- Looking for oil pump/timing belt part
- Oil Cooler Pipe
- 97-2000 Audi A8 D2 Fuel pump assembly with fuel level unit
- Need help diagnosing no start issue
- To keep the D2 or sell it and move on.....opinions please
- A8 4.2 Quottro D2 1995 Genuine 125KM
- Headlight adjustment system
- Will these wheel size and tire size fit?
- Another P0018 code
- best location to put jack stands?
- cracked trunk mat
- Fuel filter location
- Good read about a D2 S8
- 1997-1999 Audi A8 D2 4.2 Exhaust system
- RNS-E upgrade
- Aftermarket wheels
- Widebody D2
- Merry Christmas!
- Triangle warning sign
- Interior rear dome light
- 2020 S6/S7/S8
- TRUNK ISSUES 2014 Audi A8L
- wheel gap problem
- Instrument Cluster Failure
- FL symphony head unit CD/CDC help
- 4.2L camshaft bearing cap bolt replacement?
- Need help with Twin Turbo Project
- 2001: High milage maintenance?
- CML tranny (4spd)
- S8 Avus Rims
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- Why so many posting in the wrong forum section lately!?!
- Tranny stuck in P and key stuck in ignition
- Software upgrade recall A8 2018
- NO: A few quick diesel questions😅
- 99 A8 4.2L Random Multiple Cylinder Miss Fire
- OIL COOLER WATER LEAK
- Intermittent multiple misfires, P0455 Evap large leak
- Rear sunscreen retro fitting. Good idea?
- fuel line fitting ID?
- Sport suspension vs. non-sport suspension?
- 2001 d2 s8 needs servotronic module in the rack
- P0117 Engine coolant temperature low input
- 2013 Audi A8 4.0 T needs turbos replaced.
- Is this Nissens radiator fabricated wrong? Or change during 1997 model year?
- Rear CV Axle
- Driver front foot well light?
- died at idle a few times, started right up again
- What is the purpose of the red lights on the door cards?
- Body kit A8 D2
- D2 Center caps
- Facelift D2 A8 oil level warning / sensor
- Need a front sway bar
- Corrected post 2000 a8
- '00 FL 155k potentially available for parts
- I have some issues
- Audi a8 2011 v8 4.2 locking crankshaft
- S8 (d2) 2002 final edition. Head skimming limit
- Chasing down some gremlins
- Throttle Position Sensor - how do you get it out?
- Air box fasteners rusted to Hell, now what?
- 1999 A8 REPAIR MANUAL ?
- Tiptronic lost, need help
- A8
- Lower Front suspension Arm.
- Bad Idle Trembling and Shaking Mystery
- Fans running all the time
- ABS Module coding help?
- I still cant believe that Rob from motordyne still sends me email virus stuff.
- Hitch? Anyone?
- Shakin' 50-60mph
- Raditor fan
- Complete Newbie
- 1999 A8 battery doesn't keep charge
- Front Turn Signal Housing Part#'s???
- Scan tool abs bleeding?
- No speed or odometer
- 1998 S8 won't start
- What’s the usual failure mode for the transmissions?
- WHAT ARE THESE CUT WIRES UNDER THE FLOOR?
- S8 d2 water leaked inside and transmission went in limp mode.
- Help with Idle Speed Control Valve
- Grrrr, how do you get jackstands under an A8L?
- Puddle and footwell lights not working.
- Parking heater
- D2 pictures
- 4.2 intake manifold actuator
- Big “whoosh” on removing gas cap?
- Audi A8 D2 1996 2.8P
- transmission cooler lines don't seal
- Timing belt job and tools?
- Runs rough in mornings before it warms up, no CEL.
- Help me identify this Part Please!
- Need a name and part number for subframe bolt
- How many D2 cars have been swapped to manual transmissions?
- Cam Adjuster Noise
- Active headrest reset procedure
- Diagram for fuel pump / sender wiring?
- Help water level warning light
- Im part of the failed drivers window club!
- High pitch squeak noise after installing new brake pads?
- Random ticking, clicking behind dash, gauge cluster area
- Help with Timing Chain Tensioner
- Do facelift trim pieces fit pre-facelift?
- Furry oil pan magnets, excessive?
- FI: Flashing diagram?
- Heres what i did today... Added frustration! Fuel sender, misfire...
- Driving wife's D2 home from Lowes
- Gearbox oil pickup tube?
- Bentley Manual info
- Where to hook up for switched 12 volt?
- Lost sunroof wind deflector
- Fuse panel location?
- Any idea on airbag fault code 01025 ? Seems to be faulty airbag lamp?
- Coolant temp sensor help
- Help with VANOS on A8 D2
- 2001 Audi A8 L Quattro Running in Limp Mode For Sale or Part Out
- 2001 audi s8 4 sale runs great
- Need a brake block.
- S8 Pre-Facelift block swap
- S8 D2 vs D3 - seek advice from those with head to head experience
- ZF4HP24A Auto Trans Filter/fluid change..
- Need guidance to replace AC Compressor DIY
- D2 for sale?
- 1999 transmission help!
- Great article on d2 s8 170mph
- Car died suddenly, now intermittent. Ghost in the machine?
- Widest wheel/tire combo?
- Saw this on car gurus. Not mine 2002 Audi S8 quattro AWD - $3,333
- Lack of CEL/MIL?!
- Did the oil cooler for a coolant leak, still a small leak somewheres... No drips
- door car fabric coming apart
- 2003 S8 transmission?
- Cup holders
- Where is the G266 sensor located?
- 2006 Audi A8L crank but won’t start after jump start battery
- Check engine light flash and missfire
- Gosh it's impossible to find a A8/S8 keychain
- Anyone upgrade to this style key fob?
- Success on the a/c recharge (easy way)
- Can someone please explain the a/c recharge procedure to me?
- Wanted Fog Light Grills for 2001 model
- Rear Brake Issues
- Front CA pinch bolt must be replaced new?
- Cooling system help
- Startup rattle
- Service Light Reset
- Anyone dealt with the difference ...
- Anyone parting out?
- Heavy Battery Removal 1998 A8 Tips??
- Ventshades / rainguards
- Sachs OEM Shocks F/R
- Need help after major work
- 2008 A8L
- 2001 Audi A8L 4.2L Quattro Front And Rear Breaks *HELP*
- Drove it home yesterday. Today replaced leaking valve cover gaskets, now wont start!
- are the TYC Fog Lights good quality?
- Audi TT s-line wheels on D2 A8
- Advice from the Fatherland.....
- New owner, not new to forum life. 2000 audi A8, heres my list of woes.. Need help!
- 1998 Audi A8 (D2) unplugged trans connector / Safe mode
- Anyone have a lead on Window Glass?
- Why does the pop-up not have some way to exit??
- what item might cause misfire when coolant gets hotter than usual?
- Water leaking through key hole of trunk lock cylinder
- D2 S8 Suspension, OEM vs. Aftermarket
- 2000 A8 4.2L (228kw) Euro, cold start & idle anomaly
- Timing belt part number?
- Fuel pump only empties one tank
- S8 (1999, facelift) won't start any more :-(
- 4.2 ltr v8 engine replacement.
- 2001 S8: Any good options for front coil springs?
- Unknown engine wiring connector
- Intermittent Front End Shaking
- how to get the A/C restrictor out - tight nut?
- A8 vs. A8L
- instrument cluster LCD screens be fixed?
- anyone have the wiring diagram for the CD changer?
- hello everyone. new d2 owner here
- Should I buy this 2000 Audi A8
- Front Suspension
- replacing the key shell... now remote key won't work.
- 1999 Audi A8 4.2L V8 Oil In Coolant and Overheating in Traffic
- Air Velocity
- Seeking a working fuel pump assembly
- why is my A/C condenser line blocking my radiator drain plug?
- how to clean dried brown goop out of spark plug boots?
- Help needed
- Problema electro
- 2002 A8L D2 No Power to ignition after Dead Battery
- The dreaded DEAD FUEL PUMP
- All 8 Cylinders Misfiring
- why is the timing mark on the crankshaft damper in the wrong spot?
- Quickest way to drop the rear strut?
- Dashboard fading limp mode
- Central lock motor rebuilder?
- A8 d2 4.2 no start
- Audi a8 no power but navigation screen pops up
- Trunk will not open at all
- steering rack differences
- Suspension Options
- Slow over heat issue solved with thermostat
- Audi A8 owners feedback
- Blower resistor, location and replacement
- 2000 A8: No signal from crank sensor
- Intake Manifold Actuator Over-Rotate?
- 97-99 dual-stage intake manifold changeover mechanism questions
- Project car thread, lots of questions
- Immo3 chip locations (cluster) ?
- Coolant type issues?
- Led conversion — warning light problem
- Update
- Trans first gear slip at full operating temperature
- anyone know the part number for the trunk lid stop?
- Steering Rack Failure
- Which Manf., has the best CV Boot Kit?
- P0174 p0491 p0492 code info
- Blower motor
- Speedometer sensor location and replacement guide
- What are the chances?
- Transmission issue and Power steering issue related?
- Cleaning Intake Manifold
- Dose anyone know if
- IPhone in my 2004 A8
- TRANSMISSION HELP
- How to change the rear strut mounts?
- spring perch
- D3 rear calipers and a6/passat transmission in a d2?
- 2000 audi a8 4.2 Quattro need to program my keys for my audi. Not the fob
- Transmission cable, only three positions?
- Need help with a problem: P0322, no input signal
- Just checking in
- D2 A8 brake conversion advice
- Diesel Conversion
- S8 starts, then dies after 45 seconds
- 2005 Audi A8L W12 Gas Tank has allot of pressure
- Pre facelift 4.2 A8 manual conversion
- 1997 Audi Ecu Fried Wont go into gear?!
- Fuel system has no power
- J105 RELAY LOCATION HELP
- Xenon Headlights not turning on after it rains
- Need help with possible fuel pump issues
- water leaking form back of the engine ?
- Mr. Fixit in West Michigan?
- Acceleration problem
- Loud knocking from right rear, any theories.
- 03 S8 Transmission jerks HARD for no reason
- '99 Rear Spring Upper Pads
- New to me D2 4.2 2000 A8: Misfire, rat poop airbox, water in ecu box.
