View Full Version : Audi Original "S" Cars
- Crazy
- Speaking of Bentley Manuals if anyone in the NYC area wants to use mine
- My local petrol station is selling super unleaded 99 octane!!!!
- Please come on out!!
- Will an S6 belly pan fit an S4?
- headlight
- I know the Supertone, but are Hella Compact Trumpet Horns louder than the stock Mixo horns?
- w00t! I'll have my cylinder head back at the end of this week
- If anyone has a Bentley Manual Set for sale please contact me!
- Is that ok for 0.6-0.7 bar @ idle?
- When was the last time you checked the volts to your fuel pump?
- Updated ECU calls for a boost gauge!
- shopping list....for all the wrong reasons:(
- Fuel pump going bad??...
- 034Motorsport AAN 1.8t Coil conversion, updated pictures.
- Siemens fuel pump replacement
- Strange stalling problem
- Clutch pedal woes - again
- getting a new clutch (Centerforce), also new throwout bearing, what else need to be replace?TIA
- State your age!
- Sound coming from rear suspension....
- Quattro 20v - what are these - e-code Xenons with Range Control Motors?
- is there any way that when i lock my car via key button it puts up the windows?
- Whats my 993 TT rotors hats and brackets worth
- How can I reset the brake pads worn indicator if the brake pads are fine?
- Add express up/down to any window
- Well, made it back from Mid America Motorsports Complex.
- diagnose this: at WOT turbo boosts ~ 0.9 bar then surges to ~2.0 bar after 3 secs (read on)
- rattle at idle.....gennerally under 1000rpm...comes and goes....
- So, who else is anxiously awaiting "plastic" surgery to their rear end?
- dumb ass me.....
- Photos from last week's Hartford CT GTG c/w wiener balancing lesson
- 'new' V8 differential ready to go!
- Source of ABS failure was found;
- Cleaning MAF
- Anyone have problems w/ fumoto valve leaking?
- Tips on Removing/Installing new injectors
- This was on rennlist somewhere but; what are you doing with your tax returns
- OK let's end this Monday with some humor..
- [REPOST] Its on, its tomorrow...LA GTG @ The Stand in Encino (SFV) - 7pm
- Keyless entry inoperative
- Anyone have an extra airbox/MAF cover they want to sell?
- Well decided on saturday after a long talk with a local well respected tuner to go ...
- MAF story:
- "Miniman", YGM.
- Conversion guys. I have a question. I know that the eS2 car maintained....
- Coils, POSs, Ignition Systems and Sparkplugs... Easter wishes...
- once again i have an issue
- New to this forum, but I had a couple of questions
- Here's a super dumb WG question...
- My air intake upgrade is FINISHED(at last)!!
- Bucking / Cut-Out / Mis-Fire cured. GTechPro & Butt-dyno says "Wow !"
- Fault codes 2341 & 2413, need some help...
- DRL disable question
- Stupid Question...
- Confessions of a Moisture Trap
- What is it, and why's it leaking?
- All speed sensors tested- they seem ok
- I want to paint the chrome surround and 4 rings on the grill,
- Back in the green again
- What injectors to use?
- hate to ask you to do my pic searching..
- A plug for Autohaus Arizona
- s6 1995.5 timing belt change how often? i have 123000 miles
- Anyone have an extra 17" Avus wheel they will sell?
- The unhacking of the S4 continues
- Anyone have a Kamei grill for an S6 they want to part with?
- Simple airbox mod/searched plenty
- Another wash pic-all Audi
- Great northeast saturday , perfect wash cars day...........
- Can you define this symbol?
- Hey, none of you have a clue how to solve my ABS issue??
- It's starting to look... EVIL-"The Sti's Nightmare"!!!! :))
- this will be offered in a couple of weeks...
- Marc, I already found a solution for the MAF to turbo boot:
- 5/13/06 - CT/NY Audi Group & EPL present Dyno Day for Breast Cancer in Stratford, CT
- timing belt components
- I'm absoluty, positivly sure it's my fuel pump, maybe!
- Project S4 update...
- Yummy, 993tt rotors and custom hat
- Do you know what happens when you 1-2 power shift?
- Rear End creaks (not mine) the S6 1995.5
- Where can I get a new moisture trap?
- Driving down the freeway and car loses power and dies. It cranks but doesnt start.
- Hey Bob...
- Wrenching the new S4 continues
- Wasn't this guy at S-Fest?
- KILLZZ
- This is horrible! why would someone do such a thing...
- anyone interested in my old wheels
- Eugene and Alex.... Your parts are sent out!
- ABS warning light is(still) on!
- I love this color combo-
- Hot FMIC-on-car action
- X - Post: Only 3 weeks till Road Atlanta Driver's School - Sign Up! ->
- Pics of the ECU hack job
- I have a brain teaser here... Steering problem!
- Anyone with VAG? What's the ECU report temp at idle e.g. after running 20mins? Mines 95.2C, 203F
- 1985 (european) BMW 635 CSI versus 95.5 S6
- So I got the new S4 delivered today...(Long)
- Dumb question of the week : which way does the crank turn ?
- Temp sender T pipe water temp sensor circlip--I can't get it back in, any suggestions?
- 034Motorsport AAN Coil Pack Plug and Play Replacement Kit, $355 -- NOW AVAILIBLE!!!
- Some Highway shots on the way to Show'n Go
- "Against facts, no arguments!"
- The Stroker comes alive mit some Boost!!!
- New UrS4 Coil Conversion Harness...
- Leather Repair
- w00t! Cylinder head arrived from 034 today
- How much different is the rear B5 S4 sway bar from the 92 design?
- Are these the calipers I'm looking for?
- Springs
- Checking for boost leaks
- Unbelievable...I know this has been talked about, anyone have a source for S6 front bumper?
- Overkill?
- Samco Hoses....
- Life with my new S6
- bolt pattern woes
- Jesus H christos are 996 x50 TTs fing fast. This car ontop of being a x50 had more work
- Does anyone sell a full Porsche 993tt break kit for our cars???
- X-post from the 4kq forum (carlisle GTG)
- couldnt help it
- ZOMG there's a hot chick at this conference I'm at, guess what she drives...
- Thanks for concerning
- A/F gauge question
- Anyone know about this coil over noise when turning the wheel?
- Anyone have a good set of used stock injectors?
- Stop modding your s car for power gas slated to cost 3.60 a gallon for regular
- What's the market price for a driver's seat, excellent condition ?
- Anyone Have Flik Rims?
- 245/40 on 17x8 40mm offset.. will it rub? any BTDT?
- Does anyone need a stock metal intercooler or oil cooler?
- Couple problems, any ideas?
- Need radio code
- PSA: Tighten all your boost hose clamps...
- Got tomorrow free, what should i do to my car
- [Tuesday, April 18th - 7:00pm] Monthly GTG @ The Stand in Encino (SFV)
- Update: North East Audi VW Show & Dyno June 10, 2006 *New Sponsors Added!!*
- Anybody have a pic of a s4 w/ 17" Borbet Type E wheels?
- how do the batterys fit in the key fob??
- Disaster strikes my car today =(
- Any 'Yoopers' out there - Northern Michigan? need a mechanic
- okay, so my boost cut issue...i've been trying to think through how it can be the coilpacks...
- Stebro Group buy oppty
- S4-Fireblade - check this out :)
- Whats a reasonable price?
- help
- PSA--Check those spark plugs!
- Imola Yellow RS2
- power locks not working...
- Whats the best place to have my tires ballanced?
- Special thanks to the CT S-car gruppe for tonight's GTG. I really appreciated...
- A4 Pillar Pod VS 2Bennett
- Who in CT knows who these wack-jobs are?
- Whats the word on 034's Plug and Play 1.8 coil harness?
- are these wheels relly heavy?
- Anyone have extra wheel centers laying around?
- If anyone is looking for or knows someone looking for a UrS4 drop me an email.
- CD changer no longer works.. :(
- what kind of glue should i use on the black center piece on the hub cap?
- Boston Area AWNE 4/27 Pizzeria Uno's GTG <<<UPDATE>>>
- Anyone pls take a photo in this view for me?i want to put on 19 rims...
- Anyone have a Dahlback Air Intake... (I know I can make my own, but don't want to!)
- sqeaking sound??
- Sunday project- updated strut bar
- Deal for Ecodes?
- no boost in the rain...ideas?
- Who makes this Bypass?
- My New S4
- do the chrome trims around the windows come off? i'd like to paint them black...
- Some clean car and new plate pics...
- Some E-Code housing install pics... Took all of 20 minutes to install them.
- One pics of the new wheels
- Ping emmett03...
- Stromung install: Drop Subframe?
- Will this turbo work on our cars? I bought a whole kit for my other car and was wondering..
- Engine stalling at idle when cold.
- 1.8T coil conversion done. First impressions...
- x-post: BBS RX wheels
- What's So good about the UrS4, anyway?
- Anyone pick up the tire rack $25 front brake rotor special? did you receive
- FS: 1995 Audi S6 Look-Alike
- I got rid of the 18x8 AR1s for these
- Hartford, CT S-car GTG - Monday night, April 10
- HAHAHAHA YES!!!!!!!!! TOZOM8!!! CHECK THIS OUT ALL
- Bored so I took a new pic...
- ARRRRR!!!! It must be spring... my brakes have started sqealing again
- 3071 first impressions:
- So when did OBD II compliance requirements take effect ? 1996 ?
- How is the MTM RS2 Software??
- 17" wheel fitment/appearance question -opinions wanted
- Source for RS2 EM?
- A gathering of mostly older iron. BWW
- StopTech delivers the goods. Apikol, too.
- I just opened my trunk and water came gushing out from under the carpet on the trunk lid...
- S4 logo
- Hey SoCal, who wants a FREE set of H-Sport sway bars? Come out to the H-Sport GTG tomorrow
- 1995.5 s6 inside fan blower TICKING like mad !! how do you install??
- Since we are on the topic. I smoked an old camaro the other day.
- Cannot find the igor camber plate modification PDF anywhere WTF!
- Killed a 350Z today. =)
- Vr Life, please post me some pics off your 3071
- KILLZZZZ
- STaSIS Motorsports needs your help.
- anyone have any advice on adjustable camber plates?
- Anyone instersted in my old 17's?
- The monster arrived!
- Thought we would share as they turned out very nice.
- Where to buy Suspension bushings?
- S car GTG in the Hartford area next Mon or Tues? Special guest UrS4boy! Leaning towards Monday.
- True or False?
- Please post RS2'ed dyno numbers here and mods.
- Something to keep my S4 company, while it is in the hospital
- trying to asses the value of my short block anyones opinion would be greatly appreciated
- uRS4 AND urs6 owners going to the ucon car show? chefbob in spirit?
- headlights
- Anyone know p/n for o-rings on power steering pump to rack, please?
- Anybody live in or near Hartford CT? I will be in the area next week.
- The block from EB_1920's Avant lives on in the Crispy ChikAAN. Need some help.
- i just got owned
- oK Ive fing had it HELP I need an aluminum flywheel preferably cheap as they come !!
- Colorado S owners, anyone available this Friday to help me
- forgive my poor photoshopping...i'm very tempted ...99 bucks each(17 inch)
- Is it a sickness. Everytime I meet a UrS owner I tell them, "gee, your car looks lower than mine"
- Where's the OBD1 port on a '95 S6 wagon?
- Can you guys verify the location of these parts on the trans? Transmission oil change
- 710N vs. Bosch 110 DV musings + I found my coolant leak
- First post on my first S4!!!
- White smoke coming out....
- Well had to get new BFG KDW2's today!! :(
- Anyone running an Audspeed manifold?
- How hard is doing suspension? I have done work on all my previous VW's...
- Chefbob.
- So I'm driving today...and see an S6 for $3200!
- Europrice Pre '96 On-the-Shelf Blowout Sale... SOLD LISTING INSIDE
- Rotors and Pads
- A big bowl of wrong
- Has anyone improvised a radio removal tool? If you've BTDT, explain...
- Anyone have their stock exhaust manifold and turbo?
- S6 Avus wheels....how wide are they?
- hey guys my coupe got beat up by a deer...look into gettin an s4...
- My wife wont let me by 94 S4, but maybe yours will!...
- do wheels that fit a B5 S4 fit our cars? my dad has winter mille miglia's that i want for ..
- Reinstalled rearview mirror on the 95.5 today- what a PITA....
- Talked with the body shop for an hour today
- ok, this boost cut issue is driving me crazy. it cuts boost at 25psi, no matter what gear
- idle issues
- stock Avus wheels(7.5x16)...what's the biggest tire i can fit ? thanks!
- s6 mud flaps factory ????
