PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. Any wagon guys ever replace any hatch wiring?? My right reverse light doesnt work
  2. Iddle problem
  3. Easy way to do CPS on 93 s4...
  4. David A (95 black S6), passed you today (E.Greenwich RI)
  5. Score!
  6. Need to find one of the two wheels inside for summer coming up!
  7. Oil Warning Light (False Positive?)
  8. Recommended S-Car mechanic in Portland, OR area?
  9. pulled 4 codes from ecu
  10. ooh, new toy to play with
  11. Audi Club Northwest track day at PIR
  12. And so it begins... Project "S4 Refresh"
  13. Any of you guys here....silver car towars the end
  14. PSA about removing cell phone antenna
  15. a few leaks (ive posted about them before but have a few questions)
  16. The "S" made an appearance at a local get together... then she blew a coolant hose =P
  17. does any one make a 3" replacment dp?
  18. Got my oil plug off, thanks Fireblade!!!
  19. Draining coolant, questions.
  20. woot...i have windshield washers again
  21. the Detroit Audi Gruppe is putting together a rally around Lake Michigan
  22. Re: Can't find any info on the position of the inner 2 sway bar bushings(mounted tot the subframe)
  23. FS: 1993 Audi urS4 300 hp w/upgrades
  24. What's everyone's favorite picture of their car?
  25. I have Quaker State 5/40 Euro car synthetic in car, need to top off about 1/2-3/4 quart is it ok
  26. so my car burns about 2.5-3 quarts every 5,000 miles on synthetic oil
  27. This is an example of the tubular exhaust manifold a freind and I are making for my car.
  28. Anyone needs a pair of 10mm spacers for the rear shocks?
  29. Hap would like this one...
  30. I cleaned my headlight projectors tonight using Dave F's instructions from s-cars.org.
  31. I tried to fit my S4 cluster in the S6 casing so I could have those cool rings.
  32. Fog Light Disfunction
  33. New subframe bushings installed today. Woo.
  34. Is there a special tool to align the driveshaft / bearing.I have replaced the clutch and now have..
  35. RE: Is the subframe bent???....
  36. Re: Finally got all the parts for the front suspension rebuild...need help..
  37. Notes for folks installing the Bosch high-flow 005 or 044 pumps
  38. I need to let her go guys...
  39. This is why I need a power rear sunshade (video)
  40. VAG..
  41. Thinking about getting another car so I can do repeair myself - dealer is too expensive. Any ideas?
  42. Re: Opinions on LubroMoly oil. Found a local distributor that carries a full line of this brand.
  43. GD OIL PLUG!!!
  44. so i think my gas mileage went up significantly since my head rebuild adventure
  45. KoupeKrazy sent me this vid...
  46. Something bad happened to Tom? I hope not.
  47. Hahahah turns out the Crispy ChikAAN has never had the KY recall for the fuel line...
  48. OK, so who here lives in VT? How do you like it?......
  49. Opinions on Elf synthetic oil?
  50. Anyone heard how the Hapster is doing with his MOTEC install with Davey?
  51. Thanks to Ursoccer and everyone else who helped me with fluids
  52. Pics from our recent Pines to Palms Drive
  53. cool large Audi vid
  54. OH NOES I found a rear view of PBall Playa's ride ;)
  55. Trim pieces
  56. Saw a pearl S4 on I-5 southbound in WA btwn. Vancouver and Woodland-anyone here? Nice car....
  57. 1.8t Coil Pack Conversion Pin P/N Change
  58. Once again... new post.... Car not what I thought?
  59. Does somebody know what kind of wheels those? S6 winter package?
  60. Picked up my new (to me) shininess today.
  61. recommended tools for replacing timing belt
  62. Is brown cooling water OK? I flushed the system once but water in the reservoir is still brownish,
  63. Fun ride home tonight.......
  64. Function over form. Help me out?
  65. skolnick: YG-OT-M
  66. Got all my parts!
  67. As we are talking about suspensions...
  68. How long should it take to replace front shocks?
  69. Skeptic has to eat crow on Pop's POS alternative 4A0 905 351
  70. Anybody know the size of the two bolts required to mount the front bumper to the bumper shocks?
  71. Air Conditioning Switch
  72. Transmission rear seal leak - 95 S6
  73. i need to do a brake system flush...mechanic wanted $130 when he recommended it last year
  74. ignition cylinder needs repalced
  75. I found a pic of PBall_Playa's Inspiration...
  76. 94 S4 Voltage Regulator Cutover on a Canadian Car
  77. So, after buying an ever so rare 95/96 remote fob the S6 on ebay, I get the following
  78. I noticed somthing working under the rear of my car...
  79. Looking for Factory and aftermarket parts for a 92 s4.
  80. So, those of you running MRC 1, how rich do you find the mix?
  81. Skolnick! anyone with knowledge of gear oil, can i mix mt90 in my rear diff?
  82. how do i access the fuse wires??
  83. Replaced the fuel pump today..
  84. My car is no longer for sale aside from being bugged by strokers who dont have any money
  85. What fluid to use in the rear diff?
  86. And so the parts ordering begins, and 1 more question...
  87. bob, do you have a spare pass side headlight sprayer?
  88. Sparco and/or Momo Steering Wheel Hub Number? Anyone know which one fits our cars?
  89. S4 winter video..
  90. can i really use 4A0 905 351 pos on S-car?
  91. Now might be the time to buy a new front windshield. I just paid $254 CDN for OEM glass.
  92. Finished the garage cleanup tonight...
  93. Thermostat question??
  94. Fuel line recall question
  95. Anyone give their S-car anything for Valentine's Day? I gave mine fresh Mobil 1, 5w-30w.
  96. What kind of bolt patter is on our exhaust manifold.
  97. Anyone know the approximate (non-dealership) cost of a new crank position sensor? Thanks!
  98. Anyone know a ballpark price for used RS2 injectors?
  99. anyone, skollie included has a spare pass side headlight sprayer?
  100. The S4 glass sunroof is noticeably heavier than the S6 glass sunroof.
  101. Videos from this weekend...
  102. I can't believe no one had a pic of A4 Sport wheels on a urS6/S4
  103. Rear Diff Fill Plug?
  104. Thermostat stuck?
  105. O, by the way way. The UrS front passenger seat weighs ~58lbs and the driver's seat weighs ~60lbs.
  106. XX Tuning Dyno Plots are up from Sat's Dyno Day...
  107. were these wheels an s-car option?
  108. Hot pics!!! New strippers on the block!
  109. How to NOT pass Air Care with a VAG product
  110. Does the WG setscrew stop at the top when you unscrew it?? I ask this cause I can't remember...
  111. For those who have never seen a busted Ignition Switch..
  112. Are there 2 plugs on the tranny or just the rear diff?
  113. skollie, do you have any lines on a canadian rear shade? i need it here in cali.
  114. Free: most of the burled walnut door trim pieces.
  115. Coolant gargling sound.
  116. 1993 S4, what were the factory options?
  117. One problem after another
  118. Fast4esT, do you live near Mike (fullgas) ?
  119. Anyone have the librarians email i cant seem to get it off the sight ? I need his expertise
  120. Oil temp and water temps gauges don't work. Is that usually the gauge or the senders that break?
  121. Springs are gone?
  122. Where is the best(price) to buy shocks and spring sets?
  123. anyone have a spare afterfun pump, mine just went bye bye
  124. Wheel spacers to fit ECS stage 2 front brake kit
  125. Looks like I'll be driving her again in a couple weeks. The 90 is gonna be put down.
  126. alignment and suspension
  127. Yesterday I was 4 wheel drifting, hit glare ice, spun, stalled, and departed the road in reverse...
  128. J hose refurb complete - (OR - can you sing, 'Happy Happy - Joy Joy?') Long.
  129. Link to "Jen's" Audi C4 story (with internal links to C1 to C5) for those that lost track of...
  130. BLING!!!
  131. Just bought a '95 S6
  132. Thinking about replacing most or all vacuum lines this spring...
  133. Repacking CV joints
  134. Any of you guys have a powersteering pump and coilpacks for sale?
  135. i learn more and more about my car every day...because $h!t keeps breaking...
  136. Red coolant warning flashes under heavy accel.
  137. Gear Oil (germantoy)
  138. Slow seat belt retraction
  139. '93 UrS4 vs. '95 A6 Body (conversion?)
  140. My photos from Saturdays' Dyno Day / Gathering at XX Tuning in E. Hartford, CT
  141. Is it possible to tighten the front headrests so they dont tilt so easily?
  142. Low Load/Low RPM Inconsistency?
  143. <smacks forehead> Blew the diff lock vac line and now I can't find where it connects... any pi
  144. T-Shirt Poll:
  145. Need some advice on RS2 software
  146. Redline Gear Oil
  147. Hey Crapple: Found a split on my vacuum line for the door locks.
  148. Another blown PS hose.
  149. Stupid question. Where is the voltage regulator?
  150. No fuel car wont start
  151. Anyone know the working pressure of the pump to bomb J hose?
  152. How many miles a week do you drive?
  153. 1.8 Bar WG spring install on an RS2'd car - 1st impressions.
  154. Need one rear caliper guide pin...
  155. I wanna go do donuts in an empty parking lot, sniff....
  156. It's snowy...
  157. Things that make you go hmmmmmm...
  158. Blew the #4 coil according to my mechanic.
  159. hit the speed limiter yesterday...that was fun.
  160. Has anyone gotten momentatry severe deceleration under WOT & Full-Boost around
  161. I'm diging the A8 polished and forged wheels on a black/black UrS look.
  162. Any thoughts between a gt3071 and k26/to4e? Anyone switch from 1 to the other?
  163. Happy birthday, Bob!
  164. Took the S on a road trip to take the wife shopping today....
  165. Anyone interested in a CF hood?
  166. When is S-Fest 06'?
  167. Anyone have one of those cheapo clear corners (left) that they don't need?
  168. 7A oil pan installed on 1993 S4
  169. Fit 6 people in my wagon today.
  170. Check out my transducer
  171. Tom...
  172. one of us could have gotten very lucky...
  173. Odometer running fast!
  174. What do you think Karquattro wants for this bad boy.....8500 miles.
  175. Anyone know which is lighter? Fuchs URS4 16x8 or the 16x7.5 Avus?
  176. |skolnick , do you still have some exterior door trims left? I need
  177. Who's car is this? At Laguna Seca a few days ago.
  178. Can someone point me to who makes/sells the stronger swaybar links?
  179. Bonus: 7A versus AAN. Who has the omega pan?
  180. Inside this issue: A fix for "smoked" gauges plus odometer rollback clinic
  181. Looking for the part #'s for Crank position sensor & hose from steering cooler to rack. Thnx
  182. dumb Q about my volume knob crackling
  183. Jeebus. 18x8s are too big.
  184. did you guyz see this?
  185. got the WG spring from Javad...impressions
  186. I need a vent for my boost gauge, can someone tell me where to find one??
  187. turning 30 on sunday, opening this tonight to celebrate!!!!
  188. I think Dave F. mave have had a heart attack today when he saw the crispy chikaan and the guy
  189. Could this be a sticky ISV?
  190. O2 Sensor Bung Size?
  191. Comparison of low bims: HIR and HID kits
  192. CT/NY Audi Group Gathering & Dyno Day - We're still on for tomorrow (Sat) - E. Hartford, CT
  193. Would anyone be interested in Audi TT HID retrofit brackets?
  194. alread put this in AWOT, but for those that don't check it, enjoy
  195. 80 or 87 degree thermostat? which one to get for the PNW climate?
  196. Norwegian Audi owner..
  197. Odd request: Could someone provide measurements...
  198. CEL and Fault code for #5 injector. Any ideas why?
  199. ouch, poor black on black
  200. Pop quiz : What is this C4 ?
  201. top gear is back on. from 8pm to 3am here on the west coast. thursday nights
  202. Front coil spring question
  203. Hey Skoolie...
  204. I was going through some old records from PO and found out that CPS was changed at 95K..
  205. Imsa powered blue S2 anyone have the link to the pictures of it not on the ice?
  206. Stutturing problem mostly solved ... some mysteries still linger ... Mihnea around ?
  207. What is the stock length of the rear rubber brake hose??? I got some 9 5/8" SS lines! Hopefully ...
  208. MOFO! Somebody kicked in the door of the garage where my coupe was being stored.
  209. One year ago today....
  210. Fuel Economy Endurance Race!
  211. for those of you looking for ipod integration, check out alpine's 2006 line
  212. Taillight for a S6 wagon....
  213. I am curious.....
  214. Well the S4 has some new stuff...
  215. Re:Also Bentley recomends to replace a lot of bolts/nuts/washers....
  216. RE: Going to order parts tommorrow got few questions.....
  217. Some pics of my $2.98 iPod mount...
  218. Ride with 18's and Lowered
  219. Gas Tank Problem!!
  220. can i put a t-connector on the line coming from the intake manifold to the bypass valve?
  221. One UrS4 and one UrS6 on the dyno this Sat at the CT/NY Audi Group gathering....
  222. Can tire chains damage QUATTRO system?
  223. Need everyones help as you know I put my avant up for sale, now ...(not a for sale post mods)
  224. RE: While subframe is out, how to evaluate the condition of the tie rod..
  225. Question: I hear a whistle like noise coming from the rear of my S4
  226. Scuff plate broke - any ideas on replacing it.
  227. new Exide battery, car now starts on first crank and car overall feels stronger
  228. sandblaster noise in 3rd at WOT...normal or not?
  229. The ultimate S4
  230. Used rotors....
  231. Dirt draining out over rear tires after a car wash, a lot of it
  232. Follow-Up: My 1995 Owner's Manual's Fuel Tank Capacity Spec...
  233. Can the front axle bearings be removed / installed while the strut is on the car?
  234. Went to order my new WG spring, but after talking to Javad...
  235. Hood release cable
  236. Timing belt labor?
  237. Rear Brake Woes...
  238. Ok I have a question... rather than asking how many miles you get per tank.
  239. Is it possible to get F5DPORs cheaper than $10.43 each?
  240. Another positive side effect of the 1.8bar WG spring
  241. Skolnick...
  242. Wow...overboosted to >25psi today.....first time for that.
  243. Oh yeah. The Crispy ChikAAN no longer belongs to me and is now Canadian.
  244. ACNA 2-day track event @ Buttonwillow Raceway coming up on March 27 & 28th (Mon/Tue)
  245. Hey guys,.. got a few important questions ...(long)
  246. Sunroof Questions (been STFA)
  247. Installing boost gauge
  248. Re: Changing subrame bushings and other front end misc...
  249. Stolen S-car, keep an eye out for one of our brothers.
  250. I think this forum needs some pics.....
