PDA
View Full Version : Audi Original "S" Cars
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127
  1. 95 S6 help needed
  2. Its Gone!!!
  3. Oil temp low
  4. Buying S4 / S6 what to be aware of ?
  5. I have some 5cylinder BT boost and ignition chips
  6. Am I doing this right? 92 S4 suspension , rear
  7. Big Cheers for Kris Hansen and Dave
  8. hdpe in a s6
  9. Alternator behavior
  10. Can someone look up P/N?
  11. New S4 owner.
  12. Picked up URS4 yesterday-England-Hello-First question
  13. Door Panel for S6...will S4 panels fit
  14. how do I get to use my old account
  15. front fenders 4 93?
  16. How many S-Cars in British Columbia ?
  17. Sway bar end links (rear)
  18. FYI: My car is for sale on Audifans.
  19. Clutch Problems... Please Help
  20. Audi urs4 1992 Wiring Diagram
  21. Audi Urs4
  22. I can't seem to find a definitive answer: Can the seats simply be recovered.....
  23. Group Purchase - Replica S4/6 Sport Spring Sets...
  24. Anyone Selling Aftermarked Exhaust? Stromung, 034?
  25. S6 Rattling Noise
  26. Where to get special timing belt tools in Canada?
  27. Montreal F1
  28. stupid vibration from ring?!?!
  29. changing coil and need help with yellow
  30. My UR S6 on EBay
  31. I need a Sunroof gasket where
  32. Wastegate bypass regulator Value
  33. Lock pushed in trunk won't open tried the remote & glove box switch
  34. Any help
  35. What to look out for.
  36. Timing Belt Tensioner (054 903 133)
  37. Ice racing update, Gravenhurst or Sundridge Canada
  38. My very first post…and I need help.
  39. Is anyone interested in buying a 92 UrS4?
  40. Replacement procedure for AAN coilpack?
  41. Stretched the legs on the ol S today
  42. Attempting coolant flush, t-stat not opening?
  43. Part out 1995 S6 Blk/Blk
  44. Audi UR S6 on Ebay
  45. VAG - COM Protocol
  46. Am running green antifreeze from previous owner, forum search to no avail...
  47. Front bumper feeler....Hands up
  48. Carlisle 2010 sign up now open!!!
  49. A replacement for the TDS-1?
  50. coils or output stages
  51. Help out a brother - connector needed
  52. Clutch deals?
  53. Engine Mounts ?
  54. Good thing I ordered a new crank pulley...
  55. Happ New Year
  56. 034 stage 1 +
  57. Zzzzzz Zzzzz Zzzzz - part one
  58. Merry Christmas
  59. Looking to buy a clean S4.
  60. Thinking about selling my S4
  61. HIDs no workie
  62. Need Help! Windshield Washer Pump Replacement Instructions
  63. Anyone know this avant? I'm picking it up...
  64. 1997 UrS6 Database is now open for submissions
  65. MTM stage 1 chip
  66. Sick of my ignition system. EFIExpress or Apikol?
  67. Compression Test Results/Numbers:
  68. Does anyone know where i can get the S6+ tail lights?
  69. finaly made an account..thought id post something.
  70. Common problems?
  71. RS2'd S4, blown motor, right mods 4 sale....
  72. 95 S6 on ebay
  73. What would cause oil to blow passed VC gasket
  74. Would old Audi 5000 rims fit on an urS6?
  75. Brake vacuum conversion
  76. STOCK Boost
  77. Snow
  78. anyone know the weight of a 3B flywheel?
  79. Ice racing in Sundridge
  80. I suck...
  81. Bilstein stiffness?
  82. wastegate question
  83. New UrS4 owner as of today!
  84. It's here
  85. o2 or maf
  86. Big Snows
  87. On Board Diagnostics Through Climate Control
  88. Car has a Miss HELP PLEASE
  89. Over boost?
  90. Do you agree with blue book values on these cars?
  91. Rally video from the U.P. (LSPR)
  92. Valve Stem Seals Replacement Procedure
  93. Low mileage s4 for sale (not mine, etc.)
  94. Problem with my Instument Cluster
  95. Looking at a C4 S6, couple questions
  96. MANUAL BOOST CONTROLLER
  97. Let's see some pics
  98. Anyone breaking a black S6?
  99. Paging Mushasho! Do you still come here? YGPM
  100. Valve chatter anyone?
  101. what is a nice condition S6 with a bad motor (rod) worth?
  102. Anyone ever bypass the brake wear sensor
  103. Coil Solution Confusion (csc)
  104. Simple question - what front turn signal bulb do I use? Multiple answers.
  105. Newbie
  106. Clutch pedal on the floor AND car won't move in any gear. What's up?
  107. Quick question, is my stock down pipe worth anything? I have a new exhaust now.
  108. stock bose radio removal??
  109. Samco Lower Turbo Intercooler Boose Hose
  110. modifing 95 s6
  111. airbag light stays on??
  112. Valuation help on sweet S4 (RS2'd) with blown motor?
  113. S6 stock wheels?
  114. External coolant weep from HG
  115. Radio/Cruise Control
  116. Turbo Tech Question
  117. RS2 Chipset recommendations / detonation
  118. what clutch should I go with?
  119. S6 Avant for $2500
  120. repair manual
  121. Help!! Can someone point me in the right direction?
  122. Anyone selling a clean UrS4/6 in New England??
  123. power steering growl
  124. Coil question
  125. rear defrost not working
  126. Drive shaft support bering
  127. poll: what to do with weeping thermostat housing
  128. Best parts?
  129. Just start with will help me find
  130. how do I delete an old post i no longer want available?
  131. Newbie of UrS6 Auto Tranny doing Manual Conversion AXM tranny...
  132. Newbie of UrS6 Auto Trans doing Conversion Manual AXM....
  133. over boosting with cut out\ hesitation
  134. FWD Springs for S6?
  135. just installed 034 "street" tranny mounts
  136. brake pad change instructions for 993tt calipers (i.e. Big Reds)
  137. pressure test
  138. Wastegate and Front bumper help
  139. Dutter S2
  140. Anyone very knowledgeable with working on the C4 s4/s6 around Philadelphia?
  141. coolant level sensor leaking...
  142. climate control panel lights
  143. '95 S6 Avant intermittent blinking right tail light.??
  144. Intermittent low boost w/ check engine light
  145. Big Red Brake pad rec. for a track day
  146. this trim piece fell off my car, looks to be glued on? where can i get
  147. Fuel pump replacement
  148. Are these rims stock?
  149. Newbie 93 s4 owner has 2 questions...
  150. Secondary or Auxillary Fan running all the time
  151. spotted an s4
  152. Spare parts and tools to carry with you (**please read inside before replying**)
  153. 1992 Ignition Coil new harness
  154. Oil Cooler
  155. Reset Service Engine dash light.......
  156. Who has some old school oem 15" or 16" wheels?
  157. A diversion - S1 Replica Driven
  158. Where can I get the metal T for the coolant temp sensor TODAY!?!?!
  159. coolant question
  160. Bentley Manual for UrS Cars
  161. Twincharged S4
  162. 95.5 S6 - Engine shuts down @ 125-130mph
  163. Door Weatherstrip - Replacing
  164. 1994 s4 help!!
  165. viscous fan coupling.
  166. Getting replacement AC blower motor - which brand
  167. Boost gauge in clock?
  168. UrS4 full boost engine cut at high RPM
  169. Cool Audi Poster
  170. s6 rear caliper up grade?
  171. Other than bumpers, lights what other Euro S4/S6 parts are cool??
  172. Anyone have a link to the pollen filter replacement PDF
  173. Timing belt snapped on 1995 S6 (AAN)
  174. Does anyone know the exhaust manifold stud specs?
  175. Not Luck With Clear Corners
  176. Any BTDT with a broken EM stud?
  177. Sources for a new OEM shift knob?
  178. RS2 Front Bumper on S4/S6?
  179. ebay exhaust manifolds
  180. Still no heat??
  181. Freshly Detailed Tornado Red with new suspension/brakes
  182. Problem with locks
  183. Trying to install auto dimming mirror and failing (switched power problem)
  184. Will 9.5inch wheel fit?
  185. Aftermarket unit humming but not popping
  186. Thoughts on cold air intake
  187. S4 on ebay, do not buy
  188. Strange: EF Civic Hatchback Spoiler is identical in width to stock Avant spoiler
  189. Anyone interested in a brand new VMAP-d?
  190. Crap. Just did the brakes, now have rumbling/whining noises... help?
  191. questions about smoked headlights
  192. Block Question
  193. Porsche 928 wheels on S6? Will it work?
  194. Where's the pdf for the blower box DIY
  195. Drove a 2005 s4 today...
  196. alternator not charging...
  197. 95.5 S6 Avant rear hatch trim removal pics?
  198. Installing Hella Supertones on S6 Avant
  199. compression on an aan motor??
  200. Seat heater wiring diagram assistance please!
  201. BBK options
  202. Anybody have any Silicone Hoses for sale?
  203. New drip/leak
  204. 95.5 S6 Avant Door Chime Question?
  205. after-run pump question
  206. Hypothetical question regarding "restored" UrS cars
  207. power steering pump X plug...
  208. best batt. ?
  209. Lots of new names on here.
  210. brake upgrade
  211. looking for wiring diagram for s6 lights
  212. Best Price for suspension parts??
  213. Porsche boxster calipers with no text on them, what would you put?
  214. rear window cost
  215. D-BAG ALERT: Digital Motorsports Inc.
  216. Dave F, Do you remember replacing you MFTS?
  217. Dyno Results from today
  218. Anyone in New England running a GT30r or GT30/40r that can take me for a ride?
  219. Real time help: rear brake caliper bolt?
  220. RS6 or UrS6.. someone driven both?
  221. Aftermarket Stereo Options, I have been STFA...
  222. Buying b5 s4 rims. anything to look for?
  223. stupid question??
  224. Don't forget!!! Sunday 3pm EST the return of WRC in HD on Dicovery HD theater channel
  225. Next week: GT30R or GT30/40R? I can't decide.
  226. Updated Dyno Numbers - GT3071
  227. has anybody remove the muffler under the rear seat
  228. Looking for s6 front bumper
  229. Would an A6 rear bumper work on an S6??
  230. '95 Avant Chime warning with lights on/open door??
  231. Couple of software questions
  232. roll bar??
  233. Hood cable snapped
  234. Help! Need ideas for driveability issue!
  235. Installing door weatherstrip
  236. A8 with 12 Cylinder Engine
  237. Headlight relay questions again
  238. Uprated rear subframe bushes. Link to my thread on S2forum...
  239. Are CF hoods available from anyone?
  240. Feeler: Thinking of selling my turbo, injectors and software. Whats it worth?
  241. looking to buy a car with a built AAN. How are the reliable and maintenance of them?
  242. i getting small puff of white smoke out the exhau
  243. Up for sale: My Car
  244. Born yesterday at 5:45 pm; Colton Christopher
  245. Are there any tricks to removing the A Pillar rim
  246. Can we ban JerseyMike68 please?...
  247. what type oil do you use in the 2.2 turbo
  248. New to Audi/S6
  249. Won't start as of this morning
  250. 15k HIDs... any pics?
