PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. Guys anyone got any info on aircon system??my condensor has blown a hole in itself!!
  2. OT: Found out Friday I'm going to be a Dad! Yeah!!!
  3. just to reinforce a known fact...... only use OEM igintion switches
  4. 92 R12 High side port
  5. Q for those converted to 1.8T coils
  6. Could not start car this morning and discovered i was running wrong ...
  7. Just pulled the trigger on a new steering damper from impex for $28.
  8. HVAC System
  9. WTB: 95.5 S6 Avant
  10. Does anyonehave .bin files for stock chips?
  11. 24 HOUR FATHER'S DAY SPECIAL 18% OFF
  12. Troubleshoot a no start issue
  13. UrS6 steering is heavy at low speed. Is that normal?
  14. Had me a look-see under the hood this afternoon, found two blown strut mounts
  15. what are the chances?
  16. How long is the tray around the sunroof, is there space for a roof mounted antenna at the back?
  17. Frack ! UrS4 won't go into reverse 1st is hard to engage also. Any BTDT? Anything obvious to check?
  18. any trick or tips on dropping the subframe. anything else in there that i should change...
  19. Decision time, paint the whole car or not? (long)
  20. Brakes!
  21. Do you have to remove the rear seat or trunk liner to do rear springs and shocks?
  22. HELP! bentley's spec's snapped my lower contral arm bolt. what next?
  23. Anyone familiar with New Orleans?
  24. can i put this think on the ground w/out a front sway bar. long story,
  25. Well, i auto-xed today and now I think I need stiffer springs...
  26. Who here is from Vermont??? I saw you.
  27. Selling my 1992 S4 Pearl/Ecru in Chicago, IL
  28. Custom Audi 100 2.8 turbo Buick appearance package w/sharkfin
  29. Is it GenuineAudiVWparts.com who is the new kickass supplier "in town"?
  30. AutohausAZ.com ROCKS !
  31. Fuel pump removal? Dr. Dave, I'm whining...
  32. Car is not running as good as it did (before 2 coils died)...
  33. I see Apikol has a new brake caliper bracket for Big Reds
  34. What are the impacts of the EM gasket leak in one cylinder?
  35. K26 Turbo?
  36. Going to install my aftermarket alarm soon. Any advice before I start?
  37. Did 1997 A6's get the 3 spoke "sport" steering wheel?
  38. Fook - Radiator has a hole
  39. QUESTION chek engine light up and the cars turn at 2500 rpm at slow ?
  40. To remove injectors is it smart to pull fuse.... #17 is it? and let the engine die?
  41. Yes or no on the spoiler?
  42. Realized my horns were dying when the slow drivers trying to save gas weren't flipping me off.
  43. 3rd Annual Colorado 14er Climb!
  44. Looks like a pair of Big Blacks for a decent price on ebay.
  45. I need some help with general 1/4 mile times
  46. Viscous Fan Wobble
  47. anyone have a part number for the remote (key fob) for the 95.5? TIA
  48. Any UrS owners in San Diego like pizza?
  49. Insurance saga update
  50. OT: What would you do with an afternoon in Seattle area?
  51. Audi Expo 2008 - It's almost here!
  52. had a fooking dream that someone parted out my Ur
  53. selling the car
  54. My misfiring saga...
  55. Keegan Bartel
  56. Will be doing PS fluid flush this weekend. How many (Pentosin) cans should I get? Thanks.
  57. Hepu or Graf water pump?
  58. Complete databse of Audi part numbers?
  59. Hesitation & idle problem solved with a new ISV unit
  60. Is it posible to replace EM gasket without removing DP, turbo, EM, WG?
  61. blutooth installed, cannot get factory mic to pic up vocal, using kit mic & wires it works but
  62. Listed a brand new 034 gt3071 kit in the classifieds
  63. GREAT NEWS INSIDE!!!
  64. Ebay Injector cleaning a good deal?
  65. Need some help with replacing bulbs for european housings....
  66. I have sort of abandoned my S4. I haven't seen it in a couple months. I just wanted to say hi2u...
  67. Source for 993tt calipers, Benson is $499 now???
  68. Debosed.
  69. Anybody have a MAF --->Turbo hose laying around?
  70. Note for future reference - Replace this part whenever doing clutch, flywheel or tranny service
  71. So... are 19" wheels forgivable when...
  72. TOP GEAR Endurance Race Sponsors
  73. Wiper Arm Continued, Blade is an inch off the glass....
  74. bluetooth wiring: it's pretty easy. here is what I have so far
  75. Antilock brake weirdness
  76. MAF to turbo silicone hose fitment.
  77. Buyer Beware...
  78. How much can the O2 sensor compensate for fuel pressure?
  79. Rattle rattle rattle rattle
  80. Just repaired a gas tank( yes, it can be done)
  81. Should be interesting....
  82. so last thursday I pull into the lot at work and realize my car isn't running on all 5... damnit
  83. Has anyone ever seen Lambo Doors on an S-car?
  84. The 2Bennett Camber Plates are on the way.
  85. OK, two stupids in one day.
  86. So I sold my car today......
  87. Help! I can't decide if i have a boost leak or not/ what else could this be:
  88. The Grease in one CV joint is almost solidified : ok, fix when have time, or 'go panic' ?
  89. So my "hooter" valve died (bypass valve) I bought a new one and i don't like this sound
  90. Looks like a good deal.....
  91. Need help with weird electrical problem after leaving car in parking garage in NYC...
  92. How to remove gauge needles?
  93. S6 guys, got stained/oxidized trim around the windows?
  94. bluetooth ,if all the wires needed are pluged into the factory phone, why cant we just
  95. Anybody who part out the car with ecru interior has a carpet available?
  96. anyone have the bulb #'s for the interior lights?
  97. so how critical is the steering rack boot?
  98. where do i splice in for the illumination of the boost gauge where it turns on and off when i turn
  99. i installed a new battery and noticed that it doesnt have a hole to use the vent tube.
  100. Anyone have a part # for the sensor on the bottom left corner of the radiator?
  101. cracked inner valve cover, common?
  102. I just spent the day examining my washer fluid reservoir, it's leaking around the window pump base..
  103. Discuss: Slotted rotor direction? Which way and why?
  104. Last year I tried to replace my cabin air filter, couldn't do it. Was confused. Today I tried it..
  105. For those who want to spend some money..
  106. Why is my engine pulling boost when warm
  107. clearing out my spares. posted randoms on AF. thx.
  108. Excellent S2/RS2/Urq video
  109. When I do a quick turn or slowly going over street bumps, the brake light flickers.
  110. So I was searching for something on my car tonight and found this. I lubs the archives. ;-)
  111. Rack and pinion is leaking? How do I know if my 93 S4 has a R&P with servotronic of not?
  112. UrS4 Speaker issues
  113. Cell Phone Retro Fit
  114. hello everybody ! :)
  115. power steering fluid on the garage floor
  116. Continued highway ignition cutout
  117. Can somebody please give me the part # for the bolt that holds the caliper carrier to the hub?
  118. Happy birthday, S4
  119. Anyone else not have the belly pan in? I noticed how it should help direct air to the intercooler...
  120. does the a/c compressor and condensor on a 92 100s fit on our s4s?
  121. UrS4Boy, you got mail on shaw...
  122. Yet another new shoes pic (hey Jay, have you checked your garage recently??)...;-)
  123. kday, did you re-seal anything after drying your carpet?
  124. so i just changed my steering damper, wow what a difference... this thing feels german again!
  125. Have you kissed your UrS today? I know I have
  126. Quenching drama.
  127. Steering rack R&R?
  128. Anyone in the market for some rear bilstein sports?
  129. Using 0w 40 Mobil1 synthetic, consuming a bit much, should i go to 5w 40?
  130. Apologies to Javad and Nate at 034. Corey asked me to....
  131. RS2 Heading for Montreal !!
  132. Rear ended......the insurance saga begins
  133. What is the current procedure/go-to-guy for bomb repair or rebuild or exhange...? TIA
  134. Before I get home today I have a brake quastion,
  135. Where your parts go when they are "lost in transit"
  136. 412 miles on 19.5 gallons
  137. MiniMan: WTF is up with your car? I thought 034 was supplying you with some hot parts and a tune
  138. vagcat users: is it just me or are some of the items listed off by 1 or 2 numbers from the reference
  139. wow. SJMauto.com is fast. will use them again A+
  140. Car donation
  141. Rob has a garage now (2car, tight fit) for the S4 to be queen of. Go into pieces for the next weeks
  142. Update to my "Clackity Clack" engine problem.
  143. NEQ HDPE @ The Glen 7/21-22
  144. clutch slave cylinder success!
  145. Power steering pump resistance?
  146. Rattle in strut bearings?
  147. Finally rollin on summer shoes. You like?
  148. So my ebahn software doesn't give part numbers?
  149. Front passanger and drivers side door panel removal
  150. tie rods/ball joints/rear control arms this weekend. any words of wisdom?
  151. (recent topic) Recent ga$ trends really have me considering LPG or CNG conversion...
  152. I tried Liqui Moly valve clean this past week...
  153. Homebrew refinishing of Fuchs lips...
  154. Preliminary Annoucement: Vancouver UrS-car club meeting: Thurs June 12th.
  155. RPMs dip when I spray the windshield washer stuff. Is this normal?
  156. de'lan hitch?
  157. Where can I find the power steering pulley?
  158. How I've been rolling lately (with the monster truck traffic escort)
  159. Happy Memorial Day to All! -from our family to yours...
  160. Travis, still have those fenders?
  161. My system check is really freaking out now, throws crazy warning buzzers..
  162. Anyone got working POSs they want to sell?
  163. UrSoccer_mobileĀ® i have a question about your old exhaust setup
  164. Rear Diff was leaking and then stopped - what do you recommend?
  165. I was informed today by my mechanic that I have a water leak from the freeze plug that has a nipple
  166. What is this oil leak?
  167. Problems viewing Audi Videos on Youtube
  168. Did someone let their Redheaded son drive their Black S-car to a grad campout?
  169. Another car update... see the last pic for the source of my rage...
  170. 6203 Serpertine Belt Tensioner Bearing plus hardware
  171. Broken Avant Antenna Fix
  172. damn x-plug is still leaking. Took it out again and the o-ring has a slight
  173. do you need a wiring harness with relays when using a aftermarket HID kit?
  174. Reverse noise
  175. Wiper Arm Adjusment possible? Also Free Gas From Recall!?
  176. awesome Audi kicks major a$$
  177. audi/s/scott....YGM!!!
  178. Replacement CD changer cartridges?
  179. Who here has S6+ bumpers? I have a mouting question...
  180. Dave F. can you email me
  181. do you all put new bolts in when doing front lower control arms?
  182. Whoa there chief....
  183. What goes on the top right little hole on this MAF to Turbo hose?
  184. Comments on brake bracket quality....
  185. How do I remove the rear quarter glass on the Avant? FA are no help.
  186. Car update - dayum this is taking forever...
  187. Anyone here on I-495 in Mass. near Rt.3 today with a blue UrS4 around 9:00am?
  188. serpentine belt tensioner SNR 6203.FT150 bearing?
  189. I searched... PS pump is leaking (not from top X plug) is there...
  190. Lower strut mount plate studs unseated...now what?
  191. 15" All-Season Wheels
  192. paint recomendations? going to finally fix big stone chips behind wheels in front fenders
  193. did this one slip through the cracks?
  194. S6 avant with dead engine for sale on Audifans
  195. Eeek, spots on my floor by the rear end
  196. wet carpet / FYI / help needed / longish
  197. Will control arms for a 100 work on a 95 S-6?
  198. Does anyone have a dead remote locking transmitter? I broke the hook on mine!
  199. so where is the Ur under KATE
  200. Its official!!!
  201. Getting my colourcoded rear bumper valence fitted tommorow then will take pics of the final resulted
  202. had busy day with my S today,fitted new rs2 Maf,i really noticed a difference!!!
  203. Are all our cars pre-wired for a CD changer?
  204. what can i expect to pay for a 100k mile AAN longblock?
  205. AAN chipset comparo extravaganza!!
  206. This morning I found washer fluid dripping out of the car and leaking all over my garage.
  207. VAG-COM question, measuring blocks and data logging.
  208. porportioning valve rear brakes, do we have this? does it need to be bled?
  209. can strut mounts/bearings be replaced without a spring compressor? thought someone
  210. Does anyone have the part number for the input and output shaft seals for the transmission?
  211. Oh. My.
  212. Anyone with 034 intake kit?....
  213. Who was that Cyclamen UrS4 w/ NH plates on 93 today?
  214. is there a pic of c4 100 bumper on UrS4 somewhere?
  215. offset.... what are people running?
  216. Anyone have an extra "strut housing" <- right term?
  217. Where you guys ordering IAT sensors? Dealer quoted me $100 and im having little luck finding them.
  218. I anyone rocking the OEM rear deck shade?
  219. I have an unhealthy desire to slam my S4 and put some big ass rims on it
  220. Happy 109th Anniversary...
  221. T-red? Ready - bid!
  222. Request for data - TDS-1/X owners.
  223. Has anyone revisited the aftermarket headunit "POPPING" issue?
  224. Anyone get around 4 wheel emissions testing w/ low profile tires in Denver?
  225. I've STF can't really find what I'm looking for , So My after run coolant pump is..
  226. 245/45 17, is it too tall?
  227. 034 2871R AAN Stage 1 Chipset, now availible.
  228. Car's running on 4cyl intermittently
  229. Input on second IAT test...
  230. A little off topic. Recommendation for a cordless impact gun 3/8 drive.
  231. Well, that's interesting.
  232. heater doesnt blow. I assume the fans dead/dying? the car has 241K so i assume somethings have begun
  233. checked coils... advice...
  234. urS6 section?
  235. x-plug on power steering pump came loose while driving.
  236. Still kickin.
  237. reviving a 250k+ s-car
  238. Intermittent starting problem..part 2...Help!
  239. performance upgrade 101. please help out a noob
  240. Why doesn't somebody buy this S4 already!!
  241. Screwed....
  242. Brake pedal hard after bomb replacement?
  243. Rough Idle with A/C on.
  244. Anyone have UrScubed's email? I have a rallye golf question.
  245. How to mount 5x110mm wheels on 5x112mm bolt pattern cars?
  246. How to mount fuel pressure sender?
  247. when testing the bomb...
  248. foot on brake and parked on hill, start car can/should you feel in the pedal brake pressure build?
  249. Is there a diy procedure to fix or replace the broken side mounts...
  250. Bought a PAIR of Paradigm Monitor speakers today. $10. Did I score?
