View Full Version : Audi Original "S" Cars
- Thinking about 255 40 17's with 17x8 ET 35...
- Is there any issue mixing G11 and G12 antifreeze?
- Anti-Theft suggestion...
- Alignment issue - Camber's maxed
- Free Gmail invites, just e-mail me.
- anyone selling a s4 or s6? i'm lookin forone
- Goddam insurance companies are a fing joke!
- need a complete audio write up
- how can i tell if my BPV spring is too stiff?
- Looks like a great catch!
- You may see my Avant on the big screen come 2005.........
- Clear corners
- Removing ECU: any special care/procedure/tip? Hope to have the chip upgraded this week.
- Walker o2 sensor from ECS tuning.... anyone know who actually makes it? It says made in japan.
- any good classifieds for original S cars and parts
- synchro crunch
- Argh I can't wait to drive my car again...
- XPost from S-Cars List: Dyno Results from Dave D. Testing
- Question for Bill the Cat regarding fuel pump removal tools:
- A little follow-up
- Window Switch
- Hey Hap...how did the dyno go with you and Dave today?
- Help with the stereo
- Ok I decided to stay stock 92 springs and Bilstein HD...but
- wider tires in rear?
- Pedmaster, a couple question about painting your headlights black . . .
- Hap...any new HRSB shipments going?
- Stromung group buy cool...how about Stromung group install???
- Will 18x8" ET35 with 245/40/r18 fit on audi 100 S4 1992?
- Silly wreckers...
- where do i go for custom ecu tuning for rs2 parts?
- Looking for transmission mounts, ETKA list 2 types...
- Hmmm...i don't think my pump is in that bad of shape:
- Kent Falls, Ct gtg/bbq...Saturday, Oct. 9th
- Mihnea...YGM..thx!
- s6 vs. s4
- Does anbody's trunk lock button get stuck...
- Can I use anti-seize on the caliper guide pins? I did so I hope so.
- Mihnea, please ASAP! (+)
- brake light on
- the coolest thing ever happened last night (kinda long)
- The shifter is up nice and high here....
- Here we go, better pic...
- My new license plates...
- Air/fuel gauge working, says I'm running very lean......
- Anybody have a source for Stromung gaskets? Need 4 of them.
- Brake Pad warning light will not go off even w/new pads!!
- Can you guys get me the part # for this hose? "see pics."
- headlights
- even more brake problems...
- quattrospeed...
- Hey Pizzo, you out there.......question about air/fuel mixture gauge......
- One more slightly meaner pic of the FMIC
- see anything is possible: huge! intercooler
- Davtron Intercooler Gauge Installed
- My 1993 audi 100cs wagon
- S6-4RiNGS....according to ETKA...
- Lookie...
- Alternate for BBS LM rim
- i thought our wheels were 35mm offset
- yeah, do i get to be apart of the caliper guide pin seized club??
- Can a "S" owner get a little help?........
- Ok ticking lifter noise is gone :) But now... i just recently replaced my steering pump... and its
- Cody, 500R, Hap........you guys with "big" turbo's....what kind of boost are you running?
- Engine started ticking loudy, lifters as usual... went to check the oil had to add...
- OK so don't hate me but to make my life easier I dropped the subframe...
- Control Arm and Tie Rod job done. but I noticed the caliper carrier bracket was seized...
- Elijah or anyone, are you gunna be at Gingerman tomorrow? i will be there!
- What size wheel bolts do we require with et35 wheels? Is it 40 mm or what?
- Here's an example of a positive exchange between two ebay members:
- 26x8x3.5 FMIC mock up
- Cheapest fuel pump I can find is $160...
- Damn... my power steering leak is a SIX HUNDRED dollar hose... Pump to accumulator... any ideas!?
- Apikol FMIC Installed
- RS2 MEETING
- 10v Timing Belt tools work with a 20v?
- GT500.... What do you recommend for a stripped wastegate adjustment bolt?
- Think i'm selling the S4
- Gary Lewis...please pick up the red courtesy phone...
- What do you guys think of this setup...?
- In searching for an RS4 shift knob I found this...
- How do I get this sway bar to bolt back up???
- Black S4 with the RS6 wheels.........
- So with Big Red pads on my mind....POLL... what are you using and do you like them?
- First full day driving w/ boost gauge.........no wonder these little turbo's last so long.....
- Damn. Hawk HPS's on Big Reds squealing like mad hell now after 2K miles.
- Well, found my coolant leak....
- Picture of my clear corners
- brake problem
- where to get S8 style crome mirror caps at?
- Not to flog a dead horse but..... (top speed related info inside)
- What exactly is leaking here?
- 9/25/04 - Audi Dyno Day and Get Together - Come Hang Out - near Hartford, CT
- Big Bump, now need an orphraned Borbet type C
- My brake pad warning light has been on for a while...
- Control Arm Question. Size of nut number 8, bigger than 21mm
- Apikol FMIC Dimensions
- Well, finally got power back on. I hate hurricanes ;-P
- OK guys, boost gauge FINALLY installed, how do these numbers sound?........
- Has anybody had experiences with Flik wheels?
- Does anyone know where to get replacement mirrors for my 94, brown crud an inch into it!
- Oxygen sensor musings...
- Notice for the Current 9011/9012 GP.
- I'm going to say this now so no one else has to... New A4 = one more reason to keep your old cars.
- Hey Yummy, are you goin to GingerMan for the event, you live in MI right?
- FREE ANTI-LOCK SWITCH
- ECS Squeal, did a search, and I see some of you used some "goo" last year.
- i'm just not a Clear-Corner- type-of-guy... so who wants my depo's?
- I <3 BBS LM's.
- So I might go run the Texas mile this year........
- So has anyone managed to roll their back fenders to match the fronts?.....
- Chrysler Crossfire...
- thoughts on car project: looking to get a nice, used S2...
- BTW...other current issue is...
- Brake warning light just came on...
- New Speed - Horsepower Posting below.
- once more i can post freely without being hounded by porno links. audi content
- Recommended 100k tuneup?
- stromung questions regarding heat and top speed
- is the top speed limiter in the same place on all urs cars?
- I know this has been dicussed before, but I never cared till now
- Just ordered my front end parts: control arms, tie rods, sway bar bushings...
- Should i say FU cossie and build a 90 with the guts of my car?
- S cars is down??
- Any of you guys want a Gmail invite? I have another 4 unspoken for.
- FS: 1996 RS2 spec S6
- where is the cooling fan resistor???
- has anyone here done this cheap IC mod?
- Installed Depo clear corners today. Perfect fit. I like the look.
- New SS Shot
- I will be parting out my car if its totalled.
- first driving impresions
- Who else was at LimeRock today?
- Need advice/help on where to tap for power for the boost/air/fuel gauges.....
- Got my Boost Guage installed - the "repeater" version.
- Better off changing headgasket when I go RS2?
- Car's using antifreeze very, very slowly.......
- Dahlback Intake on...
- FMIC is on.
- need some help up in Milwaukee, WI
- Guys. What do you think about Roundell #58's. I wonder if they clear Big brakes?
- Anyone have the bentley page that shows the........
- Timing Belt...I have to do it comming up soon and was wondering...
- Maybe someone can give me some advice on fixing the small stuff that's wrong with my car:
- CAR FOUND GRRRRRR
- my home depot intake kit. haha
- body, squeaky noise, throttle????
- What 100,000 EUR will buy ya.
- Reminder - BBQ Sat Sept 4 for any & all Audi owners
- Hi guys!Need a quick response!!Looking at a 95 S6 with just over 100K for 10K
- Opinions of Hybrid turbo's from people that are actually running them...
- Do I get to play with the big kids now? Or should I stay in the 80/90/coupe forum
- x-post: questions about boost, power & Mihnea's chip...
- Cashmere S6 on eBay
- anyone have a spare clear corner light , driver side for sale?
- Sway Bars....92's have em but does anybody make good ones?
- X-Post... Nav Plus and BAC iPod installation
- clicking in the early morning...
- For those that already have FMIC instaled......
- Replaced the o2 sensor... still running rich... grrrr I hate problems that don't go away.
- still more brake problems
- What advantages do the 7a and RS2 ex cams offer?
- S6 & A6 Avant spring / chassis differences
- Anyone have a Part # for the SPA Intercooler crossover hose? My D$%N ^T$# , Shortie Samco.....
- What is the towing capacity of a UrS6 Avant??
- Wish me luck...damn hurricane making a bee line for me!
- OMGHI2GT42
- CV Boot Issue
- silvURs4.........did you get my payment for the T-fitting?
- What is the I.D. of the moisture trap hose?
- Are S4 rear arm rests like this one?
- Anyone have any crack/chip-free passenger side headlight lenses hangin around?
- Question: What is the 90011/9012 GP I keep reading about? Would these lights be a simple swap for
- owned
- Brake help needed.....
- Apikol Short Shifter problems?
- 9/25/04 Audi Dyno Day Spots are now Open - Wethersfield, CT ....
- More Stromung...
- Yay! Wheels fixed. I'll post pics later.
- Anyone here let their dogs ride?
- Hey A-Pillar boost gauge guys......did you remove the A-pillar cover or.......
- Need to store the S4 for the Winter, Any Suggestions?
- BP valves. Did the 710G supercede the 710N? Car has a boost leak...
- Good source for the Autospeed MBC parts?
- Slotted rotors versus OEM regular ? For NORMAL driving does it make sense?
- 4Driver4
- Anybody have a window relay for sale?
- 1996 URS6 6 speed on Ebay.......in the U.K......only 5000 pounds
- Stromung Comments
- FMIC is in...
- Cody Payne can't be trusted with tech reports anymore!! The Apiikol Short Shifter...
- Anyone have the Mattig grill on their S4 or S6?
- Just won an ANTI-Lock brake dash swtich off of ebay... what was the link...
- Any tips in removing the rear shock/spring assembly?
- I would like to have express down with my passenger window....?
- Suede Headliner X-post
- Anyone have that list of which Breeze Clamps we need? I searched and only found the napa/mcmasters..
- More on that crazy street race video (M5 vs RS4)
- NTAG drive - 8.15.
- 1995.5 S6
- Black Avant on eBay
- S Fest Media (BWW)...
- //S Fest
- any news on germantoy's car ?
- Tested my hoses this weekend
- i need a new boost gauge, suggestions??
- Got some vids up of this weekend's import war. Including this 8 sec car that hit the wall!
- ACNA GingerMan event still has openings`
- to those who have had coolant leaks, sorry for repeating question, but have new Q's.
- will stock S6 sedan springs fit an Avant?
- Run in w/ fellow Audi Driver HWY 36 West Bound towards Boulder CO
- Im getting real tempted to buy one of these
- View/upload pics of //SFest '04 here.
- UrS4boy: Thanks for the beer.
- Tachometer no worky..
- //SFest ruled, that is all.
- coolant leaking bad
- Northeast S Fest - teaser pics.
- Where is a good place to get those self tensioning hose clamps? TIA
- O\/\/ned by the Dallas "City Titty"
- 2nd Turbo Upgrade?
- Whats a preowned MTM 1+ worth??
- Is it normal for this Samco hose to have a joint in the middle?
- where can i buy a 710n bpv?
- Gunmetal or Black Chrome plate frame with Audi Sport logo, where to find ???
- Just pulled codes, 4444, nothing reported....questions??
- what kind of coolant to use
- help, need to take off the pass. rear view mirror
- Off to //SFest!
- will an alignment be needed after replacing the strut inserts (fronts only)?
- OMGWTF....
- Drove a 91 20V sedan earlier in the week.. Turbo felt less obvious than our S4/S6's, almost slower?
- Any interest in a 9011/9012 GP?
- New Here!! W/ Turbo Question
- Link to S-car.org's 3 spoke steering wheel install instructions
- 95.5 S6 Loss power, fluttering , rough idle; BG44k and questions!
- blkaudicq, have you replaced the side seals on your diff.?
- To RS2 or not to RS2 ...
- '95 door moldings removal ?
- Boleros fitted..
- Do the B5 S4 steering wheels fit our cars and if so I might have a line on one....
- Finally got Bilstein HD installed.
- Anyone selling floor mats? E-mail me.
- Over boost>>>>>>
- ATE superblue brake fluid ok for 93 S4?
- Another Avant on eBay
- What's the max boost we can use on a chipped, everything else stock S6? What kind of boost should I
- EURO Ur S4 speedo FS
- 92'-94' S4 door moldings vs. 95' + S6 door moldings...anyone do this?
