PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. Black UrS6 sedan spotted at PIR Historics
  2. Has anyone tried or heard of welding a dual mass flywheel together to make it a solid wheel?
  3. Suggestion on coil over rates and where to buy?
  4. UPDATE: Driving around today... the car's sterring wheels shimmy's left to right a little...
  5. random question....FMIC related
  6. Anyone here have HID's
  7. NEW URS4 Headlights options!!
  8. Update - Pressure test showed head is cracked :-( ... Anyone else "got head ?"
  9. Anyone running the 034EFI K26/GT30 Hybrid? Any idea how it compares against the RS2?
  10. will a 35mm offset 17x8.5" wheel fit our cars?
  11. What dyno numbers would you expect from a Stage 1+ w/ 3" catback?
  12. Upper Strut Mounting Plates wanted
  13. Don't try this at home
  14. Got head ?
  15. During a spirited drive on Saturday my oil temp reached 130C. How bad is that?
  16. Just for fun: the carpet weighs 59lbs.
  17. What is the best way to remove the driveshaft C.V.'s?
  18. (Help!) Anyone got a stock injector they don't want ? I need just one
  19. 928 GTS caliper the same as the big red???
  20. stupid turbo question:
  21. Replacing engine mounts. Safe to jack it up under Oil Pan ?
  22. Installed OEM HID's this weekend
  23. My car is shaking after changing the brake pads...
  24. where's the fuse for the after run pump on a 95.5? TIA
  25. Beta Testing Kevin Day's Turbo Display System-1 (TDS-1) - first notes.
  26. maf to turbo hose: anyone w/ a spare?
  27. Mr. URSoccer_Mobile, can you elaborate on your suspension suspicion?......
  28. Changing rotor rings on 993big reds anyone ever done this
  29. Anyone have chipped stock vs. RS2 dyno curves?
  30. Dyno results inside:
  31. How do you enter the Unlock Code for Bose Radio?
  32. Custom Exhaust UPDATE
  33. Got the big brakes installed today...
  34. Drove a Gran Sport today...
  35. Went to the dyno today...
  36. Non-owner...is it possible to fit RS2 bumpers on a normal A6
  37. any good performance suspension suggestion?
  38. I found a new RS2 turbo for $1000, now I am in need of some cheap RS2 brackets and EM..any leads?
  39. Need Interior Parts-93 S4- northeast prefered
  40. Trying to help friend: Going price for a 1996 S6 wgn black/black 50k mls all original good cond?
  41. So, who's all in the funky dash display club?
  42. Thinking about good sound in my Avant.
  43. UR-Idiot Savant-S6: Have you figured out yet where your clunk is coming from?
  44. So about once every six months when it's rainy and nobody's around, and the car's sitting...
  45. Anybody in the Vancouver area.....
  46. Getting a custom exhaust done tomorrow......
  47. Blackstone analysis
  48. Strange engine problem...
  49. 3-Spoke Steering Wheel Install Questions...
  50. Friday is picture day...
  51. Saw an UrS6 Avant in Colchester VT today...anyone here?
  52. Slotticus! I command thee to rise!!
  53. Once again, another dyno shootout for plugs.....
  54. I'll be in Minneapolis after next Wednesday......
  55. Whose Green 95.5 at C&S Auto in NY this week?
  56. Removing Heads to do Gasket. Can I get by without a Crank Lock? What about locking the Cam Pulley?
  57. When you guys installed your Bilstein inserts,
  58. Can an HRSB still be purchased somewhere?
  59. Hmmm... on a rainy day like today I can see why Audi took the rear sway bar away from us.
  60. Any high boost guys running an uprated/stiffer wastegate spring?
  61. Anyone run into issues with the stock spark plugs?
  62. Another cashmere S6 for sale.
  63. Best place to buy spark plug connectors?
  64. 1 bbs LM on eBay for Cheap Cheap Cheap
  65. cooling options
  66. 10mm / week Coolant Leak .... sorted!
  67. Racetronix 37lb/h injectors
  68. I just replaced engine mounts. Results can be resumed in one word: WOW!!! Read on if you suffer
  69. Paging �S6-4RiNGS�
  70. FMIC Done and Done
  71. Opinions on these compared to Carillo,Dahlback,etc.
  72. my first post @ AW =)
  73. Rear brake caliper/line question
  74. said I'd post a few pics of my ic mister and intake. so here goes
  75. Is this a bad chip or is the chip making something else noticable?
  76. please help the computer illiterate.......
  77. Royal Canadian Mounted Dog Team brings home the FMIC goods
  78. black out surround for grill?
  79. Backfiring gone, smooth power on tap...
  80. S4 automatic going weird
  81. my car is a fuching ass hole magnet
  82. X-post: i thought my brake kit is big. :)
  83. Pentosin 7.1 is correct, right?
  84. Newbie question...how to tell if car is US vs EU?
  85. This Sunday, 7/10, CT/NY Audi Group Meet & Meguiar's Detailing Clinic - E.Hartford, CT
  86. Good source for 75mm overall length lug bolts(edited)?
  87. 2B camber plates & coilovers.....
  88. Possible Headgasket
  89. Update on Coolant leak
  90. FMIC Install and First Impressions
  91. VR, what is this?
  92. Side football logo.....
  93. Driver's side window switch question
  94. Lower Rocker Moldings
  95. what is that part?
  96. Forgot to post these and someone requested them today...
  97. The New England Grand Prix ALMS race at Lime Rock Park was fun as H-E-Double hockey sticks. [UPDATE]
  98. the new guy.
  99. If I remove ABS fuse, does that disable the ABS module completely?
  100. Spotted: Black S6 black wheels, MN plates.. Drove next to you for some time on 394W in Minneapolis!
  101. Where to find the chrome trim around the window? New preferred. also... how hard is it to remove it?
  102. One quick pic taken this weekend
  103. So what "would" it take to have a dyno shootout on....
  104. Audi is #2 in Q-Ship ranking
  105. About removing cats: I did the homework reading everything that was written
  106. WOO!
  107. Odd request......
  108. Kicking up some dust about bending piston rods.
  109. FYI if anyone wants my stock springs
  110. Summertime repost
  111. Will these bad larrys work with our gauges?
  112. Performance Upgrade Recommendations
  113. First from the 'Annual Portrait' shoot ....
  114. Feeler: FMIC
  115. HELP S6 stranded on side of road in Green Brook NJ
  116. Any recommendations on good shops, experienced with UrS4, in the Bay Area ?
  117. looks grumpy
  118. This Sunday, 7/10, CT/NY Audi Group presents Meguiar's Detailing Clinic - E.Hartford, CT
  119. Question: Audi Club Membership worth it?
  120. dumb question maybe? Big reds and stock calipers share them same size pads?
  121. Happy 4th for the USA. Let's all try to remember what it really means.
  122. What's a good price for 17x8 S6 Avus wheels?
  123. doing a rear caliper brake rebuild...
  124. What a great weekend- cars, weather, no work
  125. plotting compressor efficiency points on a graph
  126. Here you go TIM...
  127. this pressure tester looks familiar
  128. So has anyone used the K26/GT3071 turbo from 034efi yet?
  129. S6 Avant = MILF
  130. i'm getting a little looney. on the lookout for a ch33p black/black UrS4
  131. Where's the best place to tap into a battery source under-hood?
  132. Polished up a '02 A6 2.7t today
  133. Anyone with G-Tech?
  134. 100W fog lights......
  135. HID Problems 1 : Tim's Patience 0
  136. Which plug under the driver seat is for the seat heater, mine is stuck on?
  137. Yf you want to find "YOUR" woman follow me- Come to Açores!! :)))))
  138. Long shot but it worked - Navigation & Phatnoise
  139. Nice black 95.5 ur S6 avant at Merlino's Belvedere tonight. Are you here?
  140. The Miata is broken.
  141. Stand Alone Update...
  142. incredibly pissed offfffffffffffffffffffffffff
  143. More than a bit off topic, but Carl will appreciate this even if nobody else does.
  144. Today I'm doing all the cuting on the FB. In a few hours I will post the results!
  145. Hey UR Soccer_Mobile..........
  146. Interesting experience while going pretty fast...
  147. Porsche brake people..
  148. My car is eating coolant.
  149. Yokohama Advan032R....
  150. mechanic said my clutch is dying, because its stiff!!
  151. Edge Racing selling Black 17x8 Flik Justices for $79/wheel
  152. Poll: Anyone else find it hard to walk away from their S-car w/out taking one look back?
  153. any btdt on outside temp display bulb replacement? i'm fed up with it being dark
  154. The Brandon Hull Ersatz S2 (E//S2) is alive and living in Canada. Yippee!!
  155. I kinda like..
  156. Someone is drunk
  157. Just finished my engine swap. Took an hour. Unfortunately,.....
  158. Looking for a high altitude boost gauge beta tester
  159. Need a 710 BPV and clear corners for S6...anyone know good source for both?
  160. Hey, all you fellow Canucks, Happy Canada Day, eh? Chime in with your location. (Vancouver)
  161. Who's this? BWW
  162. some upgrades
  163. Noisy 2Bennet Camber Plates
  164. i found some kami stuff if any one is interested
  165. Some stuff on ebay from my co-workers car if anyone is interested..
  166. Anyone here have my old UrS4?
  167. Is it normal for the after-run fan to come on, but not the pump?
  168. Question for people who have used the MRC chipset and others.....
  169. ok whos pristine s6 in marlborough heading int hudson mass today?BBS rx2s kameii grill?
  170. Anybody ever have their diff lock engage when you first...
  171. Just the way we like it.....
  172. For Kday. Tensioner is rock steady with or without AC on.
  173. It's gettin' cloudy and we're rollin' Audi...
  174. w00t! Falkens arrived today..
  175. Went to turn on winshield washer fluid with lights off.. pull wiper stock....
  176. Headlights mod update
  177. OK, new harness just came in with relays....
  178. Poll: Would you prefer Autometer over VDO, or vice versa, and why?
  179. Now i'm upset... sent all the VDO stuff back... haha tell me i was right to go with
  180. anyone replace the bulbs in the side view mirror controler
  181. Carl, and those interested...
  182. So i hooked up the boost gauge its pretty dim with the red bulb condom on it!!! anyone had this
  183. How I Fixed My CPS or Hey, Glue Melts
  184. front bumper removal instructions?
  185. For URSoccor_mobile.......one more shot of H&R V8's w/o spacers.
  186. New Sig, comments?
  187. 10% Ethanol - OK?
  188. Open up and say "Ahhh"
  189. "Got brakes?"
  190. "Now that his body's in the trunk, I can steal his car"
  191. OK bout to put the Gauge pod on this morning... Q's...
  192. EVO question? Is it normal to see black smoke after every upshift?
  193. it runs like hell, but at least the brakes squeal loud enough to wake the dead
  194. Of those who post here from the Seattle area, who was actually at the Burien...
  195. Should i leave it where its at???
  196. Ok. I've been lurking this forum for along time now......
  197. my new (and last) set of rims
  198. Can anyone point me to some sources for good SS lines please
  199. Getting ready to buy new shocks to use with H&R sports #29800.
  200. My next Mod
  201. Ran w/ a E30 M3, I'd like to have one of those.....
  202. suspension
  203. So far I've located two RS2 Exhaust Manifolds.
  204. Who wants a '93 S for $3k?
  205. Mance Preloading Strut Brace Last Chance...
  206. SommerFast'05 Pictures
  207. Anyone know where to get Vogtland springs?
  208. Who here has painted their A-Pillar Gauge pod to match?
  209. arrrr, broke the master cylinder rod
  210. Hmmmmmm... the early '92 CPS that lives at the back of the head
  211. I got a friend to donate a couple of shiny gadgets for the raffle at //S-Fest.
  212. RF Door Locks
  213. Sources for plastic bellmouth / velocity stack parts?
  214. Well, the S4 didn't do too bad at MSR today.....
  215. Any other folks interested in getting Phenolic Intake Spacers ?
  216. After letting off throttle under load, i hear this sort spitting type of hissing sound.
  217. S4 Euro lights - look quick before it's baleted!
  218. Need help with part number for rear bumper shock?
  219. Anyone ever log with VAGCOM, specifically the MRC RS2 chipset?
  220. How many of us are going to represent the "good ole' days" at Waterfest?
  221. What is the McMaster Carr part # for the correct T-Fitting for the moisture trap plumbing?
  222. falken tire feel
  223. WG question
  224. lowering the car soon what should i replace while in there?
  225. clutch pedal adjustment?
  226. About to buy a boost gauge and pod!!! what do you guys think of this???
  227. So which of you maniacs will be attending Waterfest?........who do I need to look out for? 8^)
  228. So who's going to Limerock for the ALMS race on July 4th.
  229. The S4 is in Season...
  230. Got my KY fuel line recall notice today
  231. Wish me luck at MSR tomorrow.....
  232. Any leads on an RS2 manifold?
  233. Who here has a Dahlback Cold Air Intake they wanna sell me???
  234. It's official. Turbo_Anarchy is one of the nicest guys ever.
  235. Heh... I thought this was kind of a funny photo...
  236. Who else offers adjustable fuel pressure regulators other then 034efi.com?
  237. Slight coolant leak - what are the chances this is just a bad gasket, and not cracked head ?
  238. Not sure if you saw this..this B5 A4 w/ an AAN today won their Division at Pikes Peak
  239. 5 hours of techtime and my alignment is done...sort of..
  240. Can someone remind me or email me a link to S6 rf remote programming?
  241. Fuel Pressure Gauge and Adjustable Fuel Pressure Regulator Install
  242. What's the nicest replacement : S6 vs S6+ vs Euro Bumpers ? Source ?
  243. explain to me how i wasnt passed by a rs6 on the highway
  244. Any ideas what can be done with my rear headrest?
  245. So I backed my muffler into a rock tonight and now my car sounds like a broken honda civic. . .
  246. So my fun alignment story....
  247. 2 weeks... until Streets of Willow. Registration deadline is July 1st, space still available
  248. Anyone going up to Pikes Peak this weekend?
  249. Anyone have a pair of dead stock pads and going to bison creek sat?
  250. 20vT Bling!
