PDA
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. S8 transmission fluid/filter change
  2. Help
  3. Oil Change shortcuts?
  4. Cel
  5. ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
  6. HOW TO AVOID A BURNED BULB SIGNAL USING AFTERMARKET HEADLIGHTS?
  7. 2002 A8 driver front window glass (WTB)
  8. PCV / Valley Pan
  9. NO START WHEN COLD HELP!!!!!!
  10. 2001 Audi S8 won't start
  11. central locking system unusual problem
  12. Heater Core Leak?
  13. Car accident with a huge truck. Driver side ruined!! How to proceed with fix?
  14. !AUDI ONLINE PARTS WINTER RAFFLE!
  15. WHAT DO YOU WANT TO SEE FROM A PARTS DEALER?
  16. Yaw rate sensor
  17. changing the thermostat WITHOUT removing the timing belt
  18. A8 d2 1995 automatic question
  19. Chrome molding restoration. Using steel wool 0000 doesn't work. Advice?
  20. headlight restoration on 2002 A8. headlight has very strange pattern? looks like tree
  21. White smoke coming from hood. Oil leaking onto exhaust. Quoted $700 for fix. Any DIY?
  22. Inner tie rod removal - 38mm - won't budge!
  23. Drag race time
  24. Coming to the end of my ownership of an A8 & the story
  25. MISTERIOUS STARTING PROBLEMS - 1995 A8 4.2
  26. Mixing TRW w/ Lemforder
  27. Need correct arms!
  28. The tale of my transmission (warning: long winded!)
  29. Interchangeable body parts
  30. A8 tip chip
  31. Used Audi A8L 2002 4.2L
  32. A8 D2 Sunroof Knob (Beige)
  33. 1999 A8 rear suspension coil spring. Which one to buy?
  34. Blower fan motor replacement
  35. Dreaded oil cooler oil leak or not
  36. !NEW AUDIWORLD EXCLUSIVE PROMO!
  37. Dashboard warning lights come on after 30 min
  38. 1998 A8 4.2L MAP Sensor location?
  39. Steering wheel SUPER HOT!
  40. Brake noise, creaking, dry or worn pins?
  41. '98 Audi A8 Quattro Stalling Problem
  42. can't finde a Computer TCM
  43. AC Not blowing hard enough?? 2001 S8
  44. Where to find upper spring plate
  45. A8 2000 - No Start/No Crank/ No dash lights
  46. Fuse Box and Cigarette lighter fuse
  47. Must I use Audi maintenance after 85k on my A8L?
  48. Sealant or Not under outer cam Bearing Caps?
  49. Shudder while turning
  50. Mechanical Lockup
  51. Carpet removal - A8 D2
  52. Service Manual - A8-D2
  53. Interior LED Kit + Exterior LEDs-Error Free-Lifetime Warranty-Free shipping
  54. climate control changes speed with direction
  55. FNG With A8
  56. BIRTHDAY SALE!
  57. VAG-COM Readingd fault to a/c flaps /Vents and A/C Magnetic Clutch
  58. Wing mirror Qn. for S8 / A8
  59. CV Joint/Boot Repair - Issue
  60. A8L brake recall???
  61. Car sounds like jet and loss of power!!
  62. Icm location
  63. A8 Blower motor wont shut off
  64. Transmission shudder at low rpm
  65. Bilstein Front Struts
  66. rear glass ?
  67. usit rings? (5HP24a trans oil pump mounting)
  68. D2 Fridge
  69. 2003 S8 Mystery Knob
  70. D2 S8 Transmission Shifter Detent Spring Adjustment
  71. :: ECS Tuning:: FREE SHIPPING ends 6/28 MIDNIGHT
  72. something with Gearbox
  73. limp mode - replacement trans A drum details - one with funky snap ring?
  74. Front upper rear control arm replacement
  75. Summer Start MEGASALE!
  76. Need purchasing advice. 2003 D2 S8
  77. 1998 A8 Quattro power steering line leak
  78. Air Quality Sensor
  79. Headlight/Igniter/Adjust Motor Wire Harness Repair
  80. Instrument Cluster Issue
  81. D2 S8 Manual Trans Swap
  82. 2000 A8 Airbag controller location?
  83. S8 Transmission
  84. Which Coolant Crossover Pipe 0-Ring for 2003 S8
  85. Durable engine? 2.5 3.3 or 4.2?
  86. 2005 A8 Control Panel not working
  87. Misfiring Issues PLEASE HELP! BIG HEADACHE
  88. send out torque converter for rebuild or buy one?
  89. 03 S8 No start
  90. Another issue with my audi s8
  91. Vacuum Pod stuck
  92. how to separate the rear driveshaft from the trans output flange?
  93. Cabin pollen filter air flow
  94. S8 Transmssion dead afer rebuild
  95. FREE SHIPPING through Memorial Day!
  96. Service position needed for serpentine belt change?
  97. Less than 24 hours away from launch!
  98. D2 BOSE (oem) Deck Speaker pn
  99. Rare factory options?
  100. New S8 owner 2000 in UK
  101. Seems to be a transmission problem.
  102. Oem steering wheel brand new for 138$(sabre black)
  103. 02 Audi a8 repaint, wanting to spice it up. Suggestions?
  104. 2011 Audi A8L no start code P025C need help
  105. No Start, No Spark, and no fuel to cylinder
  106. Thule Fit Kit 1222 for Audi '96-03 A8/S8
  107. New 02 Audi A8 owner, Q's about maintenance and upgrades
  108. FS: 2001 S8 with 147K miles, $5300 (Chicago)
  109. Bogging
  110. Thule Audi A8/S8 (D2) system for sale ($325)
  111. AutoPreme Prices (2 Weeks Away from Launch!)
  112. New D2 S8 owner
  113. In Back.. but need some help
  114. Performance chip
  115. Best wearing brand of tires for S8?
  116. No start
  117. Catalytic converter question
  118. Spring tune up
  119. FREE AutoPreme Floor Mats!?
  120. Nice S8 For Sale
  121. S8 - nifty improvised tool for loosening the forward exhaust nuts
  122. Where do I obtain a gasket for the S8 drive shaft CV joint?
  123. 2006 Audi A8 4.2 10 Codes Help
  124. 2004 A8 brake issues ...please help
  125. SUN ROOF STUCK OPEN
  126. ***Don Nguyen | WannabeRacer.com | Vehicle Wrap - Tint - Plastidip - Custom Decals***
  127. 03 a8 transmission slaming into gear
  128. Audi A8 Quattro D2 2.8l 1997 - Corner lamp
  129. Exhaust diameter
  130. A8 fuel pump relay
  131. 2001 S8 battery replacement
  132. 4.2 Swap Wiring info needed.
  133. Audi A8 D2 Gearbox input for topup or additive?
  134. D2 A8/S8's life expectancy?
  135. HVAC Nightmare!!!!!
  136. AUDI A8 D2 2.8 V6 radiator year 2000
  137. Xenon Bulb Recommendations?
  138. 97 A8 heat trouble again
  139. First D2 S8 possible purchase
  140. Early 1995 A8 engine number ABZ 008178
  141. Transmission fluid fill question/clarification
  142. Hitch Recommendations...
  143. A8 D2 4.2 V8 anti theft going crazy
  144. Why is my computer display very dim and unreadable in daylight?
  145. Interior Color Combo Question
  146. Transmission interchangeability?
  147. 2001 s8 4.2 engine swap???
  148. Symphony 6 CD changer won't load or unload
  149. 2000 A8 doors won't open from outside.
  150. accelerator
  151. broken transmission wire?
  152. Very slight amount of oil & coolant mixing. Possible oil cooler or tubes?
  153. any body familiar with this S8?
  154. Pulling motor and tranny, things I should do
  155. S8 trans service, pan won't drop past exhaust?
  156. A8 D2 started, died, mechanic says no compression
  157. Help with no crank no start
  158. Straight pipes on 01 S8
  159. Drive Belt Tensioner
  160. Where is this coolant dripping from by my alternator?
  161. 2004 A6 3.0l TCM Question
  162. new User: D2 A8 purchasing advice
  163. Hello rims question
  164. 1997 4.2Q D2 Weird AC issue
  165. Another start up problem again
  166. New Guy
  167. Keyfob problem Audi A8L D2 2002
  168. Vag login codes? For 3.3 akf
  169. Power Steering Hose cheap alternative, perhaps.
  170. 2002 A8 2.8 Quattro - Reverse gear selection issues.
  171. causes of p0300, p0301, p0302, p0303, p0304 ( '99 32v )
  172. Seeking a 1999 A8 Quattro Owners Manual
  173. How my 13 year old fuel filter looks like after 122k miles
  174. My 2002 D2 A8 2.8Q
  175. Fixing FM Antenna disconnected Problem
  176. Connection between misfire and low fuel level
  177. Replacing belt fan with electric (wiring help)
  178. Audi Navigation Plus Sat Nav conversion
  179. Coolant hose replacement 99 A8 4.2
  180. Heavy Power Steering, diagnostic procedure?
  181. 2,8 Audi a8 dont start 95 aah engine code
  182. 01 S8 timing belt
  183. :: ECS Tuning :: 50% OFF CYBER MONDAY ONLY! Audi Ziza Master LED Kits
  184. Audi A8 transmission problem
  185. Febi upper control arms
  186. Black Friday/ Cyber Monday deals from Car Parts Discount
  187. 2001 A8L - Transmission Problems (among others)
  188. :: ECS Tuning :: 11th Annual Customer Appreciation Sale|Save up to 25%!!!!!!!
  189. Catalytic Help
  190. No radio station or navigation in display instrument cluster
  191. Tips - not driving car for 8 months ?
  192. Oil leak? Sanitary towel solution!!
  193. Front Muffler Removal?
  194. electrical surging
  195. I'm going to cut my nuts off
  196. Cooling fan running all the time
  197. A8L to 01E, BAAABY!!
  198. Filling transmission
  199. Coolant temp a steady 105 Deg?
  200. Start up problem
  201. Timing belt and chain install
  202. Brake question
  203. 2002 S8 Just a few questions
  204. Cam chain tensioner install
  205. Special promotion for Audi World Forum members
  206. 97 A8 Quattro 4.2 gear selector binding after short drive
  207. Glass issues
  208. Breaking in to my S8 - help please!
  209. Forum group buy with Car Parts Discount
  210. Failed Vacuum Pod
  211. Audi a8 95
  212. 98 a8 Q airflow controller
  213. 280mm Rear Brake Disc conversion
  214. Removing F clutch pack
  215. What hoses are these?
  216. Water leaking from liner
  217. S8 98 engine starting problem
  218. Massive coolant leak
  219. Passenger Window issue
  220. 1997 A8 Quattro wont Crank
  221. transmission won't reversed
  222. S8 Unitronic Tune DONE!!!
  223. P0171 P0174 help.
  224. audi techs?
  225. Exterior Temperature Problem
  226. Looking for S8 front uprights
  227. 6 speed swapping an s8, any advice/warnings?
  228. transmission shudder
  229. found this while cleaning the car
  230. Beware Cheap Car Hoists
  231. How to remove steering line retainer?
  232. S8 Brembo crossover pipe leak
  233. Have misfire in cyl. 4 so i swapped icm's and now it won't start period.
  234. Electrical confusion
  235. Have misfire in cyl. 4 so i swapped icm's and now it won't start period.
  236. Is the D3 power steering line interchangeable with the D2?
  237. Source for D2 S8 caliper seal kits?
  238. Strangest problem: Central locking system reversed. Dont know where to start.
  239. Front Struts for 2001 S8?
  240. :: GruvenParts.com Billet Intake Manifold Linkages, Oil Cooler Tubes, and More for A8
  241. low oil pressure
  242. Misfire #4 not going well..
  243. Special promotion for Audiworld members
  244. Clockspring fix
  245. 98 S8 turnover,but won't start
  246. D3 19's on my D2 S8
  247. Outside temp
  248. Thread Bump - Downpipes for 4.2
  249. My WTB list if anyone can help
  250. 1995 Audi A8 HID/Xenon headlight
