- Looking for driver's side lower grill... I know, I know, tie wraps...
- wow checkout auto trader. A8 prices are up there for 97-98....
- Paging Greenie...
- 98 A8 "Skating"
- Higher mileage A8
- Any S8/A8 southeast drives coming up ? North GA Mtns ?
- 2002 S8 Brake Question
- Did i mention that i LOVE MY TRANSMISSION!?!?!?
- S8 brake question
- Lumber support problem
- I know it is a pain to do the oil
- Itchin' for an S8!
- Gas smell and CEL revisited
- Running 225/55/17 dunlop M3's for winter, ok on a 7.5 wide rim
- Zimmermann brake-disc to A8 ?
- Help With Brake Change on 01 A8L - Can't Get Rotor Off!
- Weird problem with Brake wear sensors 2001 S8
- lowering question
- Boot for outer constant velocity joint
- Sig pic-how to?
- Instrument cluster correction
- Fuel lines leaking again. I need to splice and lengthen my fuel line.
- Looking for a D2 S8.
- Seconday Air injection sys
- 3.7L with 5HP-19 Transmission Service - Update
- The car is amazing and I like the red! (2002 S8)
- Walnut shifter?
- Is it possible to buy an A8 Diesel in America ?
- 2000 A8 front brakes
- anyone know of front sway bar nylon or poly bushings for our cars?
- Pics of my new car
- Red or what??
- New Pix on my picposter here fyi
- the German P word . . .
- Mileage...
- Kumho Tires and Brakepad Worn Light
- STEERING LOOSENESS/ALIGNMENT
- S8 Tire opinions
- Possible Torque converter lockup and hunting solution
- Fact or fiction?
- so how fast are 02 s8's supposed to go and what are they limited to?
- Whoa, check out this convertible
- off the topic, how to add pic. to a signature.
- engine fault code
- American wonder has reached me finally after 3 month. :-)
- cluncking is back in the front
- Installing a Solar Sunroof?
- Rough Idle (Vibration)
- Phatbox question.....
- check engine light on scanned code got 2ndary air inject bank 1 fault
- Alaskan Looking for A8 in PNW
- Disappointed new A8 owner-Can't use my V1!!!
- Can anyone help with suspension??
- Joined the club
- VAG-com alternative to Ross Tech that works well
- How bad do you think these tire would suck?
- Prefacelift fog light project..
- Car Alarm and GSM module
- Scope results proven true.
- Both lower grills for $21.00
- apparently my CEL bulb is OUT
- Codes P1432 & P1411
- wheel refinishing
- phatbox
- 2nd request..ne1 install rns-e in us-spec A8/S8?
- anyone mod fogs to operate with parking lamps only?
- Why do I pay so much much for insurance? I move around alot, and it is high everywhere
- Boulder/Denver Vag com HELP
- Finally....
- new chrome under head lights
- ebay roof rails
- hands free volume
- Giving some thought to selling my 16" BBS wheels and putting snows on my 19s.
- 2001 Audi S8 for sale
- Is the grass really greener on the other side(s)?
- any experience with TRW pads on S8 Brembo calipers?
- I sold my baby
- rattle and shake
- Has anyone ever "blacked out" the chrome trim on an S8 ?
- Anyone put this into an A8?
- 1999 A8 won't start
- Rear sunshade
- Would the oil cooler housing ever go bad? Is the access easy after the front end of car is removed?
- Will the 7JX16 Seven spoke rims off the 98 A4 fit the A8?
- Research for hunting, oil flow question...
- Hunting finally started at 148k miles!
- Floor Mats
- Audi Factory Parts source?
- Sadly gave up the A8...can't deal with the Audi service anymore
- Question about hunting and anerobic sealant on the transmission valve body
- Goodbye 1997 S8 - Hello 2002 S8
- D3 S8: An oppotunity to lead the category lost?
- PhatNoise on a 97 A8
- Maximum Safe Tire Width
- ATF change on CML transmission
- Quick pic:
- badly fluctating idle..help!
- Paul W- fuel line repair... I remember you had a leak at the
- Paul W. HELP! 1999 A8 won't start again
- RONAL, wheel-tire packages, SNOW etc
- Vag result query[ long]
- let's go smaller older cars
- Just finished replacing the front control arms etc.........
- 3.7L Frontrac owners - Transmission Question
- Off-topic: Why you need to be overly cautious with eBay purchases
- does my a8 got a subwoofer?
- HELP! 1999 A8 TROUBLE STARTING AGAIN
- Wheel size / Staggered
- Okay....I am a jackass....but please help
- Random Coolant Leak...
- Can someone provide detailed instructions on how to post pic
- Changed climate control light bulbs
- ?What could be the reason for fault: 00561 - Mixture adaptation
- What spec.s for wheel/tire runout & concentricity?
- Body Shop in CT
- front seats do NOT heat up fully
- FAILED emissions today!!
- Got some new Tires
- Considering an 2001 S8. Should I
- POLL: Three Audi race car graphic treatments...Which do YOU prefer?--->
- Same difference!
- Hey Paul i think you need to update your A/C Recharge Link :)
- Recoding from Valet key
- Summer Package - Bluetooth compatibility?
- Instrumnet Cluster F*ck...looking for advice...long
- '01 S8 - Slvr/Blk for sale...
- Tranny fluid question....
- ABS/Brake Light Problem that I cant' seem to fix.
- X-Post: Anyone from Southern California heading up to Infineon?
- remote locking....unsucessful
- Coolant... evap
- Center muffler leak
- Give it the boot
- Transmission Rebuild
- CEL.
- Broken armrest solution, Cost me 25$ and time
- recommends on A/S tires for 2003 S8?
- 99 A8 armrests
- Trans Service
- S8 wheel & Tire Modification
- Problem filling at gas stations yesterday
- Tire size (again)
- A8 Audi Deltas amplifiers?
- Does anyone know a fix please
- Looking for Audi Mechanic in the south bay (San Jose area)
- divided rear seats upgrade
- good stereo website
- L.A. REMINDER -- GTG @ The Stand tomorrow night, TUE Oct 25th,7:30pm
- Is it possible to own an A8 and live in peace?
- Front end noise and clunking feeling...and I have replaced everything
- Power Windows
- transmission woes
- I just put my stock wheels back on with my snows
- I have 9 liters of original Audi ATF that I won't be using. If anyone wants to buy it from me...
- Moving sucks!
- aftermarket source for side view mirror glass ?
- Boston Area GTG is ON for tonight!!!
- What are the most common sources of oil leaks on 32V engines? I just noticed that I have one :(
- got my new wheels!
- Tozo, how about an update on the stick? How are things coming?
- 2002 Audi S8 $35,000 27,850 miles Silver over Black
- Might be a dumb question, but has anyone tried reseting the TCU
- Looking to buy an A8
- Help please-procedure for cleaning door locks so lights work??
- A8 tranny question from Italy
- Off topic, G-rated, if you're in need for speed, try link inside :)
- Just incase you missed it!!!!
- Climate Control light out.
- Lf Front cluncking, 97 A8, 94K
- Photo from down under
- Question on oil Filter drain plug and oil viscosity
- Interesting mode for '00 green S8 with manual tranny.
- Tranny fluid...
- Webasto problem
- 6 months, 29 days later...the forged wheels are here - *warning big pics!*
- High Res of D3 S8 Interior
- C-NAV or D-NAV
- Anyone have a drivers side headlight assembly laying around? W/o lens is fine.
- Europrice is Moving....
- Skiwi and quattrokiwi what part of godzone are you from
- trans coding difference
- Value of S8 wheels? Selling mine.
- standing lights
- I'm looking for some D2 S8 wheels if anyone has any for sale ... thanx.
- Audi vs Lexus
- Your Vote for the Ugliest Current Production Automobile . . .
- Please help. 98Q 112k located in Boulder, CO area contemplating the Trans rebuild. Need advice.
- Part request: dark green paint for 99 a8!
- Paging Dan McBoost--
- part # for rear hoes
- new s8 announced
- Need help with oil Leak
- Maint Shop Rec? - New Owner - 2000 A8L New York
- Where these seats available on the 2003 A8?
- Transmission recoding
- EdyJun's S4 Directory - Updated October - 16 - 2005
- Want to buy - Navigation CD Set for C-NAVI system
- PaulW, here's your Green S8 for $26k.
- iiiiiits timing belt time, anyone know where I can get a kit for my 40v engine?
- Help in Fairfield CT
- Sunroof possessed by demons
- Source for '97 reman MAF?
- Replacement Fuel Pump - Pump Only
- A8
- So now we know why Tozo had to lower his car!
- Kansas City Audi GTG--Wed Oct 19th--River Market Brewery 6:30 PM comeone come all
- Anyone in the Washington DC area?
- update on noise (sticky lifter)
- Hey Paul.. do you still have cold air or did it all leak out?
- Door latch switches.. we need a solution! I dislike the disco effect
- factory mats
- 10/24 Boston Area GTG update!
- anyone make coil overs for the s8 that go higher than stock
- Ok, who's next?
- Serious problem with A8, please help!!!
- Observations on recode of trans.[long]
- Front Axle Oil Seal
- Any Suggestions on rotors for a 97?
- Removing rear A8L door...
- 17" 5-spoke Premium Wheels
- Final Drive help...
- Home! Need sleep.. going to bed! Love tranny. mmmmmmmm
- Boulder
- Has anyone ever seen this fault code?
- My car
- Vag-com auto code
- clipped antenna
- Followup to my previous post re: my central locks.
- US model differences [long]
- This is going to hurt. Six speed manual.
- I stand corrected....Jack charged my AC system today!
- T-3 Hours
- wood trim
- Automatic Transmission Fluid R/R Question
- Battery Replacement Trick
- Cental locking module - VAG
- fuel injector O-ring seals fyi
- Just replaced control arms with the Blau kit..
- HP vs. 0-100km\hspeed
- Jack and Gabor: 1 Audi Transmission: 0
- St. Louis Audi Shop?
- Velcro Fidel strikes again!
- Time? 1.5 hours. Felt? 10 bucks. New A8 sport seats? Priceless.
- Suggestion for new cell phone/car kit
- Whirring/Soft Grinding/Groaning Noise at Low Speed?
- wooden tapping/whirling noise when turning
- FINALLY! I spoke to soon with my last diagnosis of my clunking.
- Misfires on cylinders 8,7, and 5
- Serpentine Belt Routing on S8 40V ???
- What a trip.. NO absolutley NO traffic i am in my hotel room now.
