- Lights out icon & Purndy
- Just what might I do with this?
- Exhaust pipe dimensions...
- PaulW is this your tranny?
- no emisions limitation in my county
- S8 ECU Chips?
- Follow Up On Eurotrans Replacement Transmissions
- UPDATE: 2005 Viking Cup Classic Annual Ice Race & GTG - pre-registration ends 2/11!
- Does anyone have a Gray interior S8 Dash Pic
- Follow up to my electrical issues
- For those who want a six speed, this guy has a 98 S8 with one parting it out
- Factory vw or audi gps antenna--will it work with non audi gps??
- Another one bites the dust...
- Hello from a new Audi Owner
- TozoA8 and PaulW. Do you think you can put this in the A8. It could be the end of the tranny sagaLOL
- Looking for S8 slotted rear rotors to upgrade my S4. I can't find any. Anyone have a source? TIA
- Call me crazy, but I'm getting excited!
- anyone going to the Chicago AutoShow?
- What the ^%$@#? The Audi Bank in Jordan....
- 25 degrees and NO HEAT in my '99!!!
- shifter removal ?
- TONIGHT! LI Hooters G2G Hempstead Turnpike/Meadowbrook 8:30pm
- Let's face it. Sooner or later our trannys will go south.
- PaulW are you going to have the seats installed by Grattan?
- RS4 vs M5 - street race on Moskaw Ring video 4.7 mb
- erisalaw - Possible wiper solution
- Tiptronic shifter. Anyone interested?
- two questions. Sun roof seal and audio
- seat heater malfuction
- Chalk another tested part up on the board! 150amp alternator in!
- Alright Tozo! I WANT IN!
- A little tranny monitoring.
- MTM Supercharger Info...
- 1998 A8 in need of Aftermarket Warranty!!
- shifter
- Allways learn something.
- Just testing signature...no topic
- New wheel bolts - what do I need?
- CT/NY Audi Group "Spring" Gathering - Momentum Tuning, Wallingford, CT - 3/12/05
- Question about the rubber valve cover gaskets. Since they are rubber, what kind, if any,
- I just signed up for Grattan 4/30 and 5/1, anybody else gonna go?
- While I'm at it
- New and needing help
- Drilled Zimmermann Rotors 312mm--What do you think?
- What is the engine speed sensor part number. How much is it? Any clues?
- '01 S8 w/ 37k. Will ask dealer for ATF change today. Shall I do filter too?
- Independent Repair Facility/Northern New Jersey
- How many miles before your first tranny problem?
- Here's my options......what would you choose? (slight edit on option 3)
- Jack - Are these the brake lines you got? I need to replace just my rears
- 01 S8, buying advice
- Some others are trying Mobil 1 tranny fluid...
- Please help with Transmission Codes
- Anyone recommend a product to respray the black lowers?
- Lower Bumper Grills
- Has anyone changed the flange seals on the rear diff ?
- Everyone's Invited to Our GRAND OPENING!!!
- So now I'll have a custom interior!
- Rear Blind motor removal?
- fixing headrest - question ?
- Need opinions!! Any luck with the new MAF's Transmission BAD gotta do something
- The 250 amp alternator is being replaced...
- 1998 A8 Injectors
- Tozo --> Any updates?
- Would you farm it out or do it yourself?
- Importing Audi S8. A question.
- Toureg forum somewhere?
- Long shot - anyone know of a source for ONE H&R rear spring ?
- Recoded transmission back to 00002. Vibration before stop disapeared so far, but I am affraid it wil
- I got the Engine Speed Sensor fault code again. Cleared it. Why does it keep comming back? Normal?
- Paint repair
- Axel Blaschke of ZF apparently confirms that 71141 is special for its friction modifiers
- How is the A8q with OEM 16s"???
- anyone have an s6 avant?
- Shift Trek III, the Search for Clutch...
- Nav+ or Euro Nav
- Can somebody Photoshop this seat to Ecru?
- Check out these Evo wheels, would look cool on my car!
- headrest repair questions
- You guys have to see this D3 A8L with the "HOT" red leather
- Re-Dying Leather, I can do it, but how about the Alcantara?
- humorous reminder that the A8 is made of aluminum
- My tranny is getting JERKY. About 2 months since recoding...
- Did WOT nothing great to report still Bad
- Throttle position sensor
- Best Mods for S8 Performance
- Server to Upload ETKA
- There is no such thing as easy solution.
- Need Some Opinions!!!??
- Bentley (eBahn) problem
- Bosch part numbers for your car.
- Anyone dealt with Kim's Garage.....
- shift knob
- Hey Randy - Heeeeee's baaaaaack!
- Any thoughts on which BBS wheels to buy?
- Light sprayers
- Transmission exploded view ZF 5HP19
- Do you want the good news or the bad news?
- Check out my new MMI.
- To access the radio antenna
- Difference between 02 and 03 S8
- Timing Belt + Water Pump + Tensioner + Thermostat
- Tranmission exploded view ZF 5HP19
- Windshield wipers are getting worse (slower)
- Does anybody know the Bosch part number for the ABZ fuel injector?
- ABS pump failed
- Evil She-demon PuRNDy!!! (cripple mode)
- Gabor - Which tranny pressure control valve controls hydraulic pressure?
- a8 sports air bags on ebay. --kamakaziep??
- H&R coilovers. I called them tonight and got the run down....
- Tiptronic Shifter
- Video of Audi S8 MTM (D2). 0-100 Km/h in about 4.4 seconds...
- ETKA 6
- Been away for a while. Any recent transmission revelations?
- A8-996-Odyssey..a little help please...
- Transmission exploded views?
- Lower curved control arm replacement was a snap!
- Use your A8 for city daily driving?
- nav system won't activate & nav cd won't eject
- The Sport Seats have cleared customs!
- Thanks to ScotD, you can now change your own fresh air blower!
- [UPDATE] SoCal Audi Club track event @ Buttonwillow Raceway -- March 7th & 8th
- Any experiences or opinions on Enkei wheels?
- Sudden Downshifting
- The new Audi Q7..
- Audi A8 wheels
- 00-03 Center Armrest
- HID Conversion
- Analysis of Mobil 1 0w-40 from my S8
- ATF in ZF trans
- Paul - - Seat updates???
- Help- car overheating.
- Mobil 1 Transmission noise update
- 2005 Viking Cup Classic Annual Ice Race - pre-registration now open!
- Warning: AoA warranty change for pre-2004
- A package from Germany....
- PaulW - MTM distributor. Maybe get the supercharger from them?
- Has anyone searched out the SAE site for papers on the transmission fluid and possible compatibles?
- Ceramic Oil...
- I Fear this has been covered, but, is there a definitive solution to the "7-minute dash click?"
- A8's Available at Hertz
- That was scary, I just visited Off-Topic to post a cell phone service question
- Axxis Metal Masters Brake Pads
- Hey badgerbolt , did you try the WOT?
- Some recommendations please......
- VW drops ZF for the ne generation PASSAT. Hmm. I wonder why
- JimR sent me this link about A6's and Passats. Do we have a vaccum pump like that in the A8 engine
- A8/S8 differences...
- What has become of the hunting in cars with recent MAF sensor changes?
- Paging PaulW to the AudiPages courtesy phone... (Fresh Air Blower)
- Stuck Key
- New noise after Mobil 1 trans fluid change
- I recoded my transmission 2 weeks ago and it was great___BUT!!!!
- Rear brake calipers- any sources?
- Ordered a Xenon Headlight Conversion Kit Today
- Needed help from the tranny experts
- Question 2 - O2 Sensor (A8)
- What would you do?
- Question-parts
- 60K km service questions
- Did S8s come in a pearl white or a tan?
- Gearbox Problem?
- Dan McBoost
- Low Beam Failure Indicator Light
- Hi, I'm visiting from a6 forum, may buy my dad's A8L...
- Recoding Tranny
- coolant bleed screw o-rings - Pep Boys
- Jag S-Type Vs A8?
- Custom TOZOA8 lower outside grills?
- Road trip! Need help and advice.
- Lower Center Grill
- 97 vs 98 stereo
- So, it is day 8 with Mobil1 synthetic ATF and there is absolutely no change in my tranny's behavior.
- Parking brake sticking
- front fender replacement help/advice
- cheap parts
- Switchblade Remote for a '97 A8
- Surge of power almost at redline?
- 18" RS4 Replica Chrome finish. Anyone running these ?
- Ok let me try this again...
- Just installed chrome mirror caps.
- A8 Chrome Exhaust Tips
- Thinking about the Unthinkable -- motorsports forum x-post
- Heater Fan (aka Fresh Air Blower) weird behavior revisted/repaired
- top speed of 01-03 S8?
- Any thoughts of 19" Sportec anthracites on a D2?
- PaulW, it's been so long since you did your BIRAs could you recap it for all the forum newcomers?
- I keep forgetting to post this. Raves for the A8L.
- X-post: "business use" questions.
- Dukes of H&R revisited: update on ride performance of H&R coilovers
- ECS rotors / PBR ceramic pads: update on performance of new brakes
- what speed does the fuel cut off happen? Thought it was 140 but I seem to hit it at 130
- Picture from the H&R site - A8 D2 coil-overs.....
- This is the kind of guy who drives an Audi
- Any A8'ers here have a 996 Porsche?
- Poor acceleration/performance
- Xenon HID Coversion Kit on Ebay
- OOOPS!!!! Quattro isn't always enough......
- I AM SWIMMING IN OIL (SYNTHETIC) Mistery warranty saves my butt.
- Rotors on EBAY
- NOS / Nitrous Oxide
- 99 A8 five spoke OEM wheels: are they 17x7, or 17x7.5? Anyone know?
- Does anyone remember the video of the D2 being crash tested ? Anyone have it or know where it is ?
- Paul, can the supercharger project really be that hard?
- NEW Rotors check
- OT..... Fast Car video
- Day five,230 miles with Mobil 1 synthetic ATF and no hunting.
- New worst driving conditions that I have ever driven in.
- NAC~ Time for Paul to remove the doors, hood, trunk lid, back seat and most everything else. 2nd TRY
- clicking under dash
- New video. 1:20 My A8 on 1 - 22 - 05 - 19MB
- Thanks. Replaced dead battery.
- paulw
- Heavy misfire when cold - stops when restarted.
- ran aground round two
- Need some service advice please...
- I think I finally sized the compressor for the supercharger
- Repost: CT Krispy Kreme meet this Sunday (1/30/05) at Noon
- Does this S8 look "wrong" to anyone else?
- What are your thought on driving these things hard??
- front spring height.. need a 1" drop
- Paul, are you going to change the ECM with the supercharger?
- KevinR.....your springs look sooo loaded
- ryoung, are you out there? need Block, my email to you bounced
- Regarding the TC lock-up -
- I have verified that the tranny misbehavior goes away immediately after recoding.
- 01 S8: just bought the phatbox...
- will 2000 a8 parts
- The sport seats are in Chicago.....just waiting to clear customs....
- New tires and an alignment. Car drives awesome.
- Anyone have a pic or a photoshop of 17" Avus S4 wheels on an A8?
- Wipers are very slow today - cause?
- NAV Plus on ebay.
- 2000 A8 parts - Shokan has a lightly damaged 2000 A8 in if anyone needs parts - www.shokan.com
- Where's the AM antennae on a 2001? I know FM is embedded in the glass, AM too?
- FYI, highly recommended: BEL 975R Plus Radar Detector / Laser Jammer
- UK vs. US Recall notices....
- "Oil Service" reset code?
- Suspension middle ground?
- ran aground
- Are we really only 200lbs heavier than a 01 S4 Auto?
- paging person with plow damage. --hood on marketplace
- Hill country drive for this saturday, San Antonio & Austin people.!!
- HELP need advice on sticking accelerator
- high praise for Icelink+
- A8 purchase decision - need advice
- s8 keys programing
- 01 S8 front brake pads. Same as Porsche Big Red pads?
- We need a survey K&N Filters and Transmission Problems
