- Where to get new wiper blades?
- help ,01 S8 not starting
- Rubbing alcohol and a q-tip frees up sticky buttons instantly. 03 warning label=What the heck...
- Where is the leak detection pump 97 A8 4.2
- ok, I'm gonna crash the HID upgrade party. For a facelift car, do I want H1 bulbs?
- C/V boot replacement
- Audi for daughter
- Bosch Pump for Fuel Pump Assembly
- It's amazing....in just a few years, the D3 S8 will be devalued as much as the D2
- rear headrest removal on Facelift/ S8?
- Failed Emissions Test Today (MD resident)
- Sniffs back tears-Sold the car today-very sad to see her go and I will
- Were S8's available with Ming/Ecru in '02?
- Front end noise (clunk) 99 A8
- Thanks for the "Paintless Dent Removal" info!!!!
- Where is the coolant going?
- Which sun shade is for the D2 A8L?
- Fuel Pump Question
- Fuel pump follow up...(kinda long)
- Tempting electronics mod upgrade
- Does anyone know where the Intake Air temperature (IAT) sensor is?
- How does the climate control get the cabin temp?
- EPL's 2008 Holiday Specials! (repost)
- Winter tire setup, will 17" S4-B5 wheel fit 01 A8L?
- Does this headlight aiming procedure work with the D2?
- How hard to replace rear cam seals?
- seat occupant sensor????
- I think my a/c compressor clutch may be going
- vag-com fault codes
- Any recommendations on things to do/see in Budapest?
- wheels wheels wheels
- exhaust mod
- lowering w12 with KW
- Replacement 02 sensors (again)
- resplendent response
- hid headlights
- So I got a 3rd party OBDII cable
- Hey PaulW, what are the possible instrument cluster values for adaptation in channel 62?
- Anybody remove the visor warning labels? How can I get them ugly things off?
- fuel pump - tank question
- Repair log...Sure sign of mental illness (long)
- a8 trans pump
- rough day at the mechanic
- FINAL REMINDER: EPL's 2nd Annual Dyno Day/GTG - TOMORROW
- the HID chronical..
- silver40v? Nope:
- Versatile Automotive Diagnostics
- 02 a8 trans squeal 1st and 2nd
- www.audidatabase.com
- a8 transmission in limp mode
- Relay trouble, What the heck is going on!?!
- An Audi is Like a Trophy Wife
- Just out of curiosity, anyone have an extra D2S bulb lying around? I think one of mine is going...
- i need a trans rebuild
- VDO fuel pump pic - does this look like the Bosch or OEM pump?
- Anyone have experience with Goodyear F1 GS-2 Tires? They are $99 at Tirerack
- Rubber bits!
- Racing Idle...and then no start.
- $2600.00 S8 parts car (engine fire) in Orland Park,Illinois on ebay
- Anyone remember that winter video, about 4 years back....
- replacing gas tank help
- WTF! Plastic does not work well in cold!
- A 8 Battery
- Is it worth it to recode the 02/03 trans?
- '01 Radio Controls Question
- ordered fuel pump 2 days ago (for my wife's car) and now I think mine is going....
- New Tires on the S8 - AWESOME!
- Hmmm, browsing through the off topic and found nice pics [ww]
- dash dimmer switch in w12
- D2 RNS-E Write Up
- I installed another Garmin Nuvi Gps over thanksgiving, this time in the 98 A8.
- Wifi allows you to connect OBD-II to iPhone...Awesome alternative to VAG?
- instruction manuals for w12
- bobbling on suede seats
- Planning for future
- wheel options for S8
- Unfortunate Incident on D3 board - Timing belt broke
- How common is dead cruise control switch?
- Need help-- Update
- How do i connect the button just for?
- Any interest in seeing a video of an A8 with 186,000 miles being started after sitting in a warehaus
- Weird: sunroof self-opening on jump-start, and fix
- Vag question and misc
- Rear springs
- Transmission hunts like crazy.......but not in a typical way....
- 01 A8 Xenon - Headlight up/down won't adjust
- ZF tranny update on my situation
- I was thinking of SlicerDicer's dealer tranny fix by replacing a cable.
- Drove an S8 :)
- Hi fellas! I miss having a car. That is all.
- Always great to see Robert Hack back on the forums.....
- Reminder : EPL Dyno Day this Saturday!! (2 spots still available)
- Anyone interested on a set of 4 OEM 17" 5 spoke wheels with tires?
- Pressurized tranny.
- A/C Condensate Drains at the Tranny Tunnel
- what else to replace when doing the transmission?
- SNG Pre Cat Oxygen Sensors
- code 18032
- lowering the w12, have the standard european suspension, 1bm
- my buddy has a 2000 A8
- crankposition/rpm sensor/ misssfire
- any 3.7 a8s around how many were there in the usa ?
- Could it be the starter motor
- checking ignitioon wiring
- mAgnum8 - fuel pump from AutoHauz
- suspension w12, trunk sticker
- let's play a game called: "Name that Noise"
- 02 a8 trans problems
- Alls well, but then it's an Audi
- QUestion about TDC
- d2 w12 suspension mystery
- A8 tranny install
- Pretty, black, facelift A8L kicking it with me on OH tpke., around noonish. Anybody?
- a8 trans squeal 1st and 2nd when the car is cold
- Finally got the S-Line wheels on my car. Pics
- So a friend of mine drove his 01 A8L thru the car wash with clogged drains and now the Dealer wants
- ECU/ECM
- cheap 02 sensors dont work!
- torque converter problem
- this is a scary pic - roller failure
- any one have a sales brochure for 02 or 03 A8 to sell or lend?
- visit to the dealer
- Looking for a pic of tire width comparisons......
- read this carefully :)
- Paging Bruce M...
- Sorry, I couldn't help but to share this one.
- paging dutch doofus...
- I got these axles on ebay... Anyone tried em?
- Time to play guess that thing! (seriously)
- Cam timing
- Memory Seat Part
- A8CT, parts request
- replacing climate control bulb
- quick question
- Help please-Can anyone with a pre facelift car please measure the
- New source of control arm clunking on my car
- Where is a good ground point behind the radio?
- Best nav for D2 01?
- Everyone, allow me to wish you all a HAPPY THANKSGIVING!
- Broken front spring..........
- :: ECS Tuning :: Annual ECS Tuning Holiday Sale and Holiday Give-A-Way !!!
- New S8 owner!
- No affiliation - 18" BBS wheels/tires on DC Craiglist. Guy sounds desperate.
- How would someone go about fixing rear headrests and lumbar supports?
- Looking to get a ride in an S8 in minneapolis over the holiday
- noob question
- Control arm time (again!). What's the consensus? Stealer/OEM?
- '02 Brake LIght Bulb Replacement
- What to do when the dealer can't fix it...
- Hunting and Dropout Fix, Dealership Style! Free too!
- clicking noise from dashboard
- Is there a way to reset the "parking" sensor on the car?
- New R8 wheels on my 2001 S8
- No need for an SUV when you have an A8 or S8
- PN for cruise control / light stalk?
- 99 A8, does transmission rattle on cold start (30 F.)?
- What have they done to my ECU?
- D3 Envy? No more! Audio & Telematics install.......(long)
- Kick-down switch on pre-facelift cars?
- would this do any damage?
- The TozoTranzFixed Transmission Emporium and Bible Study
- Another Fuel pump question
- I love my S8 but sometimes it drives me mad...
- hazards are flashing and wont stop
- guys do you know if a complet swap of an RS6 fit an A8 98 ?
- Important tire safety info..kind of long
- Brake squeal question - 02 S8
- Laser jammers free for Audi and BMW owners? Anyone seen this link?
- Hey guys, check out my new car :). Moving up a little bit from my A8, even though I'll miss it!
- 97 A8 4.2 Missfire
- Raxles and Mfg Date question. I'm all set with Marty but I'm curious...
- 20% Storewide Sale. Win a Wii Console and WiiFit.
- Fin antenna on 97?
- limp mode - it's back :(
- DRL
- Need help
- Lurker here since I've considered buying... this
- racking my brain
- S8 Inside Tire wear.....
- Instrument lights in 97 A8 won't go off!! Please help
- Torn front outer CV boot. Bet I can't R&R in 10 minutes like them Chi Town boyz...
- is the symphony II faceplate the same as the symphony I face plate?
- Best european D2 forum?
- Front wheel bearings worn out???
- STILL looking...
- brake /heat light
- 5HP24A Transmission, Valve Body Fix - Modification Version 1
- Transmission failed on 1999 A8
- can an engine speed sensor cause erratic transmission shifting without throwing any codes?
- Ok, so after a long summer/fall
- 37lbs. front, 34lbs. rear, good dry, slide wet.
- Got the snow tires on
- Reminder, wheel clearance and blem sale at Achtuning, save hundreds!
- dark cloud gone
- check eng
- transmission limp mode - pay attention to ALL codes
- '00 A8 Spark Plugs - Where can I get them last minute?
- More questions from S8 newbie
- I'm back, baby!
- Does anyone have the timing belt tools available for the 32V engine?
- Fuel pump again
- Warranty Info for a '00 A8 w/ 65k miles?
- Anybody need facelift A8 rotors or polished exhaust tips?
- Center vent Garmin Nuvi Nav
- Paging JimR to the white courtesy phone
- And I thought this is an International forum for Audi A8 owners not a personal vendetta vent
- dark cloud in w12 sky
- PSA: 03 S8 w/81k Avus for sale near me. If anyone is interested I can check it out..
- Question from a (very) recent S8 owner
- Looks like they are coming down.
- Hey guys, quick S8 questions
- okay great
- yo
- pics,duh
- Snowing here north of Toronto...Anyone else? The roads are disaster where I am
- pics
- BruceM YGM and What would be a good insurance settlement for my car?
- pics
- Control Arm Clunk-Is it dangerous?
- exhaust for w12
- Anyone have experience with "paintless dent removal" on an S8???
- Moving to a country that they drive on the Left side of the road...
- Boge versus Bilstein Query
- Control arms fixed........Again. Thanks Gabor!
- HID lighting
- Noob to S8's Forum- Just wanted to say hello and share my latest purchase
- lowering d2
- Spotted beautiful silver S8. 285 heading E. in Atlanta about 6:00 PM. Anybody here?
- facelift trans trouble ... codes
- Posted this in VAG-COM forum....but maybe somebody here can help
- Thanks goes out to Jim
- x-post amazing
- Hey Bob, it's back
- bac2h:
- Who had the "diesel clatter" and what was the cause?
- O2 Sensor preventative maintenance
- Tranny screaming. Sounds like ...
- tranny problem
- REMINDER: EPL's 2nd Annual Dyno Day/GTG - Saturday, Dec. 6th
- I waited patiently for a good deal on snow tires and found it!
- 2001 A8 4.2 hard steering turning right only
- F Seal F'd
- I have an extra set of wheels with all season tires. Would siping make them acceptable for snow?
- Cheapest place for Navi discs?
- d2, w12,
- If the energy abosorber in the front are bent, can they be replaced?
- any ideas on where this coolant is leaking from?
- A8 University video
- Should a '00 A8 timing belt be loose like this? (see pic inside)
