PDA
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. 2001 D2 S8
  2. Brake pedal sinks to the floor, ABS?
  3. HID headlight code? Check voltage/sensor through VAG-COM?
  4. Curise control
  5. 2008 A8 slumps on driver's side
  6. Switched to 0W-40 syn - no more smoke puff on startup
  7. Massive oil leak from below oil-pump pulley
  8. Brake Pads noise problem
  9. Just bought a 97 A8!
  10. Catastrophic Suspension Failure!
  11. 15 inch brakes on A8 D2 ;)
  12. ASR problem
  13. A8 D2 runs out of fuel with 2/3 of a tank left
  14. 20% off at Detailer's Domain for the next 48 hours
  15. REAR ABS SPEED SENSOR
  16. SUNROOF DOES NOT WORK
  17. 2001 S8 O2 Sensor
  18. 2001 S8
  19. adding amp & subwoofer to my stock radio
  20. Audi A8 D2 4.2 RHD climate control issues :( plz help!
  21. Recommend a Torque wrench? D2
  22. self caused problem with a penny
  23. Where is oil coming from?
  24. **Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - September 1st - 5th, 2014**
  25. dollarbil / 1998 A8
  26. Wont fire....sometimes...
  27. hard shift this morning
  28. 2001 with 98k miles, reverse no longer working.
  29. Looking for parts for my 99 A8
  30. :: ECS Tuning :: Genuine Audi A8 Logo Valve Stem Caps - $4.99!!
  31. 2000 S8 265kW starting problem
  32. 1999 A8 D2 trunk lid bump stops
  33. indicators have stopped working
  34. Intermittent starting issues, need help
  35. Front Axles Drivers side vs passenger side
  36. Any interest in 2000 A8 Quattro parts
  37. electric rear curtains
  38. suspension leveling
  39. Headlight upgrade?
  40. Blaque Diamond Wheels | New BD-1 pictures released
  41. New and just bought a A8 D2 3.7 V8
  42. 2000 A8...scrap it?
  43. overall cost of ownership
  44. Vent Removal
  45. oil cooler parts
  46. Wheel Replacement 2002 S8. What fits?
  47. Waterfest 20 Promo - Stock up on your detailing gear @ Detailer's Domain
  48. Thermal switch for efan
  49. Disappearing Trip Computer
  50. Got New 19" Wheels installed, what ya think?
  51. **Don Nguyen | Light Smoke/Tint on Tail Lights - White Audi Q5 SUV**
  52. Steering rack adjusting nut - anyone have an old rack they can check?
  53. Manually Adjust Moonroof?
  54. **Don Nguyen | 3M Di-noc Matte Carbon Fiber - White CRZ Hood**
  55. Code Reader+ for 2001 A8L
  56. Engine running lumpy and power loss
  57. Rev counter not working
  58. July 4th Special - Save 15% off and Free Shipping Over $75.00 @ DetailersDomain.com
  59. A8 D2 Oil Cooler Leaking - Need Cost Estimates for Whats Fair
  60. A8D2 transmission problems
  61. Flashing oil light and rev counter not working....
  62. a/c diagnostics
  63. rack growl?
  64. rear deck speakers not working
  65. what component is this?
  66. Front floor mats
  67. gear problems -incorrect ratio problem unsolved for 5 years!!!
  68. transmission problems
  69. Random Connector Help
  70. Change radio to "on" at position 1 (accessory)?
  71. 99' A8 Antenna Fender Grommet
  72. BLAQUE DIAMOND WHEELS || 2012 A7 on BD-4s
  73. Amplifier discharge problem - need wiring help
  74. 24 hour Father's Day Special Save 20% off and more and Detailer's Domain
  75. New here with some Questions
  76. BLAQUE DIAMOND WHEELS || 2013 BMW 535i on BD-4's
  77. 4.2 40V Engine Block Coolant Drain/Drains?
  78. JL Audio 13W7AE-D1.5
  79. Transmission Service....Wish I didn't now!
  80. Oil overfill
  81. Lost my keys >.<
  82. My ST Coilover Feedback for you
  83. rear seat floorboard saturated (flooded)
  84. Blower running but no air movement
  85. Audi S8 D2 2001 Tiptronic Issues and VAG COM 18152
  86. Control Arms - Ocap or Meyle or OEM?
  87. Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - June 16th - 20th 2014
  88. Memorial Day Special @ Detailer's Domain - Stock up on your detailing gear!
  89. how rare is a 2003 avus silver s8 with burgandy interior
  90. 2001 Audi A8L looking for a new garage
  91. Audi A8 4.2 - 12k miles- should I buy it?
  92. On a lighter note...
  93. Measuring Block Values
  94. S8 Rear caliper piston retraction
  95. Sunroof burst in my Audi8 2014
  96. Window woes!
  97. Brembo parts
  98. BLAQUE DIAMOND WHEELS || Audi A7 with BD-5
  99. Anyone looking to retrofit a S8 Tiptronic steering wheel?
  100. Broken driver's side door lock + Activated anti-theft system!
  101. Unsure what these switches do.
  102. 97 a8 transmision problem
  103. Warmer weather = softer suspension?
  104. BLAQUE DIAMOND WHEELS || 2013 A5 on BD-4's
  105. selling my 2002 Audi S8
  106. 2002 S8 Front Axle Replacement
  107. Should I Buy Used A8?
  108. **Don Nguyen | Gloss Black Vinyl Roof Installed - White Audi RS7 Sedan**
  109. A-8 CV joints
  110. **Don Nguyen | 3M Dinoc Matte Carbon Fiber - Wrapped Interior Trim**
  111. 2001 A8 ballast replacement
  112. Driver's window won't go up
  113. Any Examples of a Modified Suspension for 03 S8 D2??
  114. front end squeaks?
  115. Window switch removal help
  116. change original stereo
  117. 1997 A8Q starts then dies
  118. 2002 A8 Hub Relacment
  119. New Audi owner
  120. Looking for more S8 swap/6spd swap info.
  121. 2003 s8 dome lights and trunk lights not working
  122. Adding wheels with a lip (LM style rims) to my 2003 S8
  123. Rear crankshaft seal - does this look like a leak?
  124. Catalytic converter problems D2 S8
  125. Worn upper control arm? Just replace it,
  126. Sensor above drivers side front axle?
  127. A hex bolt mystery.
  128. How long will it last?
  129. Intake valve opens after TDC 10
  130. Steering rack hiss / squeak?
  131. S8 40V and RS6 V8. Timing tools the same?
  132. Floor Mat Backing crumbling apart
  133. Mystery Part Fell out of belly pan
  134. Speed sensor or possible trans problem
  135. Shared parts with Lamborghini
  136. Waterpump for the Rest warmer?
  137. Other turn signal?
  138. Climate control Sync?
  139. System Error on dash panel
  140. Fried computers 1999A8
  141. Audi A8/S8 Rear Sun Shade Clips
  142. For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95!
  143. Fuel gauge acting up
  144. New D2 S8 Owner
  145. changing out output shaft seal... what gear oil?
  146. 1999 a8 electric seats
  147. Transmission issues just started.
  148. 2001 S8 Leak Detection Pump location?
  149. Driver's side fog light grille
  150. CAT AND EXHAUST IDEAS ON A 2.8
  151. Exhaust and intake valve sizes.
  152. Small vent under radio?
  153. placed a for sale in the classified
  154. nightmare of a day
  155. BlauParts D2 Front Brake Kit
  156. 1999 A8 Cylinder head replacement and more
  157. air conditioning not working
  158. Window Tint: 35% or 50%
  159. Drive Your Dream Super Car At NCCAR March 27-30th
  160. How to Bleed Air from Heater Core
  161. Cluster/trip computer issue
  162. Diesel injectors got no 12 volt in order to start the engine
  163. Spring Therapy @ DetailersDomain.com - 15% off and shipping promos
  164. 3rd gear hesitation...
  165. D2 W12, Anybody?
  166. Rear sway bar loose right :)
  167. '01 S8 market values?
  168. '97 A8Q Small mystery hose from behind D/S timing cover etc
  169. Techron Sale
  170. Overheating - cause temp sensor to go bad?
  171. Transmission Temperature
  172. Intermittant rear view mirror fixed
  173. Tinted Windows and Climate Control
  174. Vacation disaster - how to change coolant?
  175. Driver side door panel internals
  176. Intake flap pivot dogbone?
  177. First Year of Ownership
  178. Manufacture Date vs. Purchase Date
  179. OIL CATCH TANK / CAN
  180. A8/S8 drivers I need your help!!
  181. Drove home at lunch, Now won't start
  182. Engine/Transmission Mounts
  183. HID Headlight Issues
  184. Camshaft Codes and Fix
  185. Audi A8 D2 (ABZ Engine model) passenger side cam shaft end cover stripped torx bolt
  186. new 19s but should have gone for 20s
  187. Leaky windshield?
  188. water in the trunk...?
  189. Muffler leak - best way to fix?
  190. Factory Replacement Springs
  191. Rear Seat Heaters No Work, Driver's Burns Left Thigh
  192. Did the Vag-Com read today. Here are my findings.
  193. About 95% restored...
  194. Valvoline MaxLife Full Synthetic....???
  195. Audi a8l 2005 mmi issues
  196. S8 Newbie! Just checking in
  197. 01 S8 pinging/knocking
  198. First to second gear clunk
  199. AC sprays water from center and only hot air from sides '97A8Q
  200. Went to dealer to get something and did some tire kickin'...
  201. Slipping Clutch?
  202. BUMPER CHROME RESTORATION
  203. Feeling the winter time blues? Here is a 20% off Promo Code to get better.
  204. Key not releasing in ignition
  205. 3rd to 4th gear vibration/thunk
  206. Leak from rear window.
  207. noise from auto gear box
  208. 2000 audi a8 quattro fuel pump issues....i think? please help
  209. Dome light repair
  210. Power steering fluid
  211. Loose wires in sunroof
  212. New purchase
  213. Purchasing a used A8L.. Help me out!
  214. Sea Foam before Oil Change
  215. How many options came 'pre-wired'?
  216. Disc Carrier Tranny Rebuild
  217. 2000 US-model FL D2 A8 (not L) Part Out in NE FL
  218. Clothed vacuum hose diameter on 97 3.5mm or 4mm?
  219. AMSOIL user - which type/viscosity?
  220. No Heat!
  221. Trans problem...again!
  222. 2001 Audi 17x8 5 Spoke Rims fit 2001 S8?
  223. Main Beam Flash
  224. Wing mirror problem
  225. Remove Rear View Mirror, How?
  226. Lateral Acceleration Sensor location
  227. PSA: Warning about TB Parts from Blau
  228. Disabling Parking Sensors
  229. Gas Fumes after a Cold Week.
  230. Serpentine belt replacement met with difficulty
  231. Oil leak on cat?
  232. HVAC illumination
  233. 2000 A8 no tail lights
  234. New Member Introduction
  235. BG 44K
  236. Still having fuel pump problem
  237. right rear turning light stays on for a while
  238. I want an '00 - '02 A8/S8 - Any concerns
  239. Time to Treat Yourself - 15% off and Free Shipping over $50 - Happy New Year!
  240. Pinched My Nipples Windows Stil Foggy
  241. 140K miles on my '01 A8L... What a great freaking car...
  242. RADIATOR BELT FAN REPLACEMENT
  243. 2000 A8 Windsheild Wiper Pump Replacement
  244. Dropped Cylinder.. Out of town for a week or so..
  245. 1998 Audi A8 4.2 Quattro Climate Control Problems
  246. 2002 A8L Transmisson ZF5HP24A rebuild
  247. License plate delete - Black D2
  248. Need Fenders (Front)
  249. Front bumper cover
  250. Facelift D2 psgr side trunk panel
