View Full Version : Audi Original "S" Cars
- Audi brake noise reduction Tech Servic Bulletin - including sanding discs
- serpentine belt
- Replacing a clutch on a 1995 Audi S6
- 95.5 Avant
- Rough Idle
- massive coolant leak
- is this normal?
- Wanted 95 S6 OEM RADIO or where to purchase?
- Fuel tank question
- Black on Black URS4 in Augusta, GA
- LOOKING FOR 1995 URS6 CHIPPED ECU
- Audi Original Parts Online Shopping NEEDED
- Detailer's Domain - July 4th Special
- picked up a 93 s4
- Putting on original (?) wipers with vanes
- cd player install..
- First Trial With fixing an UrS taillight with Methylene Chloride
- Trunk Shocks
- Driver's Door Panel Re&Re and Window glass removal and replacement DIY pdf
- Broken Clutch MC actuating rod
- RS80 - alive and kickin'
- where to buy a urs4 front bumper cover
- 1995.5 urs6
- Im back so is the car
- Rattle in engine area
- RS2 Manifold anyone?
- door trim moulding c4 100 s4 interchange questions
- Timing Belt Tools
- Rear drivers side door won't open...
- trunk problems
- control arm/ball joint
- Removing the rear headrests...?
- S6 vacuum concerns
- Im baaack!! 8)=)
- Stock up on detailing gear before Memorial Day @ DetailersDomain.com
- Just added these photos to the G40 Cam Position Hall Sender Info post
- Spark Plug Wires
- How to remove dead power seat
- 95 A6Q Fuel line
- popped hose "Michelin" man
- URS4 terrible smell from the cats
- Thoughts on Oil
- G69 / F60 Throttle valve position potentiometer /idle switch Testing
- Some NAmerican C4 UrS 100/A6 front bumper removal and replacement hints
- Replacing all coolant parts
- fuel pump
- ABS light
- Supposed to be 21 forum viewers right now. Sign in!
- A "new" source of used 034133471K (3B, AAN and ABY) MAFs.
- What is the idle fuel pressure?
- New 94 urs4 sluggish problem... videos!
- question
- Drivers side power window going down by itself
- C4 Outer Taillight Replacement DIY
- Serpentine belt replacement procedure
- Clutch disengagement
- coolant leak under turbo area
- heated seat elemnt
- front axle torque specs needed
- New C4 UrS (and 100/A6) heater core replacement DIY pdf
- Huge boost leak near turbo housing?
- Simplified C4 UrS Lower Control Arm Replacement DIY
- 1995 s6 brake kit
- steering noise on UrS4
- Unique Clear Coat Fracturing..
- Adjusting the UrS clock
- Next Phase of the rescue,,,Steering Rack
- Front axel removal: Draft procedure
- Thoughts on removing front struts and control arms
- Extremely thick grease dripping from car
- AAN Compression Testing Info
- New to me 97 S6 Sedan...
- No start/crank
- New AAN Crankcase Ventilation System Diagram and Photo
- OEM style quad exhaust s line tips
- AAN Boost Testing Options
- OMG help!!!
- body parts
- JVC headunit into 95 S6
- PCV bits under the Intake Manifold
- Front bumper options for an S6 - Can I use A6 or S4?
- Update to the G40 Cam Position Sensor Location Transition Post
- Brake bleeding
- Memory Seats/Remote/Side Mirrors
- Wrecked my 93 S4, make me an offer
- ur S4 help needed
- Simplified C4 UrS Lower Control Arm Replacement DIY (what did I miss)?
- Need Help
- Heated Seat Switch was hot last night
- C4 UrS Fuel System: From the Tank to Injectors and Back Again
- Revised Ignition Switch DIY with more photos and hyperlinks
- Clutch question? Smokes and releases near top of pedal?
- Revised C4 Fuel Pump Removal and Replacement (R&R) procedure DIY
- Common water entry points in urS6?
- STFAd and still no 95 S6 start.
- 1995 S6 HELLPPP!!
- where to buy a bumper grille?
- I'm an idiot - On a trip and I've killed the S6
- UrS4 advert from the June 92 issue of R&T
- Hate the sponsored posts (advertising Spam IMHO)
- Florida car and driver hit the mountains.. (and a couple glamour shots)
- Looking for floor mats for my 95 UR S6
- The monthly UrS reminder post from the folks at STFA.
- broken slider
- Bilstein HD vs touring
- blower motor i need help!
- New guy with S6 avant
- Seasons Greetings from the team at Eurocode Tuning
- coil failure...didn't make it home on 4 cyl
- 94 uS s4 - new to me.
- 1996 and 1997 Model Year (MY) UK UrS6 Features and Options c/w price list
- flame out
- Coil packs
- Pulling Codes Without VAGCOM?
- S4 is missing, running on 4 cyl when check engine line comes on intermittently?
- Running out of time
- 93 slow like theres no boost
- Slave cylinder tube hose line
- Coupe/RS2 Questions.
- Trip computer question?
- listed a mint 3 spokes steering wheel in the clasifieds
- 3k mile Trip in my S6
- Throttle cable part #'s needed (black clip)
- Lost keys, doors locked, battery out of car.....
- Hesitation on acceleration/black smoke with heavy particles
- Coolant dribbling.
- Consolidated OE Exhaust System Info
- OE K24-7000 and RS2 K24-7200 Turbo Info - Input welcomed
- No spark
- Paging Icy_Urs4
- S car owner just moved to Texas.
- Problems with Fuel Filters
- Potential solutions to why your AAN-powered UrS isn't starting
- Tramlining badly...need suggestions
- C4 Audi Wiring diagram pdf (link inside)
- just got a 1994 S4, could use some input.
- C4 AAN Engine Harness in Two Parts
- front subframe bushings
- Prepurchase inspection
- Specifications
- When is the last time you checked your sparkplug torque?
- No power from Cigarette Lighter outlet - '95 S6
- Pedal covers?
- Door panel removal
- Ear piercing noise when I turn on radio
- My UrS6 modifications
- Oldschool KKK turbo decryption
- URS4 POS Wiring Help Please.
- Navi+ in my S6 -95,
- Selling my URS4
- Throttle potentiometer
- Brake fluid slow leak - location indicate anything to you?
- Front Strut Tower Bars - PNs and thicknesses and stuff
- Driver's side wiper skips middle..
- URS4 Newb!
- Dead Battery Again
- Replacement Battery
- Euro A8 rotor replacement (for BIRA kit)?
- help needed with lower control arm
- Rear Headrest
- New owner of an old S6 - with a Power Steering mystery
- Née brake rotor help
- Minor Body Issues
- Black Rubber Trim Strips
- Things that will fail on your AAN and strand you
- Outside temperature LED backlight out
- 1995.5 Audi s6 help please.....
- Coil pak and missing motor
- Stripped Power Steering "X" Plug Removal
- Decoding UrS VINs and Build Tags
- RS2 Center Tail light !!
- Rear Strut Bushings
- Im at an impasse with my transmission
- Picked up a very clean 1993 S4 the otherday
- TWO WEEKS until S-FEST West! Register now to ensure your spot & door prize!
- Broadband lambda measuring meters - ideas?
- Aye, Back again too soon with clutch/transmission problems??
- Cruise control malfunction and "take your keys" ding dong annoyance
- Some Audi Inline 5 20VT history
- k26 question
- Hydraulic help needed
- Lock Switch
- s4 issues/intro
- Need Advice for pricing!!!
- Rear suspension clunking
- Which PS hose goes to the brake bomb area?
- Brake Pad Choices
- Connector Locations
- urs4/6 dipstick tube differences in block
- Double Din Radio Retrofit
- To mod or not to mod?!
- Sadly my '97 S6 is in classified section
- Headlight Covers
- Hood Realease Cable Issue
- Any advice on H&R 29800 Springs?
- 1993 S4 Wastegate Gasket replacing
- Looking at an S6 - coolant leak near alternator?
- 95 S6 - will be attempting Head gasket R&R
- seat belt or better yet seat!
- New Car (Possible Timing Belt Change)
- interchangable parts questions
- 95 S6 Losing Coolant, no visible leaks
- Power steering banjo "special" bolt
- C4 S4 New Guy. Need Advice
- help!!!!
- Can anybody identify these wheels? Or better yet whose car this is?
- Clutch feels heavier than normal, could be my
- UR intro`
- vibration
- A puzzle for the diagnostic guru's...
- C4 Radio Cage Differences and why
- C4 UrS Servotronic Control Module info
- looking for S4-S6 for sale (1992-1996)
- ECU bench testing
- C4 UrS Brake and Cruise Control Pedal and Switch PNs
- Need to Stock up on your Detailing Gear! Free Shipping at DD till 5/1/12
- cruise control question
- perplexed
- Help Overheating
- Frt Suspension Noise
- Window Wipers Turn Signal HVAC 1992S4
- Red S4 in Kitchener area
- KY plate "UR S4". Are you here?
- Newbie Ur-S6 Power Steering Issue
- Wheeler Dealers - audi quattro tonight
- Bigger rotors what calipers do i need?
- Hot Corner (brake?)
- Water Boiling in coolant system
- Brake pedal vibration/chatter
- UrS4 auto trans dipstick
- cruise control malfunction
- Stage 3+ questions RS2?
- New Wheels for my s6
- Jonny K's 1997 Audi S6 - Final Report. Includes detailed mileage and costs report.
- Double checking...rough idle, smooth boost curve
- New UrS4 has joined
- New to the Audi, software question??
- Stuck Radio
- Revised AAN Motronic ECU Info
- Saying hi...
- The forum where people ask questions, get answers and then
- Rough when start up
- CLUTCH PEDAL
- CLUTCH PEDAL 4A1 721 323 A
- SPAM Alert on the Gerrard1 post DON'T CLICK ON ANY LINKS
- Lockable Rear Differential Info for the S2, RS2, 92-94 UrS4 and 95 UrS6.
- Completely dead, but good battery
- Drivers side IR central locking issue
- Last Day to Pre Order the Griots 6 inch Orbital Polisher Kit at Intro Price
- urs4 no start issue ecu problem?
