PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. Put in your requests. Iam going to a yard with a WHOLE 1992 S4.....
  2. Check your rotor hats!
  3. New Audi R8 GT3 (RWD)...
  4. what is wrong with my inspection??
  5. i love my job :)
  6. poll: what's your favorite <$100 summer tire for the UrS
  7. so your running 255s, is the side of the car getting sprayed?
  8. Boost Gauge Install S6 - Poor Photos - Vague Write-up
  9. BPV questions
  10. Noob question...
  11. Legal action advise...help
  12. Could this be the cause of my no boost?
  13. Where should i begin?? My 94 Audi S4 does not want to start...
  14. Source for clutch cyl. flex line anyone?
  15. When the car's cold and you give it some boost there's a fluttering noise...
  16. Just finished boost gauge install.
  17. i fixed my car 2 weeks long.Here's the lists
  18. Sweet Yellow Bee
  19. Are the fuel pumps in all C4's the same?....
  20. No boost, whining noise
  21. Cylinder 1 misfire Continued, New plugs and Kellys Coil Pack installed. (longish)
  22. Anyone got a sunroof control panel? Mine broke over a big bump and fell out like an oxygen mask.
  23. Anyone know of a nice carbon fibre handbrake handle,that will match the carbon in our interiors?
  24. here's what $14.99 plus shipping got me :) i love ebay
  25. O2 sensor email to Robert Bosch
  26. Guys what inch hex do i need to tighten the gearbox oil exit nut?
  27. Failed emissions for not having 2 O2 sensors and 2 cats
  28. Anybody have info or a link to vacuum hose ID measurements in our cars?
  29. ACHTUN!NG | OEM Audi 17" Winter Wheel specials, $699-set!!!
  30. Installed (borrowed) my buddy's MTM tuned ECU today.....
  31. Hey FAP99 have your fuel line recall done! Mine blew up yesterday thank god i was leaving the house!
  32. Not wanting to experience a lashing from either the Audi Gods or Dave, I checked my plenum drains
  33. Check out this gem I found from mid-2003...
  34. Some Example Oxygen (O2) Sensor discussions
  35. Does everyone agree that universal O2 sensors, done correctly, will work?...
  36. Intrax?
  37. Learning something new (for some people)
  38. W T F? Look at this CL ad
  39. Knocking noise from strut towers....
  40. X-post from OT: When Audis are bought by the wrong people...S6 edition
  41. Update on no spark, I have got Kellys coil pack installed, i started the car and the #1 cylidner was
  42. Does the hydraulic pump normally make noise and vibrate?
  43. Bosch o2 sensor part number?
  44. paging posto - email me please.
  45. i suck @ O.E. microphone - Bluetooth integration.
  46. My rear Diff is wet (?)
  47. Damn!!! No boost for me. No accompanying noise, whistle, or CEL. I'm STFA-ing and getting a list..
  48. x-post from the D2 board with pics from //S-fest
  49. Interesting.... in Poland you can register quads and use them on the street like a motorcycle...
  50. Hmmm. what happened to my Sfest pics thread ??
  51. I've never seen a C4 in NA with leather dash/door trims (instead of wood)...
  52. 993 Big Brake Kit
  53. Any one reccomend a mechanic in the Denver area?
  54. Is this vacuum related issue?
  55. Car dies when it's cold?
  56. Hesitation after installing new o2 sensor
  57. lower center grill for S6
  58. Head Light and Fog Light bubls?
  59. Update on violent shaking issue, its there at idle with clutch in....
  60. While shopping for another T44, I found this.. Sweeeeeeeeeeeeeet..
  61. Jay Gietl, do you have any picts of the Fumoto oil drain valve on your car?
  62. PSA: Save your car. Find the plenum drains under the cowl cover and clean them out. Otherwise
  63. Need help! - Car just stopped running and left me stranded
  64. I've just pulled the regulating valve off...
  65. Replaced o2 sensor, do I need to reset ECU?
  66. please help. Does anyone recognize this carpet/insulation piece, and where does it go? TIA
  67. Should I stick with my S or sell??
  68. Uh oh, I think my turbo has blown a seal...
  69. Been wrenching on the S6 today....
  70. Violent shaking at low RPM and take off, goes away with speed.. I STFA, is this the bearing, more...
  71. Cooling hoses 034 kit vs OEM and hose clamps of choice
  72. Big thanks to SFest organisers
  73. what do we know so far about the wires associated with the D585 GM coils ?
  74. I'm seriously considering...
  75. constantly dripppppping hydraulic fluid...
  76. Clutch just went to the floor...
  77. Does anyone here drop engine oil out cold from their engines?
  78. Putting the carpet back in is a royal fvcking bitch.
  79. Bosch vs NGK plugs
  80. Bad news: Blew a spark plug out of engine
  81. I think I have an anti-social S4. It ruptured a line on the way to Sfest east last year
  82. Drivetrain loss
  83. Anyone know this car? 1994 UrS4, Green w/ Ecru, 220k miles
  84. did I get the right part???
  85. Leaky door seal
  86. Anyway to unlock the car from inside the trunk? my doors are locked but my trunk is open....
  87. Low and behold my plenum drain needed to be cleared...
  88. ETKA owners, what do i need to service my PCV system? part#s please. Thanks!
  89. Does anyone have one good Bilstein insert for the front?
  90. So finally figured out why i had a little knock in the front end.....
  91. Sighting in Reno. It was a little bit of a distance but looked like a black urs without plates.
  92. This seller is crazy!
  93. I KNOW there are quite a few of you in Chicago but don't mingle with the
  94. Oil burning at random times...
  95. Where are they now?
  96. Link to a Jeff Gerner background story
  97. Curb Stomped..
  98. would a Garret T/3 fit in our cars and what all would be neccesary, shes got 180 so overhaul + ?
  99. TT coil pack info... picts taken w/ cell phone so drink a beer or two first...
  100. Where does everyone buy parts?
  101. Greetings from the Baltic Sea, have a great //SFest this weekend, sorry to miss it =(
  102. Another what do you keep in your trunk poll:spare parts
  103. The ruturn of smoke,Thinking Valve stem seals or rings?
  104. Pullman, WA, S6 Avant - white (not pearl)
  105. Can someone show me a pic of what the UrS4 wheels looked like?
  106. Little pic of my S6 last weekend at a vw event in the north of the uk.
  107. Guys want to upgrade my front ur s6 door speakers what do you suggest?
  108. anyone gone urs to miata as a dd
  109. Anybody who bought the Aug. 08 issue of Eurotuner with Jeff Gerner's S4, could you please...
  110. S6 in Amherst
  111. Poll - How much is a reasonable asking price for "Soylent Green" ?
  112. Update on Meyle strut mounts.
  113. Our roads are crappy and the H&R's with the Bilstien sports aren't cutting it,,,any
  114. Any webmasters here that run their own car-related website?
  115. PSA: blau parts does not have a coolant hose kit for Ur's
  116. Anyone have pictures of a Pearl S4 with an OEM Spoiler?
  117. Hump Day pic
  118. Knock Sensor Fault Follow-up
  119. Anyone else have a cat failure? All quiet now, thanks to a pair of FRU-T-cats...
  120. This is a steal....RS2'ed S6 for $6,500
  121. After the 1.8t conversion I have 5 OEM coils
  122. DIY Aftermarket Head Unit - Delta CC
  123. So where is the best place to get a replacemnt clutch pedal fast? Mine broke (wtf!) and I cant get
  124. What oil change frequency recommended?
  125. Anyone know how to tap into the IC rheostat output for a boost gauge light?
  126. "Best" cheap HID kits, suggestions?
  127. A/C compressor clutch engaged when turned off the blower.
  128. IC Bulbs
  129. Wonder how fast this sold?
  130. fuel sender inaccurate. these senders have PCB's that work off of impedence right?
  131. Speaking of extra parts - S fest bound
  132. PSA: ECS slotted strut mounts = made by meyle. 10K miles later (3yrs) = kaput.
  133. a-pillar removal
  134. Any specific type of brake fluid to use?
  135. New Delphi not Chinese coils D585 for $15 no shipping charges
  136. anyone have info on Gerners Bonneville run?
  137. holy sh*t, dealer cost is $5 each for EM stud nuts,
  138. Couple issues my car is having...
  139. Brief message for the new forum members: Please remember you have two main sources of info that you
  140. HID issue....
  141. so if i'm trying to do an aux input to the '93 Blose with NO changer, what do i do?
  142. Turbocharger Coolant pump
  143. [OT] iPhone + $13 = in car performance tool
  144. 395 WHP URS4 for sale in Salt Lake City - $7500
  145. NIB Eibach springs for $100?! Is this guy drunk? Whoever buys these should buy me a pizza.
  146. Who has $1950 to spend on a Green on black (w/ CF) S4 that needs an ECU? - SF Bay
  147. I think I have a bad boost leak, can anyone confirm this?
  148. Is Jims Furdyn's Silver UrS4 Sold? I saw the link says sold. I know someone who is interested.
  149. My RS2'd S6 is doing 20mpg on highway
  150. is there a comprehensive clutch job parts list out there?
  151. XPost: But in case you have been wondering what been up to ;)
  152. anyone heard of/use Freeze-12!?
  153. Soo...while I was driving down the highway...
  154. I'm fairly confident this isn't 'spose to look like this.
  155. Nice red 95.5 S6 (RS2'd) for sale in Portland - $8500
  156. Coil packs???
  157. Why? Why? WHY????
  158. Are there any higher wattage IC bulbs that don't require additional installation work over stock?
  159. Just put the new Voltage Regulator on my car.
  160. Someone needs to buy this car.....
  161. Rear barke lines
  162. Best place to aquire Euro S6 headlights and clear corners?? I already STFA..no luck.
  163. 4 short studs for rs2 EM question... regarding FAQ
  164. Soylent Green (and a lot more) is on the Auction block - all reasonable offers will be entertained
  165. Project from a few years back. Finally took a picture.
  166. So my clutch dropped to the floor while driving today... Whats the deal?
  167. S-Fest sell-off -- lots of good stuff!
  168. Front conrol arm removal PIA
  169. Brake system
  170. I'm scared about the wiggle...
  171. Anybody have HVAC button problems?
  172. Drove my car for the first time in two months today; man I missed 100 octane & teh big boost..
  173. Just Curiosity. What is the expected life on a RS2 Turbo?
  174. I almost crashed because of this little guy.
  175. B7 S4 4.2coilpacks installed. so far so good
  176. Who's got what to sell at //SFest???? I'll start
  177. Just got back from a road trip.......some pics
  178. Is the small emblem on the sport steering wheel replaceable?
  179. awww yeaaa, new bling for the engine bay...
  180. Herr Schröder, were you looking for a photo of the back of a cluster?
  181. Can anybody with 2bennett coilovers verify if this the correct assembly?
  182. Dave, why didn't you purchase these?
  183. Does a compression lowering head gasket require ECU programming?
  184. Polish Clean up AAN Valve Cover
  185. Feeler: Turbo setup
  186. How expensive are seat heaters to replace?
  187. Side mouldings for S4/100's on ebay...
  188. If my driver side seat heater has a "hot spot" would that be repairable?
  189. lul!
  190. Ordered some stuff for the UrS4
  191. So which N 75 is the best to use?
  192. Some peoples kids... I swear! :-)
  193. Problem with Audi radio
  194. Found some Boxster S -996TT calipers but just the rears....will
  195. Just figured out what kind of turbo I have...
  196. Dave, did you consider the TT 3.2 coil packs? I just saw them on ECS...
  197. Can't wait for SFest.
  198. Noobie question...but still frusterated.
  199. Anyone have a MAF to Turbo hose that they want to get rid off?
  200. Does anyone have a good shot of the back of a '92 instrument cluster?
  201. Paging Skolnik!
  202. Im BACCCCCCCCCCCCCCCCCCCCCKKKKKKKKKKK :). 95.5 sedan :( black on black
  203. Thanks is due!
  204. Looked at a nice S6 today....need opinions.
  205. My new whip. Pimpin' the P-chop " kindergarten " style .
  206. Select wheels on clearance at Achtuning.com (as low as $449-set!)
  207. Another classic
  208. serpentine bearing procedure i looked in archives and found nothing on t
  209. Found it!
  210. Classic
  211. turbine on hot side of turbo is white, O2 sensor is white, inside of downpipe
  212. downpipe, turbo, EM came off easy. few EM nuts were finger loose
  213. h&r springs
  214. seating position on a 1995 s6
  215. yay only 36 hours later
  216. I'm in Colorado, Sept 4-7th. You Denver/Boulder guys wanna get together again....
  217. Getting closer
  218. Hi - I'm new to the UrS world, and I need a beater as a DD.
  219. ZF Servo rebuild kit--or access to the top seal inside the resevoir where the piston plays...
  220. can you link me to the diagram that shows the rs2 Em and where short studs go
  221. Robert's getting angry! grrrr. DaveF, how in the hell do the coilpack female terminals go into
  222. crusty vacuum lines and leaks waiting to happen, if not already...
  223. Yew Hew! Mr. Appraiser to the white Craigslist phone please
  224. Thoughts on these wheels for an S6???
  225. Replaced the voltage regulator with good results.
  226. NGK BKR7EIX-11 spark plugs. looks like a no go?
  227. Floor mats ??????
  228. my euro s6 intercooler saga continues....Now decided charge cooling is the way to go,
  229. Fitted new temperature sensor yesterday,the old one was covered in clean engine oil?
  230. So here's a shot in the dark.Anyone know where I can get the driver side rear door trim piece and...
  231. I'm bringing Sexy Back .........
  232. Well all, dropped off the S4 today to its new owner.
  233. Went to smog my car today, and it decided to take up smoking.
  234. Hi. My name is "John". I already have a high hp B5 A4 and a Porsche Cayman. I am thinking that a
  235. terrible idea BT: do i want a 2nd urS?
  236. EPL is very please to welcome Autosport Werks as our Colorado dealer!
  237. Autospeed, NJ - Rolling Road / Dyno day.... 8/23... X-Post Update
  238. Denso O2 (Oxygen) Sensor?
  239. Few s-cars I've run across in the past day or so...
  240. Mobile 1 synthetic 15,000 mile oil
  241. Has anyone here installed their carbon hood or trunk lid yet ?
  242. Silver on black rare?
  243. D585 Yukon Coil Bracket Trial No.1 (rapid prototyping)
  244. Need a winter beater and I think a 95 S6 might be the ticket....
  245. Suspension and bumper options????
  246. Front Strut Tower Stress Bar Part Numbers
  247. could a malfunctioning wgfv cause part throttle detonation when fully warmed up?
  248. Photo of Ray Tomlinson's (now AlpinaB7's) vertical flow FMIC
  249. took some pix of the kids ...one might be on the way, 3rd if i don't count my wife's one
  250. damper what are you all using and whats the avg price ati and dealer want 400
