- Final Drive for 97-99 A8 for Sale - Phx - $150
- New Owner, I have a code and a question..
- Water in Dashboard? "Dissapearing coolant"
- Transmission acting up
- 2001 A8 / 4.2 - erratic coolant gauge?
- Mysterious Brake Hose Fitting Leaking -
- 4 Wheels, tires and pressure sensors, 600.00 OBO
- Killer deal on new 40V bank 2 cam adjuster >>>
- Fog Light Bulbs - H3 or H7???
- Broken hydraulic reservoir
- think my mechanic screwed up
- will broken intake manifold linkage arms cause my check engine light to blink
- The look that compliments performance. HRE Wheels for your A8, from AWE Tuning.
- Re-Backing Floor Mats
- Nice Day, took some quick pics of the s8
- Purge valve again
- Brake info needed please
- Bolt torque please.
- Park Assist / Parking Sensors
- Audi S8 transmission problem 2
- Turn key...nothing but dash lights
- Cant Tighten Wheels
- Fuel smell in cabin.. only when Sunroof open!
- bad bulb warning light
- Temperature Gauge not reading
- Anyone with an A8 D2 with dashboard engine oil level indication?
- Stock up on your detailing gear 1st Day of Spring Special at DD
- 4.2 tip, - Fuel consuption "too high" ?
- How to unmount driveshaft
- Rim size and clearance on D2 S8
- D2-S8 / B6-S4 - Snapshots from Sunday Cruise - Enjoy!
- Decent but not overly loud exhaust for 32v S8?
- S8 Transmission
- 1999 A8 for sale
- Tranny fluid is definitely not lifetime
- Running Lights and Fog Light Question???
- Gas cap "whoosh"
- 97 A8 wont Start
- Oxygen Sensor Replacement
- 2002 S8 STARTS SOMETIMES BUT SOMETIMES DOESNT..NEED HELP!!!!!
- Soft brakes - Brake Acculumator / Bomb
- timing belt and valve cover gasket
- Car Wont Start
- is it ok to hand-crank engine with v-belt still on?
- Fuel Pump from hell.... >=O
- Condenser Fan Replacement
- Lo Beams Bulb Question
- Another D2 Transmission to talk about!!!
- Which Philips HID Bulb?
- Where can I find a used rear bumper cover for 2000 A8L?
- D2 S8 01 Cruise control question.
- Plate Block Off
- Last Day to Pre Order the Griots 6 inch Orbital Polisher Kit at Intro Price
- Just made a series of S8 stickers...
- Radio resets itself?
- Where to buy purge valve?
- LPG conversion completed..
- Vacuum Pods on the 32v engine - testing?
- Water Methanol Injection System Installation Guide
- did the 99-01 A4 use the same fogs as the facelift D2?
- D2 S8 Suspension Options?
- Known issues if I buy a D2 A8?
- Torque Converter
- A8 fuel pump
- Tip steering wheel conversion
- Have you heard of this oil?
- Fuel Pump Gasket Kit 99' A8Q
- No Heat - except higher RPM's
- Eibach springs anyone running them?
- where does that coolant end up? (oil cooler issue)
- e85 and d2 a8s
- Brake upgrade for d2 a8
- Run Motor without Serp belt for short time?
- 1997 a8 5 speed swap?
- I want to use the phone.
- A8, 3.3tdi(akf) lowering springs
- A8 Front Cleaner Apperance
- Intake Manifold Performance Gasket
- X Configuration Exhaust
- Audi A8/S8 32V Crank Sensor / Engine Speed Sender
- found new fuel pump distributor in the US
- 2000' Erco Center Arm Rest FS
- 2001 s8 67k yea or nay
- WTB: D2 S8 Front Bumper
- Trans problem...with a twist
- 97 d2 4.2 tiptronic conversion
- A8 home and waiting
- Transmission Problem - Electrical or Mechanical?
- Remote Oil Cooler Filter adapter?
- O2 Sensors
- Boot latch problem with 2001 D2 S8
- Radiator Passenger Side plastic Seal leak
- Telephone Mount/Bracket removal
- Inexpensive Brake parts for D2
- 1999 4.2 misfire. Help please.
- Audi A8 Facebook Page; Please Join!
- A little bit of info about d2
- Another no start mystery! Please help!
- Another Armrest Story
- Audi S8 32V Oil Filtration.
- 1997 S8 can not find aftermarket Control arm & Cambelt??
- 1999 Audi A8 fuel delivery issue
- high beams and washer squirts inop
- Dash "door open" indicators -- interesting electrics
- Need Help on Problems w/ 2002 S8
- Serpentine belt removal ?
- Fan Bearing? Help? No aftermarket part available.
- New future a8 owner
- Fault code obd II P1207 Cause
- Does '94 4.2 radiator fits to 2000y A8?
- Gauges and Water Methanol Switches
- D2 '01-S8 - Dead Fuel Pump turns into NIGHTMARE...... (& Member Intro)
- Water Methanol Installation
- Crankshaft positioning sensor location?
- A8 rear brakes onto a C5 A6 2.7
- Oil Cooler [Parts] Repair... Survey Question?
- a8 vs a6
- Could these codes be linked?
- Looking for some infornation 2000 audi a8
- 2000 a8 lower fog light grills
- More Horsepower for Audi A8
- S8 '98 electrical!!!!
- xpost: '01 //S8 171k with 35k on new trans - many new parts - CT - $8
- 98 A8 transmission questions
- Regulator or Alternator?
- Pictures of new wheels on the s8
- Somthing is worng with my trany
- 98 A8: No heat or A/C...
- Audi A8 Cluster Questions
- Alternator Bearings (99' A8Q)
- D2 S8 heated rear window not working
- Viton O-Rings
- :: ECS Tuning :: Up To 25% Off ECS Wheel Spacers!!!
- Can you program the coolant after run pump
- Running light problems
- 97 A8 no heat
- :: ECS Tuning :: Winter is here!!
- Looking for a S8 in Iowa
- 2001 S6 really S8, I have this car.
- power steering noisy
- '97 A8 4.2 - Incorrect Gear Ratio... :(
- :: ECS Tuning :: Save 10% On FK Automotive Products!!
- :: ECS Tuning :: Save 10% On EBC Brake Components
- CampioniShop: Forgestar 2012 collection - Year round specials
- Audi A8 4.2 TDI 350 PS Video
- personal opinions requested - paint the front spoiler on black d2 or not?
- Last Minute Holiday Promotion - 15% off - Flat Shipping - $20 gift code on next order
- 98 audi a8 part out
- headlight position sensors...
- Multi Cylinder Misfire. Violent shaking. 1999 Audi A8
- :: ECS Tuning :: ON SALE - Bentley Manuals!!
- Christmas SALE 98 a8 parts
- 2001 A8L starts but won't run
- BUY 2 GET 2 FREE UBER Microfiber Towels - Start now ends 12/8/11
- My first pictures of the S8
- Parting Out 1999 Audi A8 Prefacelift
- '03 A8L (D2) 180k miles- Change Trans Fluid? P1835 code, but cleared and now ok.
- ESP light flashing, momentary power loss, 2001
- I need a set of 'pie plates'...
- High flow cats and engine recode, 2001 S8
- Cruise control intermittent operation. Q's..?
- Belly Pan <$200 - CO/ Denver junky yard?
- Error Codes 16705 and 17800
- Timing is not right
- Small Business Saturday Special!! Free GoPro LCD Backpack with Purchase of HD Hero 2
- tranny has mind of its own
- S8 D2 bumper valance
- Audi S8 1998 transmission problem
- :: ECS Tuning :: 7th Annual Sale And Holiday Giveway!!!
- Black Friday Special at Detailer's Domain
- 2002 4.2 40v timing belt replacement
- changing s8 oxygen sensor, WTF?
- Ming blue front license plate bracket
- 2001 Audi S8 Purchase advice needed
- What is this conection
- Accessory belt tensioner
- Window Tinting Time, Advice Please - 2002 S8
- :: ECS Tuning :: D2 A8/S8 ST Coilovers Now Available With FREE Shipping!!
- cheap parts online? someone crashed into my Audi
- Lower Oil Pan Reseal Help - 2002 S8
- Transmission controller prototype, hunting gone.
- Tire size
- S8 Cheap Exhaust Upgrade?
- Window regulator clips
- brake light problems
- A8 d2 4.2 1994 instrument cluster Diagnostic.
- Transmission Problems
- Side Mirror Help
- Timing Belt time
- Suspension Pieces ?
- Lean values on VAGCOM and smell of fuel
- Swaping 6spd into S8
- Overfilled with oil...CAT light...
- Help! How do I turn off ABS?
- Intake Runner Diaphram - where on VAG Cat?
- no heat since oil cooler replaced and head gasket too
- Our Annual SEMA Special at Detailer's Domain
- CAT Light
- 00' a8l limp mode
- trim fasteners/hardware
- 2000 A8 issues looking for advice
- Oil dip stick length
- Deal of the day Save 70% off Uber All Purpose Towels at Detailer's Domain
- -Garage Sale- best offer on all parts
- converting pass mirror 125mm to 175mm
- RPM surge on cold start....
- planning on buying a 98 a8 with 98k miles. need advice
- Buying 2003 Audi A8L, looking for advice!
- 1998 A8 for $2800 w/bad trans
- 2001 D2 with W12
- Trade your Front License Bracket for my Filler-Panel?
- Anyone have trailer hitch for sale?
- Low speed clunking (10-5 MPH) - play in driveline
- S8 auto dropping out of gear?
- How do I get wires past the firewall? and other questions
- Mass Airflow cleaner
- Timing belt out of time?
- FordTennis Timing Belt Change
- '99 A8 - Cyl 1 Misfire - P1201
- Help!
- 2002 Audi A8 Stutter at some speeds
- cam chain tensioner shoe - can it be improved?
- 2000 A8 Won't Move
- Radio Unlock HELP!
- looking for Audi 10 hole 18" wheels...
- fuel injection harness plugs
- Looking for a headlight washer cover (pearl)
- Detailer's Domain: 15% off Orbital Polisher Bundles and Car Care Kits
- 1997 a8
- Help me identify a factory or aftermarket TB. (PIC))
- My new 1997 A8 3.7 FWD
- Single Cyl. Misfire trick.
- How long do Transmissions last after first rebuild?
- 2001 A8L Newbie-need Mechanic in Kansas City
- Key fob renewal refurb
- Smell of burning oil.
- Missfires and dies!!!
- Putting the 97 A8 back on the road, but several issues
- '99 A8 Traction Control System
- Coolant Flow Direction
- D2S8 Aluminum content
- Are the A8s Built Better?
- HVAC flap: Location, location, location?
- 2000 A8 4.2L with transmisson problems
- Replacing Fuel Injector (help with procedure)
- Temp gauge is running high or at zero
- FREE leather shift boots and more for Your Audi!
- Computer Failure?
