- A8 hitch
- So I'm getting a P0304 intermittent misfire in cylinder 4 only.
- A gradual whistling noise from the front end.....
- Not the usual build quality-Saw this in China last week-probably not from the factory
- CO GTG next week to celebrate our Hungarian visitor as he escapes midwest floods...
- Anybody wanna help me go shopping for track wheels and tires?
- Paging TOZO...
- Warranty discussion
- -------------->A8CT<-------------
- 10.5 width ET30 wheels in the front of an S8, how well would it work?
- Couldn't find this in the search, and it should probably be quite obvious, but which cylinder is #4?
- rotor dilemma
- my A8 is almost ready... dying over here
- I need some phatbox help
- X-Post: Detailing forum wasn't much help, maybe someone here can assist
- Heater/AC Fan Solar Sun Roof Power
- Wow. A lot of complaints on the D3 board about clouded window trim.
- Probably The Door Latch Right?
- A big "Thank You" to Pearl 8 for the intake runner repair pieces! They fit like a charm!
- "auxiliary heat"
- has anyone changed the driver side, front diff output seal? It's the only one I haven't done before.
- Any sources for polished exhaust tips?
- My dome light has started to slowly blink on and off.....
- Any Phatty wannabes may want to jump on 'em as they seem to be drying up...
- Looking for 348 Ferrari together with my A8
- Timing belt idler pulley
- Who has 32V timing belt tools for loan/rent?
- what about this one for a signature pic?
- Spark plugs for my S8?
- On the cost-effectiveness of a proper VAG-COM - objective data only please
- HVAC Fan Dash Noise
- Speedometer/mileometer
- wood shift knob. For Your Interest
- Ok one more try... What the hell do I do Code- P0441....!!!!!
- What do you guys think of these?
- Paging Tozo ( and know it alls): trans swap question
- vag-com not reading abs/airbag module. Any suggestions?
- VMR Wheels | Brand new V710: 19x8.5 +35 Available in July! Pre-Order your set now!!
- My 2003 S8 overheats with AC on when stuck in traffic
- Pre-facelift armrest (passenger side) black.
- someone help...is this a dual exhaust kit or what? i hope yes!!!!
- Instrument Panel Trim Removal?
- Leaking A/C cheap, quick fix. kinda long
- Paging Ben H... pls pick up the white courtesy phone:
- Urgently Need stock 6 spoke S8 rim will pay$$$ Heeellppp
- Odd Limp Mode Part II
- skiracer, did you take a test drive to OK City with the new sub?
- Worth consideration?
- 2002 A8L - Best Hands-Free Option
- Suprise during transmission Valve body inspection
- Water water everywhere...
- Trying again.
- OK, how do i place the sig. pic?
- S8 drive-by next to UCD - anyone here?
- Guys check this out I am sure you will enjoy it.... I did
- Question................?
- washboard feeling on shift from 3-4th
- Need Help paging PaulW again or any one else that can help!!!
- The easy way didnt work, windows still squeak, how do I disassemble the doors?
- Nice color
- Help with Fan Blower Motor?
- Any light weight car cover recs? Also thoughts on scratching the paint with daily use please.
- paging Paul W............
- 2001 S8 - no reverse. Thoughts?
- OK subwoofer guys- I'm getting ready to install a subwoofer in the trunk.......
- Source for A8 pie plates? I STF and did not see any place to get them. TIA!
- Couldn't help it. This is the front. All my bottom grilles are wire mesh although you can't tell.
- Towing with a D2 A8/S8
- Transmission advice
- Odd Trans Limp Mode problem
- 20s on a D2??? (A bit long)
- low side adapter for recharge
- has anyone found plastic arms that work for the intake from a hobby shop?
- HVAC error codes
- Detailing tips
- s8 manual conversion?
- Link to pics of the land yahct at our May DE at HPT
- Bertone Cobra 5 speed (NAC)
- I realized that i have seen pictures of everybody's car and I have not shown you guys my humble A8
- Battery Help
- Sold the car...some leftover 1999 A8 Parts...
- Transmission output seal
- Headlights shiver + warning light on dash
- Variation on a Theme -- Tranny fill device
- Paging Tozo . . .4.2 slipping in Reverse
- OT: I think I see where Chris Bangle is going with this...
- A8 Sighting at Pro-Imports
- weird issue ?anyone experiencethis? diagnostic guru's
- For years I've wished I could get rid of the shine on the leather on my front seats
- How do you fix a squeaky window and sunroof?
- does anyone know if the Front output flange seals are interchangeable?
- Great googly moogly! Facts about Meyle:
- Any of you guys ever run your car in the 1/4 mile? if so what time did you run?
- paging Jim's 03-S8... how'd you ever make out wtih your GLWC claim for cam chain tensioners? I've...
- Honestly, I want my 1998 A8 to go to a good home..... Read on....
- I have a quote on Ferodo DS2500 pads for my 99 A8... $117 set/front and $76 set/rear.
- A shocking and amazing discovery.
- Water leaking from trunk lid...fix ???
- Several Problems
- (O) ligtht came on while driving on the freeway.
- Fuel consumption
- Any interest, 97 A8 for sale? $3800
- Part# request: motion sensor switch - '01 S8
- OK, here's a wacky/fun HVAC problem
- Anyone looking?
- where is the best place to get a ac compressor asap?
- Front wheels noise
- my weekend, the picture version. (aka, the guts of an audi)
- no longer elite?
- Supersprint Exhaust
- Opinions on switching to conventional oil?
- Valet story. Long
- Sloshy Sloshy center venty
- I just did the low side recharge on a facelift car. It was on the very low end of "full"
- Seal it up.
- A8L at SFO Saturday - anyone here?
- 24 HOUR FATHER'S DAY SPECIAL 18% OFF
- A8 body kits
- New A8 owner!
- Nice deal for AW forum member or recommendation on '01 S8 - see inside
- Fault Code - 01203 - Electrical Connection between ABS and Instrument Cluster
- Todays Transmission Fluid Flush Adventure
- The great car seat debate rages on!
- A big thanks to PaulW for the help today!
- transmission thump
- Anyone have a cure for a Limp rearview mirror?
- Replaced blower motor yesterday- only warm air today
- transmission
- i'm feeling a "clicking" vibration in my steering wheel
- benefits of stainlesssteel brake lines
- Memory seat controller
- Is it just me or do S8's shift differently when going uphill?
- is it possible to lower the headrest manually, without taking out the rear of the seat to access
- This post may receive the "duh of the week" award but check ur tire pressure.
- "memory seat"
- Carrier-to-Housing Bolt on Rear Calipers - Size and Type?
- Road America, Elkart Lake WI, Badger Audi Chapter, Sept 7-9.... I will be there, anyone else?
- The S8 is GREAT, but.......
- ABS light on, Brake light blinking
- So am I the only one who is all thumbs with TIP? I also seem to...
- '02 A8L window won't roll down...motor clicks when I press button
- Thinking Ahead For Fun and Profit
- Radio static
- Boston Area AWNE GTG - Wednesday, July 16th - Chili's - Burlington, MA
- Tozo maybe another challenge for you....
- Paging RYoung to the White Courtesy Phone
- i want to make a a8 look like a s8
- audi a8 aircondistioning problem
- has anyone here replaced a headliner?
- Does the D3 bumper covers for both front and back fit pre facelift cars
- Fellow Phatboxers, has this happened to you?
- Common DTCs associated with bad vacuum hoses in facelift A8's
- TB change follow-up: water pump noise and coolant temperature higher than before
- 3rd Annual Colorado 14er Climb!
- Carbon fiber trim almost finished.
- Any Vag-Com'ers in the DC/NOVA/Maryland area
- Phaeton brake-cooler mod on A8
- Can a Dutch guy come over and play ?
- OT: you hardly ever see one of these anymore.
- Anyone interested in (2) 10mm hubcentric wheel spacers with the correct size lugs?
- 01 S8 for sale....no affiliation.....
- Audi Expo 2008 - It's almost here!
- Hey PaulW, I may take you up on your offer...
- D3 rims cheap
- On the topic of leds maybe one of you more electronicly inclined gents can help me
- 2 problems
- INCOMING...
- in case anyone is looking for LED interior bulbs...
- I bought another D2....
- stupid question
- Anyone know how to remove the phone cradle from the facelift armrest?
- Oil Level Light
- 2001 S8 transmission fluid change
- wheel/tire question...
- Does an MTM chip make sense?
- Left over parts for 2000 Audi A8 upper and lower grilles.....
- Wow, his transmission lasted long.
- Echoing Sr. Waterloo - the sub ROCKS! Facelifters on the fence *must* do it. Best mod bar none...
- I decided that I had enoug of the brake squeal.
- looking for a front bumper A8 98
- Clay Bar and Never Dull
- Is there a "VAGCOM-able" calibration variable for speedometer accuracy?
- Hesitation Question
- Best place to buy a o2 sensor? my front right one is gone...need to replace it
- i hate birds!
- OT: Auto-monogamy.
- 2001 A8L Dual Exhaust Tip conversion....?
- Fault code.
- does someone have the metal arms for the intake (front of engine, plastic ones that always break).
- ABS light/Sensor wire malfunction! HELP!
- Is it a bad idea to mount tires at home?
- HEY PAUL W I NEED SOME HELP!
- i never knew that the mirrors on my s8 adjusted down inreverse...plesant surprise
- I pinched the nipples but still have water in the rear.....
- Anyone have problem with OBD and Vagcom communication with installed after market stereos?
- Hey Tozo, are you accepting orders yet for the 6MT conversion?
- Sub-woofer install finally completed and the difference in sound quality is amazing...
- A8 Quattro For Sale-Needs transmission rebuild otherwise mint.
- just finished timing belt change: 5,6,7,8 misfire and MAF code, doh!
- supporting A8 off the ground.
- Disk rotors
- can someone tell me what this plug is in front of the radiator??
- Visiting the Big Apple
- Cannot Open Hood
- Compressor pictures, leaking A/C.
- Anyone running the Ferodo DS2500 pads without slotted rotors? Noisy?
- a/c troubleshooting
- My wife got her first glimpse of an A8 last night...she called it an "old man's car"
- My AC Vents Temp Varries by 25 degrees from one side to the other.
- Scammer warning
- Along the lines of the infamous Lunch Meat Post, where on God's green earth is the fuse for the
- I recharged my A/C about two weeks ago, air is starting to get warm again.
- One more order needed by Friday for D2 S8 group buy on aluminum mod...
- new brakes installed
- OT: A salute to a pair of professionals.
- water, water in my hvac
- crazy kid!
- My observations on the belly pan, so far. Thanks to A8CT
- bose amp & 2 rear speakers, stock exhaust and OEM suspension (newer) ready to go
- A8 available for parts or repair
- Losing weight.........
- Black S8 and silver A8 in Hooksett NH
- Help with RECHARGING AC system!!!!
- battery vent
- er, so was this one of the important hoses..?
- Cost of Ownership? Maintenance and Repair? Am I Just Lucky x 2?
- Better Grille Picts
- Stuck Hand Brake
- 2003 A8L w/Nav... looking to add sat. radio, what is involved, possible?
- best way to jump start
- 2001 A8L starts then dies immediately....
- Lump in throat -Maybe Im going to quit the A8- sadly I am not using so much now and
- Leaky Leaky - oil and water, oh my!
- Hands-free phone question
- Advice on crankshaft locking for TB replacement
- Slight oil overfill...
- what kind of fastener are the head bolts? I can't really see down in there.. size?
- What would it take to hook up the standard gps system?
- Dry shot plus CNG?
- Update on broken electrodes. Miracles do happen.
- Most Expensive Cares to Repair-- article
- 10mm Spacers Installed.....
- Video clip showing sound difference from H-pipe, to X-pipe to Balance pipe
- TB Replacement! Input needed!
- Wheel question for the masters
- 2001 Silver S8 now availablle in aisle 6!
- Engine mount needed
- Anyone parting a 4.2 engine?? I'm looking for a used cam chain tensioner,
- pics of new grills, fogs/running lights and lip spoiler and new rear valence
- Just in!!! MAF readings from my 03 S8............
