad Exhaust fitted.
- my A/C is blowing warm air (again) from driver side vents
- Another successful "The Block" install......
- questions about headlight mod - reflector removal
- Angus - The Eagle has Landed!
- Alarm question...
- Paging PaulW. Please, do you remember the size of this bolt?
- Possibly parting my 1997 A8
- Does anyone have a passenger's side lower plastic grille piece (pre-facelift) and
- A6 estate 1998
- Group buy on D2 aluminum dead pedal - details inside...
- My Tint isn't Very Dark
- A6 estate 1998
- Need ideas/opinions (maybe orders) on my parts car......
- Clear Corner Mod Complete - Guess I don't have to worry about Bi Xenons
- S8'ers: Conti ExtremeContact All-Seasons 245/45/18 $139 each @ TireRack w/free navi unit!
- Anyone have one or know a source for a silver 03 S8 front license plate insert?
- Paging RicoBlanco re. Cruise control...
- Hate to trade in our babied 01 a8l with 799XXk miles
- does anyone know what this does? It's making a horn type of noise which goes away if I move it...
- Wheel offset question...
- PaulW, do you have more pics of your tinted windows? I am getting mine done next Tuesday at 35%
- PaulW, I'm amazed and grateful.
- Screeching mystery solved! Thanks A8bil!!
- PaulW once again you have inspired me!
- Procedure for retrofitting S4 tiptronic wheel?
- How hard is it to replace the carrier bearing on our Driveshafts? is it even do-able?
- Ladies and Gentlemen, Riverside Audi's Online Parts Website, AudiPartsDepot.com is now live!
- Anyone know the 03 S8 stock wheel offset? Anyone tried spacers yet?
