PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. Looking for purchase in Canada
  2. Where to buy stainless steel brake lines for use with BIRA System 6?
  3. Hypothetical brake bleeding question
  4. Last Chance S6 Plus Taillight GP?
  5. How long does it take to replace the J hose?
  6. Pics of my new A8 Sport Alloys with Avon Tech M550s
  7. Inter-Marque Spring Kickoff 05.21.2006 Photos BWW
  8. snap
  9. Those of you with an EGT gauge. What kind of temperatures are you seeing under WOT?
  10. Boost leak?
  11. drove an mk5 gti today in both DSG and 6speed and i like the motor, but the car is all plastic
  12. For S6 4RINGS.....here is the new shifter....
  13. Methanol Injection kit......what would you do?...........
  14. Anyone looking to sell an URS6 Avant in Pearl?
  15. STaSIS Motorsport has strongest team qualifying at Mid Ohio in 5 years of competing.
  16. new wheels and tires
  17. Check your moisture trap!!!! Mine was full!
  18. is this the right harness for a 92 with the gamma radio?
  19. She's got company....
  20. the new radio is in...have some questions
  21. Front upright is worth what, do you think? Good shape. Just the strut ass.
  22. Welp, after sitting on my workbench for almost a year the Billzcat SS is on and what a difference...
  23. ok, not my pic but leaks from here. just to make sure.
  24. Germantoy, is your car done yet, I want see pics of rear wheel well lips
  25. power steering high pressure hose problem
  26. J Hose - Steering Rack
  27. I'm BACK ON THE ROAD, BISHES!
  28. Frustration with continued breakdown in performance with my 95.5 S6. Troubleshooting help requested.
  29. Need a quick answer about the Billzcat SS.......where is this tab that I need to remove?.......
  30. Driver-Side Door Lock Broke
  31. S6+ Taillights
  32. Ok..I am blind..where is the 2x2 Connector behind the Climate Control Unit?!
  33. Suggestions for removing really bad brake dust from wheels?
  34. Update:CT S4 ROAD RALLY & BBQ SUN JUNE 11TH
  35. combining a few issues heater core/aux belt(long)
  36. How can I improve handling without .....
  37. A weird thing happened to my clutch pedal today when I was stuck in traffic...
  38. tonight's little project
  39. Sell the car, part it, or keep it?
  40. CPS GB #2 (S-List X-post)
  41. alignment woes... need camber plates, outer tie rod ends, and new drivers side strut
  42. Source for heated seat heating elements?
  43. crap...got my wiring harness adapter from crutchfield, and it looks wrong
  44. Red Avant in Michigan
  45. After run pump relay: Where is it, and where to buy?
  46. Hanging with Hap, part deux (18 +/- pounds of boost and my diaper is full)
  47. Do I need a new speedo cluster?
  48. C4 Nav+ Update
  49. I dread even posting this, but i have to
  50. Think TurboJew can fix this one?
  51. ac compressor and dryer replacement
  52. Coming from 100/A6 forum, just a quick question. If you're stock or just chipped what's your MPG?
  53. Anyone sent the wrong size heater core?
  54. Where can I get the little hose that goes on the nipple on the top of BPV?
  55. *Update* North East Audi/VW show and dynoo June 10, 2006
  56. Anyone remove the chrome belt molding at the bottom of windows?
  57. OK, fess up, who beat me by $1.05?
  58. Conclusion; wagons with roofrails off = HOTTTTTTT
  59. so who is gonna be the first guy to use these?
  60. Speaking of Javad...
  61. How do you remove upper timing belt cover?...
  62. I think my DV or wastegate diaphram blew
  63. I got it running!
  64. My '95 S6 hood won't open properly
  65. Coolant reservoir needed...
  66. Mid Ohio looks like it is shaping up to be a quattro weekend.
  67. Fiber Images CF hood GB question. I think the person "organizing" it is on the forum.
  68. Noisy/Squeaky Emergency Brake?
  69. Along the seat recovering front...
  70. Zwoobah, where are y? CPS?
  71. Sorry alpinab7, my cold starting honeymoon with the temp sensor just ended. I need fuel press 101.
  72. The seats will be ready this week.
  73. Anyone have two good working RS2 injectors they'd be willing to sell?
  74. MRC Stage 2 goes in tonight.
  75. If you are looking for the NICEST S-car I have ever seen...
  76. new euro model focus ST has 2.5l inline 5, turbo making 220PS.
  77. Results / Photos / Videos posted from 5/13 CT/NY Audi Dyno Day at EPL
  78. AC is not cold, tried to recharge it but pressure is OK. There is some condensation in
  79. XPost: Anyone else going on the Marin Drive this Saturday? Or am I going to be the only one
  80. FYI Str4nger & Bill The Cat
  81. audi 80 (with a 3b engine) video
  82. TB machining is finished:
  83. headlights
  84. Bigger turbo on stock EM...
  85. Blitz turbo timer install s6
  86. Why does the recirculate not stay on when i push the button?
  87. Ben post some new pictures of your Coupe!!
  88. Front Inside Sway Bar Bushing Source
  89. Boost Leakage... suggestions?
  90. Actuator on cruise control vaccum pump????
  91. anyone know anything about these
  92. after-run pump running ALL the time? temp sensor malfunction?
  93. Hood strut?
  94. Power locks inop since removing the door panel.
  95. S6 Avant meets the over achiever...
  96. anyone else having problem with HRSB sliding to the side and hitting spring?
  97. Nashville Mechanic - Engine rebuild/install
  98. Okay, turbo gurus, i need your help
  99. Stock Intercooler mods
  100. TB upgrade:
  101. Seats update:
  102. Anywhere besides the "stealer" to get mud flaps?
  103. What is a 93 UrS4 worth?
  104. Clunking and Vibration Under Acceleration
  105. Paging URsoccor_mobile..
  106. Hard start after sitting overnight. Ideas?
  107. No, Mr. Pierburg, I expect you to die!
  108. Who was the Red S6 at the Audi Streets of Tomorrow, Sat in Mtn View ?
  109. I'm blinking out Code 4343..any thoughts?
  110. OK, you guys have a lot of opinions...
  111. Got a mystery plug down around my ECU...
  112. Hey, buddy - spare a j-hose?
  113. MotorGeek meet Sat @ 5pm in Seattle area
  114. With all this MTM Chip talk..
  115. need some info on ABS system
  116. Can any one suggest a source to remap an MTM chip and provide me with the transducer?
  117. How do I remove the viscous fan clutch from the mount? Seems impossible.
  118. I'm actually making progress, no really.....
  119. Boost flutter?
  120. As dirty as my car is, a guy in a very nice MK2 golf pulled up next to me and told me...
  121. does anyone have a spare front exhaust hanger laying around?
  122. Water in the trunk - Strange
  123. FMIC Turbo Bypass Valve Plumbing?
  124. Anybody have a HRSB that they want to sell? Or how long is the wait for a new one Hap?
  125. Does anyone know if Alex@Stasis or wherever is still selling the short shift kits for our cars?
  126. Opinions on a 1996 Audi S6 for a first time Audi shopper
  127. My UrA6 heater core experience...
  128. Anybody have or know of Any write-ups on Aluminum Subframe Bushings,etc
  129. Question for other TDS-1 users - or if you have an intake air temp gauge
  130. i guess it the intake hose
  131. WB Gauge Kit- any one here running this?
  132. Awww, crap.
  133. 034 Motorsports Big Bore Throttle Body upgrade.
  134. drive shaft, bearing or rear diff. noise, no clue what
  135. How much do the stock UrS4 wheels usually go for?
  136. Driver's door lock
  137. Taking out the Instrument cluster??
  138. WTF is the part number for the AAN crank pulley, NOT the harmonic dampener?
  139. A8 Sport Wheels - What size spacers?
  140. Suspension Work Done - Finally!
  141. Is there a procedure to replace the cable from the door handle to the latch
  142. AUDI S4 20V Turbo
  143. Spring rates on 2B coilovers, how much is enough?
  144. is this the best thing to do?
  145. I have them on my 91 CQ and they look good in my opinion
  146. 993TT calipers + RS2 caliper brackets + A8 323x30 rotors...
  147. Pulled Codes: 4343 Carbon Canister any ideas???
  148. How do remove cam sprocket? Do I need the locking tool? (for CPS replacement)
  149. ABS Module
  150. Could the "over center spring" on the top of the clutch pedal assembly cause a stiff pedal feel?
  151. ETKA Experts - see if you can find the part number for the Vehicle Speed Sensor G22 aka G68 !
  152. Anti-urS post on the TT forum...
  153. Looking for a stock airbox. Anyone got one?
  154. Major update on my S4...
  155. Source for RS2 Turbo + Manifold Gasket/Hardware kit?
  156. spiralsmurf: YGM!
  157. Car went in the body shop today :)
  158. RE: Hand brake light is always stays on...noticed on cold starts brake..
  159. would this be worth it? i was looking for a sport quattro exhaust manifold and got this...
  160. 5/13/06 - This Saturday: CT/NY Audi Group & EPL Gathering / Dyno Day (3 open Dyno spots)
  161. Old school MotorGeek meet
  162. It's times for AAN need to be overhauled...
  163. Somebody should try these tires out on thier car. Falken Azenis RT-615
  164. Pedal mod update:
  165. KDW2 Tire width comparison
  166. Uh-oh - glass troubles...
  167. clutch master cylinder
  168. [Saturday, May 13th] SoCal, last call for our annual Julian Drive. Should be big like last year.
  169. WG Spring is the source of stumbling... Do I need a new WGFV or Upgrade IMP sensor to a VMAP??
  170. Which stereo harness do I need for HU install?
  171. CPS hall sender GB - Order placed, please see inside for payment details
  172. i bought a standard-DIN radio. what do i need to mount it in my 95.5?
  173. S64RINGS, with your BFG tires there is no rubbing?
  174. Project S4 Update: Finally some progress
  175. Also does anyone have the part number for subframe mounts
  176. does anyone have the volvo part number for the pos direct plug and play coil conversion
  177. Ignition module fail.....
  178. No brake assist from PS/brake pump.. any ideas?
  179. Whats does a new (vehicle speed sensor) cost and where can I get one?
  180. 16 inch Borbet type H wheels...how heavy are they? lighter than my stock Avus?
  181. Last call: CPS sensor GB. Moved up due to my car not running
  182. Gonna have a left-over part - who needs one?
  183. C4 bentley question, chime in please if you have a bentley manual
  184. I didn't resist...
  185. anyone have Stasis brake kit? what size are your rotors?
  186. Ebony 'n Silvery.
  187. Kday, what do you think about this?
  188. Alcantara ordered. Going in for seat surgery on the 15th. That is all.
  189. Side mirrors stopped working.....
  190. turn signals stoped working
  191. stereo braintrust -- thoughts on this head unit?
  192. What happens if you just install a 370hp chip and 3bar ?
  193. Factory Sport Rims/Tires for Sale
  194. Where can i buy a new VSS (vehicle speed sensor)
  195. KKK K24 turbine upgrading question?
  196. Let me guess...
  197. TDS-1 Installed!
  198. this Auto check sign light on....
  199. Str4nger, I didn't see you at the Maple Wood Auto Fair 2006! (BWW)
  200. a/c question
  201. Is this the temp sensor on the back of the head? Thanks.
  202. in desparate need of tails
  203. can i just replace my radio head unit without replacing other components?
  204. A few pics of my new Nav system...
  205. Any members in Europe who know any cheap online parts suppliers based in europe?
  206. Here it goes:
  207. Anyone in NE want in on a GB for Cheng Yang CPS? [ordering 2 for myself]
  208. Is a major voltage drop normal when you load the system by turning on the A/C comp?
  209. I found a good deal on a B5 S4 , what do you guys think , should I go for it? only has like 60k ...
  210. Does it has UrS4 4.2 V8 in US?
  211. Had my car flatbedded home for the first time =(
  212. Help: Cold Starting Issues (again)..
  213. S4 distinction Please Help
  214. How fast are STi's?
  215. Funny story...
  216. Opinion poll....
  217. For those couple of you running GT3071 Turbos, what software and injectors are you running?
  218. Source at TireRack tells me....
  219. Hey ChefBob-
  220. Germantoy someone is posing as owning your car on myspace
  221. Samco 3 piece hose kit Non Uk
  222. what kind of wheels are these?
  223. Bosch 3 bar map sensor
  224. Stumbling Continues.... help please....
  225. Oil Filter - Drain-Back Check Valve
  226. New S6 pics
  227. Front brake line replacing write ups??? I need one...
  228. Reminder: Deutsche Marque Concours Sunday May 7 2006 Vienna VA (open & free to all Audis)
  229. Project 95.5-2005.5 S6 upgrade- Audi Nav+ into a C4
  230. PS "J" hose from pump to accumulator - sources with better prices?
  231. Where is a common source for oil leaks??
  232. NAC, but entertaining mechanical carnage nonetheless...
  233. Rear Bracket in Picture ?
  234. Adjusting front caster
  235. 900whp is downright scary!
  236. Project S4 Update: She Breathes...and coughs
  237. 01E Transmission Question
  238. our cars dont have self leveling suspension do they?
  239. Guys,I need some advice!
  240. Should the toe-in on the lowered front suspension always be set at 0 no matter what?
  241. CEL came on than the car locked me out of 3rd and 5th gear
  242. "Bomb" is getting replaced tomorrow... Where are these screens to clean to help the bomb?
  243. had fun with a porsche 928s today
  244. 95.5 S6 Wagon Clutch Problem??
  245. receiver drier location?
  246. Some pics i took today at my friends house
  247. Apikol FMIC install upcoming, got some questions...
  248. Is S-fest happening this year?
  249. No bearing forced induction . . .
  250. Looking for the best(cheapest source for the seat heater element), as well. Autohaus?
