Log In
View Full Version : A8 / S8 (D2 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
  1. Do they sell vented rear disk brakes for the 1999 A8
  2. sticky lifter? Valve problems? Need some help please
  3. Did you read the 'Shooting Brake' concept that Audi's shown at Tokyo?
  4. What would be the easiest way to add fluid to the tranny?
  5. Error on ABS unit
  6. Lean Mixture Problem
  7. Some what off topic but hilarious
  8. Winter wheel time...
  9. rear hose solution?
  10. Looks like I can't live my shifter alone. What do you guys think?
  11. ABS issue ?
  12. Water in vents?
  13. T-14 Hours!
  14. Electrical Question
  15. seat memory, how it works? I dont get it??
  16. my seat memory buttons popped out
  17. Brake squeel fixed, but outer rim of rotor nolonger has contact...
  18. Wheels, tires, + Packages
  19. Help! Where can I buy a used ECM?
  20. oil cooler leak
  21. Brake Rotors and Audi Advantage
  22. Rough Idle
  23. has anyone put rns-e in usa spec A8/S8?
  24. Thinking about lowering you car, but want to see how it's going to look before spending big $?
  25. rear breather hose replacement
  26. where do you buy mobil 1 and how much?
  27. Boston Area GTG 10/24 update...
  28. CD changer plug, confusion
  29. Questions (kinda long)
  30. Subwoofer + Delta player ??
  31. TB service just completed
  32. Right side fender molding lost!
  33. Front end "clicking"
  34. Finally! Tracked down the clunking....
  35. Manual says no mobile phone inside the car?????
  36. Sat nav instructions for use
  37. body shop in Sacramento, CA suggestion?
  38. Considering sale of my 99A8
  39. white smoke....... on warm day
  40. Extremely loose tie rod end, dangerous?
  41. Two plus weeks waiting for an instrument cluster and than...
  42. In the beginning...
  43. No way.. Paul i have a present for you
  44. Bulbs
  45. a8 headlights not working!!!!
  46. Audi A8 [old shape] seat wiring diagram??
  47. Did my powersteering fluid flush this weekend as per the Audipages Tech.....
  48. i found a new button
  49. transmission fluid
  50. 1999 A8 4.2 Strange dash light experience
  51. Question for Paul?
  52. water in transmission possible?
  53. I'm finally getting around to selling my 01 A8L.
  54. Link to TopGear Review of A8 4.0 TDI driving 800+ miles on one tank
  55. Tool Kit and Lug Nut Caps
  56. '97 A8 in Denver with only 34K, in case anyone's interested
  57. ECU problem
  58. Need 16" A8 Wheels/Tires!
  59. Breather hose replacement
  60. A8 2.5TDI Quattro - problem
  61. Central NJ GTG - Saturday, October 15th, 10 AM
  62. '01 S8 Central Locking weirdness. (long)
  63. dashboard removel.
  64. Next Saturday GTG
  65. Front Brake Pads & Rotors replacement
  66. Does anyone know how this comes apart?
  67. Control arm torque specs and misc comments - long
  68. Still Have Slight Vibration After Hub Centric Rings Installed
  69. Better Gas Mileage - Audi TT/A4/S4/A6/A8 +MPG
  70. Earth for trip computer
  71. Just got a S8! questions...noob
  72. Syracuse to Saratoga Fall Foliage Run - Postponed to Sunday October 16th.
  73. Looking for advise on part delay
  74. my S8 has arrived!
  75. New 2001 A8 with questions
  76. '99 A8 Water continues to get into the engine control module
  77. Aligning headlights.
  78. 1998 Tranny Re-code in NoVA
  79. So the Parents are getting a 2006 Passat 3.6 280HP 4motion!!
  80. Cant get belt fan off!
  81. Upstate NY Fall Cruise 10-8-05 Update - If it rains......
  82. bumper problems
  83. Silly Q... about Diesel...
  84. 18" RS4s, cheap
  85. front final drive fluid check - how to ?
  86. Driver Side Mirror
  87. Does type of coolant fluid matter? Suggestions on raditor stop leak?
  88. New pic. Please help me, 01 S8 motor with harnest...
  89. Telemetrics
  90. $520 for my tranny service, and $600 to fix my radio reception? I don't think so...
  91. fixed the creaking noise in the front end..
  92. Exhaust Compatibility A8/S8
  93. Recode Transmission in Boston area
  94. Noisy boot with steering column?
  95. Will 2001 S8 motor go into 1999A8 D2? Easy or forget it??
  96. Our path for the Fall Cruise - October 8th.
  97. Didn't someone want pictures of the new Q7? I have access to some Frankfurt Auto Show pics.
  98. Beep when locking car..
  99. Very Pleased with my Gas Mileage Thus Far
  100. Joining the club, justbought an A8
  101. Fuel Tank Damage from gravel on the road.
  102. Raise the alarm
  103. Serious Missing
  104. Overheating...cont.
  105. Roof Rails Lubrication
  106. Grinding Noise
  107. Somebody here should want this.
  108. Odd request: Picture of '97 antenna or a part number/source.
  109. Here is a short geared tranny for you guys.
  110. what's the longest time period anyone has gone WITHOUT changing timing belt??!
  111. Radiator replacement
  112. What wheel is this?
  113. Anyone in Chicago that could check out an A8 for me?
  114. Transmission Hunting and Thumping, something to try
  115. S8 FAQ ? Anything exist for these? Looking for more info...
  116. Where can I find camshaft locating tools ?
  117. Timing belt on ABZ question
  118. What is so great about oil 5W-20. Newer engines seem to use it
  119. 1997-99 3.7 or 4.2 Timing Belt
  120. Anyone know where I can find 1 or 2 BBS SX 18" X 8" wheels?
  121. 130k on original timing belt?
  122. o2 sensors and temp switch location
  123. Stupid horn. I am so pissed off
  124. Ok, I am at 62,000 miles with many "issues", I need some advice!
  125. Paul what was the part number of your S8 instrument cluster?
  126. trans overhaul update '97 Quattro
  127. axle, cv removal
  128. Central NY fall cruise This Saturday ( Oct 8th). If anyone is interested write back here.
  129. 2000 A 8 front brake pads
  130. sounds like the new s8 is ready to launch
  131. Transmission thump part 2 ( I do not want this to get lost at the bottom of the page ).
  132. Can someone tell me if this car has Xenons?
  133. I don't think carfax will clear this title ...
  134. 26 days old... New Transmission
  135. GIAC vs. MTM
  136. flange seals - transmission
  137. I hope this pic isn't a repost / someone doesn't like the A8
  138. Seeing some A8's at PLM this weekend makes me want one. Need opinions....
  139. Pictures from my climate control light bulb replacement ATTN PaulW
  140. o2 sensors??
  141. I found my A8 twin! </friends joey voice>(Petit Le Mans photos inside)
  142. overheating
  143. Transmission thump ( or two ) on down hill, after fluid and filter change. Please read, but long.
  144. Axle nut - how tight ?
  145. Transmission problem, A8 '97 need some advice (long)
  146. So Paul, are we going to see this in your garage?
  147. creaking and rattling front end
  148. Lemmiwinks
  149. Is right side according to Vag Com, passenger side?
  150. LEDs
  151. Power steering / suspension noise?
  152. are the 18" a8 monoblock/pie plate wheels forged? How much do they weigh?
  153. will breather line breaks/faillures give p1136 and p1138 codes
  154. The Perfect Pump for Trans fluid
  155. Instrument cluster died. What to expect for part ETA ?
  156. Help --brake squeal
  157. Get ready for some tire squealing!
  158. Does anyone have a spare Concert I Radio head unit from a 98 or 99 A8
  159. I got a Hybrid. 255 HP Accord. It is really amazing.
  160. Mod questions....
  161. stumped
  162. leather products
  163. TB Complete!
  164. Repair adventures
  165. found more info on the scam letter I got
  166. We dont need no stinkin' armrests....
  167. Source for clear corners for a '97?
  168. Started the upper control arms...
  169. breather hose problems??
  170. Phat Box
  171. Steering Wheel Heat
  172. Four wheel drive - how to diagnose?
  173. Tranny service needed at 60k?
  174. look another scam.. I saw this posted on here a few days ago
  175. WTB A8 Rims/tires
  176. Diagnosis?
  177. A8 Coolant G 012 A8DA1 cross to G 012 A8FA4?
  178. Im purchasing a control arm kit... however i dont need the tie rod ends or sway bar braces..
  179. Anything going on saturday?
  180. 200 A8L vibration 80+ ? Front end??
  181. I need control arms - again !
  182. Looking for pictures of Black S8 or A8 with black rims.
  183. Exaust system check
  184. I like 18" pie plates
  185. I don't think I want to buy a new A8, after reading their forum for the past year...
  186. "Honey, let's watch a movie starring an Audi tonight."
  187. SNOW wheel-tire Packages.
  188. Cig lighter flashlight
  189. Does anyone know this dealer? I'm curious why this S8 didn't move on Ebay.
  190. Vendetta of hot Balkan people - A8 "horror"
  191. Is $34k a good price for an '01 S8 w/70k miles???
  192. Are plastic hub centric rings okay? What about 73mm when manufacturer says 73.2?
  193. Looking for an S8, i have a few questions
  194. I found the sucker!!!!
  195. Porsche drops on plan to take VW stake
  196. IN to the dealer we go.
  197. ABS Module or??? Opinions
  198. 1999 or 2000 A8 v. 1999 or 2000 e320 4matic
  199. How much is my car worth? Estimate please
  200. 2 quick questions PaulW one for you...
  201. Paging PaulW...bluetooth install help!
  202. Ouch! Speeding... yes. Reckless... absolutely not! Any recommendations for
  203. Advise on A8 oil cooler
  204. [O.C. Reminder] Audi GTG @ G.Bilotta's in Brea -- Tomorrow TUE Sept 27 8:00pm
  205. Hand Brake when applied does not stop the car from rolling
  206. Triple Square Bit..?
  207. bolt torques -- do they really matter?
  208. Trans rebuild report
  209. looking for pictures of the Q7 .. anyone have a site
  210. Driver's side rear view mirror stuck
  211. Just put Bridgestone RE050s on yesterday.... man these tires are sweet! Anyone else have 'em
  212. Porsche AG plans to invest 20% in VW AG announced today in Germany.
  213. I have some idle control problem.
  214. Exhaust mod
  215. I am considering buying a hybrid. Does anyone know anything about maintanance costs, problems etc.
  216. I've never read about oil consumption here from US owners. But
  217. how do you search by author of a post
  218. Does anyone happen to know if AoA has plans to import diesel cars?
  219. how to lower the headrest
  220. Clogged windshield washer nozzle..
  221. I think my car is starting with the "hunting". Here is what happens
  222. Trade My Custom Zender wheels for stocks
  223. Failed Texas state Inspection due to parking brake problem
  224. FK HighSport Coilovers, D2 A8, 94+
  225. got my tranny flushed today from the place
  226. 01 - Control Arms Recalled and Replaced
  227. What is Average Time to Sell A8 (01) on Autotrader?
  228. Front upper control arms- tips or tricks
  229. 2001 S8 Navigation Plus question
  230. d2 oil pan
  231. 2001 S8 Running Too Hot
  232. Car (98-A8-4.2Q-152K) will not start - please help.
  233. Question for those who have the TC locking/unlocking problem..
  234. 1998 A8 with transmission problems. Help!
  235. OK...transmission rebuilt
  236. Is there any problem with putting D3 wheels on our cars?
  237. BOSTON AREA GTG - Last hurrah before the cold!!!
  238. What do we think this S8 will sell for? I'm surprised it hasn't been bid up earlier.
  239. More Manual Trans Conversion Goodness...
  240. Can we all just chip in, maybe everyone could have it for a month at a time
  241. Where To Buy Hub Centric Rings?
  242. power mirror switch gone bad
  243. Experience with Luxury Motors (largest internet car sales firm)
  244. AMS is having an end of summer sale
  245. Driver Side Mirror
  246. viscous fan clutch - 100K miles and can stop with pencil
  247. Anyone have (4) 18in D3 Five-star wheels for sale?
  248. I wonder what will happen to gas prices in a few days because of RITA
  249. Anyone use FK Highsport Coilovers?
  250. Front bumper ripped off due to rebar (or driver)
