PDA
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. 2001 S8, 60k..services up to date exept plugs, trans redone in 07.
  2. are the washer tank pump grommets available as separate parts? Mine is leaking and I don't see them
  3. transmission swap appears to be a success! (long)
  4. Oil goes down, value of used A8 goes up?
  5. suspension component thunk
  6. Tozo & some others might be able to make sense of these pics/diagrams from a ZF repair kit.
  7. Anyone here live in Connecticut with a vag-com ?
  8. CD's hiss. AM reception poor. What gives?
  9. Anyone know the bore diameter of an A8/S8 rotor?
  10. My dad needs a trans on his A8, you guys used this guy on ebay?
  11. tip 'o the day - squeaky control arm
  12. Ciggy lighters won't
  13. What's supposed to be here? missing some sort of trim piece. And I tried on some OEM wheels.
  14. So lately my car sounds like its not running on all 8 cylinders...HELP
  15. How to remove 3rd brakelight cover when sunshield is installed. Cannot pull the cover backwards.
  16. EPC light on and no throttle, getting these codes. All buttoned up and ready to roll!
  17. Rear electric sunshade
  18. ODB II scan tool(from local auto store) shows "(MIL) is off" and ...
  19. Warning light update.
  20. Thanks Gondar! Now Gabor, Paul or anyone...S8 dies after starting...
  21. kudos to the list
  22. Brembo vs. Lucas front brakes
  23. I need Gondar's help!!!!
  24. looking for wheels in Chicago/NW Indiana
  25. can anyone run a carfax for me?
  26. gps, navigation problems
  27. 142 mph in speedo and still climbing before I let off due to exit. Planted and solid as a rock.
  28. transmission is installed, not quite right though
  29. Key stuck in ignition after breakdown
  30. Question for those with aftermarket xeons -
  31. should i buy it?....
  32. Newer ETKA for XP?
  33. the D2 vs. the D3
  34. Replacing Door Mirror
  35. timing belt 90k or 105k?
  36. 98 A8q partout in Boston fyi
  37. PaulW, did your rns have these side bars?
  38. timing belt issues in the 40v engines?
  39. What are the main relevant changes between a D2 and D3?
  40. Fuel Pump Replacement Costs
  41. intake manifold (IM) jammed actuators, saga continues
  42. body kit(s) for the d2, STFA to no avail
  43. strut measurement - I lost track of your post or email :)
  44. Replacing 125mm mirror with 175mm
  45. any European members have the electric tray table option ?
  46. Is it normal to hear air movement at the master cylinder as the brake pedal is pressed?
  47. Brushed aluminum shift trim mod. Pics inside...
  48. Rear caliper won't go in (be rotated and pushed back)
  49. New wheels
  50. OT: Never steal cars in an unfamiliar neighborhood.
  51. has anyone changed a rear main seal on a 4.2? There's a reference in the Bentley about a "dowel"
  52. Vag.Com
  53. Unburied.
  54. electronic issues after body work
  55. Can a McPhearson spring-tensioner of 1000kg compression-strength, pull A8 springs together or..
  56. Intake manifold (IM) actuators jammed/finally unjammed
  57. pic request: 20" B7 rs4's on a d2
  58. Why do I have a slight whine after transmission service?
  59. Got my Tozo'd VB back this morning....need hardware advice....
  60. RNS-D questions
  61. Crazy tow Idea....or is it?
  62. Trans Oil Change pump
  63. rim question
  64. starter hookup - Paul, read your post about connecting to the wrong solenoid post
  65. Warning light help, please!
  66. Winter Tires
  67. DIY alignment
  68. Bosch ABS "brain" rebuild/replace
  69. Transmission Information :Tozo! ;-)
  70. ****Hartford CT GTG - New Date - Wednesday, September 17th
  71. Forced cabin air circulation - How does it work?
  72. specs on custom s8 exhaust?
  73. Ignition Control Module/POS - which is which
  74. I won 1st Place at DubFest 08!!
  75. when do tie rods/control arms need to be replaced?
  76. intake pic
  77. tie rod ends & control arms
  78. Riverside Audi
  79. //S6 Plus Avant - anyone 'interested'?
  80. ***Postponed, 9/9 Hartford CT GTG, due to weather.....new date to follow
  81. Audi replacement fuel pump failures
  82. Stupid Questions, (New owner with NO manual)
  83. New noise under hood, what is it?
  84. I have 3 codes. 591, 592, 1044 incorrect software code.
  85. 40 V intake manifold --jammed actuactors, disassembly of IM-halted
  86. So my fuel gauge read empty on a full tank once agan. I had replaced my fuel level sending
  87. For the tranny specialists: a tip from across the big pond
  88. headlight leveler alarm
  89. what kind/type of fog light do we use? (face lift) h3?
  90. Talk about lesson learned
  91. proper name for the pie plates?
  92. Is there a substitute for Mineral Oil
  93. I am looking for a green bumper for a '97 A8
  94. Key Source/color code
  95. Remaining lurking for now with a new V8q 5 gang
  96. Whoa! The THUMP! revealed
  97. In an attempt to get rid of those morning squeaks as the chassis settles in...
  98. When is enough enough?
  99. Have 18" wheels for sale with tires made by RH!!! 12" tires in the back!!!!!!
  100. Transmission control function: Perhaps only Tozo has interest
  101. my elaborate transmission fluid filler
  102. cool...turning the steering wheel causes 'rubbing' noise...
  103. Advise please....Now that my interior is all torn apart, I am taking the...
  104. I guess I can go ahead and order my new S8.
  105. 2002 S8 shuddering. Im scared of what this might cost
  106. A8 stock strut/shock lengths
  107. Anybody tried to use a TT MFSW?
  108. Another RNS-E install with questions
  109. Changing oil on the D2 for the 1st time got 2 questions?
  110. Temperature Thumbwheel on Dash ??
  111. mass air flow
  112. Vavona wood saga
  113. So...I slammed the brakes around 70 mph and the car left a 15-20 foot skidmark on the left side.
  114. So, one major hurdle cleared- head was able to be fixed at the machine shop. It is now on it's
  115. ECU defective
  116. Changing rear discs and pads. Does handbrake need adjusting afterwards. (Pads are almost gone)
  117. OK, another S8 coming down the line for sale (sold the last two S8's)!
  118. 99 Trunk Lid won't seal, opens itself on bumps wtf
  119. interesting reading (MP's replies in particular)
  120. Are there any repair manuals for the A8?
  121. Vibration in rear
  122. Gentlemen... HELP...How do you get the %^&*$# drivers side AC vent out?
  123. Stainless brake lines?
  124. 19" Tire Offerings
  125. NAC: Watkins Glen - Vintage event... freebie crew passes to the first callers
  126. Assorted Questions / Inquiries for 2002 S8
  127. Week 2 Update: Ferodo DS2500
  128. Tozo....got a A6 4.2 slushbox sitting around......I'm losing reverse, failure is
  129. new brakes for next week
  130. ZF Valve body rebuild
  131. Where do you guys buy CV boot?
  132. FYI: Failsafe thermostat at autozone, pn 7304-192, $20.
  133. Spacers cause vibrations. I give up...
  134. looking for Cashmere A8 L
  135. Who here is going to Road america next week for the Audi event?
  136. OEM timing belt supplier : 2000-2001 A8?
  137. //SFest '08
  138. Does anyone want to see an F clutch repair?
  139. Anyone elses brakes go to the floor after not being used or being on a four point lift?
  140. Can TB be changed without renting tools on 01 A8?
  141. eng conversion
  142. From our BMW friends regarding Transmission service
  143. Harsh kickdown
  144. '03 S8 transmission..vs. 02/01 S8
  145. V8/S8 owners
  146. paging paulw and kynz
  147. CRAZY TRANSMISSION?
  148. Road trip
  149. '97 A8 Ignition Switch would not turn off engine
  150. ***Reminder, Hartford, CT GTG - 9/9/08***
  151. Help...First time post
  152. High Mileage anyone? my '02 is up to 195k miles now, still going...
  153. x-post: Spacer Sizing Tests
  154. S8 rear brakes on A8 ?
  155. NORTHEAST AUDI End-of-Summer JAM.....3 weeks away!!!!
  156. Replacement Nav Knob ?
  157. Dear S8: Where have you been my whole life.
  158. Pic of the A8 with the 20 and H&R's
  159. Blue D2 spotted on CT 10 in Farmington
  160. FYI, dont try to mail liquor to CT
  161. Pimped!
  162. A8 technical question
  163. The SFest Gallery is COMPLETE!
  164. 1998 A8 4.2 ocatane.......87 vs premium?
  165. 98 a8 4.2 front bumper needed
  166. OT: Audi beefs up Ad Budget
  167. Our favorite Troll strikes the D3 board
  168. Need help w insurance settlement "offer"
  169. My interior light show
  170. off chance: anyone looking for a yellow RS4 6k never titled - ~ low $50k's? 8-)
  171. Chrome dreams...
  172. Who's your Daddy-could this be a replacement???
  173. Busy week.
  174. My //Sfest 08 pictures (cross post)
  175. Looking for an ecu
  176. PSA - The Parts Bin has 15% off through Labor Day. I am not affiliated just passing it on...
  177. Hmmmm, Dealer changed plugs seems like lower gas mileage
  178. again, why are soooo many A8 owner having to rebuild their tranny???
  179. My //SFest pics
  180. Does a 99 A8 have a replaceable PCV valve?
  181. Anyone used the Febi brand ATF? Seems like it's just packaging..same as Esso or Pentosin?
  182. priced too high?
  183. rear cam seal leak - 40v
  184. Cylinder Numbering & Spark Plug Question
  185. Headlight control module testing???
  186. Another update on the blown TB...
  187. Seeking buying advice - '99 A8Q, 80K miles
  188. Hey Paul, where are those SFest photos? :-)
  189. Valve Body multi pin connector removal?
  190. The reason for the finally off-ing those modas:
  191. This can't be right.
  192. Any of you guys from West Virginia sell/trade an 02 andorra red (looks like it) S8 recently?
  193. Car won't shut off
  194. How do you know if your intake manifold is not working?
  195. aftermarket GPS/sat/radio
  196. Are there any UK members here that would be willing to help out.....
  197. I removed my intake manifold this weekend, pictures....
  198. PaulW, someone copied your license plate
  199. Can anyone recommend a used parts source? I haven't had good experiences.
  200. 98 D2 - anyone have a front view pic showing the grill and bumper? I'm missing some parts
  201. Zumkopf, you are not alone...
  202. Eibach Pro Kit with Bilstein Sport Shocks
  203. '01 S8 $12,800
  204. Can you adjust the backing position of the right hand mirror???
  205. Any 19" moda R6 owners?
  206. Ignition Control Module Location
  207. Valve cover Gasket
  208. Suggestions for Cleaning Tan Leather ?
  209. If anybody is lookig for a RNS-E
  210. For all those following my little saga, here's the latest...
  211. Hey Gondar- while we're on the subject of transmissions..
  212. FS: Five Full Size "Spares" (17" OEM 5 Spoke Wheels)
  213. Dunlop SP8000! Someone was looking for 1. I have. denbis@aol.com
  214. Requesting opinions on 2 wheel options, pics included....on a mission today.
  215. Source for floor mats with logo?
  216. S-Fest - parts I can bring if anyone is interested
  217. '98 A8 D2 Quattro no power...
  218. Another S8 sold, and another one bought! Anyone looking for a black '03 S8??
  219. I had the tranny from my other car bench tested now that I need it for my wife's
  220. i read in my manual the a8 98 had a 17" wheel option. what model was it?
  221. S8 Tranny Flush question.
  222. Five 17" OEM 5 spoke rims
  223. The correct fog light bulb for a pre-facelift A8 is an H3-55W.
  224. Getting rid of Her....
  225. 1998 A8 A/C Low Side Charging Port
  226. Paul W's i-pod integration write-up questions
  227. Mobil 1 Synthetic ATF now "suitable" for LT 71141 applications - transmission experts please comment
  228. Installed the Ferodo 2500 Pads 2 days ago.............
  229. Brake question
  230. Can I put lowering springs on my car and keep the stock shocks?
  231. Adaptive Cruise Control in D2 A8?
  232. Kudos to Carson at Riverside Audi
  233. Under headlight trim
  234. Can someone give me the torque specs for the intake manifold bolts on a 40v?
  235. will a 2007 A4 S-line wheel fit my 1999 A8? are the center holes the same?
  236. Sooo, I get ~ 200 miles on my first half tank (indicated) of petrol and the another 80 miles...
  237. Finally, MIlltek S8 and A8 SWB (D2) exhaust system back in stock...
  238. looking for an a8 1997-2000
  239. Tiptronic mods?
  240. Off to the mountains this week for snowboading-Yeehaaa-cant wait to get
  241. What spark plugs are you running?
  242. Need brakes for my '03 S8...
  243. Anyone have experience making an insurance claim?
  244. F**K! The timing belt tensioner went as well! I have a feeling this is going to be pretty expensiv
  245. Got the Staggered BBS's on.
  246. Dashboard display has disappeared
  247. A8 FAN removal
  248. Rear driver side window
  249. Anyone know where are fuel filter is located? (facelift/40v)
  250. question about oil
