- Body Kit?
- Ok a friend of mine and I are going to throw the coil overs on. I know I found a link with some ...
- An nice email from a fellow A8 owner:
- Anyone else having trouble searching recent topics in this forum?
- I finally installed my SR1.
- Well I cleared the code(s) and after I did, I pulled out of the driveway hit the brakes and....
- I got good news for those of you that were part of the Control arms Group buy. Refund update!
- As the Stones Said.....You Can't Always Get What You Want.....
- Limp mode when hitting 2nd gear. Any had exact scenario?
- Follow up from yesterday's creeking control arms...
- Paging "Cjshutts"....
- Computer , Radio, temp display gone , trans indicator numbers ok
- Gas Smell and Mirror Question...
- 99 A8 on ebay, wheels not included.
- this is just an idea, so please CMIIW
- Ball Joint Life Expectancy and $$$
- Can someone name this probably near useless part(s)?
- Happiness is another two wheels showed up....waiting on the 4th!
- Poor russian A8 owner - he read so many bad words about himself.
- Ronal USA, 16-19" wheel-tire Packages
- After 30 minutes of driving or so, awful squeek/creek from passenger side front suspension.
- does anyone know the OME for Spark Plugs?
- Curious, what's a set of forged 17x8 polished 5 spoke wheels worth?
- Paul, I know, that you are going to like this.
- My VAG falt codes. Arg.. all of them:
- Zimmerman X drilled (all 4) with Pagid pads $450 shipped
- Look Mom.....No Tires!
- Tried to change my clock for the time change..
- April SoCal events -- special event / driving school / breakfast mtg + Julian Drive
- Crazy incident
- Air conditioner smell
- PRND432 All Lit Up
- Headlight replacement for 1997 A8Q
- Where can I get these wheels in this size?
- Anyone still have their used control arms laying around from the installs? I'm making some Audi
- Wheel/Tire Combo Weights
- Seattle (PNW) A8ers... Xpost to PacificNW forum. GTG this Sat.
- I'm just about to put an air body saw on ebay if anyone is interested - email me for details
- shady Nav Plus on ebay
- I did weighing of the wheels. Winter 225/55-17 Dunlop Wintersport M3 on OEM 5 spoke rim...
- Brake BT revisited: about time to change the rotors & pads all around
- Who on this forum posted pictures of lower control arm repair...
- fuel filter part #'s - 2000, maybe other years
- recommendations for a cigarette lighter battery charger / jump starter
- 99A8 Swiming pool
- I need to take my car today. Can you reset the code for the transmission ( all blocked lettering )..
- Response from H-Sport on the Sway Bar Project
- Want to fix your door handle light switch? I think this might do it
- Anyone using one of these? G-TECH PRO METER
- Antifreeze issue?
- VAG tool. and BP manual on the way. Time to get to work.
- Spark Plug
- 99 a8 front rotors, HOW much is OEM? What is part number??
- How hard is a strut/spring install? What special tools are required?
- Happiness is......
- So this punk kid tried to steal my car today . . .
- A8L transmission question
- Paul, Welcome back, viscous coupler question.
- $1100 for Transmission Rebuild in Chicago W/Warranty
- Nav+ alternative?
- its not mine... but a friend of mine whom I work with just picked up an 01 A8L 4.2
- which power brake bleeder should I buy?
- My new "german badd ass" look!
- has anyone removed the factory "GPS" antenna on the trunk ?
- Getting deployed, no more fun with the 8 until '06
- My transmission mystery coming to the end.
- I'm getting a new transmission
- Now tonight....my trans is in limp home mode.....
- Another service help
- More on my issue from last night, and last week.. In need of alarm location as well..
- Rotor help
- I'm in at grattan becasue of the mix up is anyone else still going
- SteelBr8ed--Which email are you using?
- Go and look at the top of the D3 "Cheeze Forum" It's great!
- Head gasket oil leak, timing belt replacement (long)
- Next issue. Please give me some ideas. No reverse, and no R in the dash. BLANK.
- Randy, where did you buy your Alcon 2-piece 355x32 rotors?
- Brake BT: about time to change the rotors & pads all around
- anyone coming to "One Day of Fun" mon. may 16th
- Bose audio stuff
- FYI on ECS/PBR ceramic pad combo, and request for advice
- Goodridge G-Stop lines fit '99
- I know pauls not around for this theory but....
- 1st time power bleeder user. Any hints?
- '01 S8: Recently I don't feel the car is putting the same HP....
- A4 MAF change over readings... 218.9 g/s with A4 MAF
- Trunk stuck
- Grattan Driving School -- date changed !!
- A8Q Tuning
- Update on ECS 2 piece rotors and Ferodo DS2500 pads
- 00 A8L Vs. 02 WRX STI
- What would be a good tool collection to have for this car?
- Navigation disk question.
- XM Radio connect via cd changer cord in trunk?? '02 Bose
- S8 Interior Trim Kit
- Nav Plus Unit Available
- eBay car with custom wheels...
- Floydd Bennet Field GTG NYC and Surroundings
- Does anybody know a good source for Euro A8 front rotors?
- CV Boot Change
- New wheels, tires, clear corners and sides
- (w/o looking at the manual) when do these pupies req. a tune up?
- Oooh look what Spyker's (former, since today) head designer is driving...
- Timing Cover Gaskets
- Hey Tozo, any ideas on this?
- help with color code 98 silver a8
- red cockpit lighting
- heres some good videos of the audi a8
- Need help from an expert with these track videos.
- figured out groan from front end - shock recommendations?
- noise from body flex
- Questions/answers regarding the new Toyo T1R tires:
- Trip Computer display is gone. Has anyone seen this one?
- a8 with 275/40 18
- Oil Pan gasket @ $108?
- Has anyone done a staggered wheel setup?
- Did these wheels come on any A8's to North America?
- ATF change
- Soft gurgling sound
- S8 brakes onto A8??
- Mid- Ohio is SOLD OUT!!!
- lo speed *groan* in front end
- tape stuck in deck...
- What is that second button on the B pillar ?
- adjustable steeringwheel currently not so adjustable...
- 2003 A8L was towed to dealer
- Sensor attached to the lower arms?
- oil pan gasket r&r
- checking oil pressure
- grattan is full I got wait listed apparently even though they had opening when I applyed by phone
- LOWER COWL DRAINS
- Hub for steeringwheel A8
- Whats going on w/ the picture poster?
- PSA - 2002 70k S8 for sale in AW classifieds.
- You are all hereby cordially invited to the D3 forum
- Rear Passenger Window rolled down by itself????
- Tozo, here is our next PC upgrade!
- Paging PaulW.......Red X problem persists!!! HELP!
- Okay decision time...
- ABS Fault Code
- Getting GIAC ECU/TCU ..anyone here have them? Also,
- What is dealer list price for a 99 A8 tranny filter? TIA
- wheel swap.....Will it work?
- Bulletproof Chancellor Schroeder A8- $250,000 in DuPont
- Shock Noise at 80k miles?
- Just came back form Key West. No Audi's there.
- Audi Sues Nissan for Q, BWM sues Nissan for M, GM sues Nissan for Z
- Falken Ziex tire review
- What do S8 rims with tires sell for? I may sell mine to get larger rims.
- 75k service
- Service interval question. (longish)
- Anyone done a curb rash repair on the factory aluminum wheels?
- Work is over for the weekend, Time for the Holiday, Happy Easter to everyone
- Looking for a Bose replacement speaker
- Thoughts on O2 sensors
- Yellow A8 on ebay..
- JimR, How do you like the boxster thinking about adding one to the household for summer commutes
- Missed a sweet 02A8L w/7k miles=$35k CPO
- ECSTUNING upgrade in progress.. where do washers go for spacing?
- Wheel and tire question. Yes, I searched first! :-)
- Replacement of seal-valve stems is undergo now.
- Randy Young..........tire question!
- LLtek cold air intake
- Follow up to Yesterdays X pipe Discussions
- How about this for a twin turbo project?
- A8Tranny code
- Did any A8 3.3 TDI quattro's make it to the states?
- Brake fluid seepage revisited.
- Does the S8 come with a factory installed Tunnel Brace?
- Thanks for the help, now I'm an owner and actually need the help
- Throttle body...
- Transmission
- Kickdown/distributer theory
- Lifetime Firestone Wheel Alignment
- tire recommendations?
- Bluetooth Parrot kit questions, voice dialing/install
- Did I pay to much-97 A8
- Transmission filter, pan gasket & 8-9 Liters of Audi ATF for sale.
- Pics from our recent Buttonwillow track event
- The files are transferred over
- Just Want to Verify
- Nissan Reliability
- Ferodo 2500 pads and ECS Tuning rotors arrived! Along with a few more goodies.
- Will B7 2005 A4 Nav work for others?
- Transmission Code!
- Life Expectancy of 97 A8?????
- Will this work as a spare for my A8?
- If anybody wants a tip shifter
- for techies only!!!!
- Bad guy's nice car....
- 97 A8 155k miles
- Pie plate rim
- Nav Plus "how toos" with the pictures
- ** a8driftrer ** Looking for a set of 19" RS6 Rims
- TT NAV for A8?
- Back in the shop again....
- Getting Ready for the Track and Autocross this Year
- Here is my new monitoring software.
- Interior Lighting of the 2000 A8L
- Want to Flush Your Power Steering Fluid? Do I have some advice for you!
- How do you get into your RV mirror for a bulb change w/o breaking anything?
- NAV question for Paul W
- SoCal reminder: FRI March 25th, SCC Audi special event @ Mosier Restoration in Inglewood
- StonGard headlight protection for $25 (reduced from $60).
- anyone know how to change the interor roof light in the front and rear area. I want to install red
- Impotant info about xenon light
- And the Answer to the 40 Valve Motor Groan is.......
- Is a Bridgestone Potenza RE050 245/45-18 96W right choice?
- Stealer annoys the hell out of me....
- how hard is it to change the fuel filter?
- Brake Fluid seepage?
- Lead > Follow
- Trunk won't open by any means
- 2004 A8L Remote Start System?
- Transmission Pan Leak
- Chrome Bumper Trim
- Can anybody to write code of famous Ferodo DS2500? Can't find its in Federal Mogul catalog.
- tire question
- Korea emergency A8 airlift!
- Should I buy it? '98 A8 4.2 20k miles $16k
- Paul did you ever get your chip for your car?
- what ever happened to the guy that was rebuilding his motor and custom making parts for more HP????
- Paul, looks like jeffb has the fuel delivery figured out for the s/c project
- Pimp My Door Panels!
- Where is the filter screen on the Power Steering/Hydraulic fluid system?
- replaced the bumber yesterday and strut bushings bilateraly yesterday. Looks good with the bumper
- Idea of new mod - color LCD from mobile phone SE T68 to dashboard
- Finally changing servers over
- do we need a specific power steering fluid? mine is a bit low
- Opinions on these wheels
- a newbie question about the ASF
- the 10.8:1 compression ratio
- AW GB update: dension ice>link plus. 33 folks in-check my sig's link for full details
- control arm heads up...
- '99 rear diff filler
- Your opinion about stock A8 18" rims?
- Kind of off topic?
- Mini mac's for music, gps, computing
- I went to buy brake fluid last night, asked the counter guy for either castrol or ATE type 200 brake
- Question About Warning Lights on Dash
- S8 owner on Tyresmoke.net installed DVD-based NavPlus unit
- Audi Police Cars & Off-Roading the A8, at Sebring Raceway FL
- Paul W - Question on Parrot install
- Luiz's Twin Turbo is gone!
- never saw this one coming
- Can somebody tell me what language this is?
- My name is tim, and i drive an aries
- Closest I've ever gotten to Schumacher!
- Codes for my A/C controls
- Have you seen new french tire - "Tweel"?
