PDA
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. In the absense of Wendy....
  2. all tip'd now waiting to fall
  3. Rear differential service
  4. Navigation Cd's for 2001 S8
  5. right corner light on ebay
  6. great a8 on ebay--cheap for the miles??
  7. WHAT are two big buttons on the wheel??
  8. Anyone discover what happened to Wendy?
  9. AMS Holiday Year-End Clearance!
  10. Help On A High Pitch Engine/Trans Wining Sound
  11. Need right from turn signal lens assembly
  12. Black S8 spotted this morning 11/2 I-90 Eastbound near Ashtabula Oh...you here?
  13. Anybody sell oem or replica A8 18" 10 hole wheels online?
  14. 17546 - Fuel Trim: Bank 2 (Add): System too Lean p1138
  15. engine code
  16. Exhaust smell getting pretty strong. What's up with that.
  17. Alternate way to polish and seal chrome mouldings
  18. Foggy widnshield
  19. Pic of my A8
  20. See Børge drive his A8 in Norway. It's the edited 5 MB version...
  21. Transmission issue - worse in older years?
  22. Steering wheel swap?
  23. stock springs rates
  24. 17" rims street price
  25. how far you from fairfield, ct? i just got in for this saturday
  26. Grrrrrrr. The earliest available slot for an alignment at My dealer is 3 weeks. 11/19
  27. Eagle F1 GS-D3 or Potenza S-03 Pole Position 2002 A8L?
  28. Potential new tools to "Jack Labs"
  29. Brahma, could you post a wav clip of how your car sounds?
  30. ventilation question
  31. Short movie of me pulling away in the S8 (V8 grawl) (new screenname btw)
  32. HELP: Guide bolts for caliper carrier stipped...
  33. New to the S8 family...
  34. Anyone in MN, ND or SD have a VAG Com that...
  35. What kind of wheels are these? Very cool!!!
  36. Could use some Fault Code help 16684 & 16690
  37. Window?
  38. Head rest fixed another way!!!
  39. 225 55 17 New Tires on the Market
  40. heater control valve and hoses...
  41. 99 A8 Coolant Issues/Type
  42. G-Tech Pro Numbers
  43. Left rear caliper bracket failed...
  44. does anyone know where i can get a all blacked out grill and maybe some type of lip, similar to A4's
  45. wanna get 425bhp from your n/a v8???
  46. Met up with 2000BlackA8 in Jersey City tonight.
  47. upsolute chips
  48. need new corner light
  49. key fob
  50. New (Second) Owner of '01 S8
  51. X-post: Looking for an AW plate frame...
  52. Save a marriage !
  53. Is my 2000 A8 too old to debadge?
  54. Power Steering Filter in out A8s?? Where is it??
  55. How much do you think stealer will charge for checking and replacing cerpantine belt?
  56. Self-leveling suspension or ABS?
  57. VW Phaeton
  58. Got my new plates
  59. Video from My A8 on some narrow roads
  60. And my 2nd question for the day...switch brain down to "dumb"....
  61. Opinion needed- My oems have pirelli P6 Allroads on 'em
  62. oil filters for 2000 a8
  63. Transmission Problem Resolution or Wishful Thinking
  64. Scary Discount A8...
  65. Front door speakers
  66. Tozo A8, if your still doing the grills, count me in.
  67. 2001 S8 Front brake pads and rotors - where and how much?
  68. tozo8a thanks headrest done
  69. Anyone deal with Maplewood Imports in Mlps?
  70. Bought a G-Tech Pro Today
  71. reengineered control arms??
  72. Good Luck/Bad Luck Hit a deer and need some parts.
  73. Randy, Mobil 1 Racing oil..
  74. Backed out of parking spot...... =(
  75. Hey, new 4.2 development forum
  76. Ugg.. i pulled in to my parking spot at work today..
  77. Are we able to install the S8 sport seats in the A8 vehicles?
  78. control arm bushings instead of the arm??
  79. K&N Air Filter
  80. Chips and Superchargers and stuff
  81. KaMaKaZieP, any update on the ebay chip upgrade you were looking at?
  82. has anyone tried engine upgrades w/RS6
  83. is it common for the the check eng light to come on for a lose gas cap?
  84. Any way to get fogs to stay on in a 2000 A8?
  85. Brake, ABS light
  86. Has anyone used PRO GUARD injector cleaner?
  87. V60 hands free phone help???
  88. Guess what Paul is getting!!!
  89. caliper carrier braket.
  90. shocks size?
  91. will this work?
  92. 2000 A8L to buy or not to buy?
  93. check eng light fixed
  94. Can I upgrade to Bilstein sport w/out upgrading springs? eom
  95. Stainless steel grill inserts.
  96. Headrest problem fixed.
  97. does anyone have a pic of JUST a headlight?
  98. update: test ride with and without ESP (01 S8, 60k)
  99. 01 S8 temp gauge problem
  100. Anyone running wheel spacers? I'd consider to fill the fenders a bit more. Also,
  101. was just looking at audivideos.com and was wondering has anyone ever heard from Terry?
  102. 2001 A8L or 2001 A6 4.2?
  103. 10%-15% OFF HRE WHEELS!
  104. memory seat rests stopped working over the weekend any thoughts.
  105. A8L 6.0 Test Drive (A $1500-off-a-new-A8 coupon....for you?)---->
  106. Front Bumper Adjustment
  107. replacing lower front control arms.
  108. Is $49,500 for a 2002 S8 with 15,000 miles fair?
  109. Electronic Control Module
  110. Water flooding into the footwells
  111. Anyone in the Rochester area with the software/equipment to re-code tranny?
  112. Video from My A8 on some narrow roads
  113. Chrome moulding painted?
  114. Is there a /real/ A8/S8 nitrous oxide Wet system?
  115. Brake Problem
  116. Help: Glove box lock removal?
  117. Maintenance question 2001 A8
  118. Positive feed...
  119. 2000 A8L
  120. Paul need help! My car is giving me wierd codes! What does "Gear Monitoring" code mean?
  121. Front End Improvement Thanks to tozoA8
  122. Quick question... what's that noise!
  123. Just a survey. I got my paddle shifting tiptronic mod almost down to a nice finished product.
  124. '01 Black on Black on Black with a Tan interior! LOL
  125. Silver S8 on i-80 in Vacaville ~ 5pm?
  126. Hay paul... How much does BIRA version 1 run?
  127. Interior Light flashing....
  128. For S8 owners Q: what numbers/letters in 3 digit code has your cars about suspension.
  129. Air Bag Sensor
  130. Winter wheel-tire Specials..
  131. Is this bonafide? Is this comparable to Bentley?
  132. Mobil 1R 0W-30
  133. Whatever happened to JeffB and his engine rebuild?
  134. getting closer
  135. A quick note
  136. 1000rpm rattle...
  137. Looking for info on 2000 A8 w/40v engine...
  138. Could just be the classy finishing touch I'm looking for....
  139. Time for new brakes - suggestions?
  140. NOW, Ronal Snow Wheel-Tire packages...
  141. smoothering rides
  142. Will a dealership recode transmission?
  143. Bent Wheel - Where to get replaced in Chicago?
  144. Two very short squeals at start
  145. valves lubricant
  146. Sidewall Size Confusion on A8q
  147. Tinting out tail lights?
  148. vag
  149. Finally got the new front end installed this weekend. Alignment time.
  150. Info regarding chip tuning.....
  151. ESP question (2001 S8)
  152. remove phone from armrest
  153. HID Lights Shut Off & Engine Runs Hot At Idle
  154. 80% depreciation in 6 yrs? Wow.
  155. Eastern PA Trivia Road Rally 10/23...LAST CALL! RSVP now!
  156. Steering wheel controls
  157. Spacers for S8 with Avus
  158. Selling car.. Is this normal for an agent sale?
  159. H&R Coilovers
  160. Automatic Transmission Fluid Oxidation
  161. Digital display of speed code = 33, anyone know the others?
  162. Lemmiwinks baseline advice..
  163. Front brake pads
  164. abs sensor
  165. Final tire decision time....
  166. Oil Capacity -- Plz Verify
  167. Are stock exhaust tips stainless steel?
  168. Cleared 100K, time to update my ride...
  169. 2000 A8 clear corners???
  170. 18" vs 19" RS4 Wheels....
  171. Brake Fluid: How much do you need to bleed the system?
  172. Repost for the working crowd...
  173. A4 ultrasport wheels on S8
  174. Axxis metal master brakes
  175. Listed the car this weekend... still no reasonable offers
  176. Audi repair in Toronto
  177. Couple less creaks and rattles...
  178. Transmission fluid
  179. Installed new tie rod ends, and eyed up the installation of the strut bar.
  180. Take dash cluster apart. Removing covers.
  181. Rear lumbar motor location?
  182. Does ANYBODY know what's up with Wendy?
  183. Nobody tried lemmiwinks yet?
  184. Headrest repair procedure improved!
  185. which side of the car
  186. Timing belt problem!
  187. Summer time oil change
  188. H&R Coilovers
  189. wheel and tire specials
  190. OBD II tuner question
  191. 2002 A8L radio dimly lit, but doesnt play
  192. Here's the exhaust sound. Finally got it hosted right!
  193. Ebay seller-w/"Chicago area warehouse"..
  194. Would I want to fill my tyres with nitrogen ?
  195. Digital read out of your exact speed on your climate control display???
  196. Factory Installed Hands Free Question
  197. How do I smooth out the ride of my S8?
  198. where do you find mobil one racing????????????? no one in my area has heard of it.
  199. REMINDER: EAST COAST AUDI MEET TOMORROW (WITH AWE-TUNING)....
  200. thinking about going from 00 A4 to 99-00 A8.... any big concerns?
  201. Want to lower my A8
  202. Compatibility of parts between 3.7 & 4.2
  203. Which tire sizes would fit the stock 18" on the S8?
  204. Is this Taboo?
  205. control arm group buy
  206. Suspension Kits on EBay won't fit...
  207. A8 problem areas ?
  208. Ronal - Nokian winter program
  209. Question for PaulW
  210. Eastern PA Trivia Road Rally Oct 23rd!! Sign up now!
  211. Wery interesting info about automatic transmissions and torque converters.
  212. Paul always has something to say and show!
  213. Wiring Diagram for Light Control Module
  214. Farewell A8 fans... I'm going to sell this weekend.
  215. Transmission Filter for DTE type
  216. Pearl White
  217. instrument cluster
  218. where can I find a place that sells A8 body parts?????
  219. Which of the Pilot Sports are the ones that everybody likes?
  220. Paul's Dreaming again....Supercharger Revisited
  221. vag serial vs usb
  222. Reverse is wierd...
  223. How many people have noticed that the drop downs bring you to the D3 forum?
  224. any one heard from Wendy? I have got to buy some parts again
  225. NICE RIMS
  226. Price check (98 A8Q)
  227. AutoX spy shot
  228. came across this on ebay its nav+ for your cars, great buy it now price
  229. Well I finally got the gumption for my little exhaust experiment...I hacked off the muffler to see
  230. 2001 S8, 32k mi, Certified to 100k.......
  231. Another "will it fit" question...
  232. '97 A8 4.2Q Stainless Brake Hoses
  233. Any opinions on Denso Iridium Spark Plugs? Or should I stay w/Bosch 4+?
  234. abs/emergancy brake light (long)
  235. Market Value of '97 A8 3.7 Frontrak
  236. Anyone heard from Sven lately?
  237. Price Estimate?
  238. Can anyone help with some torque specs? Bentley is DOA untill 1105
  239. New Wheels and Tires?
  240. For the life of me, I can't get the alternator off!
  241. Diagnostic tools A8 2.8Q '97 (European)
  242. Aftermarket exhaust options
  243. Grinding/ Whirling Noise in Engine or Transmission
  244. Replacing a front bumper skin
  245. can someone give me the exact measurements for a symphony stereo from an A8 (2000-2002)
  246. REMINDER: EAST COAST AUDI MEET OCTOBER 16TH......
  247. Anti-theft
  248. Two more pictures of the autocross this last Saturday
  249. X-Post: 2nd Annual Cuyahoga Valley Fall Cruise and Clambake - 10/16
  250. Track wheels and tires...I'm thinking some AMG wheels
