PDA
View Full Version : Audi Original "S" Cars
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. Quick Coolant Question
  2. HI all. Need help my audi 100 c4 s4 v8 4,2 burns A LOT of oil.!!!!
  3. 1993 UrS4 rough idle when cold
  4. Reason why fluid(s) might their way into the 01E transmission bell housing
  5. New guy with a few questions.
  6. AAN vacuum/pressure on idle
  7. NEW BILSTEINS FOR THE S6--WHAT SHOULD I WATCH FOR?
  8. Question about brake light on dash
  9. Where can you find a decent tri spoke steering wheel?
  10. Links to a Website with UrS Parts numbers
  11. Need help with UrS4 AAN 2.2T Motronic ECU wiring
  12. Ford RS200 and Sport Quattro Comparo video
  13. Grateful to URS4boy
  14. Gofundme for Jeff Gerner's 2015 UrS Bonneville Attempt
  15. UrS A/C Evaporator R&R
  16. Please welcome M'Autolite; new vendor on AW and receive 20% discount on all items!
  17. 1993 urs4 infrared locking not working
  18. where to buy coolant return line hose pn: N0202621
  19. Need a passenger side mirror for 95 S6 Avant
  20. mann w719/5 work on aan
  21. Question on fuel pump?
  22. Used to post here unde S4audinut - I have perf. chips
  23. Exhaust question
  24. Need your help and opinions please
  25. low oil pressure
  26. Interior swap...
  27. C4 A-pillar cover removal: pre-windshield R&R
  28. C4 Hatch Dome Light Bulb Access and Replacement
  29. C4 100/UrS4 A6/UrS6 Interior B-Pillar Removal
  30. anyone have the pictures to this old post
  31. Checking Continuity between the S64/115 switched power supply and the ECU
  32. AAN ECU T55 Pin-out with hyperlinks to devices
  33. C4 UrS/100/A6 Dash Trim Removal DIY
  34. air filter housing cover aka air inlet assembly
  35. won't accelerate properly
  36. 95 Urs6 Steering Pulse
  37. UrS4 Headrest Disassembly 101 - with the goal of swapping headrest posts
  38. Boost Question
  39. suspension kits
  40. Video Review of the 2015 Audi SQ5
  41. Locking system
  42. brake caliper question
  43. C4 AAN Cooling and Heating System (with hyperlinks to more info)
  44. Aftermarket headlight switch issues.
  45. MERRY CHRISTMAS! HAVE TO BUY AN ALTERNATOR FOR 95 S6--WHERE'S A GOOD PLACE??
  46. Tool number 3214
  47. 1995 UrS6 Starting Issues
  48. pentosin vs audi ps fluid.
  49. Super clean 95.5 S6 for sale on bringatrailer
  50. cooling and hvac overhaul... what am i missing?
  51. Hello...new owner and first Audi.
  52. DEAD SHORT--BATTERY GOES FLAT IN A COUPLE OF HOURS
  53. Need Front Turn signal, clear markers? 95 S6
  54. Replacing Climate Control Head Illumination Bulbs
  55. Consolidated C4 UrS steering rack info, including Servotronic and non-Servotronic
  56. Easier car to live with: UrS4/S6 or B5 A4 1.8TQ?
  57. front lower control arm question
  58. Green S6 hood and fender
  59. Back after 10 years...
  60. Brake pulsation
  61. Passenger Side Fender
  62. Sexy, smooth and shiny - and cheap (for a change!)
  63. New to me bug: UrS4 cranks, runs up to 2,000rpm and dies.
  64. 2009 B8 S4 front belts all snapped
  65. Body tare down
  66. 94 S4 Difficult to start
  67. Turbo not responsive
  68. urs4 won't shift into reverse
  69. How Much Boost?
  70. 1995 UrS6 clutch problem
  71. Need help (what type of connector do I Need install on my car ?)
  72. HID LOW BEAMS WITH BALLAST--DO I HAVE TO CHANGE THEM FOR STOCK BULBS?
  73. clutch replacment
  74. SPARK PLUGS VERY TIGHT--AFRAID I'M GOING TO SNAP--PLEASE GIVE ME SOME POINTERS
  75. Oil Pan R&R
  76. 95 S6 downpipe and tune question
  77. THE ANSWER ON THE 3256 PULLEY TOOL IS SAMSTAG TOOL
  78. WHERE CAN I BUY DAMPER PULLEY LOCKING TOOL #3256??
  79. High Beams not working
  80. 20 Minute Test Drive--S6 arrived last night
  81. Centennial CO sighting
  82. 5 MINUTE TEST DRIVE--MY NEW TO ME S6--JUST OFF THE TRUCK FROM NORTH DAKOTA
  83. brake issues
  84. ECS TIMING BELT KIT--ANY GOOD?
  85. 20VT Front Crank Seal Replacement Info
  86. tail light help?
  87. 95 S6 on the way
  88. Canister
  89. New member with a boost question
  90. Ordering Parts from Audi Tradition
  91. S4 valuations for replacement insurance
  92. sulphur smell
  93. Six Speed Transmission for the S6
  94. new rebuilt J hose
  95. banjo bolts for j hose.
  96. Where is the other end of this hose
  97. SHOP TO SERVICE A URS6 NEAR BOSTON MA
  98. Testing MAF
  99. Injectors
  100. E-Brake
  101. Head rebuild and refresh
  102. Lower/Middle Door Trim
  103. broken tensioner bracket
  104. Need advice on buying parts
  105. 94 UR S4 ECU fuse instantly pops
  106. Anyone know where I can source a wagner RS2 manifold with KKK flange?
  107. Rear sway bar
  108. My beauty is getting back on the road ;)
  109. Callout for the Above ECU Fuse Panel Fuses - UrS4 and UrS6 differences
  110. 1997 S6 no start
  111. Can someone explain the button under the loud pedal ?
  112. REAR Freeze out plug
  113. Testing for Switched Power at the C4 J17 FP relay
  114. Back in an Audi (95.5 S6) - some questions
  115. RS2 ECU
  116. Memorial Day Special @ Detailer's Domain - Stock up on your detailing gear!
  117. Inside the rear diff lock switch
  118. 92' Audi s4 timing problems ( aan engine)
  119. Wastegate Hose Not Connected
  120. '86 5k CS Turbo - Formed Fuel Injector Line
  121. going to carlisle? need parts?
  122. Some the "secrets" hidden behind the front fenders.
  123. 6 speed swap advice?
  124. eccentric bolt part number
  125. New C4 sill scuff plates are now available from Audi Tradition
  126. G4 Crank Position Sensor and G28 Engine Speed Sensor Maintenance
  127. C4 100/S4 and A6/S6 Sunroof Drain locations and hints on clearing them
  128. Radio issues. LOUD Noise
  129. Found in my basement... TDS-X
  130. Experience with H&R Race Springs?
  131. 93 S4 leaks fluids
  132. C4 100/S4 and A6/S6 Manual Gas Flap Unlocking Info
  133. Some C4 Trunk and Hatch Lock Info
  134. HELP
  135. 08 S6 Experience - Problems, Warranty +....
  136. painting bumpers
  137. Scrapyard compatibility: 95 Avant hatch door?
  138. Going up for sale
  139. For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95!
  140. Urs6 Stutter and Jerk Accelerating
  141. 1993 Auto Transmission Woes
  142. Drive Your Dream Super Car At NCCAR March 27-30th
  143. Spring Therapy @ DetailersDomain.com - 15% off and shipping promos
  144. instrumnt panel light watage?
  145. random question
  146. ABS/speed sensor
  147. Might have to sell my 93 S4. Need opinions on asking price.
  148. What color is the o2 wire at the ECU?
  149. 1995 vs 1995.5
  150. Brake pedal issue
  151. 5 speed problems
  152. HR springs, what shocks?
  153. Fuel cut at 6000
  154. Wide Band O2 install?
  155. Feeling the winter time blues? Here is a 20% off Promo Code to get better.
  156. Sunroof Control Panel Removal (and the inevitable clip repair)
  157. One Rear Brake Caliper Re and Re DIY
  158. FM reception bad when engine running..
  159. Bilstein HDs?
  160. I need a G62
  161. rear dif
  162. Crank position sensor vs engine speed
  163. New to forum - 2 questions
  164. WTB: Audi Sport springs for 1995.5 S6 Avant
  165. suspension issues tire rubbing
  166. Adaptive Damping
  167. Another issue...never ends haha
  168. '92 s4 I5 2.2 Turbo 5speed (I need some serious help with Trans info)
  169. Sulphur smell
  170. AWD dyno in Chicago and warm start/fuel issue
  171. chipped or stand alone
  172. 1995 Audi US Model Range Brochure
  173. Failed Smog :( (California)
  174. C4 UrS4/S6 Starting circuit
  175. rattle sound
  176. Lights out
  177. Blast from the past: Ayrton Senna tests the new 1994 Audi S4 20V turbo
  178. Tranny flush
  179. Brake Bomb R&R procedure?
  180. Looking for some parts
  181. Parts Car
  182. 1993 S4 for sale
  183. Odd HVAC behavior
  184. B5 small spline on 95 S6
  185. boost gauge in clock location
  186. Looking at an Avant. Can I exploit your expertise?
  187. AAN Intake Removal R&R (with injector insert replacement)
  188. Boost hoses?
  189. Trade for an E39 M5 with 58k 2001
  190. No rear brake lights
  191. urs6 for sale
  192. Baby Black Brakes SQUEEEEAK
  193. Possible Starter Issue?
  194. Audi S4 2.2 quattro Automatic gearbox problems
  195. Please DO NOT post questions in the FAQ
  196. front end squeal
  197. I5 Engine/Coil Cover?
  198. Replacing Radiator and Fan - Any advice?
  199. lowering springs options
  200. 95.5 Ur S6 Questions: Seats, Lights, etc.
  201. Looked at a 94 UrS4 tonight, have questions.
  202. intermittent no-start condition when engine is warm
  203. Wiper arm question
  204. wheel bearing tool
  205. 1994 S4 for sale
  206. New member with 95.5 S6 and a quick question
  207. Some testing resistances for a few of the Engine Devices (to be used in other posts)
  208. 15% off for the next 48 hours at DetailersDomain.com
  209. Stock or GT28rs, best bang for buck MPG
  210. Trouble-shooting a dead C4 UrS6 Avant rear wiper
  211. Secrets of the C4 Rear Hatch Wiring
  212. its in the shop
  213. C4 UrS (and 100/A6) Driver's End-of-dash Fuse Panel
  214. anti-theft
  215. 1993 S4 Thermostat Replacement Leak
  216. Fuel Pump Testing Kit DIY
  217. 95 S6 Avant radio needed? Also aftermarket not working with Safe Mode?
  218. rubber hose fix
  219. High Fuel Pressure
  220. N0202621
  221. heater core writeup
  222. in search of a pos unit
  223. Best coil pack option
  224. "Mysteries" of the C4 CEL/ Air Bag/Seat Belt warning light panel
  225. Pinging UrS4
  226. Looking for a new grille
  227. Springs
  228. looking for a specific picture of a green urs4
  229. License capture nuts/Removing rear license plate holder
  230. Transmission problems
  231. Mystery shocks
  232. Lumpy idle and lugging..
  233. Urs4 coils and brakes
  234. S6 oil pressure gauge
  235. 1995 S6 Avant on ebay - CLEAN!
  236. Possible S6 purchase
  237. Does anyone have a 6 speed swap?
  238. S-car back on the road,,,
  239. Sunroof won't open.
  240. Door lock tubing and cowl vent screen.
  241. After-run pump electrical/mechanical logic
  242. Compilation of hints on RS2 EM and Turbo PNs and Installation
  243. Can't get the turbo out. Help please.
  244. The four 2 pin device control connectors on/near/under the AAN intake manifold
  245. AC/HEAT -Either but not both? Motor or control head?
  246. Strange potential stall and bad turbo...
  247. Under Back Seat Electrics
  248. Intercooler reomoving
  249. starting problems s2
  250. Starter Replacement
