View Full Version : Audi Original "S" Cars
- What chips were available in 1995?
- What would you do with $10,000?
- 1995 S6 gas cap source?
- When I steer I get an awful squeal/squeek at low speed.
- wheel bearing replacement hints
- Digital Boost Gauge from Auber
- Gas gauge stuck on empty.
- a/c controller not working..(details inside)
- x-plug failure -- how soon?
- PSA: If you're not sure of the source of bad engine noises, assume the worst...
- PSA: Colorado UrS / Any 5 Banger GTG Saturday July 25th in the foothills above Golde
- Anybody in the midwest/rocky mtn region ever think about an //S Fest rocky mountains?
- What are some symptoms of problems with the cats?
- T40E
- can't change my oil and its coming due!
- Can urS4/S6 run a staggered wheel fitment?
- Motor repairs complete...kinda disappointed.
- What the hell does this hitch ACTUALLY belong to?
- preferred methond of flushing cooling system?
- How to remove speed cable?
- My 93 is a 92!!
- S-Fest West 2009 - August 15th 2009 - Registration Site
- 94 s4
- Rear Deck Lip for 1995 S6
- Autocross in S6, advice?
- PSA: Just say no to clear bras
- urs6 finds new home in nashville!
- Need to vent!!!
- Hitch Installation Procedure
- Front and rear wheel bearing, the same part?
- Dead on Road today
- Quick thank you
- euro front bumper
- Questions about painting the whole car
- Anyone know if Steffen ships bumpers?
- I have white paint all over the side of my car. How do I get it off?
- Bypass / Diverter Valve noise
- Clearing the ECU?
- Rough Idle, Smells bad
- Gorgeous S6 Avant Pictures in Colorado
- cheap 1.8T coils... for anyone running them
- Royal Purple anyone?
- Calgary UrS-heads: I will be in Calgary on the evening of Mon. June 22. GTG?
- S-Fest East?
- OT - joined a Scion forum....
- Goal 400 hp
- RS2'd UrS4 passes AirCare with flying colours (again)
- Anyone know of a good place to get my clutch replaced in CT?
- Went to have a look at an S4 today
- Clear corner lenses 4 93????
- Another Audi tool supplier,
- These guys have Samco hose kits for $307
- Model interchangeability questions
- Super cheap 93 in CO
- Stance / Just washed / UrS4 parts
- int1 / int2 message???
- Vibration @ Idle and speed, help, stranded 4 states away from home. Colorado?
- Addict Motorsport???
- 18" SSR vs. 18" OZ what you think?
- Thinking about parting ways. E36 M3 or B5 S4?
- HEAD GASKET
- 27.5 MPG - anybody done better than that?
- methanol injection
- new to the family!
- ◦Anyone know the date this car was manufactured? Any way to tell? WAUZZZ4AZTN011281
- S-Fest West - Who is In?
- Head Gasket
- AC Clutch Relay wiring diagram needed
- Swason hitch and my custom basket/bike rack is on the car.
- Blew Fuse S94 for Fan! Where to locate?
- Running Rich and am running out of ideas why...
- serp. belt length with no A/C? Anyone know what it is?
- Bilstein Sports FS
- Damn, it just HAD to go to Shokan
- mercedes wheels..
- Guys say a little prayer or word for chapel
- WIRING HARNESS FOR DIFFERENTIAL LOCK WARNING / NO LONGER AVAILABLE / rear
- Roof rack for s4?
- Cig Lighter not working, need fix ASAP
- Searched, no luck. How to replace air filter?
- hyd clutch line needed..
- Radiator Fan Series Resistors
- 2005.5... reallly...??????
- 20valve motor
- Intercooler question
- 93 s4 won't start
- Getting out of the NAVY by the end of the month!
- Paging Jan_PL_S6 q? about Stromung
- Coolant issues
- Finally some pictures of the S4.
- New Sound - Bearing???
- flywheel options?
- Bilstein HD rear shocks, which one?
- where to buy misc bolts for the audi.....
- seidl bumper
- MVOC VW/Audi meeting, Moncton NB
- Upgraded my dash bulbs
- clutch kit?
- Nashville TN Audi mechanic/shop suggestions ?
- Poly/High Density Bushings
- Timing Belt Job
- Where can I buy a quality coolant reservoir and cap?
- steering damper for 93s4
- stromung turbo back exhaust anyone??
- Starter doesn't engage?
- RS2 ME
- Creaky rear suspension
- Couple bottom end questions.
- just picked up a '92 parts car
- Synapse Engineering WasteGates and Diverter Valves
- Cheap '95 S6 in CO
- Help finding two wires?
- Where is a good place to get side mirror glass these days?
- Project / On the Bed roll call!
- Clean S4 F/S in atlantic canada
- selling my Avant
- What happened to the thread with all of the weights for
- Adding subwoofer stock bose system
- Clutch fan removal
- ImQuattro: here is your sequential turbo layout.
- Need help with unidentified connection !!
- A/C trouble
- finally time to get my S4 back on the road
- PSA Change your voltage regulator! Link to a good source to consider buying from
- Hitch for a UrS4/S6 for sale on Audifans market place
- Wow, this seller has a lot of confidence...
- AutoX at an airport this weekend
- Coolant Problems
- Current day outlook on longevity and ownership cost of UR S cars?
- Bad ABS Pump Module?
- Looking for a crankshaft and connecting rod OR a good complete short block.
- Just removed my 350/450 springs and put in 750/800. Much better.
- anyone looking for a clean 95.5 black on black sedan?
- Anyone have a clutch alignment tool they could lend me?
- Is there a Bosch universal voltage regulator?
- Wanna see an ugly wheel? This is my pick.
- Want to buy a car...
- pulling codes
- Would anyone be interested in a Bilstein Sport group buy?
- New to the forum curious about TAP1
- e brake light flashing on while driving
- Who likes donuts and drift cream
- Possible to adjust Sunroof?
- exhaust exiting near spark plug still
- Pulling codes...long
- Here's an old article about the S2 (which we did not get in N America)
- After about 5 months refinishing the wheels they're finally done and on the car.....
- Motor price...Tranny price, what's fair?
- Anyone with a spare after run fan relay?
- Error code 00567 mixture adation
- midland 93 urs4
- Turbo Install info AGAIN
- just got my '96 UrS6!!
- Part # for rod bearings? VAGCAT is giving me #s for the 4000
- 18s not so bad as i thought...
- Wheels on
- Great deal for Canadians (for once)
- Holy Mind Fvck!
- Pics and videos of the knocking and burnt bearing.
- Car does not start. Ideas?
- Part-throttle hesitation when cold
- Found the source of the KNOCKING. Thanks for all the troubleshooting tips.
- ddm h.i.d."s
- Boston UrS Owners - Cars and Coffee 3 - May 17th
- Could a valve guide have come loose and be the source of my knocking?
- Are the ARP Head Studs reusable?
- Cleeeean 1995.5 Audi S6 Avant
- My left signal light indicator (inside the car) works intermittantly now.
- Dave, time to make a URS Wiki? Just sayin'
- Turbo upgrade discussion
- Just for fun - playing with launch control
- transmisson CRACKED !!!
- My engine started clicking yesterday, too little oil?
- Overloading rear shocks + storage for 5-6months= oh boy.
- Reverse sometimes no engaging
- 94 urs4 shuttering/misfires
- IR to RF remote conversion
- 30+ G deceleration = interesting results
- Stock Dyno Numbers?
- I keep seeing random s-cars in wellesley and natick MA
- intercooler replacement . Which way to go?
- Trunk strut replacement, is there some trick I don't know?
- It happened. My ignition switch broke yesterday.
- Anybody selling a hitch?
- You know you're getting old when....
- Spotted: Heading West on Hwy 16 between Saskatoon and Battleford
- Car won't start...
- how to fill and drain transmission fluid...
- Rear subframe bushings and diff mount?
- FINALLY have some good pics of my suede headliner : ) [big pictures]
- Suspension DONE
- Dave - I have an update for your fuel pump replacement procedure
- CANT PUT FLY WHEEL BACK IN...
- Radiator Fan Mod (PO)
- Audi rallye video for your Sat AM
- What are Eibach springs for worth, trying to decide whether to sell them or not.
- car died on me had to have tow any ideas? it has spark
- I'm looking for a C4 rear....
- How to search in vB AudiWorld
- Where's that website again that has all the rims selections on UrS cars?
- AAN ignition coil info
- Occasional reduced power
- OE AAN ignition part numbers for future reference
- Windshield, anyone ever tried to change one?
- 01E rebuild kit... pretty cool!
- can i run a 245/40 on b6 S4 wheels.. lowered s6avant.. *searched
- T-Belt job this weekend what should i replace while im there?
- It wasn't the lifters.
- Anybody have an extra S4 sport steering wheel badge laying around they want to sell?
- problems......????
- Trunk opening with ignition
- I'm not getting any boost!!! any idea guys
- anyone have a source for TRW front Lower Control Arms for less than $150 ea?
- 94 S4 STEERING RACK REMOVAL
- Anyone what to run a Carfax?
- Urs6 ressurection (week end project! )
- Actually NOT a bad deal...
- How do I know if my turbo is blown (1995 S6)
- Cash68, I am holding relay 441 959 257 B marked 329 - do you want it?
- How do you find the old DIY threads?
- My CC is crapping out. I got a 96 A4 unit, is it the same?
- $560 Power Steering Hose; Need Help!
- Whats a RS2 turbo worth that needs rebuild
- Whats draining my batt. ??
- TT steering wheel swap? anyone BTDT?
- TDS-1
- UrS Sway Bar Kits - Update
- play in spark plug?
- Ooooooh Shiny.......
- anyone looking for a clean s4 here is one
- Bilstein Strut PROBLEMS!!
- Coolant T replacement info (for future searches: tee)
- A more specific question in relation to my lifter problem,
- OT: Where can I buy #6-32 pan head machine screws locally?
- My lifters went from intermittently clicking, to KNOCKING...LOUDLY.
- WINDOWS STUCK DOWN. HELP. (tried searching, no luck)
- Chipped and BBS'd....what more could a guy want?
- Installing a Symphony Radio in urS4/S6?
- quick help
- Another plug for Marc Swanson
- FAQ?? I need the insrtuctions to relay the FP
- Aftermarket Rear brake setups?
- Finally...pics while it's clean
- Pictures, no reason
- UrS Rear Sway Bar Kits
- Who did I meet at dustoff?
- window sunroof problems
