PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. door lock problem - well ????
  2. NorthAtlanticAudiClub Driver Safety School registration open for NHIS
  3. Which car would you buy for reliability 95-97 A6q or 92-95 S4/S6?
  4. RE: Finally got her started. Spark problem was due to a bad POS...
  5. Anyone got the part number for serpentine belt cover?
  6. Lower suspension arm
  7. Is -1.27 camber too bad? I know that the limit is -1.15, but should I leave like that or
  8. Random failure to start = ignition switch? It seems that my problem is a little bit
  9. Thanks Jason C for the A8L rotors! Got 'em today.
  10. fire extinguisher mount?
  11. dave, ygm.
  12. on a budget performance
  13. Next person on the list for PSpump to Accumulator hose
  14. anyone have some alignment suggestions?
  15. pulled relays under IC, removed IC and unplugged ignition switch...
  16. Ah, I'm a bit more worried now
  17. Message to the Mods (Jason T, whoever) re:abuse email account
  18. Note to fellow owners: On my second set of Textar pads for my 993 Twin Turbo Brakes...
  19. Why rear rotors wear much faster then front?
  20. my S6 runs again! and questions about snubber mount and coolant temps
  21. Hey Crapple, I found the nos that you were looking for, it's on the floormats...
  22. Boost gauge for Europe Blue?
  23. shifter linkage slop question.
  24. Anybody ever run up against a stock Mazda RX-8?
  25. Samco Hoses
  26. FYI: Stratmosphere has old style hyperboost BPV's on sale for $99.99
  27. a bit more wiring to go
  28. Put a new 710N BPV last weekend. Might be a placebo-effect, but its seems
  29. Sunroof opening by itself, dying battery?
  30. Anyone ever see a "badgeless", non Kamei grill for our cars?
  31. what is the diameter of sway bar?
  32. so whats the deal with this car? you guys know anything about it? looks pretty nice
  33. anyone have Etka pic of rear subframe mount/bushing?
  34. Okay. I watch the Oscars and come back and they changed the frame and the font and I can't'...
  35. Thanks to those who helped with my new wg spring problem.
  36. Is it at all possible to get a new K24 turbo? If so, anyone know where?
  37. Umm, did the look and feel of the forum just change?
  38. CT plate 1ANN9...nice run on RT 9S today....
  39. buying 1995.5 s6 any suggestions please help !!
  40. OT: Just ordered an International Tool Box. Anyone have/seen one?
  41. need small black plastic piece for throttle cable
  42. Insurance repair question...
  43. update on battery drain, using amp setting, need advice
  44. Need oil lines for a big oil cooler where the IC was.......where to get? Summit racing?......
  45. I always have to break something
  46. Slow starting problem in summer
  47. so i think i have a stock cd changer i might not need. anyone interested?
  48. Well, i can scratch "drive on the autobahn" off my list of things to do.
  49. Anyone parting with used suspension upgrade kit?
  50. blowin a little smoke
  51. Anyone have the cd changer mounting bracket for an Avant? Just the metal bracket. Skollie?
  52. so i raced a Stg III B5S4 for a bit yesterday
  53. Where to find replacement body parts for 92 S4?
  54. So how reliable is your UrS car?
  55. battery drain woes...
  56. Anyone have a rear inner cv-joint that they don't need "good one" and as always cheap!!! Thnx.
  57. So the S is going into semi-hybernation....
  58. spark plug gap for 93 s4?
  59. Just returned from a week in sunny FL........man I would love to have their roads! My suspension...
  60. Drive axle bolts - is it XZN-8 or XZN-9 (triple square)?
  61. Scary - Electrical short found...
  62. Sleeved the snubby mount.. wow!!
  63. after replacing pump to bomb hose yet another PS leak
  64. Engine stalling...need DTC advice
  65. any pointers for R&R of VCG?
  66. Link to fuel pump replacement procedure. Don't forget steps 3 and 4 or you will wear...
  67. Has anyone performed an analyticat test on all of the replacement bypass valves
  68. Dave F - Fuel pump is in and my back is in some serious pain ;-)..
  69. the warning display in my dash dimmed when I started the car this evening and it still hasnt
  70. Snap ring size on wheel hub?
  71. getting spark
  72. REPOST: anyone with Wastegate Spring Mod had momentatry severe deceleration under WOT/Full-Boost?
  73. 93 s4 upgrades
  74. got my snub mount housing adjusted, didnt have to take off my mount
  75. Which rotor will fit with 993 non-turbo calipers?
  76. Overheating a Urs4
  77. Retarded question: How do I remove the shift boot?
  78. What's a fair price for 95.5 S6 Avant
  79. Part # on the UrS4 headligt harness?
  80. Looking at a URS4, What would you pay?
  81. My water temp will not go above 85c, even after hours of driving
  82. Tech Session by Audi Club NW and Speedware
  83. Ok, maybe a wastegate problem
  84. Fault code help!
  85. Question: What size R Compound tire for the OEM 16" wheels. One of the tire calculators I'm using
  86. More BLING...
  87. Installed Poly Snub Mount, got some questions
  88. another vid for you S1 fans (edited for stupidity)
  89. vid for you S1 fans
  90. A few questions?
  91. should i have a factory cd changer and silver box would anyone be interested?
  92. 1.8 bar wastegate spring measurement please
  93. woohoo, my 1.8t coil conversion parts came in!
  94. Suspension question?
  95. Does anybody here have the Ned Ritchie exhaust manifold?
  96. Hey, my post about the firewall plastic cover was deleted????
  97. An electrical short has made itself prevalent now...
  98. Audi S2
  99. As the project nears completion,,,
  100. ok guys, help for battery drain (tozom8 i have update for u)
  101. Puttering?
  102. Love is in the air...
  103. 92.8mm crank
  104. where can i find an emblem for the front grill?
  105. does anybody know if the PN for the RPM sensor and crank sensor is the same??
  106. What would you guys pay for a set of 5-spoke 16x7.5 A4 wheels with...
  107. HELP:electr. problem; display clim.contrl, wipers off ->rest is on
  108. I am selling my S6.
  109. For all you NW Gearheads coming to Burien Washington Audi Expo June 24th.
  110. Anything negative regarding serp. bearing replacement?
  111. Suspenssion again....
  112. Electrical cutout when ABS activates.
  113. Ipod integration in a 95 S6 with a Gamma CC Radio
  114. ZOMG TEH S4 IS HEADLESS!!!
  115. Trouble with brake pad wear sensor
  116. Super nice lookin S4 for sale but look at the price 8^o
  117. anyone have an extra badge for the front grille that i may purchase???
  118. so, I guess I'll start with the VCG
  119. are OEM brakes on the urs4/6 the same as a c4 a6....
  120. "borrowing" a mechanic's bay to do subframe bushings. suggestions on what else to do while there?
  121. Low Boost Question
  122. car is gonna sit in garage untouched for 6-8 weeks, should I do anything?
  123. anyone have a pic of a yellow S2 like emry just posted? that link is dead now
  124. WTB Eibach 1529.140? I know they're discontinued, but ....
  125. What i'll be driving for the next year while the S4 is in storage.
  126. Another A4 1.8t coil pack conversion
  127. Interesting Boost Issue
  128. RE: Today followed the entire procedure in Bentley uder section,,,,
  129. FMIC Ducting wit da BLING!!!
  130. avant rear wiper issues
  131. Dyno tested my car last Saturday. Pics and videos inside. (BWW)
  132. Someone hit my car. Boston+30mi radius for great bodyshops? Other than Dick's?
  133. How much should I expect to get for a used RS2 EM?
  134. The skid plate is a lot easier to take off than put on.
  135. Where is the best place to buy a stromung exhaust from?
  136. RE: Checked the fuse above ECU, it's good. Used the POS from...
  137. Wastegate cap needed....
  138. OT - What was the first year of the BMW M5, E39 imported to NA?
  139. Specs on 993tt caliper bolts?
  140. Trying to cover all replacement bulbs
  141. It wanted a bath... I was bored on Friday!
  142. rear diffs do not like shock! kabooooooooom
  143. What is the uses of after running pump?
  144. Karl, My fuel consumption jumped up almost 4 mpg after replacing the fan clutch. Thanks again!
  145. What lowered spring do you using?
  146. Anybody got a C4 A6/S6 pass-side HL washer jet & cover for sale? Pref black.
  147. Re: Could POS's get damaged from improper use of multimeter on the terminals and plugs on firewall.
  148. To end the gauge discussion... Greddy sucks too Forgie! If you want functionality -
  149. RE: Front suspension rebuild is completed....
  150. Sunday bling - WG Cap
  151. Leak transmission 1992 S4
  152. ...
  153. Blower Motor Squeak
  154. has anyone w/ ecru int. made the centers of the seats black?
  155. Go for this or not....Q for you 20vT boys...
  156. RS2 Fuel Pump
  157. On a difficulty scale of 1-10, how bad is replacing the heater core?
  158. Did a test drive A6 2.7T 6spd
  159. Phew, I'm back...what a crazy two weeks....
  160. Interesting discovery about my "RS2" software...
  161. Anyone besides Skolnick got lots of parts kickin around?
  162. Believe it or not, but there are over 200 parts in this picture!
  163. Greetings from Tampa!!!
  164. VAG commercials are very funny!!!
  165. misinformed Vortexer makes fun of Javad
  166. Man, it's a good thing Audi didn't bring this car over to the States, it woudl have never sold.
  167. spiralsmurf: YGM!
  168. boost gauge install is complete!
  169. this is why my car wasnt warming up....
  170. well no luck finding a short (tozom8??)
  171. Detailed up the S4 for a little photoshoot with the local car club.
  172. The Quattro Story
  173. going to chris semple's wedding tomorrow, so if any of you sucka's needed parts....
  174. Talk about a Crispy S4.
  175. Posted to Marketplace...
  176. Its alive!!!
  177. OT: Anyone know about Porsche 944S? Looking at one for the wife. Input appreciated.
  178. has anyone modded their gas pedal? i dont really like how it has that spring on it..
  179. Installed HIR bulbs: a little better then sliverstars, but now way 75% of HID....
  180. Couldn't handle the cold?
  181. Im putting in a new T-stat. TIPS????????
  182. Funny VAG video for VW...
  183. DRLs are easy to add for anyone who wants to import a car to Canada.
  184. ugh, new battery is draining now..
  185. slight stutter at high boost (>25psi)
  186. Wheres Repeater? Hope all is ok.
  187. Part Number cast onto RS2 Exhaust Manifold?
  188. Why is the 1993 audi s4 quattro so heavy?
  189. possible to check injectors?
  190. One week to go for Audi Club NW Track day registration @ Portland!
  191. Have fun finding that..
  192. finished my CV boots... pretty sweet :) one of my ball joints is cracked..
  193. It breathes!!!
  194. Mileage poll again: 128K
  195. *Spotted* Natick, MA Clean black S6 with euro bumpers/rear plate recess and winters....
  196. Proof that a wheel in the air will NOT leave you stranded with quattro
  197. Which color coolants can I mix the Pentosin G11 blue with?
  198. One bad catalytic converter......what are the options?
  199. doing CV boots, couple questions
  200. HIDz + new lenses + clean projectors + disabled DRLs + no warning in the autocheck + no cut wires=
  201. The S4 is running again . WOo hoo! My dad successfully welded in a new "pin" through the starter
  202. Free advice: replace your coolant tank with the Audi part only. The aftermarket one sucks.
  203. I was interested in this car....
  204. And something else for those of us considering a head rebuild
  205. Wow, AutohuasAZ really does have rock bottom prices.
  206. Anyone have a spare WG Diaphragm? I'll need it when I pull my WG apart to put in my new
  207. So earlier I took the S6 for a 30 minute drive to warm her up good from a cold state...
  208. so what's the story on HID conversions?
  209. New wastegate spring
  210. Dave, you're becoming a worldwide known figure.
  211. Lost power (boost) at full op temp this morning, then took WAY too many cranks to start at night..
  212. how much boost can a stock k24 realistically handle?
  213. X-Post: My $1.88 Boost Leak finder :-)
  214. What's on squared display in the IC center right below "OK" display? Mine dosn't show anything...
  215. Is this normal??? Water Temp Pics Inside!
  216. Oh no, my Warranty is Voided ! What will the dealer say ?
  217. Nice! Blew up my V8 diff last night.
  218. I have removed my AC and i need to know the Size
  219. car pulls to the left under hard accel. in 2nd, all tierods new and alignment done
  220. coolant?
  221. Engine/Tranny/Snub mounts. Fix a shifting problem?
  222. My temp gauges work now! could use some help with after run stuff (Dave F? :P)
  223. where is the bulb in the ash tray located? is there one bulb to light ash tray and bin below?
  224. failed emmisions 97 a6q. 2.8 v6
  225. Hey thermo, your cats are in my car.
  226. Suspension bushing ( metal with rubber inside )...
  227. Susp modification pics:
  228. S2 coupe from Buddyracing
  229. Thanks to Sean D. I have manufactured a new "pin" for my flywheel. My dad is going to weld it on
  230. Wooo hoooo!!! No more DRLs on my car. The HIDzzzzzzzzzz are happy.
  231. some folks wanted to see pics of the euro sport springs... not the best but here you go.
  232. Found this on craigs list
  233. V8 torsen FS
  234. found this old post about Oil Capacity
  235. Terminal velocity question for those that have tried
  236. Got my thermostat in. fixed my leaks (i think) Got some picture questions.
  237. Coolant Leak
  238. has anyone heard of or had an aluminum flywheel come apart from stress
  239. Rear bearing question
  240. what is the bolt spacing for the caliper carrier to strut bolts for the front?
  241. 92-94 S4's come stock with Bosch F5DPOR spark plugs correct? Do you guys know the Audi dealer part
  242. Alex... Do you have any Wastegate Diaphragms available??? I need one yesterday!
  243. I'm leaking
  244. My sad little story...
  245. fuel line recall (dave f. !!!)
  246. ICV for sale!!!
  247. Does anyone on here have the tmtek clutch kit and or know someone who does?
  248. does anyone have the contact info for the gentleman from jersey with the Red urs6 sedan 500+hp
  249. bob, what happened with my headlight sprayer?
  250. What's the current consensus on suspension upgrades?
