View Full Version : Audi Original "S" Cars
- wheel bearing kit question
- needed asap stock fuel injector
- Broke tab on 3rd brake light housing...
- -------- 034Motorsport Turbo and Turbo Kit Group Buy --------
- Another fun project 35 bolts down, 105 left =(
- Anyone selling some Igor modded plates?
- Offtopic: the new R8 5.2 V10 tachometer
- My friend just done the SS coolant pipe.
- DAMIEN HELP! Impending seat bolster doom...
- Surge, light throttle, 2k-3k.
- Proceedure for replacing the rad. fan?
- Avant rear shock/spring spacers - 20mm or 13mm?
- Slightly off topic, but has some Audi content. Flying Integra at LeMons Houston Gator-O-Rama
- anyone here living in or near Idaho falls? Im looking at a car there(fixed)
- anyone replaced all the vacuum lines associated with idle & boost preemptivly?
- So much for the Paradox of Thrift...part 1: New s6 suspension and basic maintenance
- First 200 miles of fun!
- what is the correct part number? the part # i got from the FAQ is incorrect
- Is my fuel economy normal?
- lurking in 100/A6 forum and saw this post: UrS6 f/s in Vancouver area
- Rear deck lip spoiler
- Dave F: no need to fab CF trim for non-CF cars...
- I have to replace some transmission components...
- would a Concert radio from a 98 Audi plug and play in a 95 S6?!
- Got a centre chrome square info system surround piece to compliment my chrome speedo dials..
- Trunk struts - Meistersatz from Autohaus = hit/miss?
- As promised a little pic of my shiney new B pillars,through a telescope the wrong way round!!
- Got the idea from Merlins S4!
- Sway bar
- Does anyone have a spare rear driver side caliper carrier? (Edit)
- Is anybody else not able to tap into the CC controls? Poor fuel economy, part deux
- does your car idles like this?
- Boost leak hatred. Losing sleep.
- just bought this little guy for my red car, not bad $$
- 92 s4 headlight replacament glass
- I'm in Calgary until Thursday afternoon/evening in case any local peeps wanna get-together
- FUNK switch and connector part numbers. And others like air horns and PA speakers ; )
- Anyone confirm the new, 2 piece wheel bolt part number?
- Porsche Rims
- Another S4 bites the dust
- Holy Chromey smokey chrome pillars,bit more work than i thought to fit s6plus b pillars!!
- X-Post
- PSA - if your CPS has failed (or is on the way out) and you need a way to drive the car
- stock ann cars what boost do you see when cold out?
- how to test HO coils?
- Anyone here ever try Drivewear lenses?
- Previous Owners of our S-cars....
- Damien,I think I found the Merc Rotor Spec for Cayenne Caliper.
- PC 7424 polisher, good or bad ? Blake any thoughts?
- silver rings of hell
- Just installed 034 3" Stainless DP + Turbo Back 3" Borla exhaust system on the 95.5 S6 Today :-)
- I've seen a few "what kind of boost guage do you have?" posts in the past and
- Speaker size for 1995 S6
- Guys anyone replaced the window surround chrome piping?is it a nightmare to do?
- where do these cars come from ? pearl on black 93 S4 86k miles,1 owner
- I bet your car didn't come with it's own web site?
- Found a source for stinky leather (kinda)..
- i'm about to pull the trigger on ordering the parts in need to piece together a BBK. do the 93s have
- Getting some shiney new s6plus B pillars... you know me and shiney bits!! :-)
- Show of hands: How many people have gone above and beyond RS2 bolt ons?
- When I turn on my HVAC system, my idle goes up 100+/- rpm. A/C is off. Is this normal?
- Updated POS connector pin swap procedure (edited = "un-used")
- Question: What's worse than buying five used condoms?
- Should I change my hydraulic fluid?
- Got some New Wheels! Audi R8 reps 17x7.5
- with the headlights off and you hold the brights down for 5 seconds you get the bulb out indicator
- My Porsche Cayennes arrived today!! oh wow,really happy i went for the red.
- Not my wheels but one of you better jump on these (18" Swings)....
- cheap 92 in VA Beach
- Other than come along, how to align swaybar in front swaybar?
- Last chance for wahles shirts... anyone??
- Any way to get your radio code without going to the dealer?
- Posto ygm!!
- rec'd. thank you!
- Does anybody knows how the oil flilter flange is made? When the thermostat opens, does all the oil
- main battery cable
- Noise/pulsation with clutch pedal depressed.
- So apparently having the gas tank replaced killed the RR antilock brake sensor...
- The FUNK
- Bumfight. Two drunk bums got blood all over my car then passed out next to it.
- will velcro hold liscense plate to rear euro tail center section?
- video - 'the audi gods love me'
- Periodic LEAKY sunroof
- Anyone know where my coolant leak could be coming from?
- Ok, I STFA, and am looking for a how to on R&Ring the lower control arms in my garage....
- Turbo x-s replacement of N-75
- I guess a Ma$$ member ripped another guy off for over a grand and out of state FBI here I come.
- Production figures?
- Good day / bad day / going to be a better day; GT30R fitted with the .82 A/R update..
- Paging skolnick
- What is the best shock/strut to pair with Eibach springs? Wife n toddler friendly?
- Hitler is sick of VWVortex
- WGFV Question # 34,833 - Should I hear it cycling on/off.....
- Thinking of changing my suspension..Currently running H&R race on bilstein sports
- Squeaky front end at low speed?
- who has the best price for new 928GTS calipers?
- EDIGREG
- Figured I'd check one more time, anyone have the ABT/OZ 10pt wheel sockets? TighTT?
- Damien's threads remind me of when I tried to create the tri-turbo V11 UrS4...
- Front Ball Joint replacement..
- Just got hold of a oem urs6 intercooler for £24 gona use it as a template and ...
- Looking for a reputable shop in College Park MD area
- Cruise control iffy. I'm stupid.
- Memory buttons not working?
- I had a slightly rough idle yesterday, checked the plugs.. one loose.
- The low mileage 97 cashmere on ecru S6 in Vancouver BC has sold to a NY state buyer.
- Motor Death..... :(
- Mark March 18-21 for some Audi Sebring Sunshine
- Money Pit #2 - help me get started!
- Name that turbo!
- I meant to post this this afternoon updated with 20v turbo like others suggested. In doing..
- A general idea of what I think the T-shirt should look like...
- For those in WI...Doyle want's to change over to one plate on cars!
- I found a new logo for the UrS Forum...
- More Bumper secks....
- Anyone selling an aftermarket downpipe?
- Over the moon just got hold of a set of cayenne calipers for a great price.
- What's the going rate for a front fender in good condition?
- where to buy serp belt tensioner
- turning in the wastegate screw
- Has the Cam sensor GB gone through yet?
- There aren't any words to describe this!
- Would a Mitsubishi Evo 8 Intercooler fit?
- Here's a rough idea for a T-shirt ****Updated****
- WTH? Didn't you just get this?!! (warning.... Audi abortion link enclosed)
- OK, unleash the dogs on me....
- I can't believe the gas milage you can get when your foot isn't in it...
- QUATTRO DIF LOCKS versus 95.5 EDL
- After run pump part number and replacement DIY
- When did Canadian cars get heated rear seats?
- was in a bind. SS lines to ECS stg 3 BBK worked on G60s...
- OK, so who is ready to have some T-shirts made up with our car on them?
- Anyone know what this wire is for?
- Installing a CB radio, closest 12v line
- Hi guys are we still all agreed the 044 is the best replacement fuel pump for our Urs?
- those with euro tails, does the center section sit flush with the corner lights?
- is the Mance front strut bar worth installing? made for 90?
- i wish this came up when i was in the market for a UrS
- As I stopped at Squaw Valley to go skiing. I notice guy standing nearby, mouth open, gawking
- OK, you win. 19" wheels are too big
- An introduction and a write-up
- Did some coilover type work today...
- MacWorld.....In regards of the front bumper...
- Tell me whats wrong here
- My UrScrap4 saga continues. New problem, MAJOR oil leak near the oil cooler.
- Audi really hates the US I5 enthusiasts, TT-RS is not being offered stateside
- Weird (seasonal) CC problem
- Will bad J-hose cause clutch pedal to not return to up position?
- In about one month the S goes away... and this comes out.
- Pop you got your cayenne 6 pot calipers yet?
- Supersprint rear Muffler,Anyone?
- Fuel Cutout woes continue.....gonna check the WG diaphragm.
- Hit or skip???
- Graduation Day at the Audi Academy in Exton PA today (long) :)
- Installing a stereo system. Needed some suggestions.
- Dave?
- Neuer fünf Zylinder Turbomotor.....
- Car turns on, all dash lights work, wont start, wont turn over
- Gettin' ready for some warm weather...
- 43mm Fuel Pump. VDO/Siemans or Bosch?
- CPS GB: Last chance for those of you who haven't paid.
- Anyone need a spare exhaust from the sleeve clamps back?
- Car Phone
- What have you guys, that have replaced the heater core, used to seal the opening in the heater box?
- Hydraulic groan when turning
- Can you replace the center bit on a sunroof motor??
- Anyone parting out a Green UrS4/S6 ?
- Here it is
- looking for clean silver s6 Avant
- Somebody hit and ran on my car! Both bumpers broken! AHHHHH!!!!
- No more S-car.
- What Does Your Car Color Say About Your Personality
- removing ecs stage 3 brake kit from an S6 to sell S6, reinstalling stock brakes. will the stanless
- How do I get the front tow hook to stay in and not pop out all the time?
- Strange noise coming from above clutch pedal
- Front bumpers replicas, anyone would be interested? I am looking to get a copy for my s4 since mine
- Random miss at idle. Not repeated but random. Only @ idle. Any ideas?
- Had the paint refinished yesterday
- Last Clutch MC question..............
- Anyone here buy that 95k 95.5 silver at Carousel Motors in Iowa City?
- Wow, I really like this concept....
- does a ann timing belt cover fit my car with 3b valve cover?
- Anyone looking for a very clean Pearl/Ecru 95.5 S6 w/ 120k, BBK & possibly RS2 manifold (edit)
- Will a bad FPR cause to run rich? Or do they ever go bad?
- So i've noticed my car burns a helluva lot of oil at idle...
- The new spark plugs are in. The car works normally now. Pics of plugs and coils inside.
- torque spec for timing belt tensioner 3 bolts and the one for the tensioner roller
- Some a-hole cut me off and clipped my RF fender and bumper then took off
- never tracked - right. Just wanted the roll cage for impressing the chicks.
- Save the whales.... with your paypal account... heh heh
- What IS this?
- Ok. ALL new coolant hoses will be delivered tomorrow. While I am mopping up coolant, I notice a
- Dealer installed RS2 Performance Kit?
- Guys anyone had experience with drilled or slotted discs?is it worth it?
- Will a bad clutch master cylinder always leak? Mine shows the symptoms but no leaks.
- gauge cluster warning screen not working??
- I am in the market for a set of wheels.
- Help me with my summer tire selection...
- Is the mirror switch supposed to have a light in it?
- Rear heated seats, mirror switch replacement
- Greetings
- XPOST: Detailed: 1995.5 Audi UrS6 Europa/Ecru 160k Miles out of California
- Brake sensor malfunction
- Today I took my car to the dealer to have them reset the service indicator. It was a scary event.
- California Adventure: 1995.5 Audi UrS6 Europa Blue/Ecru 160k I picked up last weekend...
- McMaster and Napa turbo hose clamp part numbers - PSA
- Intermittent clutch pedal on the floor. Clutch master cylinder?
- Few pics
- "Whats it worth" post.....
- Dave, you'll be proud of me. Checked my spark plug torque today...
- Gas smell in the back seat everytime i fill up?
- Cashmere on Black S6A on AutoTrader
- Does anyone have an extra gamma head unit lying around?
- Fuel cutout at around 15 PSI.......need help
- Hi guys decided to go with upgrading the Brakes i got!! makes sense..
- Fuel Pump Recommendations, IA Stage III+
- NAC - E36 M3
- VEMS LCD Display pics:
- rePSA regarding ignition switch install.
- a few Utah winter pics.. europa s6avant.
- I'm getting tired of dealing with the ****ing heathens on craigslist.
- Is ET35 okay for 17x7.5 on our cars? Im assuming it is and STFA but found it only for 17x8"
- cross post from the B5 side, elijahallen's s4 lives
- Guys got vibration through steering wheel under semi hard braking?
- pic request of 17" rs4 rims also factory center bore is 57.1?
- Paging Kanukistanians
- Need the clamp sizes for use with Samco turbo hoses
- Does anyone have experience with EuroTech wheels?
- anyone have the turbo oil line that runs to the engine?? need one asap
- Wondering about wrapping the turbo and downpipe with that heat tape stuff, or whatever it's called
- Cheapest place to buy bulk fiberglass fire sleeve, anyone?? Thanks!
- CPS GB: Still waiting on payments from 15 people...
- Frugal Mechanic "X post"
- well guys, she's gone.
- Anybody w/ a nice metal cross-over tube left-over from FMIC conversion pls. email me...
- Car wanders like something fierce in the rain.
- pbr rubber brake flex lines any good?
- what turns on the trunk light in our sedans?
- Can a broken trunk latch cause the car not to start?
- i know on the '92 urS4 the rear S badge was on the left side as opposed the right
- A gypsy curse on evil oil drain plugs that seize up while changing oil in slushy parking lots.
- So the drain is fixed but now the car won't start at all....
- GOT IT!!!!!!!!! the drain that is....
- Lower rubber door trim photos ( Poland seller on Ebay)
- Igor camber plate mod
- Alternative shipping methods for a car interior
- Where to get McCullogh HID bulb?
- coolant leak above oil filter?
- how do u like these brands in timing belt parts graf conti fag
- Euro Parts
