- SE: Oil pressure light
- D2 bumper hitch
- Group buy. Is there enough people interested in a billet oil filter housing cap
- transmission options, looking for Tozo
- S8 40V Restoration
- UK: Aircon Pressure Switch
- TCM grounding Issues
- AQH S8, wrong timing or what
- Front and rear passenger footwells soaked
- OEM Master Key Fob
- seat electrics
- Tutoriel 5hp24A ecz
- I believe this is the quickest/best mod for '01 S8.
- a8 d2 repair kit ?
- FR: A8 D2 code défaut 00656 Capteur d'occupation du siège ( Côté passager AV) (G128
- Cooling Part ID
- UK: Help with valuation D2
- Ronin's A8 total hp?
- D3S LEDs - brighter than xenon - cleaner white - instant on - no errors
- 2002 A8 valve cover removal
- Camshaft Chain Help!
- ABS/ESP light, yaw sensor, MOT failures.
- Front right (passenger) side headlight twitching when engine not running
- Trunk/Boot light not working
- Some interior lighting not working
- Adding powered sub to factory Navigation plus bose system
- monts?
- parts car
- Unknown knob?
- FR: reniflard d'huile moteur
- Air spring (helper)option
- Rear sunroof drains access
- Rad option
- Speed Sensor 3 pin connector part number
- Looking for exhaust parts for my 2000 Audi A8 D2 (4.2 V8) – need help sourcing
- 2000 Audi A8 overheating after repair
- Searching for D2 Cowl Cover
- intake manifold a8 d2 4.2
- S8 final edition video
- Cold Start, No Start Below 70 degrees
- GPS module but no infotainmentsystem
- S8 TMC module etc
- p0431 a8 d2 4.2 310 cv 2000
- FR: p0341
- FR: help guys
- source for fuel pump in 2025?
- Camshaft timing AQF
- Valve body transmission prob
- Swapping AKC or AQG for ABZ
- S8 P0300
- 4.2 v8(aux) [front belt timed] remote oil cooler
- Audi A8 D2 4.2l AKG 1998. idle stalling problem
- What are these?
- Removal Lower Dash Panel Driver Side
- FR: Anyone done full IMMO OFF on A8 D2 (2000) Immo 3 – Need confirmation on AM29F800
- Can't connect to engine module
- FR: eeprom v1.40
- FR: inector no start
- FR: 4d2971713N
- Anther transmission issue around here?
- Another Transmission problem 5HP24A
- Cluster Issues, Car Won't Start Correctly
- 2002 D2 transmission selector handle very hard to move
- Fuse blowing for fuse holder 5 (brown)
- Color marks on rear coil springs
- Need Advice: Smog + ECU Flash for Manual-Swapped 2003 D2 S8 (California)
- Scam? rizzblanca30@gmail.com
- Blower Motor Fuse Location
- D2 S8 transmission in a D2 A8
- Brand New Blower Motor Stopped Working
- Front Coil Springs?
- FR: Need help tracing ground wires in plenum area – Audi A8 D2 2000 4.2 V8 AQF
- Concert volume problem, possible alternative
- Cabin air not blowing
- Looking for a Legit Transmission Shop for My Audi A8 (D2)
- Crankcase ventilation ?
- Need Advice: Keep or Sell My 2001 Audi A8L?
- Transmission ECU problem
- Aftermarket headunit *Pop* noise and alternator whining
- WTB: Hood insulation pad for '03 S8 - thanks!
- 2001 S8 Reverse out
- Subwoofer box in boot/trunk
- Tozo M8
- Auto trans. locks into 4th gear, dash indicators have red background
- OEM filter
- FR: anti démarage
- GE: Help to choose proper spark plugs
- help start a8 d2 4.2
- UK: Barn Find
- How to Replace headlight washer cover on my S8
- fuel problem
- No Parts Available?
- Tc-performance a good tuning company?
- Brake pressure
- Terminals on battery 1999 A8 trunk
- Help with noisy el.motor 4D0959617A
- Engine conversion options
- Frozen air suspension
- Understanding heater flaps
- Air bag light
- Camshaft chain tensioners
- UK: Electric gremlins
- 01E swap labor
- KESSY
- HEADLIGHTS NOT COMING
- asymmetric tail lights
- Gas flap release: where in Service Manual ?
- New fuel pump parts!
- This normal/safe operation temp? D2 2003 audi s8
- power steering hoses
- 2002 Audi A8 quattro codes.. NEED HELP!
- SE: W12 dry sump oil pump
- Audi A8L 2014 8 Cylinder knock sensor 4 signal high&low??
- Brake light switch issues
- transmission output seal
- Looking for instrument cluster
- 2002 Audi D2 S8 - must do mods and issues
- Help with rebuilding engine
- Rear bushings options? (suspension, subframe, differential)
- Fuel Injectors For ABZ vs AHC
- FI: 5hp24a p0741
- Need help with oil level sensor and oil filter
- Help with the Servo Suction Pump
- Audi S8
- Fuel injector gone/Serial Number
- '01 'Silver Bullet' A8
- S8 D2 250kw/340hp prefacelift vacuum problem
- Running weird after engine and trans reinstallation
- Where do these hoses connect to?
- 2001 A8L 4.2 D2 Help with sourcing exhaust parts
- Help with PCV Valve location.
- Help with transmission gearbox swap
- New to me 2001 S8!
- Brake vacuum valve replacement
- D2 window tinting
- Remove exhaust pipe pre-cat
- Value of 'antique' 1999 A8 w/98K miles?
- Windscreens
- UK: All Audi in Bristol
- Spectacular D2 S8 on BaT!
- LT: audi a8 d2 1994 jump start points?
- UK: Windscreen?
- g200 lateral acceleration sensor, abs control and yaw?? sensor location
- D2 S8 side view mirror compatability
- Wheel Bearing Housing - Front drivers side
- Sevotronic steering rack
- p0706
- D2 blinkers not flashing/no horn while locking
- Gearbox fault, *clunk*-Neutral-P0730-"limp mode"
- -01 A8 D2 towbar
- Cold air from passenger center vent only
- 2024 A8 MMI issues
- SSP online
- Front left differential output flange seal
- A8 (D2) Amplifier location
- My left tail light won't work after taking boot light out
- Weird transmission
- How to deactivate headlight indicator in instrument cluster?
- 3.7 V8 Exhaust
- GruvenParts dot com….still in business?
- Leak on trunk lid?
- differential input flange seal
- 2002 D2 S8 inlet manifold flap broken.
- cam bearing cap broken
- D2 S8 inlet manifold strip
- Radio fitment
- Should I revive a 4yrs abandoned S8 D2 1997?
- 3.7 FWD to 4.2
- DK: Limp mode
- Headlight taillight A8 D2.
- Rear subframe
- Are the 2008 a8 4.2l good?
- G201 implausible signal
- 2002 S8 - no crank
- 2001 Audi S8
- MMI bad or digital radio?
- A8 high beam light won’t come on
- A8 D2 4.2 fuel tank scavenging tubes
- Trim is coming up ,try all types of glue ,nothing works can someone advice what to do
- FS: Manual Swap D2 on BAT
- Accessory power comes on every time I connect battery
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- Water leak, driver's side rear engine
- S8 d2 2000 abs/esp
- Rotor split in half, lugnut is now stuck in place
- UK: A8 65 PLATE. System fault please contact workshop
- 2003 S8 service manual & documentatioin
- UK: A8 2010
- S8 Wheel Center Caps?
- Tiny light bulb in high beam area?
- Optioned Facelift S8 Steering Wheel
- ICYMI I Want to Thank You All
- Fuel Injectors
- UK: ULEZ Zone
- Splendid (From What I Can Tell) S8/D2 For Sale on BaT
- A8L electrical problems. Help
- driveshaft carrier bearing vibration? See video and give me your opinion.
- Inside Door Handle
- A8 D2 noise from speakers on ignition and engine working
- Led upgrade 2001 D2 S8
- Sudden ABS issues
- Misfires at deceleration (only above 2k RPM)
- American message board members.....
- 4.2 6-speed swap with ABS and TCS lights
- S8 Gearbox Ratios
- Is there a quick guide on how to initiate a search?
- Issue with Side View Mirrors
- iPhone Mount?
- D2 immobilizer issue after battery change.
- code erreur p0733 17117
- Restoring 1998 A8 4.2
- Oil pressure loss 1997 A8 4.2 ABZ engine
- Need rear upper shock absorber mounts for 2001 A8L 4D0512169D
- Greetings from SuperSprint Italy
- 2001 S8 transmission rebuild
- UK: S8 D2 HELP WITH JUNCTION BOX
- New member and D2 S8 owner
- Black matte wrap of 1997 Audi S8 6-speed manual, V8 340hp
- Torque specs for 2001 audi S8 fuel pump banjo bolt w/ crusher washers?
- Front Brake Calliper Repair Kits
- UK: ULEZ Zone?
- Transmission issue
- Gearbox Code
- Help with Audi phone in D2
- 6 speed manual conversion ABS issue
- 1997 missfire when hot.
- Starting 4.2 a8 d2 without radiator.
- Recaro seats
- Do I need a new dash?
- Sunroof seal/gasket
- Audi A8 (D2) fuel sender cap and o-ring kit - part 4D0-298-135B
- 05 a8 quatro key immobalizer
- 2002 A8L 4.2l V8 wont start?
- UK: Power steering whine noise
- ABS VE ASR
- installing the headlamp assemblies back into A8/D2
- 2004 audi a8L realy coil?
- NO: Headliner
- D2 steering racks
- Aluminum D2 coolant bleeder pipes available
- Engine swap
- i need help. (Transmission)
- camshaft chain tensioners
- 2001 A8L randomly comes to life
- Audi D2 FL instrument cluster
- Knocking noise?
- BY: The number of engine
- Trunk lock actuator seal replacement
- 2001 A8 secondary air pump
