PDA
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. 2001 A8L central locking code question
  2. Feeler: Feeler: Complete Genuine S8 Cat-Back Exhaust
  3. 1999 A8 THE AUDI DEALER AND NEW FUELPUMP
  4. Valve Covers Leaking
  5. 98 a8 4.2 parting out
  6. Remote Key Fob Programming
  7. A great deal for someone?
  8. Dead Fuel Pump - I think (1997 A8Q 4.2)
  9. have an extra cup holder for a face lift A8 ?
  10. Thumping trans, anyone have luck with changing out TCU ?
  11. Time to stock up on Microfiber Towels at Detailer's Domain
  12. 2001 Audi S8 For Sale Low Price
  13. 2002 A8L Misc Items for sale
  14. s8 rear rotor diameter and offset
  15. Where can I buy a power steering rack ?
  16. Control Module for Climatronic (J255)
  17. A/C drain cowl blocked...
  18. Complete vacuum hose replacement
  19. Transmission Fluid
  20. Tranny goes to neutral when reaching4th gear and LIMP mode lights up
  21. iPHONE4
  22. new oxygen sensor same code
  23. Transmission Reverse Slipping 2001 A8L
  24. Anybody know the name or part number of this hose?
  25. Lower Valance
  26. WTB single cup holder for facelift D2
  27. Instrument cluster issues
  28. removing DRL'S and making your fog lights work.
  29. Trans Problems/ What am I missing/ Introduction
  30. concert radio in 97 A8
  31. BlackD2 S8 spotted today on LI, ne1 here?
  32. After market belt noise
  33. 1999 A8 15 minute shutdown
  34. I want to thank everyone and say goodbye....
  35. Fuel pump replacement
  36. Should I buy an A8?
  37. 1998 Audi A8 won't start till 3rd try
  38. Tranny problem? No power at take off
  39. Labor Day Special at Detailer's Domain
  40. Radio system sound quality?
  41. Timing the 2OOO A8
  42. 98 Audi S8 engine makes diesel noise.
  43. Phone Locked
  44. Audi Anarchy 2010 Writeup
  45. Advice needed (timing belt) 2001 S8
  46. What are you doing this weekend? How about Audi Anarchy 2010?
  47. Fight reverse rake with lowering springs
  48. High Idle - erratic readings
  49. Time for Brakes!
  50. Good oil change service in Cincinnati, Ohio?
  51. Hello all! Long time no see!
  52. Timing Belt Replacement 2006 A8L
  53. Second opinion wanted on transmission woes
  54. Confirm Correct Straight Arms With Ebay Sellers B4 Ordering
  55. Fuel starvation
  56. Wrong Straight arm? Which year is the new one?
  57. Fuel Filter
  58. Considering D2 S8
  59. Springs
  60. Greetings to a fellow D2 S8 owner in our area today, Page Mill Rd in Palo Alto, CA
  61. What hose is this???? Extremely Hard Braking Problems
  62. Fuel Pump ?
  63. Advice on what do to, ball joints and bent subframe
  64. And so it begins...
  65. Wanted Parts. (belly pan, armrest) plus questions
  66. Brake Switch replacement
  67. < One month to go until Audi Anarchy 2010 - The premier NW social gathering for Audi
  68. Looking for a good service center in Central NJ
  69. Potential D2 A8 owner in need of advice
  70. A-8 tcm? HELP!!
  71. Rough running / stalling after new alternator 2
  72. Rough running / stalling after new alternator
  73. Soot = rich mixture?
  74. Where can you get this beside the dealer?
  75. Black soot = too rich?
  76. Maximum Engine Speed Exceeded P1560
  77. wanted parts car
  78. Should I buy this 1999 A8?
  79. Completely random stalling
  80. What spark plugs should I get?
  81. P0455 - quick fix?
  82. thermostat replacement on 40V.... Help!!!
  83. 20% off Waterfest Special 7/20/2010 at Detailer's Domain!!!!
  84. Climate control
  85. Alternotor 120 Amp or 150 Amp 2
  86. Alternator 120 Amp or 150 Amp? 1997 A8
  87. Battery Light 2 1997 A8
  88. New member here... Hello everyone!
  89. What's next to break?
  90. Battery Light 1997 A8
  91. Is there a fuse to the Engine Check Light, Brake Light and ABS light?
  92. iowa to tennessee and back
  93. 1997 Audi A8 4.2 Quattro Transmission Problem!PLEASE HELP!
  94. 97 A8, how to open the door panel?
  95. VMR | Wheels - V708 RS4 Style PRE-ORDER
  96. I'm Back
  97. Transmission Problem or Something Else?
  98. 2001 a8l hesitation, shutter second to third gear
  99. tray tables for sale cheap...
  100. Auto-dimming side mirror problems?
  101. Can I reprogram the trip computer through vag-com/vcds?
  102. Some new 2000 A8L pics
  103. Superdaves Audi Fleet (picture)
  104. Anyone have this for sale????
  105. 2002 A8L or S8
  106. :: ECS Tuning :: D2 A8 Floor Mats - $9.39
  107. Trunk Button Assembly... part # included
  108. Need some help with engine misfire
  109. Want to confirm my bad tranny diagnosis. Rebuild time? Paging Tozo...
  110. 2 new fuel pumps and fuel pressure regualtor
  111. A8q D2 '98 - Transmission/ECU/TCM/Airflow Sensor related problem
  112. New to D2 / 97 A8
  113. 1999 Bose amp wiring diagram - need one
  114. Selling my 2002 Audi s8
  115. Fender liners wanted
  116. WTB: A8 fender liners
  117. 1995 A8 S-line German Spec
  118. Craziness!!! Should I Shoot It?
  119. audi a8 2000 left fender
  120. Radio Loss of AM/FM Signal
  121. Front license plate bracket
  122. Tranny question
  123. 2000 Audi A8..........WET
  124. Replacing Valve Cover Gasket
  125. Motor does not turn over - dead, dead !!!
  126. Auto to Manual transmisson Swap
  127. 97 A8 Transmission stuck in 1st
  128. problem after changing transmission fluid
  129. 1997 A8 Valve cover bolt (s) torque
  130. D2 2002 A8, For Sale, Only 69,000 miles, Splendid Condition
  131. vaccum digram
  132. starting problem
  133. 2000 A8 Tiptronic Transmission Replacement Needed
  134. Fuel Pump Problems... Still
  135. Kemparts - Throttle Position Sensor
  136. Is there anyone that can do timing belt in CT for reasonable price?
  137. a8 aux water pump
  138. What is this part called, anyone have a name or number? 4.2V8
  139. 2000 A8 MAF wire removal
  140. 99 transmission issue
  141. muffler
  142. Parting out A8/A8L or S8??
  143. Constant ca-clunk while driving!!
  144. 4.2 oil leak
  145. roof rack A8/S8 97 to 2002
  146. 2001 Transmission issue
  147. fuel pump through bolt won't come out
  148. A8 Transmission issues
  149. Rear Transmission Driveshaft Flange seal?
  150. D2 A8 Part Out, Lots of Pics
  151. looking at 01 s8, no reverse.
  152. 19 inch OEM wheels
  153. 1999 headlight brackets-headlight housing
  154. Key in Ignition and I get notin...
  155. 275s on 18x9 et 35?
  156. 1997 Quattro Steering Issues
  157. Smoked Corner Lights?
  158. Warning Chime Wont Stop
  159. D2 A8 no start sometimes
  160. Audi S8 Temperature Guage Reading
  161. Hawk pads
  162. looking for new hood for my pearl white 1999 audi a8
  163. Need help: Coolant Temperature Replacement
  164. '97 A8 for sale
  165. 1999 with salvage title and all parts
  166. 98 a8 quattro a.k.a. alumatub With Pics have a few questions too!
  167. A8 Questions
  168. A8L 4.2 quattro help please tires
  169. update on my super oil burner
  170. 2001 A8l rear diff leak
  171. Unusual oil consumption at 60k
  172. 1997 Audi A8 oxygen sensor location
  173. 1997 A8
  174. A8OC - The Annual Meet Details (UK)
  175. Fog Lamp grill (2003 S8)
  176. Need Power Steering pump & High Pressure Hose @ good price
  177. 40.5 Rejection set to: 30.
  178. EVAP Emissions intermittent vacuum leak, incorrect flow?
  179. poor response - please help
  180. Cly 4 misfire 16688 ,random mult misfire 16684
  181. 4D2 ABZ 1996 4.2Q Oxygen sensor
  182. Tranny limp mode without the limp
  183. Random Parts from totaled S8 for Sale
  184. Rear passenger foot well wet floor
  185. WTB 02-03 S8
  186. WTB: A8 ('94->) USA-model front corner (turningsignal) and rear lights!
  187. Fair price to offer on mint 01 S8?
  188. FS: 2003 S8 - Ming Blue - Endicott, NY
  189. WTB 02 or 03 A8 L
  190. Euro Lights
  191. Question on replacing starter 97 A8 Quattro
  192. Is the headlight lens sold as a separate part?
  193. Concert II in A8 96'
  194. Chrome wheel bent
  195. Linkage???
  196. 2000 Audi S8 ABS ECU location
  197. A8 4.0 tdi
  198. Pics of 255/45 tires on stock 18 in S8 wheels?
  199. Original Antenna replacement
  200. 2000 A8 TCU location
  201. '97 a8 no spark on #5
  202. No satellites?
  203. "Transmission Control Unit Incorrectly Coded"
  204. Overheating after 55,000 service
  205. D2 parts cost
  206. 2001 A8L Lower Grill
  207. Windshield cost?
  208. Engine Replacement 2000 A8
  209. HELP!!! all I want is center caps!!!
  210. Looking for D2 trailer hitch
  211. 2001 S8 Longetivity
  212. Power steering wheel will not tilt up and down
  213. Fuel Pump or Sending Units?
  214. 2002 A8 Front Brakes
  215. looking for door seall source
  216. is there an iPod interface for RNS-D ?
  217. A8 4.2 Quattro Sport 1996 Breather Pipe's??
  218. Armrest - searching for driver's side armrest
  219. wash wipe fuse A8 4.2 1996
  220. What size wheels & Tyres ?
  221. Aussie A8 Auttro drive shaft question
  222. Control Arm Differences
  223. 2003 a8 warranty
  224. Dynamic headlight dimmer control
  225. 1997 A8 codes
  226. Battery died no start,TBA??
  227. Control Arm Question
  228. VMR | Wheels - V708 RS4 Style Wheel
  229. Oxygen sensors - pre cat
  230. Turn signals are too quiet. Ideas?
  231. How-to Install a double-din head unit in a 2001 A8L
  232. Dillema: repair A8 or buy new?
  233. S8 California Catalytic Converter
  234. Head Lights Dont work
  235. Malfunction indicator light......help!
  236. Audi a8 rear transmission case seal?
  237. Enigine 2.8 30v V6 problem
  238. ESP and ABS lights on dash
  239. 12V switched and constant
  240. Transmission thump and hunt cure
  241. Remove panels
  242. concert radio volume control issue
  243. Brake issue
  244. Kenwood DNX 9140 A8 install
  245. Rear trans housing leak RR??
  246. Fuel Return Line replacement?
  247. cigar lighter & int light faults ?
  248. D2 Warm Weather Windshield and TomTom/Magellan iPhone Mount?
  249. Will Spare Tire Size Cause Problems
  250. 2000 A8L trans. problem
