- Approx cost, or flat rate, of oil cooler fix?
- Back in A8 world! - just picked up a 1998 A8 with 50K mi on the ticker....
- Need advice on the source of the source of my brake pads problem (long)
- My new MC arrived. Have some questions about bleeding
- wierd noise coming from my ssss
- Here it is.... My Baby .... (not quiet done yet)
- Transmission Fail Safe when Cold
- Jager_blonde never responded to the advices given or the commentaries..huh!
- Are 2000/2001 Transmissions more reliable?
- Car Starts, runs for 2 seconds then runs really rough then dies.
- First pics of green '01 100K mile S8 for sale, more to follow wtih writeup. But she's MINT.
- Gabor gets my '01 S8 on Sunday.
- trouble with transmission removal-down pipes to exhaust manifold
- Hey rangervr4.2, how do you go about using this stuff?
- Bit the bullet and added to the Audi family. Bought an S6....
- Alarm horn location?
- Who want an '01 S8?
- Customer in today has a very nice D3-S8-V10-Wow what a car-After
- Just a small shoot of my car....i really need to drop it
- B-pilar's rearward air vent doesn't push air. Internal duct misaligned?
- Oups, my brake fluid reservoir is empty...
- Radio Anti-theft Code
- ABS and EPS light on again only on humid days only code is 01435
- B&G springs planning on ordering today...thoughts? opinions?
- what does the inside of a8 boot look like
- Does anyone have a used radio antenna for a 98 A8Q?
- I need to settle a bet with my hardheaded boyfriend....
- Help with 97 A8 A/C Condenser
- Silver 97 A8 4.2q partout in MA/NH
- You certainly don't see Espresso Brown very often!
- Paging Tozo re;1999 Transmission
- What parts are needed for coolant leaking from the oil cooler?
- Anyone have an extra lower left grille?
- Newer A8 rims
- CD00 ERR
- transmission slipping?
- I just picked up my 3rd A8 today. 98' sport with 62K miles.
- I just checked my receipts. 3450miles=160gal=21.56mi/gal=$688
- S8 calipers
- Paging A8CT: Do you still have your intake manifold laying around?
- Question about running the output tests using VAG-COM...
- caramel interior
- OK to add G004000M2 to G002000?
- Lost my owners manual need some help
- Misplaced Radio Code
- Sak Lunch-Lets start fresh-manual would suggest that if the missfire is only
- This page got me thinking, are there two aero blades or just one?
- Evaporative Emission System Leak Detected (small leak)
- Paul W... Advice?
- How many face lifts did the D2 go through?
- What kinda genius does this?
- On a side note, what is this valve thingy circled in the picture?
- '03 Avus //S8 - Bueller?
- Tranny issue... need advice..
- Anybody know were i can buy a new / used cd player / radio like i said in my previous post,
- Mr Clampett is back :)
- Gabor - Did you make it home?
- automatic a8 windows roll down
- will an A4 3 spoke wheel work on a 98 A8?
- how to remove a8 rear seats
- X-post from B7 S4......this could be promising...VF Eng Supercharger?..
- oil consumption, compression test results
- Rainy day - so I put my park lights and dash lights on ignition relays
- Anyone know how to take the head light washer pump apart?
- CD Changer --Matsu****a 1998 A8
- Antenna 1998 A8
- Hatshelf brake lamp replaced.
- Alright, I'm pretty much at wit's end regarding my CEL situation...
- Driver's seat wiring
- Found a great deal on 3M waffle foam polishing pads
- Need help with adapting procedure for keyless entry...
- WTF? Leave it to audi to design some crazy washers
- I get this catpiss smell when I start the car and turn on my A/C. It lasts for a couple of mins.
- Hey PaulW, an A6 rns-e unit is needed right?
- Question on removing crankshaft pulley
- Water dripping all of a sudden
- Found my S6 I think. Link to my post in a6/s6 forum.
- Hatshelf Brake Light
- Is this alcantara?
- Brakeblock on well bled system = no difference
- Cd player keeps on saying ERR 1 when i use the single disk...cd changer works fine....
- Slow-speed creaking and groaning. Control arms and rod-end are new...
- Aluminum, Titanium and Carbon Fiber
- Paul W can we talk?
- 1999 A8 Transmission
- PS pump - possible replacement
- Delta CD Player
- Anyone looking for a green S8?
- Warning to all forum members of every brand of car, deutchpartsusa are thieves.
- Another 28mpg trip
- Description and Opinions of this color please.....
- clicking sound in steering column
- Wow...56% depreciation in less than 3 years. (2005 A8 W12)
- Any sources for ss braided brake lines?
- Anyone have an issue with the seat squeaking on the armrest (facelift)?
- Need ETKA part lookup
- Transmission Pan Bolt P/N and source
- Anybody sw of chicago willing to look at an S6 for me?
- Oil Leak
- FYI...Raceconcepts ebay store is ok
- Anyone ever have the coolant overflow tank leak around the seam? I think this is a new feature ...
- Drains clogged, but which is the more likely culprit...
- No relation, but FYI for pre facers...97 A8 blue interior, and dash cluster, and corners (not clear)
- Looking for C5 Corvette
- Oh great, coolant is leaking too...
- Strange phenomenon , everytime I bleed my brakes, air only comes out of the right front caliper
- So Tozo, are you back on the road again today? Did the fuel pump fix the problem?
- seeking clear corner markers
- Slight rubbing noise when I turn left or right ... wheels don't rub.
- Bleeding the brakes w/esp requires 29 psi, seriously?
- Ready to buy my complimentary s6 to hang out with my a8.... Nav questions
- OT: Anybody know WTF stations are cutting off the pumps at $75?
- My squeaking window sounds funny
- OT: where's the NEW format for this forum??? i thought it was suppose to have started by now.
- Clicking noise in dash area
- LOL
- what needs to be done to use halogen headlights in a xenon equipped car..
- Deleted my rear muffler. Love the sound of my motor. Can;t stay off the throttle.
- I've got four watchers on my auction-fingers crossed
- Is it normal to have to put new brake pads with a hammer?
- Trade-In value or outright sale value of a 2001 A8L....?
- HID lights
- i found someone who likes my s more then me
- getting into an S8
- Quick (OT) question: Do any of you know if Toluene will eat through a plastic gas can?
- as soon as i put in the key in the ignition the white reverse lights come on
- Power Outlet/Cigarette Lighter
- wee
- Driver's side rear caliper rubber boot torn to shreds.
- Brake lights come on with and only with high beams....?
- 01203 - Electrical Connection between ABS and Instrument Cluster
- A8L 2001 left side catalytic converter - removing questions.
- Big thanks to A8ct and Paul W for helping me with my fuel pump issue.
- A8 Brake Pedal Goes Nearly to Floor On Start Up
- Happy 4th (er, 5th?) - nipple pinchin, clear cornerin, lens defogin, 7 beer jobbin Fri. nite fun:
- stuff i dont like happening
- Interior cleaning tip.
- "No response from controller" with VAG-COM on brake and ABS modules
- Some pics of my UK car (If I can get this to work !)
- Some "new" styling..........
- a couple of you guys recently bought fuel pumps - same for all years? trying to match mine for Tozo
- Any news on the unitronic chip yet?
- A8CT - Do you still have your fuel pump? Anybody have a fuel pump?
- Another reason to love my A8
- Could someone tell me which one is the fuel pump relay and fuse?
- So.. I've heard some great things about Toluene on this forum. I'm curious though.. Have any of you
- Cam chain tensioner - replaced @ 121k - was nearly seized, and source of my clatter
- So my chit broke again :(
- Thinking of buying......
- RNS-E euro coding question - unit won't accept programming:
- Have a good/fun/safe weekend everyone!
- New pedals installed...
- Changing Xenon bulbs in facelift > Prefacelift
- OH MAN. pre-facelift S8 with a manual....and I DO need a car....
- Thanks PaulW. You were right on the money.
- Murphy's Law - Brake Switch Errors w/ Good Brake Switch
- While I'm thinking of it...Have a fun and safe Holiday all of yous!
- All good things must come to an end, or, Tozo can fix just about anything...
- Anyone on here in the Lancaster/Harrisburg area? I keep seeing a Silver A8 on rt.283..you here?
- Thanks to "Pearl8", I'm testing his intake arms on a 40v A8. I think he's made some for you S8 guys
- Hi from Ian at A8parts
- For sale-[sniffs back tear]
- Oil Leak
- what tire size would you recommend for 19x8 wheels?
- ABS light on after cleaning sensor.
- Busted right side mirror housing. Will an A4 or A6 Mirror housing bolt to our cars?
- black s8 spotted behind bay state road today..anyone here?
- Tell-tale sign that I'm getting old...
- Facelift windshield replaced for $230
- NOS and S6+ V8 4.2 setups
- Reverse & Right Mirror
- Bilstein Shock Question
- 97 A8 4.2 Partout starting now...
- Interior door handle failure
- Need Help Locating Coolant Leak.
- B-pillar annoying rattling noise gone after lubricating the door seals. Amazing!
- led licese plate lights
- it's alive ...... we think ......
- small, broken, idiotic pieces
- What color xenon headlight do I want?
- HHO conversion?
- Eight D2's gather in Colorado...
- need to replace rear rotors
- ABS activated all the time?
- Rough idle in open loop & CEL on Freeway when I lift off gas
- need link to service reset using Ross-tech
- A/C recharge valve location
- The Tozo has landed. Any others in CO need directions to tonite's GTG?
- Odometer/Trip display is missing pixels...
- Hey guys, while I think of it....
- foglights up for grabs
- diable the DRL's?
- Replacement brakes & rotors for 99 A8
- Paging Tozo, tranny question, I know you're on vacation...
- Front control arm job costs?
- Brake Performance Rotors
- stfa and no luck on finding fuel pump install procedures... could someone please help?
- Clean looking '02 S8 in nice color combo FS on eBay, $20K BIN.
- OT: using this in town will relieve any guilt I might've felt driving my Scaglietti on road trips.
- Any alternatives to VAG branded PS fuid?
- Attempted Start... revs to 3,000 rpms then dies.. Help
- OT: motorcycle safety, any of yous guys ride bikes with headlight modulators?
- ABS Code
- after 98,000 miles.
- Calling pkrasusky - I'll be in Suffield on Monday/Tuesday. Is there anything going on up there?
- Anybody know the size of the pinch bolt? : - [
- Paging tozo: (again sorry lol) transmission question
- Anybody know of an easy way to get the wheel hub out in order to get to the wheel bearing?
- I saw Mr Clampett packing up all his chit. He is heading west tomorrow :)
- ultimate pedal group buy
- big thanks to chris aka S8_Got_Grip
- A8CT YGM
- And so it is said and so it is done >>>>>>>>>>//SFest 2008...
- Any recommendations for MTM products on a 2002 S8?
- D3 W12 20x9 wheels for sale...
- OEM Wheel offset question- 2003 S8
- What is the correct name for the auxiliary cooling fan that turns on with the A/C?
- 255 on stock 17" rims??
- connector gone bad
- Wish me luck...
- prop shaft seal replacement - shortcut
- OT, just for the pure pleasure of it: F430 w/ Kreissieg exhaust
- 2001 A8 windshield - with or without mirror mount?
- All good things do come to an end.... IMHO
- Paging wheel and tire guru's, a little help please.
- So I ran into a little road block on my repair job so far...need some help
- OT: Top 10 cars driven by men!!!
- K&N air filter..should I install it?
- Mark your calendars for June 30 for a Tozo party in Boulder!
- heated seats - do you think wiring is already there even if the car wasn't optioned that way?
- Got to love the factory carbon
- Trans troubles
- A8 track car
- got brembos??
- Windshield Wiper speeds
- Pics of my new car! (new to me)
- zenon warning light came on
- Cars for sale - hurry or else I will torch them for insurance money (ok, maybe not)
- On the way to store (O) light. On the way back ABS light.
- Front brake system shot
- PRISTINE 03 A8L has to go
- nearly crashed the A8 ....
- Diehard no longer makes our battery... but NAPA has one...
- Anyone ever lose their trunk release switch?
- low beams blueish, high beams yellowish.. how do I fix that?
- Economy car
- Speaking of PaulW, Have you ironed out all the wrinkles in the RNS-E?
- New (to me) car on the horizon
- Well sad day for me BUT....
- 97 Silver A8 4.2 partout in MA/NH
