View Full Version : Audi Original "S" Cars
- 1992 S4 not used for 5 years
- Anti lock light coming on occasionally. Maybe a Diff lock issue?
- part number???
- Wipers can't shut off....help.
- ABS light on
- dash cluster
- A Few More Questions!!
- Where Can I find Rear Strut Mounts?
- Doors lock but won't unlock
- Wiring Diagram for Power Window Motors and Door Locks
- Want a chip for my UR S6 Avant but do not want to make turbo lag (Low end) worse?
- s-cars.org down?
- Is the driveshaft (prop shaft) indexed to the final drive?
- Power but no crank/ no start
- Warning Chime/Buzzer
- dash lights - brake and center info light
- Faint smell of coolant
- About to pick a URS4
- Im still alive fellows!
- If anyone is interested..
- whie smoke problem,,URS6
- Gutting out my interior
- Auto-Check System Display
- Turbo Hose
- Brake light problems
- Adjustment of sunroof
- Seat Heater Repair Link
- S6 Avant Value?
- 93 S4 - antilock light on - no power to radio
- replaced battery and....
- Rpm hunting / surging
- Any of our German friends have a GSM version of the Motorolla phone that came with th
- What is this '???
- Last Minute Holiday Promotion - 15% off - Flat Shipping - $20 gift code on next order
- e-brake light on dash flickering
- new header/ down pipe
- New owner here!!!
- Noob with a C4 97 S6 , looking for some help
- Car Locking Problems
- Coil Options - Review with LS2 info
- 92 S4 serp belt tensioner, where to find one?
- Anybody recognize these chips?
- C4 UrS Central Relay Panel (Under Drivers Knee Bolster ) PN callout
- C4 UrS Auxiliary Relay Panel 1 Photos and Relay PNs
- Power Output Stage Diagnostics and Solutions
- 95 S6 Code for Bag Airbag? Is this easy to replace?
- 1995 S6 No start / no spark
- :: ECS Tuning :: 7th Annual Sale And Holiday Giveway!!!
- Black Friday Special at Detailer's Domain
- FS: URS4 Bumper - Green
- Wheels
- Coil identification - help needed
- Anyone selling a urs6 avant?
- Help 95 s6 poping ecu fuse no start ;(
- Atlanta I-575
- Cigarette lighters not working
- FS: 1995 urS6 MTM Stage 1+ and more...
- I need HELP in Chicago with my aan..
- Diverter valve
- Battery Troubles
- What color is yours?
- Stock boost gauge?
- Original Hoppen/Lehman S4
- car will start but will not run
- HELP!! LF a High Pressure Steering line for my S6
- Outside temp reads -26F
- Euro S6 Bumpers for sale
- Tallest snows that fit?
- Detailer's Domain: 15% off Orbital Polisher Bundles and Car Care Kits
- Oldest urS4 in the USA
- Steering too light
- Charcoal canister behind FL Fender Liner
- Airbag Light Blues
- Mysteries of the UrS6 Moisture Trap (aka Fuel Condensor)
- AAN Engine-related vacuum lines
- Thinking about buying 94 S4 need info
- FREE leather shift boots and more for Your Audi!
- Catalytic Converter
- Best sales pitch ever??
- Consolidated Cam and Crank Pulley and Flywheel Timing Mark info
- Grinding into first gear only
- Michelin man.......again.
- Rear swaybars
- 5th gear +/- 3,2000 rpm hiccup
- RE Post- Air bag light - Defective passenger side
- boost gauge location
- Alignment
- bar spring question
- 1993 s4 20vt cutout under load/vacuum at idle?
- Seattle area shops with UrS4 expertise
- urS4 Headlight assembly to an A6?
- 1992 s4 running problems
- Control Arm Replacing - help Needed
- Forge Motorsports DV-R
- 95.5 S6 no start
- Cranks but no start
- If Air Bag light is on does that mean the system is disabled?
- Things contributing to clunks in front suspension
- Thrown Rod
- 95.5 S6 A/C Question
- '95.5 S6 "Brake" light, need suggestions
- Quantitative increase from Samco hoses
- Show Pride In Your Ride and WIN $100 !!!
- Oil Pressure Senders, Switches and Check Valves
- FS: 1995 Audi S6 - $3,500, Appleton WI
- Check Valve hose 034 103 247g
- July 4th Specials at Detailer's Domain
- How to wire trailer lights
- Intercooler question
- New to me UrS4
- Purge valve / canister location on 97 S6
- Hesitation and Stalling issue
- Flywheel and clutch
- Crickets
- Brake Bulb Malfunction Issue Solved!
- Looking for '85-1/2 S6 Steering wheel (three spoke)
- Rear Muffler?
- Fuel!!!
- 95 S6 - Autocheck issues
- trunk lock problem 95 s6
- Coupe Quattro B2 transmission/gearbox!
- Auxiliary water pump failure
- S4 25Quattro Edition with 80k in Upgrades on EBAY!
- Front speaker wire colors
- Stereo turns on but no sound or noise through any speakers?
- 97 S6 bad idle and acceleration issues
- Owner of mint 95 S6 Wagon wondering if anyone has a BMW 5 Series wagon for comparison
- outa curiousity
- tips on replacing coolant hose
- I am back - hood problem solved - now A/C
- Where to buy URS4 parts reliably?
- 95 Audi S6 misfiring.
- Shock absorber stuck in strut - help!
- Paging Brian Weldon to the white courtesy phone...
- RS2 Manifold with stock turbo
- MAF hot wire repair
- ac removed on aan need belt
- More than just CPS?
- Whose running a single piece driveshaft?
- Diverter Valve Spacer
- audi a8 brakes?
- Interested in buying a URS6
- I hate to ask this...
- Timing bolt removal on crankshaft 95.5 S-6....
- Boost Gauge
- injector problem
- For Sale 1994 Audi S4 107k miles
- hood will not open - need advice
- HELP!!! smoke
- Overheating problems.
- Leaking Power Steering Pump
- VAS 5052 not seeing ECU
- 97 S6 Heater blower q?
- Driveshaft shutter/vibration
- 3.5" Cat Back
- Ice racing pics
- G4 Crank Position and G28 Engine Speed Sensor info
- 95 s6 hesitation
- Ice racing.
- Ice racing is a go for Sat and Sun. Gravenhurst.
- How to power your central locking system when your battery is dead and
- Holding Relay Importance - Power to Pin 37/55
- Same Ignition Coils going
- AAN Positive Crankcase Ventilation (PCV) System with revised diagram, PNs and Links
- Rear Diff...How screwed am I?
- Shuddering car
- Locked out
- Rough Idle/Low on Power, running out of thoughts
- AAN Coolant Temperature Sender Info
- AAN oil temp and pressure senders.
- AAN Engine Vacuum Hoses and Related Devices
- newbie
- Ice Racing.
- Ice racing? Take a look at the link.
- Ice racing, Gravenhurst,
- Cam Cap Orientation and Tightening Procedure
- THE S6 ECU HAVE A BATTERY INSIDE?
- Shifter Part Num Search
- You know... the site does actually work
- Need brake part
- I'm thinking of selling my URS4
- UR S6- Synthetic Oil versus regular?
- 1994 S4 leaks all power steering fluid not trace of the leak please help!!!!!
- AAN Oil Pump and Oil Temp sender info
- Importance of the C4 Cowl Water Drain Valve
- Another one bites the dust.. CAR FOR SALE
- Corssover Tube
- 1992 s4 broken powers steering line
- DMF with a sprung clutch disc???
- Diagnostic remote starter connection
- Power Steering Problem + new urs4 Owner
- Beat the Winter Blues wtih Detailer's Domain - 20% off.
- Searching for "expensive" UrS6's for sale (or sold)
- Project Airbox Rebuild is on,,,
- !!@#$, new problem- timing wire connector
- Bumper
- What about mixing new tires and used front/rear?
- Random question - When coasting in gear with no fuel used, does the engine make heat?
- Rear Diff, should I be concerned???
- Need simple fuel line help
- Replacing Rotors 314 x 30
- Wiring at back of Air Intake
- S6 Bumper Cover
- Diff Question
- Chip Tuning
- '93 UrS4 Cruise Control
- Modified S6 missing at above 12psi boost
- S6 tire question
- Tachometer problem
- 1992 AUDI S-4 TIMING
- 1993 S4 2.2T
- New headlight question for UR S6 (Bulbs?)
- Forge By Pass valve
- WTB 1993 S4 ECU !
- AAN engine reborn in euro 2011 RS3
- Linc in Pemberton BC. We've lost your email address
- Strange Engine Miss, need help
- engine temps
- I just sold my S6
- Evidence of shaft play?
- Rattle sound when slowing down out of gear or at really slow speeds in 1st and second
- backfire when shifting at high rpms
- Fuel Economy
- Parts needed for head gasket replacment???
- Need some headlight lense replacements on UR S6 Avant. any thoughts?
- Finally Bought an S6 and finally saying Hi
- Fuel Pump Replacement
- Key in the trunk..
- My power locks stopped working...
- FS: 1995.5 Audi S6 Quattro (GT3071 Turbo)
- Looking to upgrade my UR S6 headlights?
- high pressure steering hose problems
- urs4 MUD FLAPS
- Noise in front tires going over a rough road
- spark plug diameter
- Steering Rack Issues
- Our cars have some very light window tint applied tothe factory windows...
- Here we go again...
- Think these would fit?
- Intermittent no start problem after driving for a while
- Weird engine cutting behavior
- Found odd wiring at servotronic relay
- Car stalling when driving, then fine.....
- Michelin man???
- Heator blower motor replacement.
- Need Help - To chip or not to chip ??
- Rear seat vents not blowing air
- ngk bkr7e 6097 or 4644 user...plug gap?
- Need lower grill insert for 92 S4
- Timing Belt DIY - need to borrow the tool kit!!
