PDA
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 [78] 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. tranny service in new jersey
  2. PLEASE HELP! Front End Banging Ground Really Badly
  3. Looking for superior example of early A8
  4. 2000+ A8 clear corner mod: where to drill?
  5. New PDA time, I ask here b/c I value all your opinions. Palm T3 or T5 and why? I'm stuck.
  6. Windshield Washer - low pressure? leaks?
  7. Anyone know if a decent S8 18" Avus replica is available?
  8. coolant leak
  9. Rear Airbag Code on a '98
  10. Happy Transmission in 2000 A8
  11. problem when applying gas right after braking
  12. Interesting bulb replacement for license plates/ trunk lights
  13. What is the good battery to replace OEM on 97 A8?
  14. NIB Eibach Pro-kit for sale, $275 + actual shipping
  15. Engine Block Heater
  16. Good S8 deal?
  17. Help repeal the front plate requirement in NJ - sign the petition!!!
  18. Randy's Dream Shelf!
  19. Could I be nuts......
  20. extended warranty for A8?
  21. Another little snow movie from Norway 40mb
  22. S4 Avus conclusively fit A8??
  23. cooling flush
  24. A erarly Christmas car(d) greeting from Norway (Video)
  25. Does anyone knows, what the code number means on the torque converter?
  26. Well the old girl is finally showing some wear...anyone know a good ballpark range to get the
  27. I took the dealers advice.. i went to sears for an alignment.
  28. Bluetooth is King!
  29. Help! Did timing belt, cam chain adjuster, oil cooler, and now car won't start. Codes inside.
  30. Paul W-RE: ECU
  31. Invisible oil leak here.... maybe
  32. Fantastic.. 3 weeks of waiting and...
  33. Garmin's Ique3600 GPS navigation installed and worked!!!!
  34. Tiptronic steering wheel on ebay.
  35. Following up on my Hands Free Phone Installation!
  36. Trunk recoded, button still no good
  37. Door panel / window rattle on 2001?
  38. rear breather hose--part numbers again please
  39. Has anybody painted the exterior aluminum trim to match the car color?
  40. Anybody know where to get cupholders for the A8 that'll match my black interior?
  41. Interesting price difference.
  42. SoCal, last chance to RSVP for "Audi Odyssey" the holiday party of the year! - Saturday DEC 4th
  43. Car is at Stealer for Alignment, and to check out the oil leak that doesn't exist.
  44. So many uses.. so hard to find..
  45. finishing touch
  46. A-8 S-8
  47. Stainless steel grill inserts.
  48. I was able to clean the drain hoses.
  49. nav plus on ebay.....anyone here bidding?
  50. Grr .. 15k miles and ~2 years after front prop shaft seal replaced .. I think I smell "The Smell".
  51. auxiliary oil filters
  52. Pentosin G 012 coolant
  53. ECU numbers
  54. So, no leaves bunging up my hole, but this don't look good..
  55. easy VAG question... I think.
  56. OSIR Zero
  57. anyone add XM radio to their A/S8?
  58. I am ready for the winter. I think....
  59. code 15176, now my trunk is remote only..wtf?
  60. Replacement Glass Part Number?
  61. Headrest fixed with tie-wraps and 5/16 fuel hose
  62. A8 rims on an S4?
  63. Wow! Called PowerChips......you won't believe this one
  64. Discolored leather on steering wheel.
  65. 10 Reasons why i love my A8
  66. What is this part called?!!
  67. Here are my tire options.....
  68. tranny fluid supplier
  69. ECU numbers
  70. Can someone shed some more light on the clogged drain/leaking issue?
  71. Falken Tires... Any good? Looking at the Ziex All season tire.
  72. rondell #73 18x9 5x112 et 35
  73. Is there anything you want to see done in an A8 @ snow ?
  74. Do you like blue Audi?
  75. More 4.2 Chip Tuning Info.....
  76. PaulW - new chip
  77. allroad tip transmission update 17125
  78. 1999 A8 w/ 50k
  79. Fender bender, need wahser nosle
  80. audipages
  81. Paul!!! --CPR-Contitech timing belt is OK??
  82. ONE more Timing belt Q.
  83. audi of america going after lots of websites! CHeck out the link.
  84. any need to replace timing chain when doing TB ?
  85. oil cooler leaking only after a year of replacement??
  86. Car on lift in drive 3 of the 4 wheels turning at the same time
  87. New Angstrom Wheels Pics.
  88. SoCal, only 5 days left to RSVP for "AUDI ODYSSEY" the holiday party of the year! - Saturday DEC 4th
  89. I know Tranny Oil is "lifetime" but I've also heard rumours that
  90. thoughts on 0w20 ??
  91. Help, transmission output seal-on lift now!
  92. Wet feet when turning
  93. All I need is straight pipes and THIS!!!
  94. car service update
  95. Pictures of damage to my door
  96. Brake Caliper Painted
  97. Timing belt replacement
  98. With Wendy gone, where can I get TB parts?? Any one has part numbers?
  99. Glowing (seriously) brake disc, possible damage?
  100. Pass.side Wiper? non oem...
  101. chip question
  102. Little late, but offical "I have joined the ranks" post.
  103. headrest repair - fastener size
  104. 275/40 18 ET?
  105. another tiptronic option
  106. My Pre Facelift S8 is one step closer
  107. New (to me) 1999 CPO A8 (long)
  108. This could be the best deal yet on Mobil One...
  109. I just received the new serpantine belt. It is Contitech brand. Is that good?
  110. airbag warning light
  111. Darn Lawyers
  112. 16721 Error Code
  113. What the %^$&? Is that possible with an Audi Quattro? Follow link -> scroll to bottom of page
  114. RIMS on my W8 Passat: What do you guys think?
  115. You too can Install a Tiadan Garage Remote Controller!
  116. Heating /Air Conditioning
  117. Stupid question ... what do I do with the cell phone antennae?
  118. So how do you install a Chip????
  119. Check out the Phaeton deal. Not too bad conmpared to a D3 which is over 1000 a month
  120. Check out the Phaeton deal. Not too bad conmpared to a D3 which is over 1000 a month
  121. Control Arm refund
  122. where can I find clear corner lights new or used?
  123. Got the chip!
  124. Wireless OBDII
  125. Just chaged all of my contorll arms! :) ONe question--
  126. First snow drive here in Norway fall 2004 (Video) (removed)
  127. Anybody know an experienced stereo installer for the A8L in the Chicago area?
  128. Stereo upgrade question...
  129. Water Pouring Out of Rear AC Vents
  130. Anybody want/need the crappy analog phone that came with my car.
  131. What type of bulb is the foglight?
  132. A/C codes
  133. CEL and Codes..
  134. Has anyone used this stuff? Is it good? Lubro Moly Vollsynthese Energy - 0W-40 HD
  135. Mmmmm, lighted mirror caps...
  136. Hit or skip?
  137. Tranny service
  138. Spray painted my Tail pipe and Muffler chrome.
  139. current A4 owner seeks advice re: used A8 purchase for wife
  140. How hard is it to change fuel filter? 97 A8
  141. What are some good tire choices for an A8L with 245/45-18's?
  142. Can I just use coolant straight out of the bottle without mixing it with demineralized water?
  143. Has anyone heard how the Tranny Replacement is going in PaulW's garage?
  144. update car service
  145. 2000 A8 Rear Drivers Door Glass
  146. performance pulleys for the a8
  147. Anyone here the bidder on the ebay ecu upgrade?
  148. Ryoung, did you solve the mystery of the 26HP gain swithcing oil?
  149. message to Wahaudi
  150. Touch Up Paint
  151. 245/50/17 on 1999 wheels PaulW
  152. custom brake brackets
  153. 97-99' Owners: when did you change your timing belt?
  154. Interesting item on ebay.
  155. Headlight spoilers
  156. SNOW wheel-tire packages from RONAL USA, 16-18"
  157. Coolant Flush
  158. All wheel drive motorcycle
  159. coolant overflow tank
  160. 18x8.5 et 30
  161. Opinions on the D2 Blue Interior??
  162. Auto trans fluid change - stealers are twats
  163. Audi Transmission mystery
  164. For those who serve, thank you from TJM Motorsport...
  165. Here is my home made engine support tool.
  166. Have you ever seen a 94' 100 with a 02' A8 transmission in it?
  167. Cold air intake (upgrade for 99 A8)
  168. there oughta be a law
  169. Miles to empty?
  170. OT - Whither "60 Minutes?"
  171. broken air box
  172. Hey guys - S8 question
  173. Escort Passport SR7
  174. stock size in mm of springs on 1997 A8
  175. lucas
  176. Somewhat new here, what's the deal with the trans oil/filter replacement?
  177. Ever Replace a Transmission Before?
  178. the best car detailing in NYC
  179. Tire "howl"
  180. can someone post diagram/pic of '00 a8 air filter box?
  181. a6 4.2 stock rims. 8.5 or 8 wide?? will it work with 225 55 17?
  182. Weight balance of A8.
  183. 18 x 8 Rims w/ 33 offset. Fit on 2003 A8L and tire size?
  184. car in for service
  185. i think i know what the new s6 & s8 engines will be....
  186. any one bought any control arms from this EBAY user>? import_service_works
  187. has anyone changed the chrome trim around the windows to completely black trim?
  188. Snow flakes a-comin?
  189. Received Taidan Garage Remote
  190. Tire siping....I know its popular in Europe, Canada, and extreme winter states, anyone know of any
  191. Navigation- Garmin
  192. How do the D2 and D3 interiors compare? More...
  193. 2000 A8 lowering spriongs & shocks
  194. Should my 2000 A8 have a heated steering wheel?
  195. wood trim
  196. OT - Tonights Aurora Borealis Pics
  197. collision repair
  198. Anyone here have an S6 Avant?
  199. Transmission fault code..trouble shooting question
  200. How come some 2001's have the old steering wheel without the tip controls?
  201. Tire wear...
  202. Convert to American specs
  203. Get ready for winter.
  204. ABS/Brake Fault Code
  205. Power steering fluid/filter cleaning.
  206. Fix for heated steering wheel?
  207. Back on the market for a car. What should I get.
  208. Snowflake on dash?
  209. No response D3: Can someone here Help? Does the '04 D3 A8 with 19" wheels have aluminum valve stems?
  210. Where can I find what options were available on different model years?
  211. Cruise control only works part time
  212. Summer is over-Now I'm back!
  213. Great S4 forum post ...
  214. Air Con flapper/damper problem
  215. antifreeze leak on top of the oil pan
  216. A8 door problem, Need help!
  217. Clear lens
  218. My SRX installation.
  219. ABS problem solved, Praise for AW and Dealer.
  220. Nokian Winter Tire pricing. I hooked us up with a little group discount.
  221. 28mm rear sway bar?
  222. Driver's heated seat worked......Sort of.
  223. tiptronic shifter
  224. SoCal REMINDER, don't forget to RSVP -- Saturday DEC 4th, the "Audi Odyssey" holiday party
  225. Selling Chrome Mirror Housing for sale 1999 A8
  226. Control Arm kit
  227. Continental ContiExtremeContact. Should I get htem for $80 each
  228. Highest Mileage in Audi A8
  229. question on stock size cat and exhaust pipe on 1998 audi a8
  230. Garmin Street Pilot III
  231. Resusitating my new found treasure
  232. Attempting the aftermarket handsfree phone install...few questions!
  233. Audi usa specials!
  234. Analog Voice Activated Cell Phone Book(s)
  235. one more wheel q: would 17 x7 wheel work??
  236. Would you recommend Winter tires?
  237. New Prestone ads in print and on TV insisting that their new antifreeze ...
  238. Check Engine Light
  239. Will these rims fit my 99 a8?
  240. Is this belt OK for my baby? I got it for $37. Dealer asking over $70
  241. LE-30 laser jammer install write-up.
  242. 38 vs 35 mm offset
  243. Can anyone show me pics of 16inch 2003 A8L. stock rims
  244. what year was standard wheel base a8 discontinued from US market?
  245. Can anyone host exhaust sound clips from my A8?
  246. Saw a beautiful '01S8 For Sale...in North Atlanta burbs @ a euro type car lot....
  247. need light socket
  248. front plate cover
  249. Los Angeles Area S8 needs Service - which dealer is
  250. Anyone have some "pie plates" for sale?
