PDA
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. 2001 Audi A8L Blower Motor Won't Stop Please HELP
  2. Interchangeable Transmissions for A8
  3. UK: Yuasa batteries?
  4. i might be back ....
  5. No reverse barely
  6. NO: Audi s8 d2 engine blows up
  7. 6 speed swap is getting ready
  8. 360hp or 300hp 4.2 liter, which is better?
  9. Instrument cluster not working
  10. 99 a8 no power at ignition. Please help.
  11. WHEEL?
  12. Straight pipe exaust
  13. Small Black Boxes on ground wire to both heads???
  14. Fuel pumps in, not
  15. My first car. An Audi A8 D2 2,8 quattro.
  16. DIY: Removing the head from D2 A8 (AUX) and valve job
  17. power steering
  18. Water in flooring, not AC
  19. Removing the head from D2 A8
  20. BR: Dashboard cluster is missing columns of pixels
  21. BR: Fuel gauge shows 3/4, but it is empty
  22. BR: Lost my front blinker lens (left)
  23. São Paulo, Brazil - Selling my 1995 Silver A8
  24. Engine 4.2 question
  25. Windshield/windscreen compatibility
  26. Buzzing noise driver's side dash under windshield?
  27. 2002 S8 Windshield (gray tint)
  28. Siphon gas?
  29. 2000 s8 d2 6mt swap
  30. 2001 S8 - Excited to be a new owner
  31. Long Wheel base hand brake cable needed
  32. Air Bag electrical question
  33. O2 sensor
  34. seat belt wiring
  35. A8 vacuum hose diagram
  36. Will 18x10.5 +22 fit?
  37. Resurrecting 1998 Audi A8 Base
  38. 2013 A8 with EPC waring light and multiple DTC's
  39. seat belt
  40. New to me 03 S8
  41. small piece needed
  42. About to be a new S8 owner, have questions
  43. Rt. Front turn indicator lens..
  44. Secondary Air Injection Pump Relay and Fuse Location
  45. 255/45/18 vs 245/45/18
  46. O2 sensor location?
  47. Help, need inner fender
  48. 22 inch rims on s8 d2????
  49. Transmission fixing issue
  50. Powering fuel pump by jumping
  51. ECU immobilizer defeat
  52. Transmission Troubles
  53. upholstery repair
  54. Where to source replacement catalytic converter?
  55. Cam timing question - 1 link off?
  56. Junkyard transmission inspection
  57. Power steering pump - Major failure!?
  58. ECU removal
  59. Collision Insurance?
  60. New headlight bulbs, now intermittently shuts off one or both lights
  61. 2001 S8 Restoration
  62. front turn glass lens (99)
  63. turn signal light assy
  64. 4 wire 02 sensor to 3 wire?
  65. 4.2 Engine Review
  66. Broken Seat heater.
  67. marker turn signal 1997 - 1999 A8
  68. Leak out of fluid reso - S8
  69. chances are?
  70. compatibility conflicting info
  71. Side panels in boot
  72. Audi D2 parts
  73. Upgrading radio?
  74. Taking a chance
  75. Show off your wheels.
  76. RHD D2 A8 Hood Wire Replacement?
  77. getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
  78. 2001 Audi Promotional Video TT S8 Allroad
  79. A8 D2 ABS sensor
  80. 2003 D2 No Reserve Auction - CarsandBids.com
  81. stock exhaust diameter
  82. RS6 Brake Upgrade on D2 S8
  83. Fuel issue, 3/4 tank runs out. Help needed
  84. Traction light blinks on long sweeping corners
  85. Part out or Fix
  86. Coolant leak, not running.
  87. Just another issue
  88. Labour time for camshaft tensioners on 40v 4.2 A8????
  89. deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
  90. "New" 2001 S8 In The House - Was this yours?
  91. ASR light mysterious behavior. Please help
  92. Removing Front Seats
  93. WTB: Rocker panel rock guards, have p/n's
  94. Weird vibrations
  95. D2 Shopping - A8 vs S8
  96. Interior hear very hot on drivers side
  97. Interior hear very hot on drivers side
  98. Crank and Heavy shaking but no start!
  99. A8 D2 Wipers and Turn Signals INOP
  100. S8 Number Plate
  101. DONOR TRANNY FOR 6SPD SWAP
  102. washer issue
  103. Servotronic valve
  104. CV Axle seal replacement, fluid?
  105. No start, new Batt,
  106. Anyone recommend a shop in Minneapolis?
  107. Upgrading my Steering Wheel
  108. DFW Roll Call!
  109. A8 D2 no crank
  110. TR: Hi guys
  111. A4 wheels on a A8
  112. Lower rear hub bushing
  113. ABZ or AEW engine installed?
  114. Wanted cam bearing
  115. Broken cam bearing
  116. HELP needed cam notches
  117. 2001 S8 transmission options
  118. Engine noise in radio and poor reception
  119. Audi A8 seat as a chair?
  120. 2002 S8, 300k+ Miles. Am I crazy?
  121. D2 pre fl Audi a8, questions. About seats, ceiling padding details.
  122. car pulls to the right. need help.
  123. Upper front control arm
  124. aux fan melted off motor. smoking.
  125. Tiptronic help
  126. code PS0492
  127. Engine Swap, or Repair?
  128. 6.0 Litre Transmission
  129. Auxiliary fan removal
  130. Audi s8 transmission swap
  131. D2 Suspension Part Numbers and Letter Suffix Annoyance
  132. Catalytic Converters OEM vs Aftermarket
  133. How long do tie-rod ends last?
  134. Selling audi a8l for parts and new engine
  135. Car overheating at idle
  136. Brake block group buy, anybody interested?
  137. Crankshaft on ABZ
  138. Can i switch MAF Sensor connectors?
  139. A8L driveline vibration/shudder at 20 mph
  140. oxygen sensor removal and replacement
  141. Audi A8 2000 Camshaft sensor
  142. New S8 owner needs electrical help
  143. Fuel gage always show empty
  144. 1997 Audi A8 rear vent removal
  145. 02 S8 redline/shift points?
  146. Question about 2.5 TDi 132kw AKE
  147. 1998 starter harness
  148. car pulling to one side
  149. Geeze Louise, hood cable snapped.
  150. wood trim
  151. Audi A8 D2 Reasonable Transmission Repair in Mich.
  152. Crank seal front
  153. Lumbar height adjustment not working
  154. Throttle Body Alignment
  155. Headlight level warning light
  156. ‘02 S8 intermittent no crank
  157. Help: left side sexterior lights not working after timing belt change
  158. No low beams
  159. Audi D2 Reincarnation
  160. HELP! Where are the camshaft timing marks???
  161. Wiper/Washer and Turn Signal Connector Location? Ground?
  162. Radiator Hose: Where to buy?
  163. No coverage accident - Napkin Estimate
  164. Battery compartment size
  165. Chinese cam chain tensioners?
  166. D2 ABZ won't go above 4500 RPM
  167. Thermostat opening temp and clutch fan engagement temp?
  168. bolts on water pump
  169. A8-D2L cam timing
  170. seats are uncomfortable
  171. Got wet (fixed drains) now interior lighting issues
  172. What's more valuable?
  173. Audi S8 bad transmission... rebuild or swap to manual???
  174. 2001 Audi S8 seats plus door panels and carpet needed!
  175. !999 Radio w/CD Player in Trunk
  176. Oil cooler propensity to leak with age?
  177. Looking for a part: intake actuator diaphragm
  178. F125 switch
  179. a8 transmission lost drive and reverse
  180. idle car
  181. Leaking water reservoir ?
  182. D2 Throttle Body
  183. Weird running issues with A8 motor
  184. Wiper linkage 4D1-955-603-D
  185. Who's got these? STOP using them and return them...
  186. 2004 Audi A8L 4.2 Liter
  187. Glovebox removal
  188. crankcase breather hose
  189. Originally fitted 360mm front brakes, can't find replacements
  190. Xenon kit advice needed
  191. Low fuel level sensor causing HPFP not to work.
  192. 2002 S8 how to remove trunk liner/trim (and lid)?
  193. 2001 S8: YouTube Auction Rebuild
  194. EE: Car died few hours after connecting battery cables wrong way.
  195. a bit of advice on coil overs/springs shocks?
  196. Air Mass Flow
  197. Too late for Transmission Output Seal
  198. Bank 2 misfire on all cylinder and fuel smell
  199. Power Steering problem
  200. Suspension failure
  201. Timing belt job help?
  202. Cam timing chain tensioner help
  203. Help identify this fuse
  204. Best window tint color
  205. Some major work scheduled
  206. S8 steering wheel paddles
  207. what goes here, in the trunk tool holder next to the spare?
  208. what does this fuel pump "sealing plug" do?
  209. D2's at scrap yards
  210. Strange whining sound key on, not fan!
  211. New Forum Member - my intro
  212. Sunroof Leak (gasket/seal)
  213. Fuel gauge issue
  214. Anyone know how to contact TOZOM8 directly?
  215. Fuel issues i think.....
  216. WTB: Tow Hook for sale?
  217. Rear spring isolators and subframe mounts
  218. SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
  219. Euro rear license?
  220. Turn signals and wipers inop at same time
  221. I am lost with these repairs..
  222. Conundrum- fix or replace
  223. Audi S8 1997 clutch kit question
  224. Constant noise from behind firewall
  225. anyone have the symphony 1 wiring diagram?
  226. Timing chain tensioner guide replaced the plastic piece now having issues
  227. 5HP24A ECZ gearbox while cold making a hit when selecting D
  228. Ugly spring fail
  229. Installing new carpet
  230. Menu button not working ?
  231. D2 A8 Battery + and - terminals
  232. US red indicator rail light
  233. Aftermarket stereo wiring help, oem concert with Bose 4 channel amp and speakers
  234. Battery dead, can not unlock my S8
  235. Need a transmission? I think my 2001 A8 is a transmission donor
  236. No fuel pump after remove stereo and putting it back help
  237. Grille
  238. Audi S8-98 manual gearbox with OBDcodes
  239. NO: Supercharging?
  240. Must suspension springs be replaced in pairs? In sets?
  241. Front end clunking over bumps
  242. Energy Management System at limit
  243. High output alternator
  244. radio wiring help
  245. Car alarm beep
  246. Valve steam seal question
  247. Misfire and code P0321
  248. Wiring Help
  249. Type of hose for windshield washer?
  250. Honeycomb Mesh grill A8
